[GRASS-SVN] r69094 - grass-addons/grass7/display/d.legend.vect
svn_grass at osgeo.org
Sat Aug 6 03:37:57 PDT 2016
Author: lazaa
Date: 2016-08-06 03:37:56 -0700 (Sat, 06 Aug 2016)
New Revision: 69094
grass-addons/grass7/display/d.legend.vect/draw.c
grass-addons/grass7/display/d.legend.vect/local_proto.h
grass-addons/grass7/display/d.legend.vect/main.c
Separator, group labels, g_tokenize
Modified: grass-addons/grass7/display/d.legend.vect/draw.c
--- grass-addons/grass7/display/d.legend.vect/draw.c 2016-08-05 14:49:57 UTC (rev 69093)
+++ grass-addons/grass7/display/d.legend.vect/draw.c 2016-08-06 10:37:56 UTC (rev 69094)
@@ -17,7 +17,7 @@
void draw(char *file_name, double LL, double LT, char *title, int cols, int bgcolor,
int bcolor, int bg_width, int do_bg, char* tit_font, int tit_size, char *sub_font,
- int sub_size, char *font, int fontsize, int fontcolor, int symb_size)
+ int sub_size, char *font, int fontsize, int fontcolor, int symb_size, char *sep)
double db, dt, dl, dr;
double bb, bt, bl, br;
@@ -25,7 +25,7 @@
double offs_y, row_ind, offs_x;
double x, y;
FILE *file_in;
- char buf[512];
+ char buf[BUFFSIZE];
int got_new;
SYMBOL *Symb;
char *symb_name, *line_color_str, *fill_color_str, *label, *type_str;
@@ -39,8 +39,8 @@
int item_count, item;
double it_per_col;
double margin, bg_h, bg_w;
- char *sep;
int type_count;
+ char **tokens;
D_get_src(&dt, &db, &dl, &dr);
@@ -66,7 +66,8 @@
file_in = fopen(file_name, "r");
- sep = "|";
+ sub_delim = G_malloc(GNAME_MAX);
+ snprintf(sub_delim, sizeof(GNAME_MAX), "%s%s%s%s%s", sep, sep, sep, sep, sep);
if (!file_in)
G_fatal_error(_("Unable to open input file <%s>"), file_name);
@@ -77,47 +78,42 @@
got_new = G_getl2(buf, sizeof(buf), file_in);
G_strip(buf);
while (got_new) {
- /* Get the maximum symbol size */
- symb_name = G_malloc(strlen(buf) + 1);
- type_str = G_malloc(strlen(buf) + 1);
- line_color_str = G_malloc(strlen(buf) + 1);
- fill_color_str = G_malloc(strlen(buf) + 1);
- label = G_malloc(strlen(buf)+1);
- line_color = G_malloc(sizeof(RGBA_Color));
- fill_color = G_malloc(sizeof(RGBA_Color));
+ if (strstr(buf, sub_delim) == NULL) {
+ /* Get the maximum symbol size */
+ symb_name = G_malloc(GNAME_MAX);
+ type_str = G_malloc(GNAME_MAX);
+ line_color_str = G_malloc(GNAME_MAX);
+ fill_color_str = G_malloc(GNAME_MAX);
+ label = G_malloc(GNAME_MAX);
+ line_color = G_malloc(sizeof(RGBA_Color));
+ fill_color = G_malloc(sizeof(RGBA_Color));
- part = strtok(buf, sep);
- sscanf(part, "%s", label);
- part = strtok(NULL, sep);
- sscanf(part, "%s", symb_name);
- sscanf(part, "%lf", &size);
- sscanf(part, "%s", line_color_str);
- sscanf(part, "%s", fill_color_str);
- sscanf(part, "%lf", &line_width);
- sscanf(part, "%s", type_str);
- sscanf(part, "%d", &type_count);
+ tokens = G_tokenize(buf, sep);
+ sscanf(tokens[0], "%s", label);
+ sscanf(tokens[1], "%s", symb_name);
+ sscanf(tokens[2], "%lf", &size);
+ sscanf(tokens[3], "%s", line_color_str);
+ sscanf(tokens[4], "%s", fill_color_str);
+ sscanf(tokens[5], "%lf", &line_width);
+ sscanf(tokens[6], "%s", type_str);
+ sscanf(tokens[6], "%d", &type_count);
+ G_free_tokens(tokens);
- /* Symbol */
- if (strcmp(type_str,"point")!=0) {
- size = symb_size;
- D_line_width(line_width);
- Symb = S_read(symb_name);
- if (Symb == NULL)
- G_warning(_("Cannot read symbol"));
- else
- S_stroke(Symb, size, 0, 0);
- symb_w = size;
+ /* Symbol */
+ if (strcmp(type_str,"point")!=0) {
+ size = symb_size;
+ D_line_width(line_width);
+ Symb = S_read(symb_name);
+ if (Symb == NULL)
+ G_warning(_("Cannot read symbol"));
+ else
+ S_stroke(Symb, size, 0, 0);
+ symb_w = size;
- if (symb_w > def_symb_w)
- def_symb_w = symb_w;
+ if (symb_w > def_symb_w)
+ def_symb_w = symb_w;
item_count++;
G_strip(buf);
@@ -133,8 +129,6 @@
item = 0;
offs_x = 0;
margin = 10;
- sub_delim = G_malloc(strlen(buf)+1);
- snprintf(sub_delim, sizeof(strlen(buf)+1), "%s%s%s%s%s", sep, sep, sep, sep, sep);
G_strip(buf);
@@ -155,7 +149,7 @@
if (strstr(buf, sub_delim) != NULL) {
/* Group subtitle */
@@ -180,33 +174,27 @@
else {
/* Map layers */
/* Symbol */
- if (strcmp(type_str,"point") != 0){
+ if ((strcmp(type_str,"point") != 0) && (strcmp(type_str, "centroid") != 0)) {
size = symb_size;
Modified: grass-addons/grass7/display/d.legend.vect/local_proto.h
--- grass-addons/grass7/display/d.legend.vect/local_proto.h 2016-08-05 14:49:57 UTC (rev 69093)
+++ grass-addons/grass7/display/d.legend.vect/local_proto.h 2016-08-06 10:37:56 UTC (rev 69094)
@@ -1,3 +1,5 @@
+#define BUFFSIZE 512
/* draw.c */
void draw(char *, double, double, char *, int, int, int, int,
- int, char *, int, char *, int, char *, int, int, int);
+ int, char *, int, char *, int, char *, int, int, int, char *);
Modified: grass-addons/grass7/display/d.legend.vect/main.c
--- grass-addons/grass7/display/d.legend.vect/main.c 2016-08-05 14:49:57 UTC (rev 69093)
+++ grass-addons/grass7/display/d.legend.vect/main.c 2016-08-06 10:37:56 UTC (rev 69094)
@@ -27,7 +27,7 @@
struct Option *opt_at, *opt_cols, *opt_font, *opt_fontsize,
*opt_fontcolor, *opt_title, *opt_tit_font, *opt_tit_fontsize, *opt_sub_font,
*opt_sub_fontsize, *opt_bcolor, *opt_bgcolor, *opt_symb_size,
- *opt_bg_width, *opt_output, *opt_input;
+ *opt_bg_width, *opt_output, *opt_input, *opt_sep;
struct Flag *fl_bg;
double LL, LT;
@@ -38,7 +38,8 @@
int cols, symb_size, bg_width;
char *out_file;
FILE *source, *target;
- char buf[512];
+ char *sep;
/* Initialize the GIS calls */
@@ -178,6 +179,9 @@
opt_input->required = NO;
opt_input->guisection = _("In/Out");
+ opt_sep = G_define_standard_option(G_OPT_F_SEP);
+ opt_sep->guisection = _("Input");
/* Check command line */
if (G_parser(argc, argv)) {
exit(EXIT_FAILURE);
@@ -245,6 +249,8 @@
fontcolor = D_parse_color(opt_fontcolor->answer, FALSE); /*default color: black */
/* I/O */
+ sep = G_option_to_separator(opt_sep);
if (opt_input->answer) {
file_name = opt_input->answer;
if (!file_name)
@@ -263,7 +269,7 @@
if (strcmp(opt_output->answer,"-") == 0)
- while (fgets (buf, sizeof(buf), source) != NULL)
+ while (fgets (buf, sizeof(GNAME_MAX), source) != NULL)
puts (buf);
else {
out_file = opt_output->answer;
@@ -272,7 +278,7 @@
fclose(source);
G_fatal_error(_("Unable to create output file <%s>"), out_file);
fputs (buf, target);
fclose(target);
@@ -281,10 +287,10 @@
/* Pre-calculate the layout */
if (do_bg)
- draw(file_name, LL, LT, title, cols, bgcolor, bcolor, bg_width, 1, tit_font, tit_size, sub_font, sub_size, font, fontsize, fontcolor, symb_size);
+ draw(file_name, LL, LT, title, cols, bgcolor, bcolor, bg_width, 1, tit_font, tit_size, sub_font, sub_size, font, fontsize, fontcolor, symb_size, sep);
/* Draw legend */
- draw(file_name, LL, LT, title, cols, bgcolor, bcolor, bg_width, 0, tit_font, tit_size, sub_font, sub_size, font, fontsize, fontcolor, symb_size);
+ draw(file_name, LL, LT, title, cols, bgcolor, bcolor, bg_width, 0, tit_font, tit_size, sub_font, sub_size, font, fontsize, fontcolor, symb_size, sep);
D_close_driver();
