[GRASS-SVN] r66250 - in grass/branches/releasebranch_7_0/lib/python/temporal: . testsuite
svn_grass at osgeo.org
Wed Sep 16 09:27:08 PDT 2015
Author: neteler
Date: 2015-09-16 09:27:08 -0700 (Wed, 16 Sep 2015)
New Revision: 66250
Added:
grass/branches/releasebranch_7_0/lib/python/temporal/testsuite/unittests_temporal_algebra_mixed_stds.py
grass/branches/releasebranch_7_0/lib/python/temporal/c_libraries_interface.py
temporal library: fix for available mapsets test (partial backport of r66205, r66206)
Modified: grass/branches/releasebranch_7_0/lib/python/temporal/c_libraries_interface.py
--- grass/branches/releasebranch_7_0/lib/python/temporal/c_libraries_interface.py 2015-09-16 16:24:10 UTC (rev 66249)
+++ grass/branches/releasebranch_7_0/lib/python/temporal/c_libraries_interface.py 2015-09-16 16:27:08 UTC (rev 66250)
@@ -152,18 +152,27 @@
count = 0
mapset_list = []
try:
- # Initilaize the accessable mapset list, this is bad C design!!!
+ # Initialize the accessable mapset list, this is bad C design!!!
libgis.G_get_mapset_name(0)
mapsets = libgis.G_get_available_mapsets()
while mapsets[count]:
char_list = ""
mapset = mapsets[count]
- if libgis.G_mapset_permissions(mapset) == 1 and libgis.G_is_mapset_in_search_path(mapset) == 1:
- c = 0
- while mapset[c] != "\x00":
- char_list += mapset[c]
- c += 1
+ permission = libgis.G_mapset_permissions(mapset)
+ in_search_path = libgis.G_is_mapset_in_search_path(mapset)
+ c = 0
+ while mapset[c] != "\x00":
+ char_list += mapset[c]
+ c += 1
+ if permission >= 0 and in_search_path == 1:
mapset_list.append(char_list)
+ libgis.G_debug(1, "c_library_server._available_mapsets: \n mapset: %s\n"\
+ " has permission %i\n in search path: %i"%(char_list,
+ permission, in_search_path))
count += 1
# We need to sort the mapset list, but the first one should be
Copied: grass/branches/releasebranch_7_0/lib/python/temporal/testsuite/unittests_temporal_algebra_mixed_stds.py (from rev 66205, grass/trunk/lib/python/temporal/testsuite/unittests_temporal_algebra_mixed_stds.py)
--- grass/branches/releasebranch_7_0/lib/python/temporal/testsuite/unittests_temporal_algebra_mixed_stds.py (rev 0)
+++ grass/branches/releasebranch_7_0/lib/python/temporal/testsuite/unittests_temporal_algebra_mixed_stds.py 2015-09-16 16:27:08 UTC (rev 66250)
@@ -0,0 +1,206 @@
+(C) 2013 by the GRASS Development Team
+This program is free software under the GNU General Public
+License (>=v2). Read the file COPYING that comes with GRASS
+for details.
+:authors: Soeren Gebbert and Thomas Leppelt
+import grass.script
+import grass.temporal as tgis
+from grass.gunittest.case import TestCase
+from grass.gunittest.main import test
+import datetime
+import os
+class TestTemporalAlgebraMixedDatasets(TestCase):
+ @classmethod
+ def setUpClass(cls):
+ """Initiate the temporal GIS and set the region
+ tgis.init(True) # Raise on error instead of exit(1)
+ cls.use_temp_region()
+ cls.runModule("g.region", n=80.0, s=0.0, e=120.0,
+ w=0.0, t=1.0, b=0.0, res=10.0)
+ cls.runModule("r3.mapcalc", overwrite=True, quiet=True, expression="a1 = 1")
+ cls.runModule("r3.mapcalc", overwrite=True, quiet=True, expression="a2 = 2")
+ cls.runModule("r3.mapcalc", overwrite=True, quiet=True, expression="a3 = 3")
+ cls.runModule("r3.mapcalc", overwrite=True, quiet=True, expression="a4 = 4")
+ tgis.open_new_stds(name="A", type="str3ds", temporaltype="absolute",
+ title="A", descr="A", semantic="field", overwrite=True)
+ tgis.register_maps_in_space_time_dataset(type="raster3d", name="A", maps="a1,a2,a3,a4",
+ start="2001-01-01", increment="1 day", interval=True)
+ cls.runModule("r.mapcalc", overwrite=True, quiet=True, expression="b1 = 5")
+ cls.runModule("r.mapcalc", overwrite=True, quiet=True, expression="b2 = 6")
+ tgis.open_new_stds(name="B", type="strds", temporaltype="absolute",
+ title="B", descr="B", semantic="field", overwrite=True)
+ tgis.register_maps_in_space_time_dataset(type="raster", name="B", maps="b1,b2",
+ start="2001-01-01", increment="2 day", interval=True)
+ cls.runModule("v.random", overwrite=True, quiet=True, npoints=20, seed=3, output='c1')
+ tgis.open_new_stds(name="C", type="stvds", temporaltype="absolute",
+ title="B", descr="C", semantic="field", overwrite=True)
+ tgis.register_maps_in_space_time_dataset(type="vector", name="C", maps="c1",
+ start="2001-01-02", increment="2 day", interval=True)
+ @classmethod
+ def tearDownClass(cls):
+ """Remove the temporary region
+ cls.runModule("t.remove", flags="rf", type="str3ds", inputs="A", quiet=True)
+ cls.runModule("t.remove", flags="rf", type="strds", inputs="B", quiet=True)
+ cls.runModule("t.remove", flags="rf", type="stvds", inputs="C", quiet=True)
+ cls.del_temp_region()
+ def test_temporal_select_operators1(self):
+ """Testing the temporal select operator. Including temporal relations. """
+ ta = tgis.TemporalAlgebraParser(run = True, debug = True)
+ ta.parse(expression="R = A {:,during} stvds(C)", stdstype = 'str3ds', basename="r", overwrite=True)
+ D = tgis.open_old_stds("R", type="str3ds")
+ D.select()
+ self.assertEqual(D.metadata.get_number_of_maps(), 2)
+ self.assertEqual(D.metadata.get_min_min(), 2)
+ self.assertEqual(D.metadata.get_max_max(), 3)
+ start, end = D.get_absolute_time()
+ self.assertEqual(start, datetime.datetime(2001, 1, 2))
+ self.assertEqual(end, datetime.datetime(2001, 1, 4))
+ self.assertEqual( D.check_temporal_topology(), True)
+ self.assertEqual(D.get_granularity(), u'1 day')
+ def test_temporal_select_operators2(self):
+ ta.parse(expression="R = A {:,equal|during} stvds(C)", stdstype = 'str3ds', basename="r", overwrite=True)
+ D.select()
+ def test_temporal_select_operators3(self):
+ and negation operation. """
+ ta.parse(expression="R = A {!:,during} stvds(C)", stdstype = 'str3ds', basename="r", overwrite=True)
+ D.select()
+ self.assertEqual(D.metadata.get_min_min(), 1)
+ self.assertEqual(D.metadata.get_max_max(), 4)
+ self.assertEqual(start, datetime.datetime(2001, 1, 1))
+ self.assertEqual(end, datetime.datetime(2001, 1, 5))
+ def test_temporal_select_operators4(self):
+ """Testing the temporal select operator. Including temporal relations and
+ temporal operators. """
+ ta.parse(expression="V = C {:,contains} str3ds(A)",
+ stdstype = 'stvds', basename="r", overwrite=True)
+ D = tgis.open_old_stds("V", type="stvds")
+ D.select()
+ maplist = D.get_registered_maps_as_objects()
+ self.assertEqual(D.metadata.get_number_of_maps(), 1)
+ self.assertEqual(D.get_granularity(), u'2 days')
+ def test_temporal_select_operators5(self):
+ ta.parse(expression="R = A {:,during} strds(B)",
+ stdstype = 'str3ds', basename="r", overwrite=True)
+ D.select()
+ self.assertEqual(D.metadata.get_number_of_maps(), 4)
+ def test_temporal_hash_operator1(self):
+ """Testing the hash operator function in conditional statement. """
+ ta.parse(expression="R = if(A {#,during} stvds(C) == 1, A)",
+ basename="r", overwrite=True)
+ D.select()
+ def test_temporal_hash_operator2(self):
+ ta.parse(expression="R = if({during}, stvds(C) {#,contains} A == 2, A)",
+ D.select()
+ def test_different_stds_handling(self):
+ """Testing the handling of different stds types as output. """
+ ta.parse(expression="R = if({during}, stvds(C) {#,contains} str3ds(A) == 2, str3ds(A))",
+ stdstype = 'strds', basename="r", overwrite=True)
+ D.select()
+if __name__ == '__main__':
+ test()
