[GRASS-SVN] r69166 - grass-addons/grass7/raster/r.viewshed.cva
Sat Aug 20 12:32:03 PDT 2016
Author: annakrat
Date: 2016-08-20 12:32:03 -0700 (Sat, 20 Aug 2016)
New Revision: 69166
   grass-addons/grass7/raster/r.viewshed.cva/r.viewshed.cva.html
r.viewshed.cva: fix broken column name also in manual
Modified: grass-addons/grass7/raster/r.viewshed.cva/r.viewshed.cva.html
--- grass-addons/grass7/raster/r.viewshed.cva/r.viewshed.cva.html	2016-08-20 19:31:03 UTC (rev 69165)
+++ grass-addons/grass7/raster/r.viewshed.cva/r.viewshed.cva.html	2016-08-20 19:32:03 UTC (rev 69166)
@@ -22,9 +22,9 @@
 and an input vector points map, <b>vector</b>. There is currently only
  one native flag for <em>r.viewshed.cva</em>, <b>-k</b>, which allows
  you to keep the interim viewshed maps made for each input point.
-Optionally, option <b>name_col</b> can be used with <b>-k</b> to specify
+Optionally, option <b>name_column</b> can be used with <b>-k</b> to specify
 the suffix of the kept viewshed maps by a particular column in the
-input vector points' database. If no value is specified for <b>name_col</b>,
+input vector points' database. If no value is specified for <b>name_column</b>,
 then the cat value will be used.
 <p>
 All other flags and options are inherited from
