[GRASS-SVN] r66343 - grass/trunk/vector/v.in.lidar
svn_grass at osgeo.org
Sat Sep 26 17:14:00 PDT 2015
Author: wenzeslaus
Date: 2015-09-26 17:14:00 -0700 (Sat, 26 Sep 2015)
New Revision: 66343
grass/trunk/vector/v.in.lidar/main.c
v.in.lidar: store return and class as cats or store no cats
If requested, return, class and generated ID will be stored in separate layers
specified by the user. ID is stored by default (original behavior).
Storing of IDs can be disabled by -c flag. This offers a slight speed up
comparing to just not storing the attributes.
Using this one can get return and class to GRASS without
creating the attribute table.
Modified: grass/trunk/vector/v.in.lidar/main.c
--- grass/trunk/vector/v.in.lidar/main.c 2015-09-26 23:25:00 UTC (rev 66342)
+++ grass/trunk/vector/v.in.lidar/main.c 2015-09-27 00:14:00 UTC (rev 66343)
@@ -112,9 +112,11 @@
float xmin = 0., ymin = 0., xmax = 0., ymax = 0.;
struct GModule *module;
struct Option *in_opt, *out_opt, *spat_opt, *filter_opt, *class_opt;
+ struct Option *id_layer_opt, *return_layer_opt, *class_layer_opt;
struct Option *skip_opt, *preserve_opt, *offset_opt, *limit_opt;
struct Option *outloc_opt;
struct Flag *print_flag, *notab_flag, *region_flag, *notopo_flag;
+ struct Flag *nocats_flag;
struct Flag *over_flag, *extend_flag, *no_import_flag;
char buf[2000];
struct Key_Value *loc_proj_info = NULL, *loc_proj_units = NULL;
@@ -170,7 +172,25 @@
in_opt->description = _("LiDAR input files in LAS format (*.las or *.laz)");
out_opt = G_define_standard_option(G_OPT_V_OUTPUT);
+ id_layer_opt = G_define_standard_option(G_OPT_V_FIELD);
+ id_layer_opt->key = "id_layer";
+ id_layer_opt->label = _("Layer number to store generated point ID as category");
+ id_layer_opt->answer = NULL;
+ id_layer_opt->guisection = _("Categories");
+ return_layer_opt = G_define_standard_option(G_OPT_V_FIELD);
+ return_layer_opt->key = "return_layer";
+ return_layer_opt->label = _("Layer number to store return number as category");
+ return_layer_opt->answer = NULL;
+ return_layer_opt->guisection = _("Categories");
+ class_layer_opt = G_define_standard_option(G_OPT_V_FIELD);
+ class_layer_opt->key = "class_layer";
+ class_layer_opt->label = _("Layer number to store class number as category");
+ class_layer_opt->answer = NULL;
+ class_layer_opt->guisection = _("Categories");
spat_opt = G_define_option();
spat_opt->key = "spatial";
spat_opt->type = TYPE_DOUBLE;
@@ -265,6 +285,14 @@
notab_flag = G_define_standard_flag(G_FLG_V_TABLE);
notab_flag->guisection = _("Speed");
+ nocats_flag = G_define_flag();
+ nocats_flag->key = 'c';
+ nocats_flag->label =
+ _("Store only the coordinates");
+ nocats_flag->description =
+ _("Do not add categories to points and do not create attribute table");
+ nocats_flag->guisection = _("Speed");
notopo_flag = G_define_standard_flag(G_FLG_V_TOPO);
notopo_flag->guisection = _("Speed");
@@ -283,6 +311,7 @@
no_import_flag->suppress_required = YES;
G_option_exclusive(skip_opt, preserve_opt, NULL);
+ G_option_excludes(nocats_flag, id_layer_opt, return_layer_opt, class_layer_opt, NULL);
/* The parser checks if the map already exists in current mapset, this is
* wrong if location options is used, so we switch out the check and do it
@@ -292,6 +321,10 @@
if (G_parser(argc, argv))
exit(EXIT_FAILURE);
+ /* no cats implies no table */
+ if (nocats_flag->answer)
+ notab_flag->answer = 1;
/* Don't crash on cmd line if file not found */
if (access(in_opt->answer, F_OK) != 0) {
G_fatal_error(_("Input file <%s> does not exist"), in_opt->answer);
@@ -344,6 +377,36 @@
G_fatal_error(_("Unknown filter option <%s>"), filter_opt->answer);
+ int id_layer = 0;
+ int return_layer = 0;
+ int class_layer = 0;
+ if (id_layer_opt->answer)
+ id_layer = atoi(id_layer_opt->answer);
+ if (return_layer_opt->answer)
+ return_layer = atoi(return_layer_opt->answer);
+ if (class_layer_opt->answer)
+ class_layer = atoi(class_layer_opt->answer);
+ /* If no layer specified by user, force 1 to be used for ids.
+ * If id_layer not specified by the attributes table was, find a layer.
+ * nocats implies notab and we don't add any layers.
+ * Also when layers are set to zero by user, we consider it as if
+ * the nocats flag would be specified. We use !id_layer_opt->answer
+ * to see that user was the one not setting the id_layer which are
+ * are about to turn on.
+ * Later on, layer set to 0 is considered as no layer set.
+ if (!nocats_flag->answer && !id_layer_opt->answer && !return_layer && !class_layer) {
+ id_layer = 1;
+ if (!notab_flag->answer && !id_layer) {
+ /* get the first free layer number */
+ for (i = 1; i <= MAX(return_layer, class_layer) + 1; i++) {
+ if (i != return_layer && i != class_layer)
+ break;
+ id_layer = i;
if (region_flag->answer) {
if (spat_opt->answer)
G_fatal_error(_("Select either the current region flag or the spatial option, not both"));
@@ -568,9 +631,9 @@
if (!notab_flag->answer) {
char *cat_col_name = GV_KEY_COLUMN;
- Fi = Vect_default_field_info(&Map, 1, NULL, GV_1TABLE);
+ Fi = Vect_default_field_info(&Map, id_layer, NULL, GV_1TABLE);
- Vect_map_add_dblink(&Map, 1, out_opt->answer, Fi->table,
+ Vect_map_add_dblink(&Map, id_layer, out_opt->answer, Fi->table,
cat_col_name, Fi->database, Fi->driver);
/* check available LAS info, depends on POINT DATA RECORD FORMAT [0-5] */
@@ -810,7 +873,12 @@
Vect_append_point(Points, x, y, z);
- Vect_cat_set(Cats, 1, cat);
+ if (id_layer)
+ Vect_cat_set(Cats, id_layer, cat);
+ if (return_layer)
+ Vect_cat_set(Cats, return_layer, LASPoint_GetReturnNumber(LAS_point));
+ if (class_layer)
+ Vect_cat_set(Cats, class_layer, LASPoint_GetClassification(LAS_point));
Vect_write_line(&Map, GV_POINT, Points, Cats);
/* Attributes */
