[GRASS-SVN] r69062 - sandbox/metz/i.segment.ms
Tue Aug 2 12:44:57 PDT 2016
Author: mmetz
Date: 2016-08-02 12:44:57 -0700 (Tue, 02 Aug 2016)
New Revision: 69062
   sandbox/metz/i.segment.ms/i.segment.ms.html
   sandbox/metz/i.segment.ms/parse_args.c
sandbox: i.segment + mean shift: polishing UI, updating manual
Modified: sandbox/metz/i.segment.ms/i.segment.ms.html
--- sandbox/metz/i.segment.ms/i.segment.ms.html	2016-08-02 19:34:24 UTC (rev 69061)
+++ sandbox/metz/i.segment.ms/i.segment.ms.html	2016-08-02 19:44:57 UTC (rev 69062)
@@ -112,7 +112,9 @@
 than 1 will add one additional pass to the processing. During the
 final pass, the threshold is ignored for any segments smaller then
 the set size, thus forcing very small segments to merge with their
-most similar neighbor.
+most similar neighbor. A minimum segment size larger than 1 is
+recommended when using adaptive bandwith selected with the <b>-a</b>
+flag.
 <h2>EXAMPLES</h2>
Modified: sandbox/metz/i.segment.ms/parse_args.c
--- sandbox/metz/i.segment.ms/parse_args.c	2016-08-02 19:34:24 UTC (rev 69061)
+++ sandbox/metz/i.segment.ms/parse_args.c	2016-08-02 19:44:57 UTC (rev 69062)
@@ -127,6 +127,7 @@
     seeds->key = "seeds";
     seeds->required = NO;
     seeds->description = _("Name for input raster map with starting seeds");
+    seeds->guisection = _("Settings");
     /* Polygon constraints. */
     bounds = G_define_standard_option(G_OPT_R_INPUT);
@@ -135,12 +136,14 @@
     bounds->label = _("Name of input bounding/constraining raster map");
     bounds->description =
 	_("Must be integer values, each area will be segmented independent of the others");
+    bounds->guisection = _("Settings");
     gof = G_define_standard_option(G_OPT_R_OUTPUT);
     gof->key = "goodness";
     gof->required = NO;
     gof->description =
 	_("Name for output goodness of fit estimate map");
+    gof->guisection = _("Settings");
     diagonal = G_define_flag();
     diagonal->key = 'd';
