[GRASS-SVN] r69061 - sandbox/metz/i.segment.ms
Tue Aug 2 12:34:24 PDT 2016
Author: mmetz
Date: 2016-08-02 12:34:24 -0700 (Tue, 02 Aug 2016)
New Revision: 69061
   sandbox/metz/i.segment.ms/iseg.h
   sandbox/metz/i.segment.ms/main.c
   sandbox/metz/i.segment.ms/mean_shift.c
   sandbox/metz/i.segment.ms/parse_args.c
   sandbox/metz/i.segment.ms/write_output.c
sandbox: i.segment + mean shift: polishing UI
Modified: sandbox/metz/i.segment.ms/iseg.h
--- sandbox/metz/i.segment.ms/iseg.h	2016-08-02 13:50:46 UTC (rev 69060)
+++ sandbox/metz/i.segment.ms/iseg.h	2016-08-02 19:34:24 UTC (rev 69061)
@@ -67,9 +67,8 @@
     /* output */
     /* region growing */
     char *out_name;		/* name of output raster map with regions */
-    char *out_band;		/* indicator for segment heterogeneity / goodness of fit */
-    /* mean_shift */
-    char *ms_suf;		/* suffix to be appended to input bands */
+    char *gof;			/* indicator for segment heterogeneity / goodness of fit */
+    char *bsuf;			/* suffix to be appended to input bands */
     /* general segmentation */
     int method;			/* Segmentation method code */
Modified: sandbox/metz/i.segment.ms/main.c
--- sandbox/metz/i.segment.ms/main.c	2016-08-02 13:50:46 UTC (rev 69060)
+++ sandbox/metz/i.segment.ms/main.c	2016-08-02 19:34:24 UTC (rev 69061)
@@ -54,12 +54,12 @@
     if (write_ids(&globals) != TRUE)
 	G_fatal_error(_("Error in writing IDs"));
-    if (globals.method == ORM_RG && globals.out_band) {
+    if (globals.method == ORM_RG && globals.gof) {
 	if (write_gof_rg(&globals) != TRUE)
 	    G_fatal_error(_("Error in writing goodness of fit"));
-    if (globals.method == ORM_MS) {
+    if (globals.method == ORM_MS && globals.bsuf) {
 	if (write_bands_ms(&globals) != TRUE)
 	    G_fatal_error(_("Error in writing new band values"));
Modified: sandbox/metz/i.segment.ms/mean_shift.c
--- sandbox/metz/i.segment.ms/mean_shift.c	2016-08-02 13:50:46 UTC (rev 69060)
+++ sandbox/metz/i.segment.ms/mean_shift.c	2016-08-02 19:34:24 UTC (rev 69061)
@@ -238,7 +238,7 @@
 	    /* spectral bandwidth: reduce by 0.7 */
 	    if (t > 1)
-		hspec *= 0.7;
+		hspec *= 0.9;
 	    hspec2 = hspec * hspec;
 	    sigmaspec2 = hspec2 / 9.;
Modified: sandbox/metz/i.segment.ms/parse_args.c
--- sandbox/metz/i.segment.ms/parse_args.c	2016-08-02 13:50:46 UTC (rev 69060)
+++ sandbox/metz/i.segment.ms/parse_args.c	2016-08-02 19:34:24 UTC (rev 69061)
@@ -11,24 +11,23 @@
     struct Option *group, *seeds, *bounds, *output,
                   *method, *similarity, *threshold, *min_segment_size,
-		  *hs, *hr, *ms_suf,
+		  *hs, *hr, *bsuf,
 #ifdef _OR_SHAPE_
 		  *shape_weight, *smooth_weight,
 #endif
 		   *mem;
     struct Flag *diagonal, *weighted, *ms_a, *ms_p;
-    struct Option *outband, *endt;
+    struct Option *gof, *endt;
     /* required parameters */
     group = G_define_standard_option(G_OPT_I_GROUP);
     output = G_define_standard_option(G_OPT_R_OUTPUT);
-    ms_suf = G_define_standard_option(G_OPT_R_OUTPUT);
-    ms_suf->key = "ms";
-    ms_suf->required = NO;
-    ms_suf->answer = "_ms";
-    ms_suf->label = _("Suffix for output bands (mean shift)");
+    bsuf = G_define_standard_option(G_OPT_R_OUTPUT);
+    bsuf->key = "band_suffix";
+    bsuf->required = NO;
+    bsuf->label = _("Suffix for output bands with modified band values");
     threshold = G_define_option();
     threshold->key = "threshold";
@@ -40,10 +39,11 @@
     /* optional parameters */
     hs = G_define_option();
-    hs->key = "hs";
+    hs->key = "radius";
     hs->type = TYPE_DOUBLE;
     hs->required = NO;
-    hs->label = _("Spatial bandwidth in number of cells");
+    hs->answer = "1.5";
+    hs->label = _("Spatial radius in number of cells");
     hs->description = _("Must be >= 1, only cells within spatial bandwidth are considered for mean shift");
     hr = G_define_option();
@@ -136,10 +136,10 @@
     bounds->description =
 	_("Must be integer values, each area will be segmented independent of the others");
-    outband = G_define_standard_option(G_OPT_R_OUTPUT);
-    outband->key = "goodness";
-    outband->required = NO;
-    outband->description =
+    gof = G_define_standard_option(G_OPT_R_OUTPUT);
+    gof->key = "goodness";
+    gof->required = NO;
+    gof->description =
 	_("Name for output goodness of fit estimate map");
     diagonal = G_define_flag();
@@ -179,7 +179,7 @@
     else
 	G_fatal_error("Invalid output raster name");
-    globals->ms_suf = ms_suf->answer;
+    globals->bsuf = bsuf->answer;
     globals->alpha = atof(threshold->answer);
     if (globals->alpha <= 0 || globals->alpha >= 1)
@@ -317,11 +317,11 @@
     /* debug help */
-    if (outband->answer == NULL)
-	globals->out_band = NULL;
+    if (gof->answer == NULL)
+	globals->gof = NULL;
     else {
-	if (G_legal_filename(outband->answer) == TRUE)
-	    globals->out_band = outband->answer;
+	if (G_legal_filename(gof->answer) == TRUE)
+	    globals->gof = gof->answer;
 	else
 	    G_fatal_error(_("Invalid output raster name for goodness of fit"));
Modified: sandbox/metz/i.segment.ms/write_output.c
--- sandbox/metz/i.segment.ms/write_output.c	2016-08-02 13:50:46 UTC (rev 69060)
+++ sandbox/metz/i.segment.ms/write_output.c	2016-08-02 19:34:24 UTC (rev 69061)
@@ -79,7 +79,7 @@
     struct History hist;
     DCELL *min, *max;
-    mean_fd = Rast_open_new(globals->out_band, FCELL_TYPE);
+    mean_fd = Rast_open_new(globals->gof, FCELL_TYPE);
     meanbuf = Rast_allocate_f_buf();
     /* goodness of fit for each cell: 1 = good fit, 0 = bad fit */
@@ -190,11 +190,11 @@
     Rast_init_colors(&colors);
     Rast_make_grey_scale_fp_colors(&colors, mingood, 1);
-    Rast_write_colors(globals->out_band, G_mapset(), &colors);
+    Rast_write_colors(globals->gof, G_mapset(), &colors);
-    Rast_short_history(globals->out_band, "raster", &hist);
+    Rast_short_history(globals->gof, "raster", &hist);
     Rast_command_history(&hist);
-    Rast_write_history(globals->out_band, &hist);
+    Rast_write_history(globals->gof, &hist);
     G_free(meanbuf);
@@ -227,7 +227,7 @@
     outbuf = G_malloc(sizeof(DCELL) * globals->nbands);
     for (n = 0; n < globals->nbands; n++) {
 	outbuf[n] = Rast_allocate_d_buf();
-	G_asprintf(&name[n], "%s%s", globals->Ref.file[n].name, globals->ms_suf);
+	G_asprintf(&name[n], "%s%s", globals->Ref.file[n].name, globals->bsuf);
 	out_fd[n] = Rast_open_new(name[n], DCELL_TYPE);
