[GRASS-SVN] r69294 - in grass-addons/grass7/vector: . v.in.pygbif
svn_grass at osgeo.org
Mon Aug 29 01:34:19 PDT 2016
Author: sbl
Date: 2016-08-29 01:34:19 -0700 (Mon, 29 Aug 2016)
New Revision: 69294
Added:
grass-addons/grass7/vector/v.in.pygbif/
grass-addons/grass7/vector/v.in.pygbif/Makefile
grass-addons/grass7/vector/v.in.pygbif/v.in.pygbif.html
grass-addons/grass7/vector/v.in.pygbif/v.in.pygbif.py
Added new addon: v.in.pygbif from Code Sprint
Added: grass-addons/grass7/vector/v.in.pygbif/Makefile
--- grass-addons/grass7/vector/v.in.pygbif/Makefile (rev 0)
+++ grass-addons/grass7/vector/v.in.pygbif/Makefile 2016-08-29 08:34:19 UTC (rev 69294)
@@ -0,0 +1,7 @@
+MODULE_TOPDIR = ../..
+PGM = v.in.pygbif
+include $(MODULE_TOPDIR)/include/Make/Script.make
+default: script
Property changes on: grass-addons/grass7/vector/v.in.pygbif/Makefile
___________________________________________________________________
Added: svn:mime-type
+ text/x-makefile
Added: svn:eol-style
+ native
Added: grass-addons/grass7/vector/v.in.pygbif/v.in.pygbif.html
--- grass-addons/grass7/vector/v.in.pygbif/v.in.pygbif.html (rev 0)
+++ grass-addons/grass7/vector/v.in.pygbif/v.in.pygbif.html 2016-08-29 08:34:19 UTC (rev 69294)
@@ -0,0 +1,56 @@
+<h2>DESCRIPTION:</h2>
+<p>The module <em>v.in.pygbif</em> is a wrapper around the
+<a href=http://pygbif.readthedocs.io/en/latest/index.html>pygbif</a> package.
+Through pygbif, it allows to download data from the Global Biodiversity
+Information Facility (<a href=www.gbif.org>GBIF</a>) using different search /
+filter criteria.</p>
+<p>The point data is downloaded and projected into the current location. By default
+import is limited to the current computational region in order to avoid
+possible projection errors, e.g. when projecting global data into UTM locations.
+However, in lat/lon location this limitation can be skiped using the <b><em>-r</em></b>
+flag.</p>
+<p>Terminology in v.in.pygbif is oriented on the <em>Darwin Core</em> standard:
+<a href=http://rs.tdwg.org/dwc/> http://rs.tdwg.org/dwc/</a>.</p>
+</div>
+<div id="examples">
+<h2>EXAMPLES:</h2>
+<div class="code"><pre>
+# Check matching taxon names and alternatives in GBIF:
+v.in.pygbif species="Poa,Plantago" rank=genus -p
+# Get number of occurrences for two geni:
+v.in.pygbif species="Poa,Plantago" rank=genus -o
+# Get number of occurrences for two species:
+v.in.pygbif species="Poa pratensis,Plantago media" rank=species -o
+# Fetch occurrences for two species into a map for each species:
+v.in.pygbif species="Poa pratensis,Plantago media" rank=species output=gbif -i
+</pre></div>
+</div>
+<div id="seealso">
+<h2>SEE ALSO:</h2>
+<a href="v.in.gbif.html">v.in.gbif</a>
+</div>
+<div id="references">
+<h2>REFERENCES:</h2>
+http://pygbif.readthedocs.io/en/latest/index.html</a><br>
+<a href=http://www.gbif.org>
+http://www.gbif.org</a><br>
+<a href=http://www.gbif.org/developer/summary>
+http://www.gbif.org/developer/summary</a>
+</div>
+<div id="author">
+<h2>AUTHOR:</h2>
+Stefan Blumentrath, Norwegian Institute for Nature Research, Oslo, Norway
+</div>
Property changes on: grass-addons/grass7/vector/v.in.pygbif/v.in.pygbif.html
+ text/html
Added: svn:keywords
+ Author Date Id
+ native
Added: grass-addons/grass7/vector/v.in.pygbif/v.in.pygbif.py
--- grass-addons/grass7/vector/v.in.pygbif/v.in.pygbif.py (rev 0)
+++ grass-addons/grass7/vector/v.in.pygbif/v.in.pygbif.py 2016-08-29 08:34:19 UTC (rev 69294)
@@ -0,0 +1,606 @@
+#!/usr/bin/env python
+MODULE: v.in.pygbif
+AUTHOR(S): Stefan Blumentrath < stefan.blumentrath AT nina.no>
+ Helmut Kudrnovsky <alectoria AT gmx at>
+PURPOSE: Search and import GBIF species distribution data directly from
+ GBIF API using pygbif
+COPYRIGHT: (C) 2016 by the GRASS Development Team
+ This program is free software under the GNU General Public
+ License (>=v2). Read the file COPYING that comes with GRASS
+ for details.
+To Dos:
+- use proper cleanup routine, esp if using csv + vrt (copy from other modules)
+- handle layers in mask input
+#%module
+#% description: Search and import GBIF species distribution data
+#% keyword: vector
+#% keyword: geometry
+#%end
+#%option G_OPT_V_OUTPUT
+#% key: output
+#% description: Name of resulting vector map with species occurrences
+#% required : yes
+#%end
+#%option
+#% key: species
+#% description: Comma separated list of species names or keys to fetch data for
+#% required : yes
+#%end
+#%option G_OPT_V_INPUT
+#% key: mask
+#% description: Vector map that delimits region of interest
+#% guisection: Spatial filter
+#% required: no
+#%end
+#%option
+#% key: date_from
+#% type: string
+#% description: Lower bound of acceptable dates (format: yyyy, yyyy-MM, yyyy-MM-dd, or MM-dd)
+#% guisection: Temporal filter
+#% required: no
+#%end
+#%option
+#% key: date_to
+#% type: string
+#% description: Upper bound of acceptable dates (format: yyyy, yyyy-MM, yyyy-MM-dd, or MM-dd)
+#% required: no
+#%end
+# Import will allways be limited to current region except for latlon locations
+#%flag
+#% key: r
+#% description: Do not limit import to current region (works only in lat/lon)
+#%end
+#%flag
+#% key: p
+#% description: Print result from matching species names and exit
+#% suppress_required: yes
+#%end
+#%flag
+#% key: i
+#% description: Produce individual map for each species
+#%end
+#%flag
+#% key: g
+#% description: Print result from matching species names in shell script style and exit
+#%end
+#%flag
+#% key: o
+#% description: Print number of matching occurrences per species and exit
+#%end
+#%option
+#% key: basisofrecord
+#% type: string
+#% description: Accepted basis of records
+#% guisection: Context filter
+#% required: no
+#% multiple: no
+#% options: ALL,FOSSIL_SPECIMEN,HUMAN_OBSERVATION,LITERATURE,LIVING_SPECIMEN,MACHINE_OBSERVATION,OBSERVATION,PRESERVED_SPECIMEN,UNKNOWN
+#% answer: ALL
+#%end
+#%option
+#% key: rank
+#% type: string
+#% description: Rank of the taxon to search for
+#% required: yes
+#% multiple: no
+#% options: class,cultivar,cultivar_group,domain,family,form,genus,informal,infrageneric_name,infraorder,infraspecific_name,infrasubspecific_name,kingdom,order,phylum,section,series,species,strain,subclass,subfamily,subform,subgenus,subkingdom,suborder,subphylum,subsection,subseries,subspecies,subtribe,subvariety,superclass,superfamily,superorder,superphylum,suprageneric_name,tribe,unranked,variety
+#% answer: species
+#%end
+#%option
+#% key: recordedby
+#% type: string
+#% description: The person who recorded the occurrence.
+#%end
+#%option
+#% key: institutioncode
+#% type: string
+#% description: An identifier of any form assigned by the source to identify the institution the record belongs to.
+#%end
+#%option
+#% key: country
+#% type: string
+#% description: The 2-letter country code (as per ISO-3166-1) of the country in which the occurrence was recorded
+#%end
+#%option
+#% key: continent
+#% type: string
+#% description: The continent in which the occurrence was recorded
+#% options: africa, antarctica, asia, europe, north_america, oceania, south_america
+#%end
+#%flag
+#% key: n
+#% description: Do not limit search to records with coordinates
+#%end
+#%flag
+#% key: s
+#% description: Do also import occurrences with spatial issues
+#%end
+import sys
+import os
+import math
+from osgeo import ogr
+from osgeo import osr
+import grass.script as grass
+from grass.pygrass.vector import Vector
+from grass.pygrass.vector import VectorTopo
+from grass.pygrass.vector.geometry import Point
+from dateutil.parser import parse
+if not os.environ.has_key("GISBASE"):
+ grass.message("You must be in GRASS GIS to run this program.")
+ sys.exit(1)
+try:
+ from pygbif import occurrences
+ from pygbif import species
+except ImportError:
+ grass.fatal(_("Cannot import pygbif (https://github.com/sckott/pygbif)"
+ " library."
+ " Please install it (pip install pygbif)"
+ " or ensure that it is on path"
+ " (use PYTHONPATH variable)."))
+def main():
+ # Parse input options
+ output = options['output']
+ mask = options['mask']
+ species_maps = flags['i']
+ no_region_limit = flags['r']
+ print_species = flags['p']
+ print_species_shell = flags['g']
+ print_occ_number = flags['o']
+ allow_no_geom = flags['n']
+ hasGeoIssue = flags['s']
+ splist = options['species'].split(',')
+ institutionCode = options['institutioncode']
+ basisofrecord = options['basisofrecord']
+ recordedby = options['recordedby'].split(',')
+ date_from = options['date_from']
+ date_to = options['date_to']
+ country = options['country']
+ continent = options['continent']
+ rank = options['rank']
+ # Define static variable
+ # Number of occurrences to fetch in one request
+ chunk_size = 300
+ # lat/lon proj string
+ latlon = '+proj=longlat +no_defs +a=6378137 +rf=298.257223563 +towgs84=0.000,0.000,0.000'
+ # List attributes available in Darwin Core
+ # not all attributes are returned in each request
+ # to avoid key errors when accessing the dictionary returned by pygbif
+ # presence of DWC keys in the returned dictionary is checked using this list
+ # The number of keys in this list has to be equal to the number of columns
+ # in the attribute table and the attributes written for each occurrence
+ dwc_keys = ['key', 'taxonRank', 'taxonKey', 'taxonID', 'scientificName',
+ 'species', 'speciesKey', 'genericName', 'genus', 'genusKey',
+ 'family', 'familyKey', 'order', 'orderKey', 'class',
+ 'classKey', 'phylum', 'phylumKey', 'kingdom', 'kingdomKey',
+ 'eventDate', 'verbatimEventDate', 'startDayOfYear',
+ 'endDayOfYear', 'year', 'month', 'day', 'occurrenceID',
+ 'occurrenceStatus', 'occurrenceRemarks', 'Habitat',
+ 'basisOfRecord', 'preparations', 'sex', 'type', 'locality',
+ 'verbatimLocality', 'decimalLongitude', 'decimalLatitude',
+ 'geodeticDatum', 'higerGeography', 'continent', 'country',
+ 'countryCode', 'stateProvince', 'gbifID', 'protocol',
+ 'identifier', 'recordedBy', 'identificationID', 'identifiers',
+ 'dateIdentified', 'modified', 'institutionCode',
+ 'lastInterpreted', 'lastParsed', 'references', 'relations',
+ 'catalogNumber', 'occurrenceDetails', 'datasetKey',
+ 'datasetName', 'collectionCode', 'rights', 'rightsHolder',
+ 'license', 'publishingOrgKey', 'publishingCountry',
+ 'lastCrawled', 'specificEpithet', 'facts', 'issues',
+ 'extensions', 'language']
+ # Deinfe columns for attribute table
+ cols = [(u'cat', 'INTEGER PRIMARY KEY'),
+ (u'g_key', 'integer'),
+ (u'g_taxonrank', 'varchar(50)'),
+ (u'g_taxonkey', 'integer'),
+ (u'g_taxonid', 'varchar(50)'),
+ (u'g_scientificname', 'varchar(255)'),
+ (u'g_species', 'varchar(255)'),
+ (u'g_specieskey', 'integer'),
+ (u'g_genericname', 'varchar(255)'),
+ (u'g_genus', 'varchar(50)'),
+ (u'g_genuskey', 'integer'),
+ (u'g_family', 'varchar(50)'),
+ (u'g_familykey', 'integer'),
+ (u'g_order', 'varchar(50)'),
+ (u'g_orderkey', 'integer'),
+ (u'g_class', 'varchar(50)'),
+ (u'g_classkey', 'integer'),
+ (u'g_phylum', 'varchar(50)'),
+ (u'g_phylumkey', 'integer'),
+ (u'g_kingdom', 'varchar(50)'),
+ (u'g_kingdomkey', 'integer'),
+ (u'g_eventdate', 'text'),
+ (u'g_verbatimeventdate', 'varchar(50)'),
+ (u'g_startDayOfYear', 'integer'),
+ (u'g_endDayOfYear', 'integer'),
+ (u'g_year', 'integer'),
+ (u'g_month', 'integer'),
+ (u'g_day', 'integer'),
+ (u'g_occurrenceid', 'varchar(255)'),
+ (u'g_occurrenceStatus', 'varchar(50)'),
+ (u'g_occurrenceRemarks', 'varchar(50)'),
+ (u'g_Habitat', 'varchar(50)'),
+ (u'g_basisofrecord', 'varchar(50)'),
+ (u'g_preparations', 'varchar(50)'),
+ (u'g_sex', 'varchar(50)'),
+ (u'g_type', 'varchar(50)'),
+ (u'g_locality', 'varchar(255)'),
+ (u'g_verbatimlocality', 'varchar(255)'),
+ (u'g_decimallongitude', 'double precision'),
+ (u'g_decimallatitude', 'double precision'),
+ (u'g_geodeticdatum', 'varchar(50)'),
+ (u'g_higerGeography', 'varchar(255)'),
+ (u'g_continent', 'varchar(50)'),
+ (u'g_country', 'varchar(50)'),
+ (u'g_countryCode', 'varchar(50)'),
+ (u'g_stateProvince', 'varchar(50)'),
+ (u'g_gbifid', 'varchar(255)'),
+ (u'g_protocol', 'varchar(255)'),
+ (u'g_identifier', 'varchar(50)'),
+ (u'g_recordedby', 'varchar(255)'),
+ (u'g_identificationid', 'varchar(255)'),
+ (u'g_identifiers', 'text'),
+ (u'g_dateidentified', 'text'),
+ (u'g_modified', 'text'),
+ (u'g_institutioncode', 'varchar(50)'),
+ (u'g_lastinterpreted', 'text'),
+ (u'g_lastparsed', 'text'),
+ (u'g_references', 'varchar(255)'),
+ (u'g_relations', 'text'),
+ (u'g_catalognumber', 'varchar(50)'),
+ (u'g_occurrencedetails', 'text'),
+ (u'g_datasetkey', 'varchar(50)'),
+ (u'g_datasetname', 'varchar(255)'),
+ (u'g_collectioncode', 'varchar(50)'),
+ (u'g_rights', 'varchar(255)'),
+ (u'g_rightsholder', 'varchar(255)'),
+ (u'g_license', 'varchar(50)'),
+ (u'g_publishingorgkey', 'varchar(50)'),
+ (u'g_publishingcountry', 'varchar(50)'),
+ (u'g_lastcrawled', 'text'),
+ (u'g_specificepithet', 'varchar(50)'),
+ (u'g_facts', 'text'),
+ (u'g_issues', 'text'),
+ (u'g_extensions', 'text'),
+ (u'g_language', 'varchar(50)')]
+ # Set temporal filter if requested by user
+ # Initialize eventDate filter
+ eventDate = None
+ # Check if date from is compatible (ISO compliant)
+ if date_from:
+ try:
+ parse(date_from)
+ except:
+ grass.fatal("Invalid invalid start date provided")
+ if date_from and not date_to:
+ eventDate = '{}'.format(date_from)
+ # Check if date to is compatible (ISO compliant)
+ if date_to:
+ try:
+ parse(date_to)
+ except:
+ grass.fatal("Invalid invalid end date provided")
+ # Check if date to is after date_from
+ if parse(date_from) < parse(date_to):
+ eventDate = '{},{}'.format(date_from, date_to)
+ else:
+ grass.fatal("Invalid date range: End date has to be after start date!")
+ # Set filter on basisOfRecord if requested by user
+ if basisofrecord == 'ALL':
+ basisOfRecord = None
+ else:
+ basisOfRecord = basisofrecord
+ # Allow also occurrences with spatial issues if requested by user
+ hasGeospatialIssue = False
+ if hasGeoIssue:
+ hasGeospatialIssue = True
+ # Allow also occurrences without coordinates if requested by user
+ hasCoordinate = True
+ if allow_no_geom:
+ hasCoordinate = False
+ # Set reporjection parameters
+ # Set target projection of current LOCATION
+ target = osr.SpatialReference()
+ target.ImportFromProj4(grass.read_command('g.proj', flags='fj'))
+ if target == 'XY location (unprojected)':
+ grass.fatal("Sorry, XY locations are not supported!")
+ # Set source projection from GBIF
+ source = osr.SpatialReference()
+ source.ImportFromEPSG(4326)
+ if target != source:
+ transform = osr.CoordinateTransformation(source, target)
+ reverse_transform = osr.CoordinateTransformation(target, source)
+ # Generate WKT polygon to use for spatial filtering if requested
+ if mask:
+ if len(mask.split('@')) == 2:
+ m = VectorTopo(mask.split('@')[0], mapset=mask.split('@')[1])
+ else:
+ m = VectorTopo(mask)
+ if not m.exist():
+ grass.fatal('Could not find vector map <{}>'.format(mask))
+ m.open('r')
+ if not m.is_open():
+ grass.fatal('Could not open vector map <{}>'.format(mask))
+ # Use map Bbox as spatial filter if map contains <> 1 area
+ if m.number_of('areas') == 1:
+ region_pol = str(m.read(1)).replace('LINESTRING', 'POLYGON(') + ')'
+ else:
+ bbox = str(m.bbox()).replace('Bbox(', '').replace(' ', '').rstrip(')').split(',')
+ region_pol = 'POLYGON(({0} {1}, {0} {3}, {2} {3}, {2} {1}, {0} {1}))'.format(bbox[2],
+ bbox[0], bbox[3], bbox[1])
+ m.close()
+ else:
+ # Do not limit import spatially if LOCATION is able to take global data
+ if no_region_limit:
+ if target != latlon:
+ grass.fatal('Import of data outside the current region is'
+ 'only supported in an WGS84 location!')
+ pol = None
+ else:
+ # Limit import spatially to current region
+ # if LOCATION is !NOT! able to take global data
+ # to avoid pprojection ERRORS
+ region = grass.parse_command('g.region', flags='g')
+ region_pol = 'POLYGON(({0} {1}, {0} {3}, {2} {3}, {2} {1}, {0} {1}))'.format(region['e'],
+ region['n'], region['w'], region['s'])
+ # Do not reproject in latlon LOCATIONS
+ pol = ogr.CreateGeometryFromWkt(region_pol)
+ pol.Transform(reverse_transform)
+ pol = pol.ExportToWkt()
+ else:
+ pol = region_pol
+ # Create output map if not output maps for each species are requested
+ if not species_maps and not print_species and not print_species_shell and not print_occ_number:
+ mapname = output
+ new = Vector(mapname)
+ new.open('w', tab_name=mapname, tab_cols=cols)
+ cat = 1
+ # Import data for each species
+ for s in splist:
+ # Get the taxon key if not the taxon key is provided as input
+ try:
+ key = int(s)
+ except:
+ try:
+ species_match = species.name_backbone(s, rank=rank,
+ strict=False,
+ verbose=True)
+ key = species_match['usageKey']
+ except:
+ grass.error('Data request for taxon {} faild. Are you online?'.format(s))
+ continue
+ # Return matching taxon and alternatives and exit
+ if print_species:
+ print 'Matching taxon for {} is:'.format(s)
+ print species_match['scientificName'] + ' ' + species_match['status']
+ if 'alternatives' in species_match.keys():
+ print 'Alternative matches might be:'.format(s)
+ for m in species_match['alternatives']:
+ print m['scientificName'] + ' ' + m['status']
+ else:
+ print 'No alternatives found for the given taxon'
+ continue
+ if print_species_shell:
+ continue
+ try:
+ returns_n = occurrences.search(taxonKey=key,
+ hasGeospatialIssue=hasGeospatialIssue,
+ hasCoordinate=hasCoordinate,
+ institutionCode=institutionCode,
+ basisOfRecord=basisOfRecord,
+ recordedBy=recordedby,
+ eventDate=eventDate,
+ continent=continent,
+ country=country,
+ geometry=pol,
+ limit=1)['count']
+ except:
+ returns_n = 0
+ # Exit if search does not give a return
+ # Print only number of returns for the given search and exit
+ if print_occ_number:
+ grass.message('Found {0} occurrences for taxon {1}...'.format(returns_n, s))
+ continue
+ elif returns_n <= 0:
+ grass.warning('No occurrences for current search for taxon {0}...'.format(s))
+ continue
+ # Get the number of chunks to download
+ chunks = int(math.ceil(returns_n / float(chunk_size)))
+ grass.verbose('Downloading {0} occurrences for taxon {1}...'.format(returns_n, s))
+ # Create a map for each species if requested using map name as suffix
+ if species_maps:
+ mapname = '{}_{}'.format(s.replace(' ', '_'), output)
+ cat = 1
+ # Download the data from GBIF
+ for c in range(chunks):
+ returns = occurrences.search(taxonKey=key,
+ country=country,
+ geometry=pol,
+ limit=chunk_size,
+ offset=c * chunk_size)
+ # Write the returned data to map and attribute table
+ for res in returns['results']:
+ if source != target:
+ point = ogr.CreateGeometryFromWkt('POINT ({} {})'.format(res['decimalLongitude'], res['decimalLatitude']))
+ point.Transform(transform)
+ x = point.GetX()
+ y = point.GetY()
+ else:
+ x = res['decimalLatitude']
+ x = res['decimalLongitude']
+ point = Point(x, y)
+ for k in dwc_keys:
+ if k not in res.keys():
+ res.update({k: 1})
+ new.write(point, cat=cat, attrs=(
+ res['key'],
+ res['taxonRank'],
+ res['taxonKey'],
+ res['taxonID'],
+ res['scientificName'],
+ res['species'],
+ res['speciesKey'],
+ res['genericName'],
+ res['genus'],
+ res['genusKey'],
+ res['family'],
+ res['familyKey'],
+ res['order'],
+ res['orderKey'],
+ res['class'],
+ res['classKey'],
+ res['phylum'],
+ res['phylumKey'],
+ res['kingdom'],
+ res['kingdomKey'],
+ str(res['eventDate']),
+ str(res['verbatimEventDate']),
+ res['startDayOfYear'],
+ res['endDayOfYear'],
+ res['year'],
+ res['month'],
+ res['day'],
+ res['occurrenceID'],
+ res['occurrenceStatus'],
+ res['occurrenceRemarks'],
+ res['Habitat'],
+ res['basisOfRecord'],
+ res['preparations'],
+ res['sex'],
+ res['type'],
+ res['locality'],
+ res['verbatimLocality'],
+ res['decimalLongitude'],
+ res['decimalLatitude'],
+ res['geodeticDatum'],
+ res['higerGeography'],
+ res['continent'],
+ res['country'],
+ res['countryCode'],
+ res['stateProvince'],
+ res['gbifID'],
+ res['protocol'],
+ res['identifier'],
+ res['recordedBy'],
+ res['identificationID'],
+ ','.join(res['identifiers']),
+ str(res['dateIdentified']),
+ str(res['modified']),
+ res['institutionCode'],
+ str(res['lastInterpreted']),
+ str(res['lastParsed']),
+ res['references'],
+ ','.join(res['relations']),
+ res['catalogNumber'],
+ str(res['occurrenceDetails']),
+ res['datasetKey'],
+ res['datasetName'],
+ res['collectionCode'],
+ res['rights'],
+ res['rightsHolder'],
+ res['license'],
+ res['publishingOrgKey'],
+ res['publishingCountry'],
+ str(res['lastCrawled']),
+ res['specificEpithet'],
+ ','.join(res['facts']),
+ ','.join(res['issues']),
+ ','.join(res['extensions']),
+ res['language'],))
+ cat = cat + 1
+ # Close the current map if a map for each species is requested
+ if species_maps:
+ new.table.conn.commit()
+ new.close
+ # Close the output map if not a map for each species is requested
+ new.close
+# Run the module
+# ToDo: Add an atexit procedure which closes and removes the current map
+if __name__ == "__main__":
+ options, flags = grass.parser()
+ sys.exit(main())
Property changes on: grass-addons/grass7/vector/v.in.pygbif/v.in.pygbif.py
Added: svn:executable
+ text/x-python
+ native
