[GRASS-SVN] r66385 - grass/branches/releasebranch_7_0/imagery/i.segment
svn_grass at osgeo.org
Wed Sep 30 12:14:28 PDT 2015
Author: neteler
Date: 2015-09-30 12:14:28 -0700 (Wed, 30 Sep 2015)
New Revision: 66385
Added:
grass/branches/releasebranch_7_0/imagery/i.segment/i_segment_lsat7_pan.png
grass/branches/releasebranch_7_0/imagery/i.segment/i_segment_lsat7_seg_min100.png
grass/branches/releasebranch_7_0/imagery/i.segment/i_segment_lsat7_seg_min5.png
grass/branches/releasebranch_7_0/imagery/i.segment/i_segment_ortho_segs_final.jpg
grass/branches/releasebranch_7_0/imagery/i.segment/i_segment_ortho_segs_l1.jpg
grass/branches/releasebranch_7_0/imagery/i.segment/i_segment_ortho_segs_l2_l5.jpg
Removed:
grass/branches/releasebranch_7_0/imagery/i.segment/ortho_segs_final.jpg
grass/branches/releasebranch_7_0/imagery/i.segment/ortho_segs_l1.jpg
grass/branches/releasebranch_7_0/imagery/i.segment/ortho_segs_l2_l5.jpg
grass/branches/releasebranch_7_0/imagery/i.segment/i.segment.html
i.segment manual: Landsat7 example added
Property changes on: grass/branches/releasebranch_7_0/imagery/i.segment
___________________________________________________________________
Modified: svn:ignore
- OBJ.*
+ OBJ.*
*.tmp.html
Modified: grass/branches/releasebranch_7_0/imagery/i.segment/i.segment.html
--- grass/branches/releasebranch_7_0/imagery/i.segment/i.segment.html 2015-09-30 19:11:48 UTC (rev 66384)
+++ grass/branches/releasebranch_7_0/imagery/i.segment/i.segment.html 2015-09-30 19:14:28 UTC (rev 66385)
@@ -111,7 +111,10 @@
identical values, perfect fit, and a value of 0 means maximum possible
distance, worst possible fit.
-<h2>EXAMPLE</h2>
+<h2>EXAMPLES</h2>
+<h3>Segmentation of RGB orthophoto</h3>
This example uses the ortho photograph included in the NC Sample
Dataset. Set up an imagery group:
<div class="code"><pre>
@@ -131,7 +134,7 @@
</pre></div>
<center>
-<img src="ortho_segs_l1.jpg">
+<img src="i_segment_ortho_segs_l1.jpg">
</center>
<p>
@@ -149,7 +152,7 @@
</pre></div>
<center>
-<img src="ortho_segs_l2_l5.jpg">
+<img src="i_segment_ortho_segs_l2_l5.jpg">
</center>
<p>
@@ -173,13 +176,51 @@
</pre></div>
<center>
-<img src="ortho_segs_final.jpg">
+<img src="i_segment_ortho_segs_final.jpg">
</center>
<p>
Processing the entire ortho image with nearly 10 million pixels took
about 450 times more then for the final run.
+<h3>Segmentation of panchromatic channel</h3>
+This example uses the panchromatic channel of the Landsat7 scene included
+in the North Carolina sample dataset:
+<div class="code"><pre>
+# create group with single channel
+i.group group=singleband input=lsat7_2002_80
+# set computational region to Landsat7 PAN band
+g.region raster=lsat7_2002_80 -p
+# perform segmentation with minsize=5
+i.segment group=singleband threshold=0.05 minsize=5 \
+ output=lsat7_2002_80_segmented_min5 goodness=lsat7_2002_80_goodness_min5
+# perform segmentation with minsize=100
+i.segment group=singleband threshold=0.05 minsize=100
+ output=lsat7_2002_80_segmented_min100 goodness=lsat7_2002_80_goodness_min100
+</pre></div>
+<p>
+<center>
+<img src="i_segment_lsat7_pan.png"><br>
+Original panchromatic channel of the Landsat7 scene
+</center>
+<p>
+<center>
+<img src="i_segment_lsat7_seg_min5.png"><br>
+Segmented panchromatic channel, minsize=5
+</center>
+<p>
+<center>
+<img src="i_segment_lsat7_seg_min100.png"><br>
+Segmented panchromatic channel, minsize=100
+</center>
<h2>TODO</h2>
<h3>Functionality</h3>
<ul>
Copied: grass/branches/releasebranch_7_0/imagery/i.segment/i_segment_lsat7_pan.png (from rev 66384, grass/trunk/imagery/i.segment/i_segment_lsat7_pan.png)
(Binary files differ)
Copied: grass/branches/releasebranch_7_0/imagery/i.segment/i_segment_lsat7_seg_min100.png (from rev 66384, grass/trunk/imagery/i.segment/i_segment_lsat7_seg_min100.png)
Copied: grass/branches/releasebranch_7_0/imagery/i.segment/i_segment_lsat7_seg_min5.png (from rev 66384, grass/trunk/imagery/i.segment/i_segment_lsat7_seg_min5.png)
Copied: grass/branches/releasebranch_7_0/imagery/i.segment/i_segment_ortho_segs_final.jpg (from rev 66384, grass/trunk/imagery/i.segment/i_segment_ortho_segs_final.jpg)
Copied: grass/branches/releasebranch_7_0/imagery/i.segment/i_segment_ortho_segs_l1.jpg (from rev 66384, grass/trunk/imagery/i.segment/i_segment_ortho_segs_l1.jpg)
Copied: grass/branches/releasebranch_7_0/imagery/i.segment/i_segment_ortho_segs_l2_l5.jpg (from rev 66384, grass/trunk/imagery/i.segment/i_segment_ortho_segs_l2_l5.jpg)
Deleted: grass/branches/releasebranch_7_0/imagery/i.segment/ortho_segs_final.jpg
Deleted: grass/branches/releasebranch_7_0/imagery/i.segment/ortho_segs_l1.jpg
Deleted: grass/branches/releasebranch_7_0/imagery/i.segment/ortho_segs_l2_l5.jpg
