[GRASS-SVN] r66386 - grass/trunk/scripts/v.krige
svn_grass at osgeo.org
Wed Sep 30 13:12:39 PDT 2015
Author: neteler
Date: 2015-09-30 13:12:39 -0700 (Wed, 30 Sep 2015)
New Revision: 66386
grass/trunk/scripts/v.krige/v.krige.py
v.krige: update to rgrass7 (contributed by pvanbosgeo)
Modified: grass/trunk/scripts/v.krige/v.krige.py
--- grass/trunk/scripts/v.krige/v.krige.py 2015-09-30 19:14:28 UTC (rev 66385)
+++ grass/trunk/scripts/v.krige/v.krige.py 2015-09-30 20:12:39 UTC (rev 66386)
@@ -6,7 +6,7 @@
PURPOSE: Performs ordinary or block kriging
-DEPENDS: R 2.x, packages gstat, maptools and spgrass6, optional: automap
+DEPENDS: R 2.x, packages gstat, maptools and rgrass7, optional: automap
COPYRIGHT: (C) 2009-2014 the GRASS Development Team
@@ -140,7 +140,7 @@
Checks for NULL values in the provided column and exits if they are present."""
#@NOTE: new way with R - as it doesn't alter original data
- Rpointmap = robjects.r.readVECT6(map, type = 'point')
+ Rpointmap = robjects.r.readVECT(map, type = 'point')
# checks if x,y columns are present in dataframe. If they do are present, but with different names,
# they'll be duplicated.
if "x" not in robjects.r.names(Rpointmap):
@@ -232,7 +232,7 @@
def ExportMap(self, map, column, name, overwrite, command, variograms):
# add kriging parameters to raster map history
- robjects.r.writeRAST6(map, vname = name, zcol = column, overwrite = overwrite)
+ robjects.r.writeRAST(map, vname = name, zcol = column, overwrite = overwrite)
grass.run_command('r.support',
map = name,
title = 'Kriging output',
@@ -408,7 +408,7 @@
# R packages check. Will create one error message after check of all packages.
missingPackagesList = []
- for each in ["rgeos", "gstat", "spgrass6", "maptools"]:
+ for each in ["rgeos", "gstat", "rgrass7", "maptools"]:
if not robjects.r.require(each, quietly = True)[0]:
missingPackagesList.append(each)
if missingPackagesList:
