[GRASS-SVN] r66249 - in grass/trunk/temporal/t.support: . testsuite
svn_grass at osgeo.org
Wed Sep 16 09:24:10 PDT 2015
Author: huhabla
Date: 2015-09-16 09:24:10 -0700 (Wed, 16 Sep 2015)
New Revision: 66249
Added:
grass/trunk/temporal/t.support/testsuite/
grass/trunk/temporal/t.support/testsuite/test_support_str3ds.py
grass/trunk/temporal/t.support/testsuite/test_support_strds.py
grass/trunk/temporal/t.support/testsuite/test_support_stvds.py
grass/trunk/temporal/t.support/t.support.py
temporal modules: Added python tests to t.support, added aggregation type setting
Modified: grass/trunk/temporal/t.support/t.support.py
--- grass/trunk/temporal/t.support/t.support.py 2015-09-16 15:46:16 UTC (rev 66248)
+++ grass/trunk/temporal/t.support/t.support.py 2015-09-16 16:24:10 UTC (rev 66249)
@@ -54,6 +54,14 @@
#% multiple: no
#%end
+#%option
+#% key: aggr_type
+#% type: string
+#% description: Aggregation type of the space time raster or 3D raster dataset
+#% required: no
+#% multiple: no
+#%end
#%flag
#% key: m
#% label: Update the metadata information and spatial extent of registered maps from the GRASS spatial database
@@ -62,7 +70,7 @@
#%flag
#% key: u
-#% description: Update metadata information, temporal and spatial extent from registered maps
+#% description: Update metadata information, temporal and spatial extent from registered maps based on database entries.
#%end
@@ -77,6 +85,7 @@
name = options["input"]
type = options["type"]
title = options["title"]
+ aggr_type = options["aggr_type"]
description = options["description"]
semantic = options["semantictype"]
update = flags["u"]
@@ -91,6 +100,12 @@
stds = tgis.open_old_stds(name, type, dbif)
update = False
+ if aggr_type and type == "stvds":
+ return()
+ if aggr_type and type != "stvds":
+ stds.metadata.set_aggregation_type(aggregation_type=aggr_type)
+ update = True
if title:
stds.metadata.set_title(title=title)
update = True
Added: grass/trunk/temporal/t.support/testsuite/test_support_str3ds.py
--- grass/trunk/temporal/t.support/testsuite/test_support_str3ds.py (rev 0)
+++ grass/trunk/temporal/t.support/testsuite/test_support_str3ds.py 2015-09-16 16:24:10 UTC (rev 66249)
@@ -0,0 +1,105 @@
+"""Test t.support
+(C) 2015 by the GRASS Development Team
+This program is free software under the GNU General Public
+License (>=v2). Read the file COPYING that comes with GRASS
+for details.
+:authors: Soeren Gebbert
+import os
+import grass.pygrass.modules as pymod
+import grass.temporal as tgis
+from grass.gunittest.case import TestCase
+from grass.gunittest.gmodules import SimpleModule
+class TestSupportAbsoluteSTR3DS(TestCase):
+ @classmethod
+ def setUpClass(cls):
+ """Initiate the temporal GIS and set the region
+ os.putenv("GRASS_OVERWRITE", "1")
+ tgis.init()
+ cls.use_temp_region()
+ cls.runModule("g.region", s=0, n=80, w=0, e=120, b=0,
+ t=50, res=10, res3=10)
+ cls.runModule("r3.mapcalc", expression="a1 = 100", overwrite=True)
+ cls.runModule("r3.mapcalc", expression="a2 = 200", overwrite=True)
+ cls.runModule("r3.mapcalc", expression="a3 = 300", overwrite=True)
+ cls.runModule("r3.mapcalc", expression="a4 = 400", overwrite=True)
+ cls.runModule("t.create", type="str3ds", temporaltype="absolute",
+ output="A", title="A test",
+ description="A test", overwrite=True)
+ cls.runModule("t.register", flags="i", type="raster_3d", input="A",
+ maps="a1,a2,a3,a4",
+ start="2001-01-15 12:05:45",
+ increment="14 days",
+ overwrite=True)
+ @classmethod
+ def tearDownClass(cls):
+ """Remove the temporary region
+ cls.del_temp_region()
+ cls.runModule("t.remove", flags="rf", type="str3ds", inputs="A")
+ def test_1_metadata(self):
+ """Set title, description and aggregation"""
+ title="A new title"
+ descr="A new description"
+ aggr_type="average"
+ semantic="sum"
+ self.assertModule("t.support", type="str3ds", input="A",
+ title=title,
+ description=descr,
+ semantictype=semantic,
+ aggr_type=aggr_type)
+ A = tgis.open_old_stds("A", type="str3ds")
+ A.select()
+ self.assertEqual(A.metadata.get_title(), title)
+ self.assertEqual(A.metadata.get_description(), descr)
+ self.assertEqual(A.metadata.get_aggregation_type(), aggr_type)
+ self.assertEqual(A.base.get_semantic_type(), semantic)
+ def test_2_update(self):
+ self.runModule("r3.mapcalc", expression="a1 = 10", overwrite=True)
+ self.runModule("r3.mapcalc", expression="a2 = 20", overwrite=True)
+ self.runModule("r3.mapcalc", expression="a3 = 30", overwrite=True)
+ self.runModule("r3.mapcalc", expression="a4 = 40", overwrite=True)
+ self.assertModule("t.support", type="str3ds", input="A", flags="m")
+ A.select()
+ self.assertEqual(A.metadata.get_min_min(), 10)
+ self.assertEqual(A.metadata.get_min_max(), 40)
+ self.assertEqual(A.metadata.get_max_min(), 10)
+ self.assertEqual(A.metadata.get_max_max(), 40)
+ self.assertEqual(A.metadata.get_number_of_maps(), 4)
+ def test_3_update(self):
+ self.runModule("g.remove", type="raster_3d", name="a4", flags="f")
+ A.select()
+ self.assertEqual(A.metadata.get_min_max(), 30)
+ self.assertEqual(A.metadata.get_max_max(), 30)
+ self.assertEqual(A.metadata.get_number_of_maps(), 3)
+if __name__ == '__main__':
+ from grass.gunittest.main import test
+ test()
Added: grass/trunk/temporal/t.support/testsuite/test_support_strds.py
--- grass/trunk/temporal/t.support/testsuite/test_support_strds.py (rev 0)
+++ grass/trunk/temporal/t.support/testsuite/test_support_strds.py 2015-09-16 16:24:10 UTC (rev 66249)
@@ -0,0 +1,105 @@
+"""Test t.support
+for details.
+import os
+class TestSupportAbsoluteSTRDS(TestCase):
+ @classmethod
+ tgis.init()
+ cls.runModule("r.mapcalc", expression="a1 = 100", overwrite=True)
+ cls.runModule("r.mapcalc", expression="a2 = 200", overwrite=True)
+ cls.runModule("r.mapcalc", expression="a3 = 300", overwrite=True)
+ cls.runModule("r.mapcalc", expression="a4 = 400", overwrite=True)
+ cls.runModule("t.create", type="strds", temporaltype="absolute",
+ cls.runModule("t.register", flags="i", type="raster", input="A",
+ overwrite=True)
+ @classmethod
+ cls.runModule("t.remove", flags="rf", type="strds", inputs="A")
+ semantic="sum"
+ self.assertModule("t.support", input="A",
+ title=title,
+ A = tgis.open_old_stds("A", type="strds")
+ A.select()
+ self.runModule("r.mapcalc", expression="a1 = 10", overwrite=True)
+ self.runModule("r.mapcalc", expression="a2 = 20", overwrite=True)
+ self.runModule("r.mapcalc", expression="a3 = 30", overwrite=True)
+ self.runModule("r.mapcalc", expression="a4 = 40", overwrite=True)
+ self.assertModule("t.support", input="A", flags="m")
+ A.select()
+ self.runModule("g.remove", type="raster", name="a4", flags="f")
+ A.select()
+ test()
Added: grass/trunk/temporal/t.support/testsuite/test_support_stvds.py
--- grass/trunk/temporal/t.support/testsuite/test_support_stvds.py (rev 0)
+++ grass/trunk/temporal/t.support/testsuite/test_support_stvds.py 2015-09-16 16:24:10 UTC (rev 66249)
@@ -0,0 +1,96 @@
+"""Test t.support
+for details.
+import os
+class TestSupportAbsoluteSTVDS(TestCase):
+ @classmethod
+ tgis.init()
+ cls.runModule("v.random", quiet=True, npoints=20, seed=1, output='a1')
+ cls.runModule("v.random", quiet=True, npoints=20, seed=1, output='a2')
+ cls.runModule("v.random", quiet=True, npoints=20, seed=1, output='a3')
+ cls.runModule("v.random", quiet=True, npoints=20, seed=1, output='a4')
+ cls.runModule("t.create", type="stvds", temporaltype="absolute",
+ cls.runModule("t.register", flags="i", type="vector", input="A",
+ overwrite=True)
+ @classmethod
+ cls.runModule("t.remove", flags="rf", type="stvds", inputs="A")
+ semantic="sum"
+ self.assertModule("t.support", type="stvds", input="A",
+ title=title,
+ semantictype=semantic)
+ A = tgis.open_old_stds("A", type="stvds")
+ A.select()
+ self.runModule("v.random", quiet=True, npoints=10, seed=1, output='a1')
+ self.runModule("v.random", quiet=True, npoints=10, seed=1, output='a2')
+ self.runModule("v.random", quiet=True, npoints=10, seed=1, output='a3')
+ self.runModule("v.random", quiet=True, npoints=10, seed=1, output='a4')
+ self.assertModule("t.support", type="stvds", input="A", flags="m")
+ A.select()
+ self.assertEqual(A.metadata.get_number_of_points(), 40)
+ self.runModule("g.remove", type="vector", name="a4", flags="f")
+ A.select()
+ self.assertEqual(A.metadata.get_number_of_points(), 30)
+ test()
