[GRASS-SVN] r68332 - grass/trunk/lib/gis
Fri Apr 29 07:20:36 PDT 2016
Author: neteler
Date: 2016-04-29 07:20:36 -0700 (Fri, 29 Apr 2016)
New Revision: 68332
   grass/trunk/lib/gis/renamed_options
libgis: reverted r68329 since global block does the job
Modified: grass/trunk/lib/gis/renamed_options
--- grass/trunk/lib/gis/renamed_options	2016-04-29 13:11:53 UTC (rev 68331)
+++ grass/trunk/lib/gis/renamed_options	2016-04-29 14:20:36 UTC (rev 68332)
@@ -93,7 +93,6 @@
 g.mapset|gisdbase:dbase
 # g.mapsets
 g.mapsets|addmapset:operation
-g.mapsets|fs:separator
 g.mapsets|removemapset:operation
 g.mapsets|measure:method
 # g.pnmcomp
@@ -458,15 +457,12 @@
 v.clean|thresh:threshold
 # v.colors
 v.colors|volume:raster_3d
-# v.db.connect
-v.db.connect|fs:separator
 # v.db.join
 v.db.join|otable:other_table
 v.db.join|ocolumn:other_column
 v.db.join|scolumns:subset_columns
 # v.db.select
 v.db.select|nv:null_value
-v.db.select|fs:separator
 v.db.select|vs:vertical_separator
 # v.db.update
 v.db.update|qcolumn:query_column
