[GRASS-SVN] r69295 - grass-addons/grass7/vector/v.in.pygbif
Mon Aug 29 02:53:13 PDT 2016
Author: hellik
Date: 2016-08-29 02:53:13 -0700 (Mon, 29 Aug 2016)
New Revision: 69295
   grass-addons/grass7/vector/v.in.pygbif/v.in.pygbif.py
typo fix
Modified: grass-addons/grass7/vector/v.in.pygbif/v.in.pygbif.py
--- grass-addons/grass7/vector/v.in.pygbif/v.in.pygbif.py	2016-08-29 08:34:19 UTC (rev 69294)
+++ grass-addons/grass7/vector/v.in.pygbif/v.in.pygbif.py	2016-08-29 09:53:13 UTC (rev 69295)
@@ -348,7 +348,7 @@
     if allow_no_geom:
         hasCoordinate = False
-    # Set reporjection parameters
+    # Set reprojection parameters
     # Set target projection of current LOCATION
     target = osr.SpatialReference()
     target.ImportFromProj4(grass.read_command('g.proj', flags='fj'))
@@ -424,7 +424,7 @@
                                                       verbose=True)
                 key = species_match['usageKey']
             except:
-                grass.error('Data request for taxon {} faild. Are you online?'.format(s))
+                grass.error('Data request for taxon {} failed. Are you online?'.format(s))
                 continue
         # Return matching taxon and alternatives and exit
