[GRASS-SVN] r66141 - grass/trunk/vector/v.cluster
svn_grass at osgeo.org
Mon Sep 7 01:09:13 PDT 2015
Author: martinl
Date: 2015-09-07 01:09:13 -0700 (Mon, 07 Sep 2015)
New Revision: 66141
grass/trunk/vector/v.cluster/main.c
grass/trunk/vector/v.cluster/v.cluster.html
v.cluster: module description wording
options in bold (manual cosmetics)
Modified: grass/trunk/vector/v.cluster/main.c
--- grass/trunk/vector/v.cluster/main.c 2015-09-07 08:01:31 UTC (rev 66140)
+++ grass/trunk/vector/v.cluster/main.c 2015-09-07 08:09:13 UTC (rev 66141)
@@ -90,7 +90,7 @@
G_add_keyword(_("point cloud"));
G_add_keyword(_("cluster"));
G_add_keyword(_("clump"));
- module->description = _("Cluster identification");
+ module->description = _("Performs cluster identification.");
/* Define the different options as defined in gis.h */
input = G_define_standard_option(G_OPT_V_INPUT);
Modified: grass/trunk/vector/v.cluster/v.cluster.html
--- grass/trunk/vector/v.cluster/v.cluster.html 2015-09-07 08:01:31 UTC (rev 66140)
+++ grass/trunk/vector/v.cluster/v.cluster.html 2015-09-07 08:09:13 UTC (rev 66141)
@@ -3,21 +3,21 @@
<em>v.cluster</em> partitions a point cloud into clusters or clumps.
<p>
-If the minimum number of points is not specified with the <i>min</i>
+If the minimum number of points is not specified with the <b>min</b>
option, the minimum number of points to constitute a cluster is
<i>number of dimensions + 1</i>, i.e. 3 for 2D points and 4 for 3D
points.
<p>
-If the maximum distance is not specified with the <i>distance</i>
+If the maximum distance is not specified with the <b>distance</b>
option, the maximum distance is estimated from the observed distances
to the neighbors using the upper 99% confidence interval.
<p>
<em>v.cluster</em> supports different methods for clustering. The
-recommended methods are <i>method=dbscan</i> if all clusters should
+recommended methods are <b>method=dbscan</b> if all clusters should
have a density (maximum distance between points) not larger than
-<i>distance</i> or <i>method=density</i> if clusters should be created
+<b>distance</b> or <b>method=density</b> if clusters should be created
separately for each observed density (distance to the farthest neighbor).
<h4>dbscan</h4>
@@ -31,14 +31,14 @@
<h4>dbscan2</h4>
Similar to <i>dbscan</i>, but here it is sufficient if the resultant
-cluster consists of at least <i>min</i> points, even if no point in the
-cluster has at least <i>min</i> -1 neighbors within <i>distance</i>.
+cluster consists of at least <b>min</b> points, even if no point in the
+cluster has at least <i>min - 1</i> neighbors within <b>distance</b>.
<h4>density</h4>
This method creates clusters according to their point density. The
maximum distance is not used. Instead, the points are sorted ascending
by the distance to their farthest neighbor (core distance), inspecting
-<i>min</i> - 1 neighbors. The densest cluster is created first, using
+<i>min - 1</i> neighbors. The densest cluster is created first, using
as threshold the core distance of the seed point. The cluster is
expanded as for DBSCAN, with the difference that each cluster has its
own maximum distance. This method can identify clusters with different
