[GRASS-SVN] r66314 - in grass-addons/grass7/raster: r.stream.variables r.stream.watersheds
svn_grass at osgeo.org
Wed Sep 23 13:45:20 PDT 2015
Author: elselvaje
Date: 2015-09-23 13:45:20 -0700 (Wed, 23 Sep 2015)
New Revision: 66314
grass-addons/grass7/raster/r.stream.variables/r.stream.variables
grass-addons/grass7/raster/r.stream.watersheds/r.stream.watersheds
check tar location and output location
Modified: grass-addons/grass7/raster/r.stream.variables/r.stream.variables
--- grass-addons/grass7/raster/r.stream.variables/r.stream.variables 2015-09-23 19:37:39 UTC (rev 66313)
+++ grass-addons/grass7/raster/r.stream.variables/r.stream.variables 2015-09-23 20:45:20 UTC (rev 66314)
@@ -5,7 +5,7 @@
# MODULE: r.stream.watersheds
# AUTHOR(S): Giuseppe Amatulli & Sami Domisch
-# based on "Domisch, S., Amatulli, G., Jetz, W. (2015)
+# based on "Domisch, S., Amatulli, G., Jetz, W. (review)
# Near-global freshwater-specific environmental variables for
# biodiversity analyses in 1km resolution. Scientific Data"
@@ -200,6 +200,7 @@
filename=$(basename $file )
cd $DIRNAME
tar -xf $file
+ cd $GISDBASE
export BLKID=$(echo $filename | awk -v GIS_OPT_AREA=${GIS_OPT_AREA} '{ gsub("0000", "") ; gsub("blockfile","") ; gsub("_sub_","") ; gsub("GIS_OPT_AREA","") ; gsub(".tar.gz","") ; print }')
export dir4d=${BLKID: -4:1} ; if [ -z $dir4d ] ; then dir4d=0 ; fi
@@ -344,6 +345,7 @@
echo "ID|non_null_cells|null_cells|min|max|range|mean|mean_of_abs|stddev|variance|coeff_var|sum|sum_abs" > $GIS_OPT_FOLDER/blockfile/stat_${GIS_OPT_VARIABLE}.txt
cat $GIS_OPT_FOLDER/*digit4/*digit3/*digit2/*digit1/stat_${GIS_OPT_VARIABLE}.txt >> $GIS_OPT_FOLDER/blockfile/stat_${GIS_OPT_VARIABLE}.txt
+rm -f $GIS_OPT_FOLDER/*digit4/*digit3/*digit2/*digit1/stat_${GIS_OPT_VARIABLE}.txt
echo Reclass the grid_id for the following output ${GIS_OPT_OUTPUT//","/" "}
@@ -380,7 +382,7 @@
r.out.gdal -c input=${GIS_OPT_VARIABLE}_${1} nodata=-9999 output=$GIS_OPT_OUT_FOLDER/${GIS_OPT_VARIABLE}_${1}.tif type=Int32 -c createopt="COMPRESS=LZW,ZLEVEL=9" --o --q 2> /dev/null
-echo "$GIS_OPT_FOLDER/blockfile/${GIS_OPT_VARIABLE}_${1}.tif has been created!"
+echo "$GIS_OPT_OUT_FOLDER/blockfile/${GIS_OPT_VARIABLE}_${1}.tif has been created!"
' _
Modified: grass-addons/grass7/raster/r.stream.watersheds/r.stream.watersheds
--- grass-addons/grass7/raster/r.stream.watersheds/r.stream.watersheds 2015-09-23 19:37:39 UTC (rev 66313)
+++ grass-addons/grass7/raster/r.stream.watersheds/r.stream.watersheds 2015-09-23 20:45:20 UTC (rev 66314)
@@ -5,7 +5,7 @@
+# based on "Domisch, S., Amatulli, G., Jetz, W. (in review)
@@ -134,7 +134,7 @@
# shell check for user break (signal list: trap -l)
-# trap "exitprocedure" 2 3 15
+trap "exitprocedure" 2 3 15
echo ""
echo "#######################################################################################################"
@@ -147,8 +147,8 @@
echo ""
echo Exporting stream grid cell coordinates and saving in $GIS_OPT_FOLDER/stream_coord_lines.txt
-rm -fr $GIS_OPT_FOLDER
-mkdir $GIS_OPT_FOLDER
+rm -fr $GIS_OPT_FOLDER 2> /dev/null
+mkdir $GIS_OPT_FOLDER 2> /dev/null
r.out.xyz --o input=$GIS_OPT_STREAM separator=space output=$GIS_OPT_FOLDER/stream_coord.txt --q
@@ -186,7 +186,7 @@
mkdir $GIS_OPT_FOLDER/blockfile
-echo "Split the stream grid cell coordinate file (X|Y|ID) into subsets of 10000 lines"
+echo "Split the stream grid cell coordinate file with $( wc -l $GIS_OPT_FOLDER/stream_coord.txt | awk '{ print $1 }' ) grid cells into blocks of 10000 cells"
awk -v PATH=$GIS_OPT_FOLDER 'NR%10000==1{x=PATH"/blockfile/blockfile"(++i*10000-10000)}{print > x}' $GIS_OPT_FOLDER/stream_coord_lines.txt
@@ -226,8 +226,12 @@
Y_coord=$3
ID=$4
-echo -en "\r$(expr $NR / 100 + 1 )% done"
+if [ $( expr $( expr $NR + 1 ) / 100) -eq $( expr $NR / 100 + 1 ) ] ; then
+echo -en "\r$(expr $NR / 100 + 1 )% done"
+fi
# replicate the start-GISRC in a unique GISRC
cp $GISRC_def $HOME/.grass7/rc$ID
@@ -255,6 +259,8 @@
r.null map=sub_streamID${ID} setnull=0 --q
r.out.gdal -c type=Byte --o --q nodata=255 createopt="COMPRESS=LZW,ZLEVEL=9" input=sub_streamID${ID}@sub_watershedID${ID} output=$GIS_OPT_FOLDER/${dir4d}digit4/${dir3d}digit3/${dir2d}digit2/${dir1d}digit1/sub_streamID${ID}.tif
+if [ ! -f $GIS_OPT_FOLDER/${dir4d}digit4/${dir3d}digit3/${dir2d}digit2/${dir1d}digit1/sub_streamID${ID}.tif ] ; then the file $GIS_OPT_FOLDER/${dir4d}digit4/${dir3d}digit3/${dir2d}digit2/${dir1d}digit1/sub_streamID${ID}.tif dose not exist ; fi
rm -r $HOME/.grass7/rc$ID $GISDBASE/$LOCATION_NAME/sub_watershedID$ID
' _
@@ -321,10 +327,13 @@
echo "Compress the sub-watersheds and sub-streams to reduce the number of inodes filling up the hard disk"
-tar -zcPf $GIS_OPT_FOLDER/${dir4d}digit4/${dir3d}digit3/${dir2d}digit2/${dir1d}digit1/${filename}_sub_watershed.tar.gz $GIS_OPT_FOLDER/${dir4d}digit4/${dir3d}digit3/${dir2d}digit2/${dir1d}digit1/sub_watershedID*.tif
-tar -zcPf $GIS_OPT_FOLDER/${dir4d}digit4/${dir3d}digit3/${dir2d}digit2/${dir1d}digit1/${filename}_sub_stream.tar.gz $GIS_OPT_FOLDER/${dir4d}digit4/${dir3d}digit3/${dir2d}digit2/${dir1d}digit1/sub_streamID*.tif
-echo list the compressed files by ls $GIS_OPT_FOLDER/*digit4/*digit3/*digit2/*digit1/*.tar.gz
+cd $GIS_OPT_FOLDER/${dir4d}digit4/${dir3d}digit3/${dir2d}digit2/${dir1d}digit1/
+tar -zcPf ${filename}_sub_watershed.tar.gz sub_watershedID*.tif
+tar -zcPf ${filename}_sub_stream.tar.gz sub_streamID*.tif
+cd $GIS_OPT_FOLDER
g.gisenv set="MAPSET=PERMANENT"
g.gisenv set="LOCATION_NAME=$LOCATION_NAME"
@@ -334,3 +343,6 @@
done
+echo "The full sub-watershed delineation process has been done!"
+echo "To list the compressed files, use ls $GIS_OPT_FOLDER/*digit4/*digit3/*digit2/*digit1/*.tar.gz"
+echo "Now you can use r.stream.variables to compute stream-specific environmental variables."
