[GRASS-SVN] r66315 - in grass-addons/grass7/raster: r.stream.variables r.stream.watersheds
Wed Sep 23 14:14:34 PDT 2015
Author: elselvaje
Date: 2015-09-23 14:14:34 -0700 (Wed, 23 Sep 2015)
New Revision: 66315
   grass-addons/grass7/raster/r.stream.variables/r.stream.variables
   grass-addons/grass7/raster/r.stream.watersheds/r.stream.watersheds
change some echo command
Modified: grass-addons/grass7/raster/r.stream.variables/r.stream.variables
--- grass-addons/grass7/raster/r.stream.variables/r.stream.variables	2015-09-23 20:45:20 UTC (rev 66314)
+++ grass-addons/grass7/raster/r.stream.variables/r.stream.variables	2015-09-23 21:14:34 UTC (rev 66315)
@@ -5,13 +5,12 @@
 # MODULE:       r.stream.watersheds
 # AUTHOR(S):    Giuseppe Amatulli & Sami Domisch
-#               based on "Domisch, S., Amatulli, G., Jetz, W. (review)
+#               based on "Domisch, S., Amatulli, G., Jetz, W. (in review)
 #				Near-global freshwater-specific environmental variables for
 # 				biodiversity analyses in 1km resolution. Scientific Data"
-# PURPOSE:      Delineate the upstream contributing area ('sub-watershed') and
-#				stream sections ('sub-stream') for each grid cell of a
-#				stream network
+# PURPOSE:      Calculation of contiguous stream-specific variables that account
+#				for the upstream environment (based on r.stream.watersheds).
 # COPYRIGHT:    (C) 2001-2012 by the GRASS Development Team
@@ -22,7 +21,7 @@
 #%Module
-#% description: Sub-watershed delineation based on the drainage direction and a gridded stream network. Based on "Domisch, S., Amatulli, G., Jetz, W. 2015 Near-global freshwater-specific environmental variables for biodiversity analyses in 1km resolution. Scientific Data"
+#% description: Calculation of contiguous stream-specific variables that account for the upstream environment (based on r.stream.watersheds).
 #% keywords: drainage, stream, hydrology
 #%End
@@ -180,7 +179,7 @@
 echo ""
 echo "##########################################################################"
-echo "Streams variables calculation based on the sub-watershads and sub-streams"
+echo "Stream-specific variable calculation based on the sub-watersheds and sub-streams"
 echo ""
 echo "Citation: Domisch, S., Amatulli, G., Jetz, W. (in review)"
 echo "Near-global freshwater-specific environmental variables for"
@@ -381,12 +380,12 @@
 rm -f $GIS_OPT_FOLDER/blockfile/stat_${GIS_OPT_VARIABLE}_${1}.txt
 r.out.gdal -c  input=${GIS_OPT_VARIABLE}_${1}  nodata=-9999  output=$GIS_OPT_OUT_FOLDER/${GIS_OPT_VARIABLE}_${1}.tif  type=Int32  -c  createopt="COMPRESS=LZW,ZLEVEL=9"  --o --q  2> /dev/null
+if test -f "$GIS_OPT_FOLDER/blockfile/${GIS_OPT_VARIABLE}_${1}.tif"; then echo "$GIS_OPT_FOLDER/blockfile/${GIS_OPT_VARIABLE}_${1}.tif has been created!";fi
+#echo "$GIS_OPT_OUT_FOLDER/blockfile/${GIS_OPT_VARIABLE}_${1}.tif has been created!"
-echo "$GIS_OPT_OUT_FOLDER/blockfile/${GIS_OPT_VARIABLE}_${1}.tif has been created!"
 ' _
 exit
 echo "The full stream variable calculation has been done!"
-echo "To list the stream-specific output variables, use ls $GIS_OPT_OUT_FOLDER/*.tif"
+echo "To list the stream-specific output variables: ls $GIS_OPT_OUT_FOLDER/*.tif"
Modified: grass-addons/grass7/raster/r.stream.watersheds/r.stream.watersheds
--- grass-addons/grass7/raster/r.stream.watersheds/r.stream.watersheds	2015-09-23 20:45:20 UTC (rev 66314)
+++ grass-addons/grass7/raster/r.stream.watersheds/r.stream.watersheds	2015-09-23 21:14:34 UTC (rev 66315)
@@ -138,7 +138,7 @@
 echo ""
 echo "#######################################################################################################"
-echo "Sub-watershed and sub-streams delineation based on the drainage direction and a gridded stream network."
+echo "Sub-watershed and sub-stream delineation based on the drainage direction and a gridded stream network."
 echo ""
@@ -344,5 +344,5 @@
 done
 echo "The full sub-watershed delineation process has been done!"
-echo "To list the compressed files, use ls $GIS_OPT_FOLDER/*digit4/*digit3/*digit2/*digit1/*.tar.gz"
+echo "To list the compressed files: ls $GIS_OPT_FOLDER/*digit4/*digit3/*digit2/*digit1/*.tar.gz"
 echo  "Now you can use r.stream.variables to compute stream-specific environmental variables."
