[GRASS-SVN] r66581 - grass/trunk/locale/po
svn_grass at osgeo.org
Thu Oct 22 15:21:46 PDT 2015
Author: neteler
Date: 2015-10-22 15:21:46 -0700 (Thu, 22 Oct 2015)
New Revision: 66581
grass/trunk/locale/po/grassmods_ar.po
grass/trunk/locale/po/grassmods_cs.po
grass/trunk/locale/po/grassmods_de.po
grass/trunk/locale/po/grassmods_el.po
grass/trunk/locale/po/grassmods_es.po
grass/trunk/locale/po/grassmods_fi.po
grass/trunk/locale/po/grassmods_fr.po
grass/trunk/locale/po/grassmods_it.po
grass/trunk/locale/po/grassmods_ja.po
grass/trunk/locale/po/grassmods_ko.po
grass/trunk/locale/po/grassmods_lv.po
grass/trunk/locale/po/grassmods_pl.po
grass/trunk/locale/po/grassmods_pt.po
grass/trunk/locale/po/grassmods_pt_br.po
grass/trunk/locale/po/grassmods_ro.po
grass/trunk/locale/po/grassmods_ru.po
grass/trunk/locale/po/grassmods_sl.po
grass/trunk/locale/po/grassmods_th.po
grass/trunk/locale/po/grassmods_tr.po
grass/trunk/locale/po/grassmods_vi.po
grass/trunk/locale/po/grassmods_zh.po
grass/trunk/locale/po/grasswxpy_cs.po
grass/trunk/locale/po/grasswxpy_de.po
grass/trunk/locale/po/grasswxpy_el.po
grass/trunk/locale/po/grasswxpy_es.po
grass/trunk/locale/po/grasswxpy_fi.po
grass/trunk/locale/po/grasswxpy_fr.po
grass/trunk/locale/po/grasswxpy_id.po
grass/trunk/locale/po/grasswxpy_it.po
grass/trunk/locale/po/grasswxpy_ja.po
grass/trunk/locale/po/grasswxpy_ko.po
grass/trunk/locale/po/grasswxpy_lv.po
grass/trunk/locale/po/grasswxpy_ml.po
grass/trunk/locale/po/grasswxpy_pl.po
grass/trunk/locale/po/grasswxpy_pt.po
grass/trunk/locale/po/grasswxpy_pt_br.po
grass/trunk/locale/po/grasswxpy_ro.po
grass/trunk/locale/po/grasswxpy_ru.po
grass/trunk/locale/po/grasswxpy_th.po
grass/trunk/locale/po/grasswxpy_tr.po
grass/trunk/locale/po/grasswxpy_vi.po
grass/trunk/locale/po/grasswxpy_zh.po
Various typo fixes, part 2 (#2776)
Modified: grass/trunk/locale/po/grassmods_ar.po
--- grass/trunk/locale/po/grassmods_ar.po 2015-10-22 22:20:10 UTC (rev 66580)
+++ grass/trunk/locale/po/grassmods_ar.po 2015-10-22 22:21:46 UTC (rev 66581)
@@ -18361,7 +18361,7 @@
#: ../locale/scriptstrings/t.rast.what_to_translate.c:7
msgid ""
-"The layout of the ouput. One point per row (row), one point per column "
+"The layout of the output. One point per row (row), one point per column "
"(col), all timsteps in one row (timerow)"
msgstr ""
@@ -19243,7 +19243,7 @@
#: ../locale/scriptstrings/v.import_to_translate.c:10
#, fuzzy
-msgid "Ouput vector map extents"
+msgid "Output vector map extents"
msgstr "الخريطة الراسترية المخرجة للمساحات ذات مشكلة"
#: ../locale/scriptstrings/v.import_to_translate.c:11
Modified: grass/trunk/locale/po/grassmods_cs.po
--- grass/trunk/locale/po/grassmods_cs.po 2015-10-22 22:20:10 UTC (rev 66580)
+++ grass/trunk/locale/po/grassmods_cs.po 2015-10-22 22:21:46 UTC (rev 66581)
@@ -18448,7 +18448,7 @@
msgid ""
msgstr ""
@@ -19341,7 +19341,7 @@
#, fuzzy
msgstr "Výstupnívektorová mapa s chybami "
Modified: grass/trunk/locale/po/grassmods_de.po
--- grass/trunk/locale/po/grassmods_de.po 2015-10-22 22:20:10 UTC (rev 66580)
+++ grass/trunk/locale/po/grassmods_de.po 2015-10-22 22:21:46 UTC (rev 66581)
@@ -18487,7 +18487,7 @@
msgid ""
msgstr ""
@@ -19377,7 +19377,7 @@
#, fuzzy
msgstr "Ausgabe-Vektorkarte, in die die Fehlern geschrieben werden."
Modified: grass/trunk/locale/po/grassmods_el.po
--- grass/trunk/locale/po/grassmods_el.po 2015-10-22 22:20:10 UTC (rev 66580)
+++ grass/trunk/locale/po/grassmods_el.po 2015-10-22 22:21:46 UTC (rev 66581)
@@ -17594,7 +17594,7 @@
msgid ""
msgstr ""
@@ -18438,7 +18438,7 @@
#, fuzzy
msgstr "Όνομα εισαγώμενου ράστερ χάρτη "
Modified: grass/trunk/locale/po/grassmods_es.po
--- grass/trunk/locale/po/grassmods_es.po 2015-10-22 22:20:10 UTC (rev 66580)
+++ grass/trunk/locale/po/grassmods_es.po 2015-10-22 22:21:46 UTC (rev 66581)
@@ -18573,7 +18573,7 @@
msgid ""
msgstr ""
@@ -19458,7 +19458,7 @@
#, fuzzy
msgstr "Mapa vectorial de salida de errores"
Modified: grass/trunk/locale/po/grassmods_fi.po
--- grass/trunk/locale/po/grassmods_fi.po 2015-10-22 22:20:10 UTC (rev 66580)
+++ grass/trunk/locale/po/grassmods_fi.po 2015-10-22 22:21:46 UTC (rev 66581)
@@ -16943,7 +16943,7 @@
msgid ""
msgstr ""
@@ -17731,7 +17731,7 @@
msgstr ""
msgstr ""
Modified: grass/trunk/locale/po/grassmods_fr.po
--- grass/trunk/locale/po/grassmods_fr.po 2015-10-22 22:20:10 UTC (rev 66580)
+++ grass/trunk/locale/po/grassmods_fr.po 2015-10-22 22:21:46 UTC (rev 66581)
@@ -19405,7 +19405,7 @@
msgid ""
msgstr ""
@@ -20330,7 +20330,7 @@
#, fuzzy
msgstr "couche raster des zones à problèmes"
Modified: grass/trunk/locale/po/grassmods_it.po
--- grass/trunk/locale/po/grassmods_it.po 2015-10-22 22:20:10 UTC (rev 66580)
+++ grass/trunk/locale/po/grassmods_it.po 2015-10-22 22:21:46 UTC (rev 66581)
@@ -18188,7 +18188,7 @@
msgid ""
msgstr ""
@@ -19078,7 +19078,7 @@
#, fuzzy
msgstr "Mappa vettoriale degli errori di output"
Modified: grass/trunk/locale/po/grassmods_ja.po
--- grass/trunk/locale/po/grassmods_ja.po 2015-10-22 22:20:10 UTC (rev 66580)
+++ grass/trunk/locale/po/grassmods_ja.po 2015-10-22 22:21:46 UTC (rev 66581)
@@ -18206,7 +18206,7 @@
msgid ""
msgstr ""
@@ -19077,7 +19077,7 @@
#, fuzzy
msgstr "ベクトルマップの誤差を出力"
Modified: grass/trunk/locale/po/grassmods_ko.po
--- grass/trunk/locale/po/grassmods_ko.po 2015-10-22 22:20:10 UTC (rev 66580)
+++ grass/trunk/locale/po/grassmods_ko.po 2015-10-22 22:21:46 UTC (rev 66581)
@@ -17697,7 +17697,7 @@
msgid ""
msgstr ""
@@ -18546,7 +18546,7 @@
#, fuzzy
msgstr "출력할 격자지도"
Modified: grass/trunk/locale/po/grassmods_lv.po
--- grass/trunk/locale/po/grassmods_lv.po 2015-10-22 22:20:10 UTC (rev 66580)
+++ grass/trunk/locale/po/grassmods_lv.po 2015-10-22 22:21:46 UTC (rev 66581)
@@ -18416,7 +18416,7 @@
msgid ""
msgstr ""
@@ -19295,7 +19295,7 @@
#, fuzzy
msgstr "Izejas rastra kartes nosaukums"
Modified: grass/trunk/locale/po/grassmods_pl.po
--- grass/trunk/locale/po/grassmods_pl.po 2015-10-22 22:20:10 UTC (rev 66580)
+++ grass/trunk/locale/po/grassmods_pl.po 2015-10-22 22:21:46 UTC (rev 66581)
@@ -18241,7 +18241,7 @@
msgid ""
msgstr ""
@@ -19121,7 +19121,7 @@
#, fuzzy
msgstr "Wyjściowa mapa wektorowa błędów"
Modified: grass/trunk/locale/po/grassmods_pt.po
--- grass/trunk/locale/po/grassmods_pt.po 2015-10-22 22:20:10 UTC (rev 66580)
+++ grass/trunk/locale/po/grassmods_pt.po 2015-10-22 22:21:46 UTC (rev 66581)
@@ -18790,7 +18790,7 @@
msgid ""
msgstr ""
@@ -19699,7 +19699,7 @@
#, fuzzy
msgstr "Gera um mapa das áreas problemáticas"
Modified: grass/trunk/locale/po/grassmods_pt_br.po
--- grass/trunk/locale/po/grassmods_pt_br.po 2015-10-22 22:20:10 UTC (rev 66580)
+++ grass/trunk/locale/po/grassmods_pt_br.po 2015-10-22 22:21:46 UTC (rev 66581)
@@ -18794,7 +18794,7 @@
msgid ""
msgstr ""
@@ -19702,7 +19702,7 @@
#, fuzzy
Modified: grass/trunk/locale/po/grassmods_ro.po
--- grass/trunk/locale/po/grassmods_ro.po 2015-10-22 22:20:10 UTC (rev 66580)
+++ grass/trunk/locale/po/grassmods_ro.po 2015-10-22 22:21:46 UTC (rev 66581)
@@ -17180,7 +17180,7 @@
msgid ""
msgstr ""
@@ -17989,7 +17989,7 @@
#, fuzzy
msgstr "Actualizări de metadate a hărții vectoriale."
Modified: grass/trunk/locale/po/grassmods_ru.po
--- grass/trunk/locale/po/grassmods_ru.po 2015-10-22 22:20:10 UTC (rev 66580)
+++ grass/trunk/locale/po/grassmods_ru.po 2015-10-22 22:21:46 UTC (rev 66581)
@@ -18515,7 +18515,7 @@
msgid ""
msgstr ""
@@ -19410,7 +19410,7 @@
#, fuzzy
msgstr "Выходной векторный слой ошибок"
Modified: grass/trunk/locale/po/grassmods_sl.po
--- grass/trunk/locale/po/grassmods_sl.po 2015-10-22 22:20:10 UTC (rev 66580)
+++ grass/trunk/locale/po/grassmods_sl.po 2015-10-22 22:21:46 UTC (rev 66581)
@@ -18449,7 +18449,7 @@
msgid ""
msgstr ""
@@ -19338,7 +19338,7 @@
#, fuzzy
msgstr "Ime izhodnega rastrskega sloja problematiènih obmoèij"
Modified: grass/trunk/locale/po/grassmods_th.po
--- grass/trunk/locale/po/grassmods_th.po 2015-10-22 22:20:10 UTC (rev 66580)
+++ grass/trunk/locale/po/grassmods_th.po 2015-10-22 22:21:46 UTC (rev 66581)
@@ -18352,7 +18352,7 @@
msgid ""
msgstr ""
@@ -19231,7 +19231,7 @@
#, fuzzy
msgstr "แผนที่เชิงเส้นผลลัพธ์ สำหรับ ข้อผิดพลาด"
Modified: grass/trunk/locale/po/grassmods_tr.po
--- grass/trunk/locale/po/grassmods_tr.po 2015-10-22 22:20:10 UTC (rev 66580)
+++ grass/trunk/locale/po/grassmods_tr.po 2015-10-22 22:21:46 UTC (rev 66581)
@@ -18031,7 +18031,7 @@
msgid ""
msgstr ""
@@ -18913,7 +18913,7 @@
#, fuzzy
msgstr "Sorunlu alanların vektör çıktı haritası"
Modified: grass/trunk/locale/po/grassmods_vi.po
--- grass/trunk/locale/po/grassmods_vi.po 2015-10-22 22:20:10 UTC (rev 66580)
+++ grass/trunk/locale/po/grassmods_vi.po 2015-10-22 22:21:46 UTC (rev 66581)
@@ -18504,7 +18504,7 @@
msgid ""
msgstr ""
@@ -19404,7 +19404,7 @@
#, fuzzy
msgstr "Bản đồ vec-tơ đầu ra dùng để lưu lỗi"
Modified: grass/trunk/locale/po/grassmods_zh.po
--- grass/trunk/locale/po/grassmods_zh.po 2015-10-22 22:20:10 UTC (rev 66580)
+++ grass/trunk/locale/po/grassmods_zh.po 2015-10-22 22:21:46 UTC (rev 66581)
@@ -18407,7 +18407,7 @@
msgid ""
msgstr ""
#, fuzzy
msgstr "输出的有问题区域的栅格图"
Modified: grass/trunk/locale/po/grasswxpy_cs.po
--- grass/trunk/locale/po/grasswxpy_cs.po 2015-10-22 22:20:10 UTC (rev 66580)
+++ grass/trunk/locale/po/grasswxpy_cs.po 2015-10-22 22:21:46 UTC (rev 66581)
@@ -19075,7 +19075,7 @@
msgid ""
"Number of cells (rows*cols) <%d> in current region is higher than "
"recommended threshold <%d>.\n"
-"It is strongly advised to reduce number of cells in current region bellow "
+"It is strongly advised to reduce number of cells in current region below "
"recommend threshold.\n"
" It can be done by <g.region> command.\n"
"\n"
@@ -19112,7 +19112,7 @@
"Multiple of bands ranges <%s:%d * %s:%d = %d> is higher than recommended "
"limit <%d>.\n"
"It is strongly advised to reduce range extend of bands(e. g. using r."
-"rescale) bellow recommended threshold.\n"
+"rescale) below recommended threshold.\n"
"\n"
"Do you really want to add this scatter plot?"
msgstr ""
Modified: grass/trunk/locale/po/grasswxpy_de.po
--- grass/trunk/locale/po/grasswxpy_de.po 2015-10-22 22:20:10 UTC (rev 66580)
+++ grass/trunk/locale/po/grasswxpy_de.po 2015-10-22 22:21:46 UTC (rev 66581)
@@ -18900,7 +18900,7 @@
msgid ""
"\n"
@@ -18937,7 +18937,7 @@
"limit <%d>.\n"
"\n"
msgstr ""
Modified: grass/trunk/locale/po/grasswxpy_el.po
--- grass/trunk/locale/po/grasswxpy_el.po 2015-10-22 22:20:10 UTC (rev 66580)
+++ grass/trunk/locale/po/grasswxpy_el.po 2015-10-22 22:21:46 UTC (rev 66581)
@@ -17896,7 +17896,7 @@
msgid ""
"\n"
@@ -17933,7 +17933,7 @@
"limit <%d>.\n"
"\n"
msgstr ""
Modified: grass/trunk/locale/po/grasswxpy_es.po
--- grass/trunk/locale/po/grasswxpy_es.po 2015-10-22 22:20:10 UTC (rev 66580)
+++ grass/trunk/locale/po/grasswxpy_es.po 2015-10-22 22:21:46 UTC (rev 66581)
@@ -19268,7 +19268,7 @@
msgid ""
"\n"
@@ -19305,7 +19305,7 @@
"limit <%d>.\n"
"\n"
msgstr ""
Modified: grass/trunk/locale/po/grasswxpy_fi.po
--- grass/trunk/locale/po/grasswxpy_fi.po 2015-10-22 22:20:10 UTC (rev 66580)
+++ grass/trunk/locale/po/grasswxpy_fi.po 2015-10-22 22:21:46 UTC (rev 66581)
@@ -17367,7 +17367,7 @@
msgid ""
"\n"
@@ -17403,7 +17403,7 @@
"limit <%d>.\n"
"\n"
msgstr ""
Modified: grass/trunk/locale/po/grasswxpy_fr.po
--- grass/trunk/locale/po/grasswxpy_fr.po 2015-10-22 22:20:10 UTC (rev 66580)
+++ grass/trunk/locale/po/grasswxpy_fr.po 2015-10-22 22:21:46 UTC (rev 66581)
@@ -18677,7 +18677,7 @@
msgid ""
"\n"
@@ -18726,7 +18726,7 @@
"limit <%d>.\n"
"\n"
msgstr ""
Modified: grass/trunk/locale/po/grasswxpy_id.po
--- grass/trunk/locale/po/grasswxpy_id.po 2015-10-22 22:20:10 UTC (rev 66580)
+++ grass/trunk/locale/po/grasswxpy_id.po 2015-10-22 22:21:46 UTC (rev 66581)
@@ -19489,7 +19489,7 @@
msgid ""
"\n"
@@ -19526,7 +19526,7 @@
"limit <%d>.\n"
"\n"
msgstr ""
Modified: grass/trunk/locale/po/grasswxpy_it.po
--- grass/trunk/locale/po/grasswxpy_it.po 2015-10-22 22:20:10 UTC (rev 66580)
+++ grass/trunk/locale/po/grasswxpy_it.po 2015-10-22 22:21:46 UTC (rev 66581)
@@ -18128,7 +18128,7 @@
msgid ""
"\n"
@@ -18175,7 +18175,7 @@
"limit <%d>.\n"
"\n"
msgstr ""
Modified: grass/trunk/locale/po/grasswxpy_ja.po
--- grass/trunk/locale/po/grasswxpy_ja.po 2015-10-22 22:20:10 UTC (rev 66580)
+++ grass/trunk/locale/po/grasswxpy_ja.po 2015-10-22 22:21:46 UTC (rev 66581)
@@ -18841,7 +18841,7 @@
msgid ""
"\n"
@@ -18878,7 +18878,7 @@
"limit <%d>.\n"
"\n"
msgstr ""
Modified: grass/trunk/locale/po/grasswxpy_ko.po
--- grass/trunk/locale/po/grasswxpy_ko.po 2015-10-22 22:20:10 UTC (rev 66580)
+++ grass/trunk/locale/po/grasswxpy_ko.po 2015-10-22 22:21:46 UTC (rev 66581)
@@ -17342,7 +17342,7 @@
msgid ""
"\n"
@@ -17378,7 +17378,7 @@
"limit <%d>.\n"
"\n"
msgstr ""
Modified: grass/trunk/locale/po/grasswxpy_lv.po
--- grass/trunk/locale/po/grasswxpy_lv.po 2015-10-22 22:20:10 UTC (rev 66580)
+++ grass/trunk/locale/po/grasswxpy_lv.po 2015-10-22 22:21:46 UTC (rev 66581)
@@ -17759,7 +17759,7 @@
msgid ""
"\n"
@@ -17795,7 +17795,7 @@
"limit <%d>.\n"
"\n"
msgstr ""
Modified: grass/trunk/locale/po/grasswxpy_ml.po
--- grass/trunk/locale/po/grasswxpy_ml.po 2015-10-22 22:20:10 UTC (rev 66580)
+++ grass/trunk/locale/po/grasswxpy_ml.po 2015-10-22 22:21:46 UTC (rev 66581)
@@ -18432,7 +18432,7 @@
msgid ""
"\n"
@@ -18469,7 +18469,7 @@
"limit <%d>.\n"
"\n"
msgstr ""
Modified: grass/trunk/locale/po/grasswxpy_pl.po
--- grass/trunk/locale/po/grasswxpy_pl.po 2015-10-22 22:20:10 UTC (rev 66580)
+++ grass/trunk/locale/po/grasswxpy_pl.po 2015-10-22 22:21:46 UTC (rev 66581)
msgid ""
"\n"
@@ -18444,7 +18444,7 @@
"limit <%d>.\n"
"\n"
msgstr ""
Modified: grass/trunk/locale/po/grasswxpy_pt.po
--- grass/trunk/locale/po/grasswxpy_pt.po 2015-10-22 22:20:10 UTC (rev 66580)
+++ grass/trunk/locale/po/grasswxpy_pt.po 2015-10-22 22:21:46 UTC (rev 66581)
@@ -19736,7 +19736,7 @@
msgid ""
"\n"
@@ -19773,7 +19773,7 @@
"limit <%d>.\n"
"\n"
msgstr ""
Modified: grass/trunk/locale/po/grasswxpy_pt_br.po
--- grass/trunk/locale/po/grasswxpy_pt_br.po 2015-10-22 22:20:10 UTC (rev 66580)
+++ grass/trunk/locale/po/grasswxpy_pt_br.po 2015-10-22 22:21:46 UTC (rev 66581)
@@ -20241,7 +20241,7 @@
msgid ""
"\n"
@@ -20278,7 +20278,7 @@
"limit <%d>.\n"
"\n"
msgstr ""
Modified: grass/trunk/locale/po/grasswxpy_ro.po
--- grass/trunk/locale/po/grasswxpy_ro.po 2015-10-22 22:20:10 UTC (rev 66580)
+++ grass/trunk/locale/po/grasswxpy_ro.po 2015-10-22 22:21:46 UTC (rev 66581)
@@ -18986,7 +18986,7 @@
msgid ""
"\n"
@@ -19023,7 +19023,7 @@
"limit <%d>.\n"
"\n"
msgstr ""
Modified: grass/trunk/locale/po/grasswxpy_ru.po
--- grass/trunk/locale/po/grasswxpy_ru.po 2015-10-22 22:20:10 UTC (rev 66580)
+++ grass/trunk/locale/po/grasswxpy_ru.po 2015-10-22 22:21:46 UTC (rev 66581)
@@ -19385,7 +19385,7 @@
msgid ""
"\n"
@@ -19422,7 +19422,7 @@
"limit <%d>.\n"
"\n"
msgstr ""
Modified: grass/trunk/locale/po/grasswxpy_th.po
--- grass/trunk/locale/po/grasswxpy_th.po 2015-10-22 22:20:10 UTC (rev 66580)
+++ grass/trunk/locale/po/grasswxpy_th.po 2015-10-22 22:21:46 UTC (rev 66581)
@@ -18638,7 +18638,7 @@
msgid ""
"\n"
@@ -18675,7 +18675,7 @@
"limit <%d>.\n"
"\n"
msgstr ""
Modified: grass/trunk/locale/po/grasswxpy_tr.po
--- grass/trunk/locale/po/grasswxpy_tr.po 2015-10-22 22:20:10 UTC (rev 66580)
+++ grass/trunk/locale/po/grasswxpy_tr.po 2015-10-22 22:21:46 UTC (rev 66581)
@@ -19279,7 +19279,7 @@
msgid ""
"\n"
@@ -19316,7 +19316,7 @@
"limit <%d>.\n"
"\n"
msgstr ""
Modified: grass/trunk/locale/po/grasswxpy_vi.po
--- grass/trunk/locale/po/grasswxpy_vi.po 2015-10-22 22:20:10 UTC (rev 66580)
+++ grass/trunk/locale/po/grasswxpy_vi.po 2015-10-22 22:21:46 UTC (rev 66581)
@@ -19451,7 +19451,7 @@
msgid ""
"\n"
@@ -19488,7 +19488,7 @@
"limit <%d>.\n"
"\n"
msgstr ""
Modified: grass/trunk/locale/po/grasswxpy_zh.po
--- grass/trunk/locale/po/grasswxpy_zh.po 2015-10-22 22:20:10 UTC (rev 66580)
+++ grass/trunk/locale/po/grasswxpy_zh.po 2015-10-22 22:21:46 UTC (rev 66581)
@@ -18653,7 +18653,7 @@
msgid ""
"\n"
@@ -18695,7 +18695,7 @@
"limit <%d>.\n"
"\n"
msgstr ""
