[GRASS-SVN] r66344 - grass/trunk/vector/v.in.lidar
svn_grass at osgeo.org
Sat Sep 26 18:30:37 PDT 2015
Author: wenzeslaus
Date: 2015-09-26 18:30:37 -0700 (Sat, 26 Sep 2015)
New Revision: 66344
grass/trunk/vector/v.in.lidar/main.c
v.in.lidar: catch case when we run out of categories
We should be able to import more points then we can have unique categories.
This protects against (signed) integer overflow, ends as if GV_CAT_MAX would
be an import limit and reports a warning.
This also fixes wrong format string in case of unsigned long implementation.
Modified: grass/trunk/vector/v.in.lidar/main.c
--- grass/trunk/vector/v.in.lidar/main.c 2015-09-27 00:14:00 UTC (rev 66343)
+++ grass/trunk/vector/v.in.lidar/main.c 2015-09-27 01:30:37 UTC (rev 66344)
@@ -149,6 +149,8 @@
struct line_pnts *Points;
struct line_cats *Cats;
+ int cat_max_reached = FALSE;
#ifdef HAVE_LONG_LONG_INT
unsigned long long n_features, feature_count, n_outside,
n_filtered, n_class_filtered, not_valid;
@@ -966,6 +968,11 @@
if (limit_n_counter == limit_n)
break;
+ if (cat == GV_CAT_MAX) {
+ cat_max_reached = TRUE;
+ break;
cat++;
G_percent(n_features, n_features, 1); /* finish it */
@@ -984,13 +991,21 @@
Vect_build(&Map);
Vect_close(&Map);
+ /* compute how much we have imported */
+ unsigned long long points_imported;
+#else
+ unsigned long points_imported;
+#endif
+ /* valid only when not having count limit */
+ points_imported = n_features - not_valid - n_outside - n_filtered
+ - n_class_filtered - offset_n_counter - n_count_filtered;
+#ifdef HAVE_LONG_LONG_INT
if (limit_n)
G_message(_("%llu points imported (limit was %llu)"), limit_n_counter, limit_n);
else
- G_message(_("%llu points imported"),
- n_features - not_valid - n_outside - n_filtered - n_class_filtered
- - offset_n_counter - n_count_filtered);
+ G_message(_("%llu points imported"), points_imported);
if (not_valid)
G_message(_("%llu input points were not valid"), not_valid);
if (n_outside)
@@ -1005,11 +1020,9 @@
G_message(_("%llu input points were skipped by count-based decimation"), n_count_filtered);
#else
if (limit_n)
- G_message(_("%d points imported (limit was %d)"), limit_n_counter, limit_n);
+ G_message(_("%lu points imported (limit was %d)"), limit_n_counter, limit_n);
else
- G_message(_("%d points imported"),
+ G_message(_("%lu points imported"), points_imported);
if (not_valid)
G_message(_("%lu input points were not valid"), not_valid);
if (n_outside)
@@ -1027,6 +1040,10 @@
if (limit_n)
G_message(_("The rest of points was ignored"));
+ if (cat_max_reached)
+ G_warning(_("Maximum number of categories reached (%d). Import ended prematurely."
+ " Try to import without using category as an ID."), GV_CAT_MAX);
/* Extend current window based on dataset. */
