[GRASS-SVN] r69167 - in grass/trunk/vector: v.mkgrid v.vect.stats
svn_grass at osgeo.org
Sat Aug 20 15:08:40 PDT 2016
Author: wenzeslaus
Date: 2016-08-20 15:08:40 -0700 (Sat, 20 Aug 2016)
New Revision: 69167
Added:
grass/trunk/vector/v.mkgrid/v_mkgrid.png
grass/trunk/vector/v.vect.stats/v_vect_stats.png
grass/trunk/vector/v.mkgrid/main.c
grass/trunk/vector/v.mkgrid/v.mkgrid.html
grass/trunk/vector/v.vect.stats/v.vect.stats.html
v.mkgrid and v.vect.stats: add examples with hexagons
Modified: grass/trunk/vector/v.mkgrid/main.c
--- grass/trunk/vector/v.mkgrid/main.c 2016-08-20 19:32:03 UTC (rev 69166)
+++ grass/trunk/vector/v.mkgrid/main.c 2016-08-20 22:08:40 UTC (rev 69167)
@@ -71,6 +71,7 @@
G_add_keyword(_("geometry"));
G_add_keyword(_("grid"));
G_add_keyword(_("point pattern"));
+ G_add_keyword(_("hexagon"));
module->description = _("Creates a vector map of a user-defined grid.");
vectname = G_define_standard_option(G_OPT_V_OUTPUT);
Modified: grass/trunk/vector/v.mkgrid/v.mkgrid.html
--- grass/trunk/vector/v.mkgrid/v.mkgrid.html 2016-08-20 19:32:03 UTC (rev 69166)
+++ grass/trunk/vector/v.mkgrid/v.mkgrid.html 2016-08-20 22:08:40 UTC (rev 69167)
@@ -129,6 +129,52 @@
Hexagon map
</center>
+<h3>Using hexagons for point density</h3>
+To compute point density in a hexagonal grid for the vector map
+<em>points_of_interest</em> in the basic North Carolina sample dataset,
+the vector map itself is used to set extent of the computational region.
+The resolution is based on the desired size of hexagons.
+<div class="code"><pre>
+g.region vector=points_of_interest res=2000 -pa
+</pre></div>
+The hexagonal grid is created as a vector map based on the previously
+selected extent and size of the grid.
+v.mkgrid map=hexagons -h
+</pre></div>
+The following counts the number of points per hexagon using the
+<em><a href="v.vect.stats.html">v.vect.stats</a></em> module.
+v.vect.stats points=points_of_interest areas=hexagons count_column=count
+</pre></div>
+User should note that some of the points may be outside the grid
+since the hexagons cannot cover all the area around the edges
+(the computational region extent needs to be enlarged if all points
+should be considered).
+The last command sets the vector map color table to <tt>viridis</tt>
+based on the <tt>count</tt> column.
+v.colors map=hexagons use=attr column=count color=viridis
+</pre></div>
+d.erase 77:77:77
+<center>
+<img src="v_mkgrid.png"><br>
+Point density in a hexagonal grid
+</center>
<h2>SEE ALSO</h2>
<em>
Added: grass/trunk/vector/v.mkgrid/v_mkgrid.png
(Binary files differ)
Property changes on: grass/trunk/vector/v.mkgrid/v_mkgrid.png
___________________________________________________________________
Added: svn:mime-type
+ image/png
Modified: grass/trunk/vector/v.vect.stats/v.vect.stats.html
--- grass/trunk/vector/v.vect.stats/v.vect.stats.html 2016-08-20 19:32:03 UTC (rev 69166)
+++ grass/trunk/vector/v.vect.stats/v.vect.stats.html 2016-08-20 22:08:40 UTC (rev 69167)
@@ -145,7 +145,90 @@
v.db.select myzipcodes_wake column=ZIPCODE_,ZIPNAME,avg_elev
</pre></div>
+<h3>Point statistics in a hexagonal grid</h3>
+The grid extent and size is influenced by the current computational
+region. The extent is based on the vector map
+<em>points_of_interest</em> from the basic North Carolina sample dataset.
+</pre></div>
+</pre></div>
+The <em><a href="v.vect.stats.html">v.vect.stats</a></em> module
+counts the number of points and does one statistics on a selected
+column (here: <em>elev_m</em>).
+v.vect.stats points=points_of_interest areas=hexagons method=average \
+ points_column=elev_m count_column=count stats_column=average
+</pre></div>
+v.colors map=hexagons use=attr column=average color=viridis
+</pre></div>
+v.vect.stats points=points_of_interest areas=hexagons method=range \
+ points_column=elev_m count_column=count stats_column=range
+v.vect.stats points=points_of_interest areas=hexagons method=stddev \
+ points_column=elev_m count_column=count stats_column=stddev
+export GRASS_FONT=LiberationSans-Regular
+rm $FILE
+d.mon cairo out=$FILE
+d.frame frame=f1 at=50,100,0,50 -c
+v.colors map=hexagons use=attr column=range color=viridis
+d.vect map=points_of_interest color=black fill_color=black width=1 icon=basic/point size=3
+d.text text="points" at=60,5 size=10 color=black
+d.frame frame=f2 at=50,100,50,100 -c
+d.vect map=hexagons where="count > 0"
+d.text text="count" at=60,5 size=10 color=black
+d.frame frame=f3 at=0,50,0,50 -c
+d.text text="average" at=60,5 size=10 color=black
+d.frame frame=f4 at=0,50,50,100 -c
+v.colors map=hexagons use=attr column=stddev color=viridis
+d.text text="stddev" at=60,5 size=10 color=black
+d.mon stop=cairo
+mogrify -trim $FILE
+<center>
+<img src="v_vect_stats.png"><br>
+Point statistics in a hexagonal grid (count of points, average of values
+associated with point, standard deviation)
+</center>
<h2>SEE ALSO</h2>
<em>
Added: grass/trunk/vector/v.vect.stats/v_vect_stats.png
Property changes on: grass/trunk/vector/v.vect.stats/v_vect_stats.png
+ image/png
