[GRASS-SVN] r68334 - grass/branches/releasebranch_7_0/general/g.copy
Fri Apr 29 07:26:02 PDT 2016
Author: neteler
Date: 2016-04-29 07:26:02 -0700 (Fri, 29 Apr 2016)
New Revision: 68334
   grass/branches/releasebranch_7_0/general/g.copy/g.copy.html
g.copy manual: remove outdated NOTES from G4 times
Modified: grass/branches/releasebranch_7_0/general/g.copy/g.copy.html
--- grass/branches/releasebranch_7_0/general/g.copy/g.copy.html	2016-04-29 14:21:57 UTC (rev 68333)
+++ grass/branches/releasebranch_7_0/general/g.copy/g.copy.html	2016-04-29 14:26:02 UTC (rev 68334)
@@ -39,31 +39,14 @@
 user's current mapset search path in the order in which mapsets are
 listed there (see <em><a href="g.mapsets.html">g.mapsets</a></em>).
-<h2>NOTES</h2>
-If the user does not enter parameter values but instead
-types only <em>g.copy</em> on the command line the program
-will prompt the user for a data type, the name of a file of
-this data type to copy, and the name of a new file to hold
-the copy.  After both file names have been entered, the
-copy is created and the user is again prompted for a data
-element to be copied, until the user hits RETURN.  When
-prompted for file names, the user may enter 'list' to see a
-list of existing files, or hit RETURN to end the file
-listing.
-<p>
-If a file has support files (e.g., as do raster data
-files), these support files will also be copied.
 <h2>SEE ALSO</h2>
 <em>
-  <a href="g.access.html">g.access</a>,
-  <a href="g.list.html">g.list</a>,
-  <a href="g.mapsets.html">g.mapsets</a>,
-  <a href="g.remove.html">g.remove</a>,
-  <a href="g.rename.html">g.rename</a>
+<a href="g.access.html">g.access</a>,
+<a href="g.list.html">g.list</a>,
+<a href="g.mapsets.html">g.mapsets</a>,
+<a href="g.remove.html">g.remove</a>,
+<a href="g.rename.html">g.rename</a>
 </em>
 <h2>AUTHOR</h2>
