[GRASS-SVN] r68333 - grass/branches/releasebranch_7_0/lib/gis
svn_grass at osgeo.org
Fri Apr 29 07:21:57 PDT 2016
Author: neteler
Date: 2016-04-29 07:21:57 -0700 (Fri, 29 Apr 2016)
New Revision: 68333
grass/branches/releasebranch_7_0/lib/gis/renamed_options
libgis: reverted r68330 since global block does the job
Modified: grass/branches/releasebranch_7_0/lib/gis/renamed_options
--- grass/branches/releasebranch_7_0/lib/gis/renamed_options 2016-04-29 14:20:36 UTC (rev 68332)
+++ grass/branches/releasebranch_7_0/lib/gis/renamed_options 2016-04-29 14:21:57 UTC (rev 68333)
@@ -91,7 +91,6 @@
g.mapset|gisdbase:dbase
# g.mapsets
g.mapsets|addmapset:operation
-g.mapsets|fs:separator
g.mapsets|removemapset:operation
g.mapsets|measure:method
# g.pnmcomp
@@ -456,15 +455,12 @@
v.clean|thresh:threshold
# v.colors
v.colors|volume:raster_3d
-# v.db.connect
-v.db.connect|fs:separator
# v.db.join
v.db.join|otable:other_table
v.db.join|ocolumn:other_column
v.db.join|scolumns:subset_columns
# v.db.select
v.db.select|nv:null_value
-v.db.select|fs:separator
v.db.select|vs:vertical_separator
# v.db.update
v.db.update|qcolumn:query_column
