[GRASS-SVN] r69093 - grass/trunk/display/d.vect
svn_grass at osgeo.org
Fri Aug 5 07:49:57 PDT 2016
Author: annakrat
Date: 2016-08-05 07:49:57 -0700 (Fri, 05 Aug 2016)
New Revision: 69093
Added:
grass/trunk/display/d.vect/legend.c
grass/trunk/display/d.vect/local_proto.h
grass/trunk/display/d.vect/main.c
d.vect: move legend code to separate file, author Adam Laza
Added: grass/trunk/display/d.vect/legend.c
--- grass/trunk/display/d.vect/legend.c (rev 0)
+++ grass/trunk/display/d.vect/legend.c 2016-08-05 14:49:57 UTC (rev 69093)
@@ -0,0 +1,75 @@
+#include <grass/gis.h>
+#include <grass/vector.h>
+#include "local_proto.h"
+void write_into_legfile(struct Map_info *Map, int type, const char *leglab, const char *name_map, const char *icon,
+ const char *size, const char *color, const char *fcolor, const char *width, const char *icon_area,
+ const char *icon_line)
+ int nfeatures;
+ FILE *fd;
+ char *leg_file;
+ char map[GNAME_MAX];
+ char *ptr;
+ strcpy(map, name_map);
+ strtok_r(map, "@", &ptr);
+ /* Write into legend file */
+ leg_file = getenv("GRASS_LEGEND_FILE");
+ if (leg_file) {
+ fd = fopen(leg_file, "a");
+ /* Point */
+ if (type & GV_POINT){
+ nfeatures = Vect_get_num_primitives(Map, GV_POINT);
+ if (nfeatures > 0) {
+ if (leglab)
+ fprintf(fd, "%s|", leglab);
+ else
+ fprintf(fd, "%s|", map);
+ fprintf(fd, "%s|%s|%s|%s|%s", icon, size, color, fcolor, width);
+ fprintf(fd, "|%s|%d\n", "point", nfeatures);
+ /* Line */
+ if (type & GV_LINE){
+ nfeatures = Vect_get_num_primitives(Map, GV_LINE);
+ if (nfeatures > 0){
+ if (leglab)
+ else
+ fprintf(fd, "%s|%s|%s|%s|%s", icon_line, size, color, fcolor, width);
+ fprintf(fd, "|%s|%d\n", "line", nfeatures);
+ /* Area */
+ if (type & GV_AREA){
+ nfeatures = Vect_get_num_primitives(Map, GV_BOUNDARY);
+ if (leglab)
+ else
+ fprintf(fd, "%s|%s|%s|%s|%s", icon_area, size, color, fcolor, width);
+ fprintf(fd, "|%s|%d\n", "area", nfeatures);
+ /* Centroid */
+ if (type & GV_CENTROID){
+ nfeatures = Vect_get_num_primitives(Map, GV_CENTROID);
+ if (leglab)
+ else
+ fprintf(fd, "|%s|%d\n", "centroid", nfeatures);
+ fclose(fd);
Property changes on: grass/trunk/display/d.vect/legend.c
___________________________________________________________________
Added: svn:mime-type
+ text/x-csrc
Added: svn:eol-style
+ native
Modified: grass/trunk/display/d.vect/local_proto.h
--- grass/trunk/display/d.vect/local_proto.h 2016-08-05 13:02:45 UTC (rev 69092)
+++ grass/trunk/display/d.vect/local_proto.h 2016-08-05 14:49:57 UTC (rev 69093)
@@ -65,3 +65,8 @@
/* zcoor.c */
int display_zcoor(struct Map_info *, int, LATTR *);
+/* legend.c */
+void write_into_legfile(struct Map_info *, int, const char *, const char *,
+ const char *, const char *, const char *, const char *,
+ const char *, const char *, const char *);
Modified: grass/trunk/display/d.vect/main.c
--- grass/trunk/display/d.vect/main.c 2016-08-05 13:02:45 UTC (rev 69092)
+++ grass/trunk/display/d.vect/main.c 2016-08-05 14:49:57 UTC (rev 69093)
@@ -57,7 +57,6 @@
struct Option *icon_line_opt, *icon_area_opt;
struct Flag *id_flag, *cats_acolors_flag, *sqrt_flag;
char *desc;
- char *leg_file;
struct cat_list *Clist;
LATTR lattr;
@@ -65,10 +64,7 @@
struct Cell_head window;
struct bound_box box;
double overlap;
- int gv_point, gv_line, gv_boundary, gv_centroid;
- FILE *fd;
stat = 0;
/* Initialize the GIS calls */
G_gisinit(argv[0]);
@@ -457,84 +453,10 @@
stat += display_dir(&Map, type, Clist, chcat, size);
- /* Write into legend file */
- leg_file = getenv("GRASS_LEGEND_FILE");
- if (leg_file) {
- fd = fopen(leg_file, "a");
- /* Point */
- if (strstr(type_opt->answer, "point") != NULL){
- gv_point = Vect_get_num_primitives(&Map, GV_POINT);
- if (gv_point > 0) {
- if (leglab_opt->answer)
- fprintf(fd, "%s|", leglab_opt->answer);
- else {
- char map[128];
- char *ptr;
- strcpy(map, map_opt->answer);
- strtok_r(map, "@", &ptr);
- fprintf(fd, "%s|", map);
- fprintf(fd, "%s|%s|%s|%s|%s", icon_opt->answer, size_opt->answer, color_opt->answer, fcolor_opt->answer, width_opt->answer);
- fprintf(fd, "|%s|%d\n", "point", gv_point);
- /* Line */
- if (strstr(type_opt->answer, "line") != NULL){
- gv_line = Vect_get_num_primitives(&Map, GV_LINE);
- if (gv_line > 0){
- else {
- char map[128];
- char *ptr;
- fprintf(fd, "%s|%s|%s|%s|%s", icon_line_opt->answer, size_opt->answer, color_opt->answer, fcolor_opt->answer, width_opt->answer);
- fprintf(fd, "|%s|%d\n", "line", gv_line);
- /* Area */
- if (strstr(type_opt->answer, "area") != NULL){
- gv_boundary = Vect_get_num_primitives(&Map, GV_BOUNDARY);
- if (gv_boundary > 0) {
- else {
- char map[128];
- char *ptr;
- fprintf(fd, "%s|%s|%s|%s|%s", icon_area_opt->answer, size_opt->answer, color_opt->answer, fcolor_opt->answer, width_opt->answer);
- fprintf(fd, "|%s|%d\n", "area", gv_boundary);
- /* Centroid */
- if (strstr(type_opt->answer, "centroid") != NULL){
- gv_centroid = Vect_get_num_primitives(&Map, GV_CENTROID);
- if (gv_centroid > 0) {
- else {
- char map[128];
- char *ptr;
- fprintf(fd, "|%s|%d\n", "centroid", gv_centroid);
- fclose(fd);
+ write_into_legfile(&Map, type, leglab_opt->answer, map_name,
+ icon_opt->answer, size_opt->answer, color_opt->answer,
+ fcolor_opt->answer, width_opt->answer, icon_area_opt->answer,
+ icon_line_opt->answer);
/* reset line width: Do we need to get line width from display
* driver (not implemented)? It will help restore previous line
