[GRASS-SVN] r66140 - grass/branches/releasebranch_7_0/raster/r.water.outlet
svn_grass at osgeo.org
Mon Sep 7 01:01:31 PDT 2015
Author: neteler
Date: 2015-09-07 01:01:31 -0700 (Mon, 07 Sep 2015)
New Revision: 66140
Removed:
grass/branches/releasebranch_7_0/raster/r.water.outlet/flag.h
grass/branches/releasebranch_7_0/raster/r.water.outlet/flag_clr_all.c
grass/branches/releasebranch_7_0/raster/r.water.outlet/flag_create.c
grass/branches/releasebranch_7_0/raster/r.water.outlet/flag_destroy.c
grass/branches/releasebranch_7_0/raster/r.water.outlet/flag_get.c
grass/branches/releasebranch_7_0/raster/r.water.outlet/flag_set.c
grass/branches/releasebranch_7_0/raster/r.water.outlet/flag_unset.c
grass/branches/releasebranch_7_0/raster/r.water.outlet/basin.h
grass/branches/releasebranch_7_0/raster/r.water.outlet/main.c
r.water.outlet: Remove unused files and variables (trunk, r65984)
Modified: grass/branches/releasebranch_7_0/raster/r.water.outlet/basin.h
--- grass/branches/releasebranch_7_0/raster/r.water.outlet/basin.h 2015-09-07 07:46:29 UTC (rev 66139)
+++ grass/branches/releasebranch_7_0/raster/r.water.outlet/basin.h 2015-09-07 08:01:31 UTC (rev 66140)
@@ -1,52 +1,10 @@
-#include <math.h>
#include <grass/raster.h>
#include "ramseg.h"
-#include "flag.h"
-#define NODE struct _n_o_d_e_
-#define AR_SIZE 16
-#define AR_INCR 64
-#define ABS(x) (((x) < 0) ? -(x) : (x))
-#ifdef MIN
- #undef MIN
- #define MIN(x,y) (((x) < (y)) ? (x) : (y))
-#endif
-#define MAX_RAM 1000000
-#define SROW 11
-#define SCOL 10
-#define SHORT int
-#define NOMASK 1
-#define MIN_SLOPE .00001
-#define MIN_GRADIENT_DEGREES 1
-#define DEG_TO_RAD .017453293 /* pi / 180 */
-#define METER_TO_FOOT 3.281
-#define PAGE_BLOCK 512
-#define RITE 1
-#define LEFT 2
-#define NEITHER 0
+#define SHORT int
-NODE {
- int row, col;
extern SHORT drain[3][3];
-extern SHORT updrain[3][3];
-extern char dr_mod[9];
-extern char dc_mod[9];
-extern char basin_name[GNAME_MAX], swale_name[GNAME_MAX],
- half_name[GNAME_MAX], elev_name[GNAME_MAX], armsed_name[GNAME_MAX];
-extern int nrows, ncols, done, total;
-extern int array_size, high_index, do_index;
-extern char *drain_ptrs, ha_f, el_f, ar_f;
-extern RAMSEG ba_seg, pt_seg, sl_seg;
-extern int ncols_less_one, nrows_less_one;
-extern NODE *to_do;
-extern FILE *arm_fd, *fp;
-extern FLAG *doner, *swale, *left;
+extern int nrows, ncols;
+extern char *drain_ptrs;
+extern RAMSEG ba_seg, pt_seg;
extern CELL *bas;
-extern double half_res, diag, max_length, dep_slope;
-extern struct Cell_head window;
- GLOBAL CELL *dis, *alt, *wat, *asp, *bas, *haf, *r_h, *dep, *ril_buf;
Deleted: grass/branches/releasebranch_7_0/raster/r.water.outlet/flag.h
--- grass/branches/releasebranch_7_0/raster/r.water.outlet/flag.h 2015-09-07 07:46:29 UTC (rev 66139)
+++ grass/branches/releasebranch_7_0/raster/r.water.outlet/flag.h 2015-09-07 08:01:31 UTC (rev 66140)
@@ -1,70 +0,0 @@
-/* flag.[ch] is a set of routines which will set up an array of bits
- ** that allow the programmer to "flag" cells in a raster map.
- ** FLAG *
- ** flag_create(nrows,ncols)
- ** int nrows, ncols;
- ** opens the structure flag.
- ** The flag structure will be a two dimensional array of bits the
- ** size of nrows by ncols. Will initalize flags to zero (unset).
- ** flag_destroy(flags)
- ** FLAG *flags;
- ** closes flags and gives the memory back to the system.
- ** flag_clear_all(flags)
- ** FLAG *flags;
- ** sets all values in flags to zero.
- ** flag_unset(flags, row, col)
- ** FLAG *flags;
- ** int row, col;
- ** sets the value of (row, col) in flags to zero.
- ** flag_set(flags, row, col)
- ** FLAG *flags;
- ** int row, col;
- ** will set the value of (row, col) in flags to one.
- ** int
- ** flag_get(flags, row, col)
- ** FLAG *flags;
- ** int row, col;
- ** returns the value in flags that is at (row, col).
- ** idea by Michael Shapiro
- ** code by Chuck Ehlschlaeger
- ** April 03, 1989
-#define FLAG struct _flagsss_
-FLAG {
- int nrows, ncols, leng;
- unsigned char **array;
-#define FLAG_UNSET(flags,row,col) \
- (flags)->array[(row)][(col)>>3] &= ~(1<<((col) & 7))
-#define FLAG_SET(flags,row,col) \
- (flags)->array[(row)][(col)>>3] |= (1<<((col) & 7))
-#define FLAG_GET(flags,row,col) \
- (flags)->array[(row)][(col)>>3] & (1<<((col) & 7))
-/* flag_clr_all.c */
-int flag_clear_all(FLAG *);
-/* flag_create.c */
-FLAG *flag_create(int, int);
-/* flag_destroy.c */
-int flag_destroy(FLAG *);
-/* flag_get.c */
-int flag_get(FLAG *, int, int);
-/* flag_set.c */
-int flag_set(FLAG *, int, int);
-/* flag_unset.c */
-int flag_unset(FLAG *, int, int);
Deleted: grass/branches/releasebranch_7_0/raster/r.water.outlet/flag_clr_all.c
--- grass/branches/releasebranch_7_0/raster/r.water.outlet/flag_clr_all.c 2015-09-07 07:46:29 UTC (rev 66139)
+++ grass/branches/releasebranch_7_0/raster/r.water.outlet/flag_clr_all.c 2015-09-07 08:01:31 UTC (rev 66140)
@@ -1,15 +0,0 @@
-#include "flag.h"
-int flag_clear_all(FLAG * flags)
- register int r, c;
- r = flags->nrows - 1;
- while (r--) {
- c = flags->leng - 1;
- while (c--)
- flags->array[r][c] = 0;
- return 0;
Deleted: grass/branches/releasebranch_7_0/raster/r.water.outlet/flag_create.c
--- grass/branches/releasebranch_7_0/raster/r.water.outlet/flag_create.c 2015-09-07 07:46:29 UTC (rev 66139)
+++ grass/branches/releasebranch_7_0/raster/r.water.outlet/flag_create.c 2015-09-07 08:01:31 UTC (rev 66140)
@@ -1,39 +0,0 @@
-#include <grass/gis.h>
-#include "flag.h"
-FLAG *flag_create(int nrows, int ncols)
- unsigned char *temp;
- FLAG *new_flag;
- register int i;
- new_flag = (FLAG *) G_malloc(sizeof(FLAG));
- if (!new_flag) {
- G_warning("Memory error in flag_create() at FLAG");
- return (NULL);
- new_flag->nrows = nrows;
- new_flag->ncols = ncols;
- new_flag->leng = (ncols + 7) / 8;
- new_flag->array =
- (unsigned char **)G_malloc(nrows * sizeof(unsigned char *));
- if (!new_flag->array) {
- G_warning("Memory error in flag_create() at array");
- G_free(new_flag);
- return (NULL);
- temp =
- (unsigned char *)G_calloc(nrows * new_flag->leng,
- sizeof(unsigned char));
- if (!temp) {
- G_warning("Memory error in flag_create() at temp");
- G_free(new_flag->array);
- G_free(new_flag);
- return (NULL);
- for (i = 0; i < nrows; i++) {
- new_flag->array[i] = temp;
- temp += new_flag->leng;
- return (new_flag);
Deleted: grass/branches/releasebranch_7_0/raster/r.water.outlet/flag_destroy.c
--- grass/branches/releasebranch_7_0/raster/r.water.outlet/flag_destroy.c 2015-09-07 07:46:29 UTC (rev 66139)
+++ grass/branches/releasebranch_7_0/raster/r.water.outlet/flag_destroy.c 2015-09-07 08:01:31 UTC (rev 66140)
@@ -1,11 +0,0 @@
-#include "flag.h"
-int flag_destroy(FLAG * flags)
- G_free(flags->array[0]);
- G_free(flags->array);
- G_free(flags);
- return 0;
Deleted: grass/branches/releasebranch_7_0/raster/r.water.outlet/flag_get.c
--- grass/branches/releasebranch_7_0/raster/r.water.outlet/flag_get.c 2015-09-07 07:46:29 UTC (rev 66139)
+++ grass/branches/releasebranch_7_0/raster/r.water.outlet/flag_get.c 2015-09-07 08:01:31 UTC (rev 66140)
@@ -1,6 +0,0 @@
-#include "flag.h"
-int flag_get(FLAG * flags, int row, int col)
- return (flags->array[row][col >> 3] & (1 << (col & 7)));
Deleted: grass/branches/releasebranch_7_0/raster/r.water.outlet/flag_set.c
--- grass/branches/releasebranch_7_0/raster/r.water.outlet/flag_set.c 2015-09-07 07:46:29 UTC (rev 66139)
+++ grass/branches/releasebranch_7_0/raster/r.water.outlet/flag_set.c 2015-09-07 08:01:31 UTC (rev 66140)
@@ -1,8 +0,0 @@
-#include "flag.h"
-int flag_set(FLAG * flags, int row, int col)
- flags->array[row][col >> 3] |= (1 << (col & 7));
- return 0;
Deleted: grass/branches/releasebranch_7_0/raster/r.water.outlet/flag_unset.c
--- grass/branches/releasebranch_7_0/raster/r.water.outlet/flag_unset.c 2015-09-07 07:46:29 UTC (rev 66139)
+++ grass/branches/releasebranch_7_0/raster/r.water.outlet/flag_unset.c 2015-09-07 08:01:31 UTC (rev 66140)
@@ -1,8 +0,0 @@
-#include "flag.h"
-int flag_unset(FLAG * flags, int row, int col)
- flags->array[row][col >> 3] &= ~(1 << (col & 7));
- return 0;
Modified: grass/branches/releasebranch_7_0/raster/r.water.outlet/main.c
--- grass/branches/releasebranch_7_0/raster/r.water.outlet/main.c 2015-09-07 07:46:29 UTC (rev 66139)
+++ grass/branches/releasebranch_7_0/raster/r.water.outlet/main.c 2015-09-07 08:01:31 UTC (rev 66140)
@@ -31,34 +31,23 @@
#include "basin.h"
#include "outletP.h"
-SHORT drain[3][3] = {{ 7,6,5 },{ 8,-17,4 },{ 1,2,3 }};
-SHORT updrain[3][3] = {{ 3,2,1 },{ 4,-17,8 },{ 5,6,7 }};
-char dr_mod[9] = {0,1,1,1,0,-1,-1,-1,0};
-char dc_mod[9] = {0,1,0,-1,-1,-1,0,1,1};
-char basin_name[GNAME_MAX], swale_name[GNAME_MAX],
-int nrows, ncols, done, total;
-int array_size, high_index, do_index;
-char *drain_ptrs, ha_f, el_f, ar_f;
-RAMSEG ba_seg, pt_seg, sl_seg;
-int ncols_less_one, nrows_less_one;
-NODE *to_do;
-FILE *arm_fd, *fp;
-FLAG *doner, *swale, *left;
+SHORT drain[3][3] = {{ 7,6,5 },{ 8,-17,4 },{ 1,2,3 }};
+int nrows, ncols;
+char *drain_ptrs;
+RAMSEG ba_seg, pt_seg;
CELL *bas;
-double half_res, diag, max_length, dep_slope;
-struct Cell_head window;
int main(int argc, char *argv[])
- double N, E;
- int row, col, basin_fd, drain_fd;
- CELL *cell_buf;
- char drain_name[GNAME_MAX];
struct GModule *module;
struct {
struct Option *input, *output, *coords;
} opt;
+ double N, E;
+ int row, col, basin_fd, drain_fd;
+ CELL *cell_buf;
+ char drain_name[GNAME_MAX], basin_name[GNAME_MAX];
+ struct Cell_head window;
G_gisinit(argv[0]);
@@ -103,9 +92,6 @@
nrows = Rast_window_rows();
ncols = Rast_window_cols();
- total = nrows * ncols;
- nrows_less_one = nrows - 1;
- ncols_less_one = ncols - 1;
drain_fd = Rast_open_old(drain_name, "");
drain_ptrs =
@@ -116,8 +102,6 @@
for (row = 0; row < nrows; row++) {
Rast_get_c_row(drain_fd, cell_buf, row);
for (col = 0; col < ncols; col++) {
- if (cell_buf[col] == 0)
- total--;
drain_ptrs[SEG_INDEX(pt_seg, row, col)] = cell_buf[col];
