[GRASS-SVN] r66251 - in grass/trunk/temporal/t.snap: . testsuite
Wed Sep 16 11:41:25 PDT 2015
Author: huhabla
Date: 2015-09-16 11:41:25 -0700 (Wed, 16 Sep 2015)
New Revision: 66251
Added:
   grass/trunk/temporal/t.snap/testsuite/
   grass/trunk/temporal/t.snap/testsuite/test_snap.py
temporal modules: Added t.snap gunittests
Added: grass/trunk/temporal/t.snap/testsuite/test_snap.py
--- grass/trunk/temporal/t.snap/testsuite/test_snap.py	                        (rev 0)
+++ grass/trunk/temporal/t.snap/testsuite/test_snap.py	2015-09-16 18:41:25 UTC (rev 66251)
@@ -0,0 +1,291 @@
+"""Test t.snap
+(C) 2015 by the GRASS Development Team
+This program is free software under the GNU General Public
+License (>=v2). Read the file COPYING that comes with GRASS
+for details.
+:authors: Soeren Gebbert
+import os
+import grass.pygrass.modules as pymod
+import grass.temporal as tgis
+from grass.gunittest.case import TestCase
+from grass.gunittest.gmodules import SimpleModule
+class TestSnapAbsoluteSTRDS(TestCase):
+    @classmethod
+    def setUpClass(cls):
+        """Initiate the temporal GIS and set the region
+        os.putenv("GRASS_OVERWRITE",  "1")
+        tgis.init()
+        cls.use_temp_region()
+        cls.runModule("g.region",  s=0,  n=80,  w=0,  e=120,  b=0,
+                      t=50,  res=10,  res3=10)
+        cls.runModule("r.mapcalc", expression="a1 = 100",  overwrite=True)
+        cls.runModule("r.mapcalc", expression="a2 = 200",  overwrite=True)
+        cls.runModule("r.mapcalc", expression="a3 = 300",  overwrite=True)
+        cls.runModule("r.mapcalc", expression="a4 = 400",  overwrite=True)
+        cls.runModule("t.create",  type="strds",  temporaltype="absolute",
+                                    output="A",  title="A test",
+                                    description="A test",  overwrite=True)
+        cls.runModule("t.register", type="raster",  input="A",
+                                     maps="a1,a2,a3,a4",
+                                     start="2001-01-01",
+                                     increment="14 days",
+                                     overwrite=True)
+    @classmethod
+    def tearDownClass(cls):
+        """Remove the temporary region
+        cls.del_temp_region()
+        cls.runModule("t.remove", flags="rf", type="strds", inputs="A")
+    def test_1_metadata(self):
+        """Set title, description and aggregation"""
+        A = tgis.open_old_stds("A", type="strds")
+        A.select()
+        self.assertEqual(A.get_map_time(), "point")
+        self.assertModule("t.snap", input="A", type="strds")
+        A.select()
+        self.assertEqual(A.get_map_time(), "interval")
+class TestSnapRelativeSTRDS(TestCase):
+    @classmethod
+        tgis.init()
+        cls.runModule("t.create",  type="strds",  temporaltype="relative",
+                                     start="0",
+                                     increment="14", unit="days",
+                                     overwrite=True)
+    @classmethod
+        A.select()
+        A.select()
+class TestSnapAbsoluteSTR3DS(TestCase):
+    @classmethod
+        tgis.init()
+        cls.runModule("r3.mapcalc", expression="a1 = 100",  overwrite=True)
+        cls.runModule("r3.mapcalc", expression="a2 = 200",  overwrite=True)
+        cls.runModule("r3.mapcalc", expression="a3 = 300",  overwrite=True)
+        cls.runModule("r3.mapcalc", expression="a4 = 400",  overwrite=True)
+        cls.runModule("t.create",  type="str3ds",  temporaltype="absolute",
+        cls.runModule("t.register", type="raster_3d",  input="A",
+                                     overwrite=True)
+    @classmethod
+        cls.runModule("t.remove", flags="rf", type="str3ds", inputs="A")
+        A = tgis.open_old_stds("A", type="str3ds")
+        A.select()
+        self.assertModule("t.snap", input="A", type="str3ds")
+        A.select()
+class TestSnapRelativeSTR3DS(TestCase):
+    @classmethod
+        tgis.init()
+        cls.runModule("t.create",  type="str3ds",  temporaltype="relative",
+                                     start="0",
+                                     overwrite=True)
+    @classmethod
+        A.select()
+        A.select()
+class TestSnapAbsoluteSTVDS(TestCase):
+    @classmethod
+        tgis.init()
+        cls.runModule("v.random", quiet=True, npoints=20, seed=1,  output='a1')
+        cls.runModule("v.random", quiet=True, npoints=20, seed=1,  output='a2')
+        cls.runModule("v.random", quiet=True, npoints=20, seed=1,  output='a3')
+        cls.runModule("v.random", quiet=True, npoints=20, seed=1,  output='a4')
+        cls.runModule("t.create",  type="stvds",  temporaltype="absolute",
+        cls.runModule("t.register", type="vector",  input="A",
+                                     overwrite=True)
+    @classmethod
+        cls.runModule("t.remove", flags="rf", type="stvds", inputs="A")
+        A = tgis.open_old_stds("A", type="stvds")
+        A.select()
+        self.assertModule("t.snap", input="A", type="stvds")
+        A.select()
+class TestSnapRelativeSTVDS(TestCase):
+    @classmethod
+        tgis.init()
+        cls.runModule("t.create",  type="stvds",  temporaltype="relative",
+                                     start="0",
+                                     overwrite=True)
+    @classmethod
+        A.select()
+        A.select()
+if __name__ == '__main__':
+    from grass.gunittest.main import test
+    test()
