[GRASS-SVN] r66671 - grass/branches/releasebranch_7_0/lib/temporal/lib
Fri Oct 30 04:06:39 PDT 2015
Author: neteler
Date: 2015-10-30 04:06:39 -0700 (Fri, 30 Oct 2015)
New Revision: 66671
   grass/branches/releasebranch_7_0/lib/temporal/lib/connect.c
temporal library: Ignore the warning of missing mapset ownership (trunk, r66554)
Modified: grass/branches/releasebranch_7_0/lib/temporal/lib/connect.c
--- grass/branches/releasebranch_7_0/lib/temporal/lib/connect.c	2015-10-30 11:03:11 UTC (rev 66670)
+++ grass/branches/releasebranch_7_0/lib/temporal/lib/connect.c	2015-10-30 11:06:39 UTC (rev 66671)
@@ -99,13 +99,17 @@
     ret = G_mapset_permissions2(gisdbase, location, mapset);
     switch (ret) {
     case 0: /* Check if the mapset exists and user is owner */
-        G_warning(_("You don't have permission to access the mapset <%s>"),
+        /* We suppress this warning, since G_mapset_permission2() does not
+         * properly check the access privileges to the mapset of a different user.
+         * TODO: develop a dedicated G_mapset_permission3() for that
+        G_warning(_("You are not the owner of mapset <%s>"),
                       mapset);
         break;
     case -1:
         G_warning(_("Mapset <%s> does not exist."),
 	              mapset);
-        break;
+        return ret_val;
     default:
         break;
