[GRASS-SVN] r66672 - in grass/trunk/temporal/t.shift: . testsuite
svn_grass at osgeo.org
Fri Oct 30 04:23:52 PDT 2015
Author: huhabla
Date: 2015-10-30 04:23:52 -0700 (Fri, 30 Oct 2015)
New Revision: 66672
Added:
grass/trunk/temporal/t.shift/testsuite/
grass/trunk/temporal/t.shift/testsuite/test_shift.py
Removed:
grass/trunk/temporal/t.shift/test.t.shift.absolue.sh
grass/trunk/temporal/t.shift/test.t.shift.relative.sh
temporal modules: Added t.shift tests
Deleted: grass/trunk/temporal/t.shift/test.t.shift.absolue.sh
--- grass/trunk/temporal/t.shift/test.t.shift.absolue.sh 2015-10-30 11:06:39 UTC (rev 66671)
+++ grass/trunk/temporal/t.shift/test.t.shift.absolue.sh 2015-10-30 11:23:52 UTC (rev 66672)
@@ -1,46 +0,0 @@
-#!/bin/sh
-# Space time raster dataset temporal shifting
-# We need to set a specific region in the
-# @preprocess step of this test.
-# The region setting should work for UTM and LL test locations
-g.region s=0 n=80 w=0 e=120 b=0 t=50 res=10 res3=10 -p3
-# Generate data
-r.mapcalc --o expr="prec_1 = rand(0, 550)" -s
-r.mapcalc --o expr="prec_2 = rand(0, 450)" -s
-r.mapcalc --o expr="prec_3 = rand(0, 320)" -s
-r.mapcalc --o expr="prec_4 = rand(0, 510)" -s
-r.mapcalc --o expr="prec_5 = rand(0, 300)" -s
-r.mapcalc --o expr="prec_6 = rand(0, 650)" -s
-t.create --o type=strds temporaltype=absolute output=precip_abs title="A test" descr="A test"
-t.register -i --o type=raster input=precip_abs maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6 \
- start="2001-01-01 12:00:00" increment="14 days"
-t.rast.list input=precip_abs
-# The first @test
-t.shift --o input=precip_abs granularity="3 years"
-t.info type=strds input=precip_abs
-t.shift --o input=precip_abs granularity="12 months"
-t.shift --o input=precip_abs granularity="2 days"
-t.shift --o input=precip_abs granularity="3 hours"
-t.shift --o input=precip_abs granularity="30 minutes"
-t.shift --o input=precip_abs granularity="5 seconds"
-# This should give an error because of the monthly increment
-# that will result in wrong number of days in the next month
-t.shift --o input=precip_abs granularity="1 month"
-t.unregister type=raster maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6
-t.remove type=strds input=precip_abs
Deleted: grass/trunk/temporal/t.shift/test.t.shift.relative.sh
--- grass/trunk/temporal/t.shift/test.t.shift.relative.sh 2015-10-30 11:06:39 UTC (rev 66671)
+++ grass/trunk/temporal/t.shift/test.t.shift.relative.sh 2015-10-30 11:23:52 UTC (rev 66672)
@@ -1,32 +0,0 @@
-#!/bin/sh
-# Space time raster dataset temporal shifting with relative time
-# Generate data
-t.create --o type=strds temporaltype=relative output=precip_rel title="A test" descr="A test"
-t.register -i --o type=raster unit=days input=precip_rel maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6 \
- start=0 increment=1
-t.info type=strds input=precip_rel
-t.rast.list input=precip_rel
-# The first @test
-t.shift --o input=precip_rel granularity=3
-t.shift --o input=precip_rel granularity=10000
-t.remove type=strds input=precip_rel
Added: grass/trunk/temporal/t.shift/testsuite/test_shift.py
--- grass/trunk/temporal/t.shift/testsuite/test_shift.py (rev 0)
+++ grass/trunk/temporal/t.shift/testsuite/test_shift.py 2015-10-30 11:23:52 UTC (rev 66672)
@@ -0,0 +1,526 @@
+"""Test t.shift
+(C) 2015 by the GRASS Development Team
+This program is free software under the GNU General Public
+License (>=v2). Read the file COPYING that comes with GRASS
+for details.
+:authors: Soeren Gebbert
+import os
+import grass.pygrass.modules as pymod
+import grass.temporal as tgis
+from grass.gunittest.case import TestCase
+from grass.gunittest.gmodules import SimpleModule
+class TestShiftAbsoluteSTRDS(TestCase):
+ @classmethod
+ def setUpClass(cls):
+ """Initiate the temporal GIS and set the region
+ os.putenv("GRASS_OVERWRITE", "1")
+ tgis.init()
+ cls.use_temp_region()
+ cls.runModule("g.region", s=0, n=80, w=0, e=120, b=0,
+ t=50, res=10, res3=10)
+ cls.runModule("r.mapcalc", expression="a1 = 100", overwrite=True)
+ cls.runModule("r.mapcalc", expression="a2 = 200", overwrite=True)
+ cls.runModule("r.mapcalc", expression="a3 = 300", overwrite=True)
+ cls.runModule("r.mapcalc", expression="a4 = 400", overwrite=True)
+ cls.runModule("t.create", type="strds", temporaltype="absolute",
+ output="A", title="A test",
+ description="A test", overwrite=True)
+ cls.runModule("t.register", type="raster", input="A",
+ maps="a1,a2,a3,a4",
+ start="2001-01-01",
+ increment="14 days",
+ overwrite=True)
+ @classmethod
+ def tearDownClass(cls):
+ """Remove the temporary region
+ cls.del_temp_region()
+ cls.runModule("t.remove", flags="rf", type="strds", inputs="A")
+ def test_1(self):
+ A = tgis.open_old_stds("A", type="strds")
+ A.select()
+ self.assertEqual(A.get_map_time(), "point")
+ start, end = A.get_temporal_extent_as_tuple()
+ self.assertEqual(start.year, 2001)
+ self.assertEqual(start.month, 1)
+ self.assertEqual(start.day, 1)
+ self.assertModule("t.shift", input="A",
+ granularity="1 day",
+ type="strds")
+ A.select()
+ self.assertEqual(start.day, 2)
+ granularity="-1 day",
+ type="strds")
+ A.select()
+ granularity="-1 year",
+ type="strds")
+ A.select()
+ self.assertEqual(start.year, 2000)
+ granularity="6 month",
+ type="strds")
+ A.select()
+ self.assertEqual(start.month, 7)
+ granularity="1 hour",
+ type="strds")
+ A.select()
+ self.assertEqual(start.hour, 1)
+ granularity="-3630 seconds",
+ type="strds")
+ A.select()
+ self.assertEqual(start.month, 6)
+ self.assertEqual(start.day, 30)
+ self.assertEqual(start.hour, 23)
+ self.assertEqual(start.minute, 59)
+ self.assertEqual(start.second, 30)
+class TestShiftRelativeSTRDS(TestCase):
+ @classmethod
+ tgis.init()
+ cls.runModule("t.create", type="strds", temporaltype="relative",
+ start="0",
+ increment="14", unit="days",
+ overwrite=True)
+ @classmethod
+ def test_1(self):
+ A.select()
+ self.assertEqual(start, 0)
+ granularity="1",
+ type="strds")
+ A.select()
+ self.assertEqual(start, 1)
+class TestShiftAbsoluteSTR3DS(TestCase):
+ @classmethod
+ tgis.init()
+ cls.runModule("r3.mapcalc", expression="a1 = 100", overwrite=True)
+ cls.runModule("r3.mapcalc", expression="a2 = 200", overwrite=True)
+ cls.runModule("r3.mapcalc", expression="a3 = 300", overwrite=True)
+ cls.runModule("r3.mapcalc", expression="a4 = 400", overwrite=True)
+ cls.runModule("t.create", type="str3ds", temporaltype="absolute",
+ cls.runModule("t.register", type="raster_3d", input="A",
+ overwrite=True)
+ @classmethod
+ cls.runModule("t.remove", flags="rf", type="str3ds", inputs="A")
+ def test_1(self):
+ A = tgis.open_old_stds("A", type="str3ds")
+ A.select()
+ type="str3ds")
+ A.select()
+ type="str3ds")
+ A.select()
+ type="str3ds")
+ A.select()
+ type="str3ds")
+ A.select()
+ type="str3ds")
+ A.select()
+ type="str3ds")
+ A.select()
+class TestShiftRelativeSTR3DS(TestCase):
+ @classmethod
+ tgis.init()
+ cls.runModule("t.create", type="str3ds", temporaltype="relative",
+ start="0",
+ overwrite=True)
+ @classmethod
+ def test_1(self):
+ A.select()
+ granularity="1",
+ type="str3ds")
+ A.select()
+class TestShiftAbsoluteSTVDS(TestCase):
+ @classmethod
+ tgis.init()
+ cls.runModule("v.random", quiet=True, npoints=20, seed=1, output='a1')
+ cls.runModule("v.random", quiet=True, npoints=20, seed=1, output='a2')
+ cls.runModule("v.random", quiet=True, npoints=20, seed=1, output='a3')
+ cls.runModule("v.random", quiet=True, npoints=20, seed=1, output='a4')
+ cls.runModule("t.create", type="stvds", temporaltype="absolute",
+ cls.runModule("t.register", type="vector", input="A",
+ maps="a1,a2,a3,a4", flags="i",
+ overwrite=True)
+ @classmethod
+ cls.runModule("t.remove", flags="rf", type="stvds", inputs="A")
+ def test_1(self):
+ A = tgis.open_old_stds("A", type="stvds")
+ A.select()
+ self.assertEqual(A.get_map_time(), "interval")
+ type="stvds")
+ A.select()
+ type="stvds")
+ A.select()
+ type="stvds")
+ A.select()
+ type="stvds")
+ A.select()
+ type="stvds")
+ A.select()
+ type="stvds")
+ A.select()
+class TestShiftRelativeSTVDS(TestCase):
+ @classmethod
+ tgis.init()
+ cls.runModule("t.create", type="stvds", temporaltype="relative",
+ start="0", flags="i",
+ overwrite=True)
+ @classmethod
+ def test_1(self):
+ A.select()
+ granularity="1",
+ type="stvds")
+ A.select()
+class TestShiftAbsoluteError(TestCase):
+ @classmethod
+ tgis.init()
+ start="0",
+ overwrite=True)
+ @classmethod
+ def test_1(self):
+ pass
+ #self.assterModuleFail()
+if __name__ == '__main__':
+ from grass.gunittest.main import test
+ test()
