[GRASS-SVN] r69306 - in grass-promo/grassflyer/flyer_2016: . it
svn_grass at osgeo.org
Tue Aug 30 15:48:04 PDT 2016
Author: lucadelu
Date: 2016-08-30 15:48:04 -0700 (Tue, 30 Aug 2016)
New Revision: 69306
Added:
grass-promo/grassflyer/flyer_2016/it/
grass-promo/grassflyer/flyer_2016/it/grass_flyer.svg
grass flyer: add italian translation
Added: grass-promo/grassflyer/flyer_2016/it/grass_flyer.svg
--- grass-promo/grassflyer/flyer_2016/it/grass_flyer.svg (rev 0)
+++ grass-promo/grassflyer/flyer_2016/it/grass_flyer.svg 2016-08-30 22:48:04 UTC (rev 69306)
@@ -0,0 +1,2600 @@
+<?xml version="1.0" encoding="UTF-8" standalone="no"?>
+<!-- Created with Inkscape (http://www.inkscape.org/) -->
+<svg
+ xmlns:dc="http://purl.org/dc/elements/1.1/"
+ xmlns:cc="http://creativecommons.org/ns#"
+ xmlns:rdf="http://www.w3.org/1999/02/22-rdf-syntax-ns#"
+ xmlns:svg="http://www.w3.org/2000/svg"
+ xmlns="http://www.w3.org/2000/svg"
+ xmlns:xlink="http://www.w3.org/1999/xlink"
+ xmlns:sodipodi="http://sodipodi.sourceforge.net/DTD/sodipodi-0.dtd"
+ xmlns:inkscape="http://www.inkscape.org/namespaces/inkscape"
+ width="297mm"
+ height="210mm"
+ id="svg2"
+ version="1.1"
+ inkscape:version="0.91 r13725"
+ sodipodi:docname="grass_flyer.svg"
+ style="enable-background:new">
+ <title
+ id="title4484">GRASS GIS flyer</title>
+ <defs
+ id="defs4">
+ <clipPath
+ id="clipPath17"
+ clipPathUnits="userSpaceOnUse">
+ <path
+ id="path19"
+ d="M 0,792 612,792 612,0 0,0 0,792 Z"
+ inkscape:connector-curvature="0" />
+ </clipPath>
+ <inkscape:perspective
+ id="perspective9"
+ inkscape:persp3d-origin="372.04724 : 350.78739 : 1"
+ inkscape:vp_z="744.09448 : 526.18109 : 1"
+ inkscape:vp_y="0 : 1000 : 0"
+ inkscape:vp_x="0 : 526.18109 : 1"
+ sodipodi:type="inkscape:persp3d" />
+ <filter
+ inkscape:collect="always"
+ id="filter5962">
+ <feBlend
+ mode="multiply"
+ in2="BackgroundImage"
+ id="feBlend5964" />
+ </filter>
+ <filter
+ id="filter6622"
+ x="-0.0075236657"
+ width="1.0150473"
+ y="-0.17736533"
+ height="1.3347307"
+ style="color-interpolation-filters:sRGB">
+ <feGaussianBlur
+ stdDeviation="0.5"
+ id="feGaussianBlur6624" />
+ </filter>
+ <filter
+ id="filter6560"
+ x="-0.0060095498"
+ width="1.0120192"
+ y="-3.7756376"
+ height="8.5512753"
+ <feGaussianBlur
+ stdDeviation="1"
+ id="feGaussianBlur6562" />
+ </filter>
+ <filter
+ id="filter6556"
+ <feGaussianBlur
+ stdDeviation="0.77529968"
+ id="feGaussianBlur6558" />
+ </filter>
+ <filter
+ id="filter6560-2"
+ x="-0.0060095498"
+ width="1.0120192"
+ y="-3.7756376"
+ <feGaussianBlur
+ stdDeviation="1"
+ id="feGaussianBlur6562-2" />
+ </filter>
+ <clipPath
+ id="clipPath8797">
+ <path
+ d="m 209.685,247.95 53.1,0 0,-118.95 -53.1,0 0,118.95 z"
+ id="path8799" />
+ </clipPath>
+ <clipPath
+ id="clipPath8895">
+ <path
+ id="path8897" />
+ </clipPath>
+ <filter
+ id="filter5962-7-1-6"
+ <feBlend
+ mode="multiply"
+ id="feBlend5964-9-0-9" />
+ </filter>
+ <filter
+ id="filter7257"
+ inkscape:label="Duotone"
+ inkscape:menu="Color"
+ inkscape:menu-tooltip="Change colors to a duotone palette"
+ height="1"
+ width="1"
+ y="0"
+ x="0"
+ <feColorMatrix
+ id="feColorMatrix7259"
+ type="saturate"
+ values="0"
+ result="result1" />
+ <feFlood
+ id="feFlood7261"
+ flood-color="rgb(0,117,0)"
+ result="result2"
+ flood-opacity="1" />
+ <feBlend
+ id="feBlend7263"
+ in2="result1"
+ mode="screen"
+ result="result2" />
+ <feComposite
+ id="feComposite7265"
+ in2="SourceGraphic"
+ in="result2" />
+ </filter>
+ <filter
+ id="filter7267"
+ height="1"
+ width="1"
+ y="0"
+ x="0"
+ <feColorMatrix
+ id="feColorMatrix7269"
+ type="saturate"
+ values="0"
+ <feFlood
+ id="feFlood7271"
+ flood-color="rgb(9,111,152)"
+ <feBlend
+ id="feBlend7273"
+ in2="result1"
+ mode="screen"
+ <feComposite
+ id="feComposite7275"
+ operator="in"
+ in="result2" />
+ </filter>
+ <filter
+ inkscape:menu-tooltip="Render in shades of gray by reducing saturation to zero"
+ height="1"
+ width="1"
+ y="0"
+ x="0"
+ inkscape:label="Desaturate"
+ id="filter4295"
+ <feColorMatrix
+ values="0"
+ type="saturate"
+ id="feColorMatrix4297" />
+ </filter>
+ <clipPath
+ id="clipPath17-5"
+ <path
+ id="path19-0"
+ </clipPath>
+ </defs>
+ <sodipodi:namedview
+ id="base"
+ pagecolor="#ffffff"
+ bordercolor="#666666"
+ borderopacity="1.0"
+ inkscape:pageopacity="0.0"
+ inkscape:pageshadow="2"
+ inkscape:zoom="2"
+ inkscape:cx="1651.6753"
+ inkscape:cy="500.67957"
+ inkscape:document-units="mm"
+ inkscape:current-layer="g4729"
+ showgrid="false"
+ units="mm"
+ inkscape:window-width="3200"
+ inkscape:window-height="1671"
+ inkscape:window-x="0"
+ inkscape:window-y="55"
+ inkscape:window-maximized="1"
+ inkscape:snap-grids="false"
+ inkscape:snap-text-baseline="true"
+ inkscape:snap-global="false">
+ <inkscape:grid
+ type="xygrid"
+ id="grid4586"
+ empspacing="2"
+ visible="true"
+ enabled="true"
+ snapvisiblegridlinesonly="true"
+ color="#e0e0e0"
+ opacity="0.07843137"
+ empcolor="#e0e0e0"
+ empopacity="0.8"
+ dotted="true"
+ units="mm"
+ spacingx="5mm"
+ spacingy="5mm" />
+ </sodipodi:namedview>
+ <metadata
+ id="metadata7">
+ <rdf:RDF>
+ <cc:Work
+ rdf:about="">
+ <dc:format>image/svg+xml</dc:format>
+ <dc:type
+ rdf:resource="http://purl.org/dc/dcmitype/StillImage" />
+ <dc:title>GRASS GIS flyer</dc:title>
+ <dc:date>20160823</dc:date>
+ <dc:creator>
+ <cc:Agent>
+ <dc:title>Vincent Bain</dc:title>
+ </cc:Agent>
+ </dc:creator>
+ <dc:description>Cosmetic renewal of the historical GRASS GIS leaflet.</dc:description>
+ <dc:contributor>
+ <cc:Agent>
+ <dc:title>Markus Neteler, Luca Delucchi, GRASS development team</dc:title>
+ </cc:Agent>
+ </dc:contributor>
+ <cc:license
+ rdf:resource="http://creativecommons.org/publicdomain/zero/1.0/" />
+ </cc:Work>
+ <cc:License
+ rdf:about="http://creativecommons.org/publicdomain/zero/1.0/">
+ <cc:permits
+ rdf:resource="http://creativecommons.org/ns#Reproduction" />
+ <cc:permits
+ rdf:resource="http://creativecommons.org/ns#Distribution" />
+ <cc:permits
+ rdf:resource="http://creativecommons.org/ns#DerivativeWorks" />
+ </cc:License>
+ </rdf:RDF>
+ </metadata>
+ <g
+ inkscape:groupmode="layer"
+ id="layer2"
+ inkscape:label="fondgris"
+ style="display:none"
+ sodipodi:insensitive="true">
+ <image
+ y="794.48138"
+ x="-74.144997"
+ id="image5957"
+ xlink:href="file:///home/vincent/Documents/developpement/grass/grass_splash/GRASSGIS_worldnb.jpg"
+ height="601.93134"
+ width="1274.397" />
+ </g>
+ <g
+ id="layer6"
+ inkscape:label="fond+reperes"
+ style="display:inline">
+ <image
+ sodipodi:absref="/home/lucadelu/compilati/grass-promo/grassflyer/flyer_2016/it/../images/grass_world.png"
+ xlink:href="../images/grass_world.png"
+ inkscape:export-ydpi="300"
+ inkscape:export-xdpi="300"
+ inkscape:export-filename="/home/vincent/Bureau/recto.png"
+ width="1052.3622"
+ height="248.4808"
+ id="image7714"
+ x="0"
+ y="247.58218" />
+ <rect
+ style="color:#000000;display:inline;overflow:visible;visibility:visible;fill:none;stroke:#bdbdbd;stroke-width:0.25;stroke-linecap:round;stroke-linejoin:round;stroke-miterlimit:4;stroke-dasharray:none;stroke-dashoffset:0;stroke-opacity:1;marker:none;enable-background:accumulate"
+ id="rect6689"
+ width="1052.3622"
+ height="744.09448"
+ x="1169.4164"
+ y="-0.125"
+ inkscape:export-filename="/home/vincent/Bureau/verso.png"
+ inkscape:export-ydpi="300" />
+ <path
+ style="color:#000000;display:inline;overflow:visible;visibility:visible;fill:#bdbdbd;fill-opacity:1;fill-rule:nonzero;stroke:none;stroke-width:0.625;marker:none;filter:url(#filter5962);enable-background:accumulate"
+ d="m 1169.2913,248.03149 17.7166,0"
+ id="path6580"
+ sodipodi:nodetypes="cc"
+ <path
+ style="color:#000000;display:inline;overflow:visible;visibility:visible;fill:none;stroke:#bdbdbd;stroke-width:0.25;stroke-miterlimit:4;stroke-dasharray:none;stroke-opacity:1;marker:none;filter:url(#filter5962);enable-background:accumulate"
+ d="m 1169.2913,247.88145 17.7166,0"
+ id="path6606"
+ <path
+ id="path6619"
+ d="m 1169.4163,256.73975 0,-17.7166"
+ <path
+ d="m 1168.9373,495.66815 17.7166,0"
+ id="path6580-1"
+ <path
+ d="m 1171.213,495.91299 17.7166,0"
+ id="path6606-1"
+ transform="matrix(0.830042,0,0,-4.5670384,198.86569,2760.5364)"
+ <path
+ id="path6619-6"
+ d="m 1169.4163,504.77125 0,-17.7166"
+ <path
+ d="m 2221.9036,495.91295 -17.7166,0"
+ id="path6606-3"
+ <path
+ id="path6619-7"
+ d="m 2221.7785,487.05465 0,17.7166"
+ <path
+ d="m 2221.7786,247.88141 -17.7166,0"
+ id="path6606-1-5"
+ <path
+ id="path6619-6-2"
+ d="m 2221.7785,239.02315 0,17.7166"
+ <rect
+ id="rect6689-9"
+ width="1052.3622"
+ x="0"
+ y="0"
+ </g>
+ <g
+ id="layer7"
+ inkscape:label="titre"
+ <g
+ id="g6536"
+ style="display:inline;fill:#000000;fill-opacity:1;filter:url(#filter6556)"
+ transform="matrix(1.9742866,0,0,1.9742866,-283.26887,-1367.287)"
+ inkscape:export-ydpi="300">
+ <path
+ inkscape:export-filename="/home/vincent/Documents/developpement/grass/grass_splash/synthese.png"
+ id="path6538"
+ d="m 220.80426,923.33891 2.19326,2.22604 0.74804,-0.80282 -1.3371,-9.9627 0.1136,-1.60874 0.68248,-2.40496 0.71498,-2.21 0.78,-1.73872 2.53498,4.25746 2.46998,4.5012 0.54842,2.64162 3.44698,-3.38202 1.74076,-13.0882 3.6562,-17.71232 2.35624,-12.02488 4.77744,-9.47364 0.715,-1.96624 0.26,-1.15372 0.0974,-1.86874 -0.2925,-1.49498 -0.6825,-1.34874 -1.25124,-1.25124 0.065,0.34126 0.61748,0.63374 0.56876,1.33248 0.065,1.07248 -0.78,2.14498 -1.00748,2.30748 -2.16124,3.88372 1.2025,-8.96992 0.34124,-4.71244 -0.43874,-0.0814 -2.42124,16.11984 -0.455,0.81248 -3.9812,7.49118 -5.0862,10.0749 -4.2737,8.7424 -2.37248,6.09368 -1.34874,-2.30748 0.84502,-1.73872 4.64744,-8.92116 4.71246,-7.86492 1.96622,-3.83494 1.62498,-3.18498 0.43876,-1.08874 0.0974,-1.05624 -0.195,-0.8125 -0.195,0 -0.1462,0.715 -0.8125,1.86874 -1.96622,3.31496 -5.62244,8.6449 -3.20122,4.74496 -2.19374,3.8837 1.34874,-13.3736 0.50374,-5.7037 0.21126,-12.05736 -0.0326,0 0.0976,-0.40624 0.30874,-0.7475 0.24374,-0.68248 0.
2925,-0.50376 0,-0.99124 -0.0974,-1.25124 0.43874,-0.81248 -0.195,-1.18624 0,-0.89374 0.1624,-0.50376 0.34126,-1.12122 0.24374,-0.60126 -0.45498,-0.74748 0.38998,-0.74748 -0.61748,-0.43876 -0.37376,-1.12124 0.53624,-0.87748 -0.74748,-0.24376 -0.325,-0.58498 0,-0.50376 -0.34124,-0.56874 -0.34126,-0.30876 0.0326,-0.47124 0,-0.51998 -0.1624,-1.41374 -0.1138,-0.8125 -0.50376,-0.37374 -0.24374,-0.43874 -0.56874,-0.27624 -0.34124,-0.6175 0.065,-0.69876 -0.065,-0.71498 -0.37376,-0.6175 -0.64998,-0.13 -0.60126,-0.21126 -0.30874,-0.43874 -0.21124,-0.47124 -0.47124,0.30874 -0.195,0.60124 -0.0974,0.65 -0.30874,1.02374 -0.21124,-0.34124 0.0976,1.25122 -0.065,0.27626 0,0.47124 0.1788,0.37374 0.1626,0.50376 0.30874,0.40624 0.13,0.1788 0.0974,0.47124 -0.39,0.2925 0.1624,0.4225 -0.37374,0.47124 0.065,0.37376 0.0976,0.37374 0.30874,0.37374 0.27624,0.34126 0.37374,0.325 0.065,0.27624 -0.13,0.40624 -0.30874,0.27626 -0.1462,0.2275 0.0488,0.58498 0.47126,0.30876 0.27624,0.2925 0.1626,0.58498 -0.50374,0.
60126 -0.0814,0.42248 0.21124,0.47124 0.30874,0.37374 0,0.37374 0.2275,0.2925 0.21124,0.24376 0.1624,0.27624 -0.0976,0.47126 0.30874,0.43874 0.27626,0.065 0.0976,0.21124 -0.0976,0.37376 0.26,0.53624 0.27624,0.21124 0.21124,0.43876 -0.21124,0.74748 0.30874,0.6825 0.2925,0.13 0.1462,0.30874 0.065,0.8775 -0.1624,0.37374 -0.1462,0.43876 0.43874,2.20996 0.77998,0.50374 -0.065,9.5874 -0.91,10.35114 -0.53624,5.99618 -0.87748,7.27992 -0.34124,0.8775 -2.89248,-4.9562 -0.99124,-6.64618 -1.28374,-10.78988 -1.52748,-10.0099 0.1138,9.1324 0.53628,7.55618 0.92624,7.19866 -6.45118,-10.22112 -9.2624,-13.89362 -2.12872,-2.95746 -0.1788,0 0.6175,1.77124 1.15372,2.87622 1.69,3.83496 2.95746,6.33742 1.78748,3.18496 2.20998,3.83496 4.5662,7.23118 4.12746,6.56494 0.63374,5.88242 1.96622,13.43862 -0.001,-0.008 -2.27376,-7.06034 -4.80994,-11.84612 -3.83498,-7.96242 -5.0862,-8.27116 -2.58372,-3.3962 -2.06372,-2.06374 -3.36372,-3.11996 1.39748,1.72248 2.25874,2.30748 1.33248,1.49498 0.8775,1.52748 1.05624,1.
68998 1.72248,2.95746 1.49498,2.74622 1.52748,3.39624 1.86872,4.53368 3.65622,9.4574 3.83496,9.9774 2.30748,7.05242 z m -6.72904,-6.69958 -0.66916,-1.79114 -1.235,-2.33996 -2.69748,-5.1512 -3.80246,-6.85744 -2.6812,-4.4037 -2.48624,-3.80246 -1.34874,-1.86872 -1.12124,-1.12124 1.93374,3.67246 1.77124,4.1112 2.66498,6.0612 1.16998,2.6812 1.17202,3.48548 z m -16.04152,-27.33586 -0.0326,-0.065 -0.0976,-0.065 z m 40.80334,-12.23612 -0.65,2.7137 -2.94122,11.7649 -1.43,6.67866 -1.49496,8.07618 -1.6575,5.26494 -0.58498,-1.36498 -3.76996,-6.98742 1.26748,-2.94124 4.12746,-8.6449 2.20998,-4.64744 2.95746,-6.23996 z m 3.6562,8.75864 -0.53624,3.11998 -1.52748,5.18368 -1.5275,3.83496 -1.68996,4.9887 -0.89376,4.90746 -0.84498,5.2172 3.05496,-3.10472 0.13,-1.59248 0.34126,-2.76248 0.81248,-3.89996 1.77122,-6.97118 0.8125,-5.16744 z m -21.87226,14.2186 1.23498,2.06374 -0.26,4.80994 -0.195,0.1462 z m 2.07998,3.46122 0.715,1.18624 -0.55252,1.3 -0.40624,0.29248 z"
+ style="display:inline;fill:#000000;fill-opacity:1;stroke:none;filter:url(#filter5386)"
+ sodipodi:nodetypes="cccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccc" />
+ <path
+ style="color:#000000;display:inline;overflow:visible;visibility:visible;fill:#000000;fill-opacity:1;stroke:none;stroke-width:0.82688445;marker:none;filter:url(#filter5386);enable-background:accumulate"
+ d="m 184.24358,890.36609 -1.55998,1.55998 11.71614,11.71612 -1.54374,1.54374 11.69988,11.69988 -1.55998,1.55998 20.00354,20.00354 20.0198,-20.00354 -1.56,-1.55998 11.69988,-11.69988 -1.54374,-1.54374 11.71614,-11.71612 -1.56,-1.55998 -38.77208,38.75584 -38.75586,-38.75584 z"
+ id="path6540" />
+ <path
+ style="color:#000000;display:inline;overflow:visible;visibility:visible;fill:#000000;fill-opacity:1;stroke:none;stroke-width:0.80000001;marker:none;filter:url(#filter5386);enable-background:accumulate"
+ d="m 222.99944,828.82799 -48.5545,48.57074 48.5545,48.57074 48.57074,-48.57074 -48.57074,-48.57074 z m 0,0.86124 47.70948,47.7095 -47.70948,47.70948 -47.7095,-47.70948 47.7095,-47.7095 z"
+ id="path6542" />
+ </g>
+ <g
+ id="g6531"
+ <path
+ style="display:inline;fill:#ffffff;fill-opacity:1;stroke:none;filter:url(#filter5386)"
+ id="path6419"
+ <path
+ id="path6421"
+ style="color:#000000;display:inline;overflow:visible;visibility:visible;fill:#ffffff;fill-opacity:1;stroke:none;stroke-width:0.82688445;marker:none;filter:url(#filter5386);enable-background:accumulate"
+ <path
+ id="path6423"
+ style="color:#000000;display:inline;overflow:visible;visibility:visible;fill:#ffffff;fill-opacity:1;stroke:none;stroke-width:0.80000001;marker:none;filter:url(#filter5386);enable-background:accumulate"
+ </g>
+ <g
+ style="display:inline;fill:#000000;fill-opacity:1;filter:url(#filter6560)"
+ id="g6425"
+ transform="matrix(1.307969,0,0,1.307969,11.983,-3.5485764)">
+ <path
+ sodipodi:nodetypes="ccccc"
+ id="path6427"
+ d="m -1.2824118,210.40625 0,1.25 99.9383648,0 0,-1.25 z"
+ style="color:#000000;font-style:normal;font-variant:normal;font-weight:normal;font-stretch:normal;font-size:medium;line-height:normal;font-family:Sans;-inkscape-font-specification:Sans;text-indent:0;text-align:start;text-decoration:none;text-decoration-line:none;letter-spacing:normal;word-spacing:normal;text-transform:none;direction:ltr;block-progression:tb;writing-mode:lr-tb;baseline-shift:baseline;text-anchor:start;display:inline;overflow:visible;visibility:visible;fill:#000000;fill-opacity:1;stroke:none;stroke-width:1.25;marker:none;enable-background:accumulate" />
+ <path
+ d="m 123.30483,210.40625 0,1.25 660.75394,0 0,-1.25 z"
+ id="path6429"
+ </g>
+ <flowRoot
+ xml:space="preserve"
+ id="flowRoot6475"
+ style="font-style:normal;font-variant:normal;font-weight:normal;font-stretch:normal;font-size:22.18499565px;line-height:125%;font-family:'EB Garamond';-inkscape-font-specification:'EB Garamond';text-align:start;letter-spacing:0px;word-spacing:0px;writing-mode:lr-tb;text-anchor:start;display:inline;fill:#000000;fill-opacity:1;stroke:none;filter:url(#filter6622)"
+ transform="matrix(1.3071898,0,0,1.3071898,56.5381,95.02076)"
+ inkscape:export-ydpi="300"><flowRegion
+ id="flowRegion6477"><rect
+ id="rect6479"
+ width="472.69949"
+ height="27.879639"
+ x="268.00415"
+ y="258.24249"
+ style="font-style:normal;font-variant:normal;font-weight:normal;font-stretch:normal;font-size:22.18499565px;line-height:125%;font-family:'EB Garamond';-inkscape-font-specification:'EB Garamond';text-align:start;writing-mode:lr-tb;text-anchor:start;fill:#000000;fill-opacity:1" /></flowRegion><flowPara
+ id="flowPara6481">Bringing advanced geospatial technologies to the world</flowPara></flowRoot> <g
+ id="g6564"
+ style="display:inline;fill:#ffffff;fill-opacity:1"
+ <path
+ style="color:#000000;font-style:normal;font-variant:normal;font-weight:normal;font-stretch:normal;font-size:medium;line-height:normal;font-family:Sans;-inkscape-font-specification:Sans;text-indent:0;text-align:start;text-decoration:none;text-decoration-line:none;letter-spacing:normal;word-spacing:normal;text-transform:none;direction:ltr;block-progression:tb;writing-mode:lr-tb;baseline-shift:baseline;text-anchor:start;display:inline;overflow:visible;visibility:visible;fill:#ffffff;fill-opacity:1;stroke:none;stroke-width:1.25;marker:none;enable-background:accumulate"
+ id="path6566"
+ sodipodi:nodetypes="ccccc" />
+ <path
+ id="path6568"
+ </g>
+ <g
+ style="display:inline;fill:#000000;fill-opacity:1;filter:url(#filter6560-2)"
+ id="g6425-2"
+ transform="matrix(1.307969,0,0,1.307969,11.983,203.03592)">
+ <path
+ id="path6427-9"
+ <path
+ id="path6429-3"
+ </g>
+ <g
+ id="g6564-7"
+ <path
+ id="path6566-1"
+ <path
+ id="path6568-8"
+ </g>
+ <g
+ style="display:inline;filter:url(#filter6622)"
+ id="g3772"
+ transform="matrix(4.792575,0,0,4.792575,-941.78106,-2255.1216)"
+ <flowRoot
+ style="font-style:normal;font-variant:normal;font-weight:normal;font-stretch:normal;font-size:17.27698898px;line-height:125%;font-family:'Fira Sans';-inkscape-font-specification:'Fira Sans';text-align:start;letter-spacing:0px;word-spacing:0px;writing-mode:lr-tb;text-anchor:start;fill:#000000;fill-opacity:1;stroke:#000000;stroke-width:0.25;stroke-linecap:round;stroke-linejoin:round;stroke-miterlimit:4;stroke-dasharray:none;stroke-opacity:1"
+ id="flowRoot3774"
+ inkscape:export-filename="/home/vincent/Documents/developpement/grass/grass_splash/logo/logo_variant_bg.png"
+ inkscape:export-xdpi="600"
+ inkscape:export-ydpi="600"
+ transform="translate(-4.5904342,0)"><flowRegion
+ id="flowRegion3776"
+ style="stroke-width:0.25"><rect
+ style="font-style:normal;font-variant:normal;font-weight:normal;font-stretch:normal;font-size:17.27698898px;line-height:125%;font-family:'Fira Sans';-inkscape-font-specification:'Fira Sans';text-align:start;writing-mode:lr-tb;text-anchor:start;stroke:#000000;stroke-width:0.19632943;stroke-linecap:round;stroke-linejoin:round;stroke-miterlimit:4;stroke-dasharray:none;stroke-opacity:1"
+ y="528.00189"
+ x="337.6904"
+ height="20.501133"
+ width="70.314125"
+ id="rect3778" /></flowRegion><flowPara
+ id="flowPara3780"
+ style="font-style:normal;font-variant:normal;font-weight:500;font-stretch:normal;font-size:17.27698898px;line-height:125%;font-family:'Fira Sans';-inkscape-font-specification:'Fira Sans Medium';text-align:start;letter-spacing:-1.39747596px;writing-mode:lr-tb;text-anchor:start;stroke:#000000;stroke-width:0.25;stroke-linecap:round;stroke-linejoin:round;stroke-miterlimit:4;stroke-dasharray:none;stroke-opacity:1">G<flowSpan
+ id="flowSpan3782"
+ style="letter-spacing:0px;stroke:#000000;stroke-width:0.25;stroke-linecap:round;stroke-linejoin:round;stroke-miterlimit:4;stroke-dasharray:none;stroke-opacity:1">RASS</flowSpan></flowPara></flowRoot> <flowRoot
+ id="flowRoot3784"
+ style="font-style:normal;font-variant:normal;font-weight:100;font-stretch:normal;font-size:21.99999809px;line-height:125%;font-family:'Fira Sans';-inkscape-font-specification:'Fira Sans Thin';text-align:start;letter-spacing:0px;word-spacing:0px;writing-mode:lr-tb;text-anchor:start;fill:#000000;fill-opacity:1;stroke:#000000;stroke-width:0.31834248;stroke-linecap:round;stroke-linejoin:round;stroke-miterlimit:4;stroke-dasharray:none;stroke-opacity:1"
+ transform="matrix(0.78531774,0,0,0.78531774,106.84321,422.66469)"
+ inkscape:export-ydpi="600"><flowRegion
+ id="flowRegion3786"><rect
+ id="rect3788"
+ width="89.535889"
+ height="26.105526"
+ x="358.83777"
+ y="134.13319"
+ style="font-style:normal;font-variant:normal;font-weight:100;font-stretch:normal;font-size:21.99999809px;line-height:125%;font-family:'Fira Sans';-inkscape-font-specification:'Fira Sans Thin';text-align:start;writing-mode:lr-tb;text-anchor:start;stroke:#000000;stroke-width:0.31834248;stroke-linecap:round;stroke-linejoin:round;stroke-miterlimit:4;stroke-dasharray:none;stroke-opacity:1" /></flowRegion><flowPara
+ style="font-style:normal;font-variant:normal;font-weight:100;font-stretch:normal;font-size:21.99999809px;line-height:125%;font-family:'Fira Sans';-inkscape-font-specification:'Fira Sans Thin';text-align:start;letter-spacing:-1.77950382px;writing-mode:lr-tb;text-anchor:start;stroke:#000000;stroke-width:0.31834248;stroke-linecap:round;stroke-linejoin:round;stroke-miterlimit:4;stroke-dasharray:none;stroke-opacity:1"
+ id="flowPara3790">GIS</flowPara></flowRoot> </g>
+ <g
+ transform="matrix(4.792575,0,0,4.792575,-941.78106,-2273.9889)"
+ id="g4549-4"
+ <flowRoot
+ id="flowRoot5356-9"
+ style="font-style:normal;font-variant:normal;font-weight:normal;font-stretch:normal;font-size:17.27698898px;line-height:125%;font-family:'Fira Sans';-inkscape-font-specification:'Fira Sans';text-align:start;letter-spacing:0px;word-spacing:0px;writing-mode:lr-tb;text-anchor:start;fill:#ffffff;fill-opacity:1;stroke:#ffffff;stroke-width:0.25;stroke-linecap:round;stroke-linejoin:round;stroke-miterlimit:4;stroke-dasharray:none;stroke-opacity:1"
+ transform="translate(-5.4250586,0)"><flowRegion
+ id="flowRegion5358-9"
+ id="rect5360-1"
+ width="70.314125"
+ x="337.6904"
+ y="531.93866"
+ style="font-style:normal;font-variant:normal;font-weight:normal;font-stretch:normal;font-size:17.27698898px;line-height:125%;font-family:'Fira Sans';-inkscape-font-specification:'Fira Sans';text-align:start;writing-mode:lr-tb;text-anchor:start;fill:#ffffff;fill-opacity:1;stroke:#ffffff;stroke-width:0.19632943;stroke-linecap:round;stroke-linejoin:round;stroke-miterlimit:4;stroke-dasharray:none;stroke-opacity:1" /></flowRegion><flowPara
+ style="font-style:normal;font-variant:normal;font-weight:500;font-stretch:normal;font-size:17.27698898px;line-height:125%;font-family:'Fira Sans';-inkscape-font-specification:'Fira Sans Medium';text-align:start;letter-spacing:-1.39747596px;writing-mode:lr-tb;text-anchor:start;fill:#ffffff;fill-opacity:1;stroke:#ffffff;stroke-width:0.25;stroke-linecap:round;stroke-linejoin:round;stroke-miterlimit:4;stroke-dasharray:none;stroke-opacity:1"
+ id="flowPara5362-7">G<flowSpan
+ style="letter-spacing:0px;fill:#ffffff;fill-opacity:1;stroke:#ffffff;stroke-width:0.25;stroke-linecap:round;stroke-linejoin:round;stroke-miterlimit:4;stroke-dasharray:none;stroke-opacity:1"
+ id="flowSpan4547-4">RASS</flowSpan></flowPara></flowRoot> <flowRoot
+ style="font-style:normal;font-variant:normal;font-weight:100;font-stretch:normal;font-size:21.99999809px;line-height:125%;font-family:'Fira Sans';-inkscape-font-specification:'Fira Sans Thin';text-align:start;letter-spacing:0px;word-spacing:0px;writing-mode:lr-tb;text-anchor:start;fill:#ffffff;fill-opacity:1;stroke:#ffffff;stroke-width:0.31834248;stroke-linecap:round;stroke-linejoin:round;stroke-miterlimit:4;stroke-dasharray:none;stroke-opacity:1"
+ id="flowRoot6517-2"
+ transform="matrix(0.78531774,0,0,0.78531774,106.84321,426.60146)"><flowRegion
+ id="flowRegion6519-8"><rect
+ style="font-style:normal;font-variant:normal;font-weight:100;font-stretch:normal;font-size:21.99999809px;line-height:125%;font-family:'Fira Sans';-inkscape-font-specification:'Fira Sans Thin';text-align:start;writing-mode:lr-tb;text-anchor:start;fill:#ffffff;fill-opacity:1;stroke:#ffffff;stroke-width:0.31834248;stroke-linecap:round;stroke-linejoin:round;stroke-miterlimit:4;stroke-dasharray:none;stroke-opacity:1"
+ y="134.13319"
+ x="358.83777"
+ width="89.535889"
+ id="rect6521-4" /></flowRegion><flowPara
+ id="flowPara6523-2"
+ style="font-style:normal;font-variant:normal;font-weight:100;font-stretch:normal;font-size:21.99999809px;line-height:125%;font-family:'Fira Sans';-inkscape-font-specification:'Fira Sans Thin';text-align:start;letter-spacing:-1.77950382px;writing-mode:lr-tb;text-anchor:start;fill:#ffffff;fill-opacity:1;stroke:#ffffff;stroke-width:0.31834248;stroke-linecap:round;stroke-linejoin:round;stroke-miterlimit:4;stroke-dasharray:none;stroke-opacity:1">GIS</flowPara></flowRoot> </g>
+ <text
+ style="font-style:normal;font-variant:normal;font-weight:normal;font-stretch:normal;font-size:29px;line-height:125%;font-family:'EB Garamond';-inkscape-font-specification:'EB Garamond';text-align:start;letter-spacing:0px;word-spacing:0px;writing-mode:lr-tb;text-anchor:start;display:inline;fill:#ffffff;fill-opacity:1;stroke:none"
+ x="230.86496"
+ y="458.92001"
+ id="text4656-8"
+ sodipodi:linespacing="125%"
+ inkscape:export-ydpi="300"><tspan
+ sodipodi:role="line"
+ id="tspan4658-7"
+ x="230.86496"
+ y="458.92001">Bringing advanced geospatial technologies to the world</tspan></text>
+ </g>
+ <g
+ inkscape:label="texte"
+ id="layer1"
+ transform="translate(0,-308.2677)"
+ <g
+ id="g6499"
+ transform="translate(36.263086,261.59024)"
+ <path
+ transform="matrix(0.95868236,0,0,0.95868236,926.2537,-550.93614)"
+ style="display:inline;fill:#bdbdbd;fill-opacity:1;stroke:none"
+ d="m 246.92085,1205.893 1.3982,1.4191 0.47689,-0.5118 -0.85242,-6.3513 0.0725,-1.0256 0.4351,-1.5332 0.45581,-1.4088 0.49725,-1.1085 1.61606,2.7142 1.57462,2.8695 0.34963,1.684 2.19746,-2.156 1.10975,-8.3438 2.33086,-11.2917 1.50211,-7.666 3.04565,-6.0395 0.45581,-1.2534 0.16575,-0.7356 0.0622,-1.1913 -0.18647,-0.953 -0.43509,-0.8599 -0.79767,-0.7976 0.0414,0.2175 0.39365,0.404 0.36258,0.8495 0.0414,0.6837 -0.49725,1.3674 -0.64228,1.4711 -1.37779,2.4759 0.76659,-5.7184 0.21755,-3.0042 -0.2797,-0.052 -1.54355,10.2765 -0.29006,0.5179 -2.53805,4.7757 -3.24248,6.4228 -2.72451,5.5733 -1.51247,3.8848 -0.85983,-1.471 0.53869,-1.1085 2.96278,-5.6873 3.00422,-5.0139 1.25348,-2.4448 1.03594,-2.0304 0.2797,-0.6941 0.0622,-0.6734 -0.12431,-0.518 -0.12432,0 -0.0932,0.4559 -0.51796,1.1913 -1.25349,2.1133 -3.58434,5.5112 -2.04079,3.0249 -1.39852,2.4759 0.85983,-8.5258 0.32114,-3.6361 0.13467,-7.6866 -0.0207,0 0.0622,-0.259 0.19683,-0.4766 0.15539,-0.435 0.18647,-0.3212 0,-0.6319 -0.0622,-
0.7977 0.2797,-0.5179 -0.12431,-0.7563 0,-0.5697 0.10359,-0.3212 0.21753,-0.7148 0.1554,-0.3833 -0.29007,-0.4765 0.24863,-0.4765 -0.39366,-0.2797 -0.23826,-0.7148 0.34186,-0.5594 -0.47654,-0.1554 -0.20718,-0.373 0,-0.3211 -0.21755,-0.3626 -0.21755,-0.1968 0.0207,-0.3004 0,-0.3315 -0.1036,-0.9013 -0.0725,-0.518 -0.32114,-0.2382 -0.15539,-0.2797 -0.36257,-0.1762 -0.21755,-0.3936 0.0414,-0.4455 -0.0414,-0.4558 -0.23827,-0.3936 -0.41437,-0.083 -0.3833,-0.1347 -0.19682,-0.2797 -0.13468,-0.3004 -0.30042,0.1968 -0.12431,0.3833 -0.0622,0.4144 -0.19683,0.6526 -0.13467,-0.2175 0.0622,0.7977 -0.0414,0.1761 0,0.3004 0.11396,0.2383 0.10359,0.3211 0.19683,0.259 0.0829,0.1139 0.0622,0.3005 -0.24863,0.1864 0.1036,0.2694 -0.23827,0.3004 0.0414,0.2383 0.0622,0.2382 0.19683,0.2383 0.17611,0.2175 0.23826,0.2072 0.0414,0.1761 -0.0829,0.259 -0.19683,0.1761 -0.0932,0.1451 0.0311,0.3729 0.30043,0.1968 0.17611,0.1865 0.10359,0.3729 -0.32114,0.3833 -0.0518,0.2694 0.13467,0.3004 0.19683,0.2383 0,0.2382 0.1450
3,0.1865 0.13467,0.1554 0.10359,0.1761 -0.0622,0.3004 0.19683,0.2797 0.17611,0.042 0.0622,0.1346 -0.0622,0.2383 0.16575,0.3418 0.17611,0.1347 0.13467,0.2797 -0.13467,0.4766 0.19683,0.435 0.18647,0.083 0.0932,0.1969 0.0414,0.5594 -0.1036,0.2382 -0.0932,0.2797 0.27971,1.4089 0.49725,0.3211 -0.0414,6.1121 -0.58013,6.5989 -0.34186,3.8226 -0.5594,4.641 -0.21755,0.5594 -1.84397,-3.1596 -0.63192,-4.237 -0.81839,-6.8786 -0.97378,-6.3814 0.0725,5.822 0.34188,4.8171 0.59048,4.5892 -4.11267,-6.5161 -5.90483,-8.8572 -1.35708,-1.8854 -0.11395,0 0.39365,1.1292 0.73552,1.8336 1.07737,2.4448 1.88541,4.0401 1.13953,2.0305 1.40887,2.4448 2.91098,4.6099 2.63128,4.1852 0.40401,3.7501 1.25349,8.5671 -6.6e-4,-0.01 -1.44954,-4.501 -3.06637,-7.552 -2.44481,-5.0761 -3.24248,-5.2729 -1.64714,-2.1651 -1.31564,-1.3156 -2.14439,-1.989 0.89091,1.0981 1.43995,1.471 0.84946,0.9531 0.55941,0.9737 0.67336,1.0774 1.09809,1.8854 0.95306,1.7508 0.97378,2.1651 1.19133,2.8902 2.33086,6.0292 2.44481,6.3606 1.47103,4.496 z
m -4.28981,-4.2711 -0.4266,-1.1418 -0.78732,-1.4918 -1.71965,-3.2839 -2.42409,-4.3716 -1.7093,-2.8074 -1.58498,-2.4241 -0.85983,-1.1913 -0.71479,-0.7148 1.23276,2.3412 1.12917,2.6209 1.69894,3.864 0.74587,1.7093 0.74718,2.222 z m -10.22656,-17.4267 -0.0207,-0.042 -0.0622,-0.041 z m 26.01236,-7.8006 -0.41437,1.73 -1.87505,7.5001 -0.91162,4.2577 -0.95306,5.1487 -1.05666,3.3564 -0.37294,-0.8702 -2.40337,-4.4545 0.80803,-1.8751 2.63128,-5.5112 1.40887,-2.9627 1.88541,-3.978 z m 2.33086,5.5837 -0.34186,1.989 -0.97378,3.3046 -0.97378,2.4448 -1.07738,3.1803 -0.56976,3.1286 -0.53869,3.326 1.94756,-1.9793 0.0829,-1.0152 0.21755,-1.7611 0.51797,-2.4863 1.12917,-4.4442 0.51797,-3.2942 z m -13.94371,9.0644 0.78732,1.3156 -0.16575,3.0664 -0.12432,0.093 z m 1.326,2.2065 0.45581,0.7563 -0.35221,0.8287 -0.25899,0.1865 z"
+ id="path4566-6-6-5-6" />
+ <flowRoot
+ id="flowRoot4976-7-3-5"
+ style="font-style:normal;font-variant:normal;font-weight:normal;font-stretch:normal;font-size:22px;line-height:125%;font-family:Fontin;-inkscape-font-specification:Fontin;text-align:start;letter-spacing:0px;word-spacing:0px;writing-mode:lr-tb;text-anchor:start;fill:#000000;fill-opacity:1;stroke:none"
+ transform="matrix(1.2981272,0,0,1.2981272,584.89882,-583.10263)"><flowRegion
+ id="flowRegion4978-2-1-5"><rect
+ id="rect4980-7-8-2"
+ width="284.66568"
+ height="34.231934"
+ x="463.03217"
+ y="871.11304" /></flowRegion><flowPara
+ id="flowPara4982-5-6-4"
+ style="font-style:normal;font-variant:normal;font-weight:300;font-stretch:normal;font-size:18.48817253px;line-height:125%;font-family:'Fira Sans';-inkscape-font-specification:'Fira Sans Light';text-align:start;writing-mode:lr-tb;text-anchor:start;fill:#008f00;fill-opacity:0.65">Formati di file supportati</flowPara></flowRoot> </g>
+ <g
+ id="g6418"
+ transform="translate(14.190976,-0.0875172)"
+ <path
+ transform="matrix(0.95868236,0,0,0.95868236,948.32581,-785.34868)"
+ id="path4566-6-6-5" />
+ <flowRoot
+ id="flowRoot4976-7-3"
+ style="font-style:normal;font-variant:normal;font-weight:normal;font-stretch:normal;font-size:22px;line-height:125%;font-family:Fontin;-inkscape-font-specification:Fontin;text-align:start;letter-spacing:0px;word-spacing:0px;writing-mode:lr-tb;text-anchor:start;fill:#008f00;fill-opacity:0.65;stroke:none"
+ transform="matrix(1.2981272,0,0,1.2981272,606.97093,-817.51517)"><flowRegion
+ id="flowRegion4978-2-1"><rect
+ id="rect4980-7-8"
+ width="284.66568"
+ x="463.03217"
+ y="871.11304"
+ style="fill:#008f00;fill-opacity:0.65" /></flowRegion><flowPara
+ id="flowPara4982-5-6"
+ style="font-style:normal;font-variant:normal;font-weight:300;font-stretch:normal;font-size:18.48817253px;line-height:125%;font-family:'Fira Sans';-inkscape-font-specification:'Fira Sans Light';text-align:start;writing-mode:lr-tb;text-anchor:start;fill:#008f00;fill-opacity:0.65">Technical datasheet</flowPara></flowRoot> </g>
+ <g
+ id="g5929"
+ transform="translate(-217.45952,-356.6581)"
+ <path
+ transform="matrix(0.95868236,0,0,0.95868236,6.6849697,71.29189)"
+ id="path4566-6" />
+ <flowRoot
+ id="flowRoot4976"
+ transform="matrix(1.2981272,0,0,1.2981272,-334.66991,39.125397)"><flowRegion
+ id="flowRegion4978"><rect
+ id="rect4980"
+ width="284.66568"
+ x="463.03217"
+ id="flowPara4982"
+ style="font-style:normal;font-variant:normal;font-weight:300;font-stretch:normal;font-size:18.48817253px;line-height:125%;font-family:'Fira Sans';-inkscape-font-specification:'Fira Sans Light';text-align:start;writing-mode:lr-tb;text-anchor:start;fill:#008f00;fill-opacity:0.65">Cos'ĆØ <flowSpan
+ id="flowSpan5927"
+ style="font-style:normal;font-variant:normal;font-weight:500;font-stretch:normal;font-size:18.48817253px;line-height:125%;font-family:'Fira Sans';-inkscape-font-specification:'Fira Sans Medium';text-align:start;writing-mode:lr-tb;text-anchor:start;fill:#008f00;fill-opacity:0.65">GRASS</flowSpan><flowSpan
+ style="font-style:normal;font-variant:normal;font-weight:200;font-stretch:normal;font-size:18.48817444px;line-height:125%;font-family:'Fira Sans';-inkscape-font-specification:'Fira Sans, Ultra-Light';text-align:start;letter-spacing:-1.54068112px;writing-mode:lr-tb;text-anchor:start"
+ id="flowSpan4319"> GIS</flowSpan> ?</flowPara></flowRoot> </g>
+ <flowRoot
+ id="flowRoot2987"
+ style="font-style:normal;font-variant:normal;font-weight:normal;font-stretch:normal;font-size:22px;line-height:125%;font-family:Fontin;-inkscape-font-specification:Fontin;text-align:justify;letter-spacing:0px;word-spacing:0px;writing-mode:lr-tb;text-anchor:start;fill:#000000;fill-opacity:1;stroke:none"
+ transform="matrix(0.80809717,0,0,0.90225882,12.354013,797.46142)"
+ id="flowRegion2989"><rect
+ id="rect2991"
+ width="406.08215"
+ height="214.86293"
+ x="48.401169"
+ y="56.338501"
+ ry="0"
+ style="text-align:justify;text-anchor:start" /></flowRegion><flowPara
+ id="flowPara3015"
+ style="font-size:14.05348015px;text-align:justify;text-anchor:start"><flowSpan
+ id="flowSpan5465"
+ style="font-style:normal;font-variant:normal;font-weight:500;font-stretch:normal;font-size:15.22460365px;line-height:125%;font-family:'Fira Sans';-inkscape-font-specification:'Fira Sans Medium';text-align:justify;writing-mode:lr-tb;text-anchor:start">GRASS</flowSpan><flowSpan
+ id="flowSpan5467"
+ style="font-style:normal;font-variant:normal;font-weight:300;font-stretch:normal;font-size:15.22460365px;line-height:125%;font-family:'Fira Sans';-inkscape-font-specification:'Fira Sans Light';text-align:justify;letter-spacing:0px;writing-mode:lr-tb;text-anchor:start"> GIS</flowSpan><flowSpan
+ id="flowSpan5435"
+ style="font-style:normal;font-variant:normal;font-weight:normal;font-stretch:normal;font-size:15.22460365px;font-family:'Fira Sans';-inkscape-font-specification:'Fira Sans';text-align:justify;text-anchor:start"> (Geographic Resources Analysis Support System) è un software libero e open source per effettuare analisi spaziali. à composto da più di 450 moduli per processare vettoriali (2D/3D), raster, voxel dati temporali (4D). Esistono molte interfacce ad altri programmi correlati in campi come la geostatistica, i database, i servizi di mappe web e molti altri esistenti software GIS. à il più vecchio e esteso codice sorgente GIS libero e open source. Può essere usato come un GIS desktop così come il backbone di una completa infrastruttura GIS</flowSpan></flowPara></flowRoot> <flowRoot
+ id="flowRoot3017"
+ style="font-style:normal;font-variant:normal;font-weight:normal;font-stretch:normal;font-size:22px;line-height:125%;font-family:Fontin;-inkscape-font-specification:Fontin;text-align:start;letter-spacing:0px;word-spacing:0px;writing-mode:lr-tb;text-anchor:start;fill:#000000;fill-opacity:1;stroke:none"><flowRegion
+ id="flowRegion3019"><rect
+ id="rect3021"
+ width="612.11755"
+ height="59.655521"
+ x="187.61229"
+ y="150.99756" /></flowRegion><flowPara
+ id="flowPara3023" /></flowRoot> <flowRoot
+ id="flowRoot2987-2"
+ transform="matrix(0.80809717,0,0,0.90225882,399.6586,902.42672)"
+ id="flowRegion2989-5"><rect
+ id="rect2991-2"
+ width="726.40491"
+ height="84.717194"
+ x="27.90641"
+ y="59.162483"
+ ry="0"
+ id="flowPara2993-2"
+ style="font-style:normal;font-variant:normal;font-weight:500;font-stretch:normal;font-size:16.39572716px;line-height:125%;font-family:'Fira Sans';-inkscape-font-specification:'Fira Sans Medium';text-align:justify;writing-mode:lr-tb;text-anchor:start;fill:#008f00">Dov'ĆØ usato GRASS<flowSpan
+ style="font-style:normal;font-variant:normal;font-weight:300;font-stretch:normal;font-size:16.39572716px;line-height:125%;font-family:'Fira Sans';-inkscape-font-specification:'Fira Sans, Light';text-align:justify;writing-mode:lr-tb;text-anchor:start"
+ id="flowSpan4207"> GIS</flowSpan></flowPara><flowPara
+ id="flowPara3140"><flowSpan
+ id="flowSpan6025">GRASS</flowSpan><flowSpan
+ style="font-style:normal;font-variant:normal;font-weight:300;font-stretch:normal;font-size:15.22460365px;line-height:125%;font-family:'Fira Sans';-inkscape-font-specification:'Fira Sans Light';text-align:justify;writing-mode:lr-tb;text-anchor:start"
+ id="flowSpan6019">Ā GIS</flowSpan> ĆØ usato in applicazioni scientifiche e commerciali inoltre dalle pubbliche amministrazioni di tutto il mondo. Il software ha mostrato una forte attitudine a risolvere problemi geospaziali in numerose situazioni in tutto il mondo.</flowPara><flowPara
+ style="font-style:normal;font-variant:normal;font-weight:normal;font-stretch:normal;font-size:12px;font-family:'Fira Sans';-inkscape-font-specification:'Fira Sans';text-align:justify;text-anchor:start"
+ id="flowPara3150" /><flowPara
+ id="flowPara3007-0"
+ style="font-size:10px;text-align:justify;text-anchor:start" /><flowPara
+ id="flowPara3009-4"
+ id="flowPara3011-0"
+ id="flowPara3013-7"
+ id="flowPara3015-8"
+ id="flowPara3152" /><flowPara
+ id="flowPara3154" /><flowPara
+ id="flowPara3156" /><flowPara
+ id="flowPara3158" /><flowPara
+ id="flowPara3160" /><flowPara
+ id="flowPara3162" /><flowPara
+ id="flowPara3164" /><flowPara
+ id="flowPara3166" /><flowPara
+ id="flowPara3168" /></flowRoot> <flowRoot
+ id="flowRoot3124"
+ id="flowRegion3126"><rect
+ id="rect3128"
+ width="211.82033"
+ height="140.92537"
+ x="467.73389"
+ y="71.456863" /></flowRegion><flowPara
+ id="flowPara3130" /></flowRoot> <flowRoot
+ id="flowRoot2987-0"
+ transform="matrix(0.80809717,0,0,0.90225882,385.25234,795.58192)"
+ id="flowRegion2989-0"><rect
+ id="rect2991-5"
+ width="723.83508"
+ height="143.3638"
+ x="48.401169"
+ y="56.338501"
+ ry="0"
+ id="flowPara2993-9"
+ style="font-style:normal;font-variant:normal;font-weight:500;font-stretch:normal;font-size:16.39572716px;line-height:125%;font-family:'Fira Sans';-inkscape-font-specification:'Fira Sans Medium';text-align:justify;writing-mode:lr-tb;text-anchor:start;fill:#008f00">A long term endeavor</flowPara><flowPara
+ id="flowPara3015-2"
+ style="font-size:10px;text-align:justify;text-anchor:start"><flowSpan
+ id="flowSpan5536"
+ style="font-style:normal;font-variant:normal;font-weight:500;font-stretch:normal;font-size:15.22460365px;line-height:125%;font-family:'Fira Sans';-inkscape-font-specification:'Fira Sans Medium';text-align:justify;writing-mode:lr-tb;text-anchor:start">GRASSĀ </flowSpan><flowSpan
+ id="flowSpan5538"
+ style="font-style:normal;font-variant:normal;font-weight:300;font-stretch:normal;font-size:15.22460365px;line-height:125%;font-family:'Fira Sans';-inkscape-font-specification:'Fira Sans Light';text-align:justify;letter-spacing:0px;writing-mode:lr-tb;text-anchor:start">GIS</flowSpan><flowSpan
+ id="flowSpan5487"
+ style="font-style:normal;font-variant:normal;font-weight:normal;font-stretch:normal;font-size:15.22460365px;font-family:'Fira Sans';-inkscape-font-specification:'Fira Sans';text-align:justify;text-anchor:start"> è nato più di 30 anni fa... e l'ultima modifica è di qualche ora fa! Molte persone hanno contributo a migliorare il software. La sua forza e successo si basano su un attivo team di sviluppo e il feedback di una vasta comunità di contributori. Entrambi combinano il loro sforzo per rendere <flowSpan
+ id="flowSpan6017">GRASS</flowSpan><flowSpan
+ id="flowSpan6015"> GIS</flowSpan> più facile, più utile e potente per chiunque.</flowSpan></flowPara></flowRoot> <flowRoot
+ transform="matrix(0.80809717,0,0,0.90225882,255.89653,304.91436)"
+ id="flowRoot3350"
+ id="flowRegion3352"><rect
+ ry="0"
+ y="47.866554"
+ x="75.202003"
+ height="157.06474"
+ width="482.09903"
+ id="rect3354"
+ id="flowPara3380">Una filosofia libera e open source</flowPara><flowPara
+ id="flowPara3368"><flowSpan
+ id="flowSpan4984"
+ style="font-style:normal;font-variant:normal;font-weight:normal;font-stretch:normal;font-size:15.22460365px;font-family:'Fira Sans';-inkscape-font-specification:'Fira Sans';text-align:justify;text-anchor:start">La filosofia libera e Open Source permette agli utenti di vedere il codice sorgente e la struttura del programma, questo offre una grande trasparenza. Gli utenti possono facilmente estendere il programma per le loro necessitĆ . Una immediata revisione del codice aumentera la qualitĆ . Con il supporto del gestore degli addons, nuovi moduli possono essere creati senza modificare il codice sorgente principale di </flowSpan><flowSpan
+ id="flowSpan4986"
+ style="font-style:normal;font-variant:normal;font-weight:500;font-stretch:normal;font-size:15.22460365px;line-height:125%;font-family:'Fira Sans';-inkscape-font-specification:'Fira Sans Medium';text-align:justify;word-spacing:0px;writing-mode:lr-tb;text-anchor:start">GRASS</flowSpan><flowSpan
+ id="flowSpan4945"
+ style="font-style:normal;font-variant:normal;font-weight:300;font-stretch:normal;font-size:15.22460365px;line-height:125%;font-family:'Fira Sans';-inkscape-font-specification:'Fira Sans Light';text-align:justify;word-spacing:0px;writing-mode:lr-tb;text-anchor:start"> GIS.</flowSpan></flowPara></flowRoot> <flowRoot
+ transform="translate(1169.7474,297.79317)"
+ id="flowRoot3434"
+ id="flowRegion3436"><rect
+ ry="0"
+ y="56.338501"
+ x="48.401169"
+ height="108.26849"
+ width="217.28075"
+ id="rect3438" /></flowRegion><flowPara
+ style="font-style:italic;font-variant:normal;font-weight:normal;font-stretch:normal;font-size:12px;line-height:125%;font-family:'Fira Sans';-inkscape-font-specification:'Fira Sans Italic';text-align:start;writing-mode:lr-tb;text-anchor:start"
+ id="flowPara9683">Design</flowPara><flowPara
+ style="font-style:normal;font-variant:normal;font-weight:normal;font-stretch:normal;font-size:12px;font-family:'Fira Sans';-inkscape-font-specification:'Fira Sans'"
+ id="flowPara3488">- Comandi modulari</flowPara><flowPara
+ id="flowPara3490">- Consiste in più di 450 moduli</flowPara><flowPara
+ id="flowPara4928">- Repository di addons per i moduli degli utenti</flowPara><flowPara
+ id="flowPara4932">- Documentazione con esempi per ogni modulo</flowPara><flowPara
+ id="flowPara4924" /><flowPara
+ id="flowPara4922" /><flowPara
+ id="flowPara4920" /><flowPara
+ id="flowPara3508" /><flowPara
+ id="flowPara3544" /><flowPara
+ id="flowPara3536" /><flowPara
+ id="flowPara3532" /><flowPara
+ style="font-style:normal;font-variant:normal;font-weight:bold;font-stretch:normal;font-size:12px;font-family:'Fira Sans';-inkscape-font-specification:'Fira Sans Bold'"
+ id="flowPara3528" /><flowPara
+ id="flowPara3516" /><flowPara
+ id="flowPara3512" /><flowPara
+ id="flowPara3492" /><flowPara
+ style="font-size:10px"
+ id="flowPara3452" /><flowPara
+ id="flowPara3454" /><flowPara
+ id="flowPara3500" /><flowPara
+ id="flowPara3502" /><flowPara
+ id="flowPara3546" /></flowRoot> <flowRoot
+ transform="translate(1169.9754,790.74782)"
+ id="flowRoot3548"
+ id="flowRegion3550"><rect
+ ry="0"
+ y="56.338501"
+ x="48.401169"
+ height="38.089043"
+ width="500.40387"
+ id="rect3552" /></flowRegion><flowPara
+ id="flowPara3599"><flowSpan
+ style="font-style:normal;font-variant:normal;font-weight:500;font-stretch:normal;font-size:12px;line-height:125%;font-family:'Fira Sans';-inkscape-font-specification:'Fira Sans Medium';text-align:start;writing-mode:lr-tb;text-anchor:start"
+ id="flowSpan6222">GRASSĀ </flowSpan><flowSpan
+ style="font-style:normal;font-variant:normal;font-weight:300;font-stretch:normal;font-size:12px;line-height:125%;font-family:'Fira Sans';-inkscape-font-specification:'Fira Sans Light';text-align:start;writing-mode:lr-tb;text-anchor:start"
+ id="flowSpan6220">GIS</flowSpan> supporta molti formati di file GIS utilizzando la libreria GDAL/OGR.</flowPara><flowPara
+ id="flowPara6224">Inoltre supporta anche Open GIS Consortiumās Simple Features.</flowPara><flowPara
+ id="flowPara3601" /><flowPara
+ id="flowPara3560"
+ style="font-style:normal;font-variant:normal;font-weight:normal;font-stretch:normal;font-size:12px;font-family:'Fira Sans';-inkscape-font-specification:'Fira Sans'" /><flowPara
+ id="flowPara3562" /><flowPara
+ id="flowPara3564" /><flowPara
+ id="flowPara3566" /><flowPara
+ id="flowPara3568" /><flowPara
+ id="flowPara3570" /><flowPara
+ id="flowPara3572"
+ style="font-size:10px" /><flowPara
+ id="flowPara3574"
+ id="flowPara3576"
+ id="flowPara3578"
+ id="flowPara3580"
+ id="flowPara3582"
+ id="flowPara3584"
+ id="flowPara3586"
+ id="flowPara3588"
+ style="font-size:10px" /></flowRoot> <flowRoot
+ id="flowRoot3110"
+ transform="translate(1170.5514,830.2465)"
+ id="flowRegion3112"><rect
+ id="rect3114"
+ width="224.59203"
+ height="131.88416"
+ x="48.401169"
+ y="56.338501"
+ ry="0" /></flowRegion><flowPara
+ style="font-style:italic;font-variant:normal;font-weight:normal;font-stretch:normal;font-size:12px;font-family:'Fira Sans';-inkscape-font-specification:'Fira Sans Italic'"
+ id="flowPara3161">Fortmati vettoriali</flowPara><flowPara
+ id="flowPara5587">ASCII, ARC/INFO ungenerate, ARC/INFO E00, ArcView SHAPE, BIL, DLG (U.S.), DXF, DXF3D, GMT, GPS-ASCII USGS-DEM, IDRISI, MOSS, MapInfo, MIF, PostGIS, TIGER, VRML, etc.</flowPara><flowPara
+ id="flowPara3120"
+ id="flowPara3122" /><flowPara
+ id="flowPara3124"
+ id="flowPara3126"
+ id="flowPara3128"
+ id="flowPara3131"
+ id="flowPara3133"
+ id="flowPara3135" /><flowPara
+ id="flowPara3137" /><flowPara
+ id="flowPara3139" /><flowPara
+ id="flowPara3141" /><flowPara
+ id="flowPara3143" /><flowPara
+ id="flowPara3145" /><flowPara
+ id="flowPara3147" /><flowPara
+ id="flowPara3149" /><flowPara
+ id="flowPara3151" /><flowPara
+ id="flowPara3163" /></flowRoot> <flowRoot
+ transform="translate(1170.3954,930.15892)"
+ id="flowRoot3169"
+ id="flowRegion3171"><rect
+ ry="0"
+ y="56.338501"
+ x="48.401169"
+ height="62.962093"
+ width="209.38058"
+ id="rect3173" /></flowRegion><flowPara
+ id="flowPara3177"
+ style="font-style:italic;font-variant:normal;font-weight:normal;font-stretch:normal;font-size:12px;line-height:125%;font-family:'Fira Sans';-inkscape-font-specification:'Fira Sans Italic';text-align:start;writing-mode:lr-tb;text-anchor:start">Formati raster</flowPara><flowPara
+ id="flowPara3179"
+ style="font-style:normal;font-variant:normal;font-weight:normal;font-stretch:normal;font-size:12px;font-family:'Fira Sans';-inkscape-font-specification:'Fira Sans'">ASCII, ARC/GRID, E00, GIF, GMT, TIF, PNG, Vis5D, SURFER (.grd), etc.</flowPara><flowPara
+ id="flowPara3181" /><flowPara
+ id="flowPara3183"
+ id="flowPara3185" /><flowPara
+ id="flowPara3187" /><flowPara
+ id="flowPara3189" /><flowPara
+ id="flowPara3191" /><flowPara
+ id="flowPara3193" /><flowPara
+ id="flowPara3195"
+ id="flowPara3197"
+ id="flowPara3199"
+ id="flowPara3201"
+ id="flowPara3203"
+ id="flowPara3205"
+ id="flowPara3207"
+ id="flowPara3209"
+ id="flowPara3211"
+ id="flowPara3213"
+ transform="translate(1474.2069,830.2465)"
+ id="flowRoot3231"
+ id="flowRegion3233"><rect
+ ry="0"
+ y="56.338501"
+ x="48.401169"
+ height="97.07724"
+ width="224.59203"
+ id="rect3235" /></flowRegion><flowPara
+ id="flowPara3239"
+ style="font-style:italic;font-variant:normal;font-weight:normal;font-stretch:normal;font-size:12px;line-height:125%;font-family:'Fira Sans';-inkscape-font-specification:'Fira Sans Italic';text-align:start;writing-mode:lr-tb;text-anchor:start">Formati di immagini</flowPara><flowPara
+ id="flowPara3279">CEOS (SAR, SRTM, LANDSAT7 etc.), ERDAS LAN / IMG, HDF, LANDSAT TM/MSS, NHAP aerial photos,</flowPara><flowPara
+ id="flowPara3281">SAR, SPOT, MODIS, SENTINEL, etc.</flowPara><flowPara
+ id="flowPara3283" /><flowPara
+ id="flowPara3241" /><flowPara
+ id="flowPara3243"
+ id="flowPara3245" /><flowPara
+ id="flowPara3247" /><flowPara
+ id="flowPara3249" /><flowPara
+ id="flowPara3251" /><flowPara
+ id="flowPara3253" /><flowPara
+ id="flowPara3255"
+ id="flowPara3257"
+ id="flowPara3259"
+ id="flowPara3261"
+ id="flowPara3263"
+ id="flowPara3265"
+ id="flowPara3267"
+ id="flowPara3269"
+ id="flowPara3271"
+ id="flowPara3273"
+ id="flowRoot3287"
+ transform="translate(1474.9563,930.15892)"
+ id="flowRegion3289"><rect
+ id="rect3291"
+ width="211.59372"
+ height="88.099609"
+ x="48.401169"
+ y="56.338501"
+ id="flowPara3297"
+ style="font-style:italic;font-variant:normal;font-weight:normal;font-stretch:normal;font-size:12px;line-height:125%;font-family:'Fira Sans';-inkscape-font-specification:'Fira Sans Italic';text-align:start;writing-mode:lr-tb;text-anchor:start">Database supportati</flowPara><flowPara
+ id="flowPara3353">SQLite, PostgreSQL / PostGIS, MySQL, ODBC, DBF</flowPara><flowPara
+ id="flowPara3299"
+ id="flowPara3301"
+ id="flowPara3303" /><flowPara
+ id="flowPara3305"
+ id="flowPara3307"
+ id="flowPara3309"
+ id="flowPara3311"
+ id="flowPara3313"
+ id="flowPara3315" /><flowPara
+ id="flowPara3317" /><flowPara
+ id="flowPara3319" /><flowPara
+ id="flowPara3321" /><flowPara
+ id="flowPara3323" /><flowPara
+ id="flowPara3325" /><flowPara
+ id="flowPara3327" /><flowPara
+ id="flowPara3329" /><flowPara
+ id="flowPara3331" /><flowPara
+ id="flowPara3333" /><flowPara
+ id="flowPara3349" /><flowPara
+ id="flowPara3351" /></flowRoot> <flowRoot
+ transform="translate(1429.7687,314.51265)"
+ id="flowRoot3355"
+ id="flowRegion3357"><rect
+ ry="0"
+ y="56.338501"
+ x="48.401169"
+ height="142.51433"
+ width="189.48055"
+ id="rect3359" /></flowRegion><flowPara
+ id="flowPara3363"
+ style="font-style:italic;font-variant:normal;font-weight:normal;font-stretch:normal;font-size:12px;line-height:125%;font-family:'Fira Sans';-inkscape-font-specification:'Fira Sans Italic';text-align:start;writing-mode:lr-tb;text-anchor:start">Output</flowPara><flowPara
+ id="flowPara3401">- Moduli di mappatura (animazioni, cartografia...)</flowPara><flowPara
+ id="flowPara3405">- NVIZ per la visualizzazione di dati 2.5D e 3D (creazione di animazione e voli)</flowPara><flowPara
+ id="flowPara3407">- VTK, POVray</flowPara><flowPara
+ id="flowPara3409">- Servizi Web</flowPara><flowPara
+ id="flowPara3411" /><flowPara
+ id="flowPara3365" /><flowPara
+ id="flowPara3367"
+ id="flowPara3369" /><flowPara
+ id="flowPara3371" /><flowPara
+ id="flowPara3373" /><flowPara
+ id="flowPara3375" /><flowPara
+ id="flowPara3377" /><flowPara
+ id="flowPara3379"
+ id="flowPara3381"
+ id="flowPara3383"
+ id="flowPara3385"
+ id="flowPara3387"
+ id="flowPara3389"
+ id="flowPara3391"
+ id="flowPara3393"
+ id="flowPara3395"
+ id="flowPara3397"
+ transform="translate(1930.1761,619.64704)"
+ id="flowRoot3415"
+ id="flowRegion3417"><rect
+ ry="0"
+ y="56.338501"
+ x="48.401169"
+ height="96.874359"
+ width="232.76051"
+ id="rect3419"
+ style="text-align:start;text-anchor:start" /></flowRegion><flowPara
+ style="font-style:italic;font-variant:normal;font-weight:normal;font-stretch:normal;font-size:12px;line-height:125%;font-family:'Fira Sans';-inkscape-font-specification:'Fira Sans Italic';text-align:start;writing-mode:lr-tb;text-anchor:start;fill:#000000;fill-opacity:1"
+ id="flowPara4886">InteroperabilitĆ con altri software GIS</flowPara><flowPara
+ style="font-style:normal;font-variant:normal;font-weight:normal;font-stretch:normal;font-size:12px;font-family:'Fira Sans';-inkscape-font-specification:'Fira Sans';text-align:start;text-anchor:start"
+ id="flowPara4884">- QGIS (GIS platform)</flowPara><flowPara
+ id="flowPara3465">- R-Language (statistica)</flowPara><flowPara
+ id="flowPara3469">- Gstat (geostatistica)</flowPara><flowPara
+ id="flowPara3471">- UMN MapServer (webmapping)</flowPara><flowPara
+ id="flowPara4894">- ZOO-Project, PyWPS (WPS)</flowPara><flowPara
+ id="flowPara3477" /><flowPara
+ id="flowPara3473" /><flowPara
+ id="flowPara3463" /><flowPara
+ id="flowPara3425" /><flowPara
+ id="flowPara3427"
+ style="font-style:normal;font-variant:normal;font-weight:normal;font-stretch:normal;font-size:12px;font-family:'Fira Sans';-inkscape-font-specification:'Fira Sans';text-align:start;text-anchor:start" /><flowPara
+ style="font-size:10px;text-align:start;text-anchor:start"
+ id="flowPara3429" /><flowPara
+ id="flowPara3431" /><flowPara
+ id="flowPara3433" /><flowPara
+ id="flowPara3435" /><flowPara
+ id="flowPara3437" /><flowPara
+ id="flowPara3439"
+ style="font-size:10px;text-align:start;text-anchor:start" /><flowPara
+ id="flowPara3441"
+ id="flowPara3443"
+ id="flowPara3445"
+ id="flowPara3447"
+ id="flowPara3449"
+ id="flowPara3451"
+ id="flowPara3453"
+ id="flowPara3455"
+ id="flowPara3457"
+ style="font-size:10px;text-align:start;text-anchor:start" /></flowRoot> <g
+ id="g5929-4"
+ transform="translate(-217.45952,-858.13351)"
+ <path
+ id="path4566-6-6" />
+ <flowRoot
+ id="flowRoot4976-7"
+ id="flowRegion4978-2"><rect
+ id="rect4980-7"
+ width="284.66568"
+ x="463.03217"
+ id="flowPara4982-5"
+ style="font-style:normal;font-variant:normal;font-weight:300;font-stretch:normal;font-size:18.48817253px;line-height:125%;font-family:'Fira Sans';-inkscape-font-specification:'Fira Sans Light';text-align:start;writing-mode:lr-tb;text-anchor:start;fill:#008f00;fill-opacity:0.65">About</flowPara></flowRoot> </g>
+ <flowRoot
+ transform="translate(1.8906317,291.87769)"
+ id="flowRoot3479"
+ id="flowRegion3481"><rect
+ ry="0"
+ y="56.338501"
+ x="48.401169"
+ height="139.48248"
+ width="331.6062"
+ id="rect3483" /></flowRegion><flowPara
+ style="font-style:normal;font-variant:normal;font-weight:500;font-stretch:normal;font-size:14px;line-height:125%;font-family:'Fira Sans';-inkscape-font-specification:'Fira Sans Medium';text-align:start;writing-mode:lr-tb;text-anchor:start;fill:#008f00"
+ id="flowPara3527">Dove trovare informazioni?</flowPara><flowPara
+ style="font-style:normal;font-variant:normal;font-weight:normal;font-stretch:normal;font-size:13px;font-family:'Fira Sans';-inkscape-font-specification:'Fira Sans'"
+ id="flowPara3529">- <flowSpan
+ style="font-style:normal;font-variant:normal;font-weight:500;font-stretch:normal;font-size:13px;line-height:125%;font-family:'Fira Sans';-inkscape-font-specification:'Fira Sans Medium';text-align:start;word-spacing:0px;writing-mode:lr-tb;text-anchor:start"
+ id="flowSpan6522">GRASS</flowSpan><flowSpan
+ style="font-style:normal;font-variant:normal;font-weight:300;font-stretch:normal;font-size:13px;line-height:125%;font-family:'Fira Sans';-inkscape-font-specification:'Fira Sans Light';text-align:start;word-spacing:0px;writing-mode:lr-tb;text-anchor:start"
+ id="flowSpan6518">Ā GIS</flowSpan> wiki:</flowPara><flowPara
+ style="font-style:italic;font-variant:normal;font-weight:normal;font-stretch:normal;font-size:13px;font-family:'Fira Sans';-inkscape-font-specification:'Fira Sans Italic'"
+ id="flowPara3531">https://grasswiki.osgeo.org/wiki</flowPara><flowPara
+ id="flowPara3533">- <flowSpan
+ id="flowSpan6526">GRASS</flowSpan><flowSpan
+ id="flowSpan6524">Ā GIS</flowSpan> mailing lists: </flowPara><flowPara
+ id="flowPara7779">https://grass.osgeo.org/support</flowPara><flowPara
+ id="flowPara7775">- Sito web:</flowPara><flowPara
+ id="flowPara7777" /><flowPara
+ id="flowPara7769" /><flowPara
+ id="flowPara3489" /><flowPara
+ id="flowPara3491"
+ id="flowPara3493" /><flowPara
+ id="flowPara3495" /><flowPara
+ id="flowPara3497" /><flowPara
+ id="flowPara3499" /><flowPara
+ id="flowPara3501" /><flowPara
+ id="flowPara3503"
+ id="flowPara3505"
+ id="flowPara3507"
+ id="flowPara3509"
+ id="flowPara3511"
+ id="flowPara3513"
+ id="flowPara3515"
+ id="flowPara3517"
+ id="flowPara3519"
+ id="flowPara3521"
+ id="flowPara3535" /><flowPara
+ id="flowPara3537" /></flowRoot> <flowRoot
+ id="flowRoot3539"
+ transform="translate(696.90698,291.87769)"
+ id="flowRegion3541"><rect
+ id="rect3543"
+ width="279.71051"
+ height="119.00055"
+ x="48.401169"
+ y="56.338501"
+ ry="0"
+ style="font-style:normal;font-variant:normal;font-weight:500;font-stretch:normal;font-size:14px;line-height:125%;font-family:'Fira Sans';-inkscape-font-specification:'Fira Sans Medium';text-align:justify;writing-mode:lr-tb;text-anchor:start;fill:#008f00"
+ id="flowPara3619">Un progetto di OSGeo</flowPara><flowPara
+ id="flowPara3593"
+ id="flowSpan5377"
+ style="font-style:normal;font-variant:normal;font-weight:500;font-stretch:normal;font-size:13px;line-height:125%;font-family:'Fira Sans';-inkscape-font-specification:'Fira Sans Medium';text-align:justify;writing-mode:lr-tb;text-anchor:start">GRASS</flowSpan><flowSpan
+ id="flowSpan5379"
+ style="font-style:normal;font-variant:normal;font-weight:300;font-stretch:normal;font-size:13px;line-height:125%;font-family:'Fira Sans';-inkscape-font-specification:'Fira Sans Light';text-align:justify;writing-mode:lr-tb;text-anchor:start">Ā GIS</flowSpan><flowSpan
+ id="flowSpan5052"
+ style="font-style:normal;font-variant:normal;font-weight:normal;font-stretch:normal;font-size:13px;font-family:'Fira Sans';-inkscape-font-specification:'Fira Sans';text-align:justify;text-anchor:start"> ĆØ un progetto fondatore della Open Source Geospatial Foundation (OSGeo) la quale missione ĆØ di creare e supportare software geospaziale libero e open source di alta qualitĆ . Per maggiori informazioni visitare il sito di OSGeo.</flowSpan></flowPara></flowRoot> <text
+ x="768.1167"
+ y="850.31226"
+ id="text3633"
+ transform="translate(0,308.2677)"><tspan
+ id="tspan3635"
+ x="768.1167"
+ y="850.31226" /></text>
+ <flowRoot
+ id="flowRoot3885"
+ transform="translate(0,308.2677)"><flowRegion
+ id="flowRegion3887"><rect
+ id="rect3889"
+ width="79.917137"
+ height="54.758038"
+ x="513.54156"
+ y="957.20685" /></flowRegion><flowPara
+ id="flowPara3891" /></flowRoot> <flowRoot
+ id="flowRoot3893"
+ id="flowRegion3895"><rect
+ id="rect3897"
+ width="241.23135"
+ height="30.708899"
+ x="480.61276"
+ y="1105.5715" /></flowRegion><flowPara
+ id="flowPara3899" /></flowRoot> <flowRoot
+ id="flowRoot7539"
+ transform="translate(1709.3084,573.61884)"
+ id="flowRegion7541"><rect
+ id="rect7543"
+ width="208.66772"
+ height="98.633392"
+ x="269.23517"
+ y="6.9745884"
+ ry="0"
+ id="flowPara7547"
+ style="font-style:italic;font-variant:normal;font-weight:normal;font-stretch:normal;font-size:12px;line-height:125%;font-family:'Fira Sans';-inkscape-font-specification:'Fira Sans Italic';text-align:start;writing-mode:lr-tb;text-anchor:start;fill:#000000;fill-opacity:1">Piattaforme supportate</flowPara><flowPara
+ id="flowPara7583"><flowSpan
+ id="flowSpan6516">GRASS</flowSpan><flowSpan
+ id="flowSpan6514">Ā GIS</flowSpan> gira su quasi tutte le piattforme. Supporta GNU/Linux, Posix compliant Unix Systems, MS Windows e MacOS X.</flowPara><flowPara
+ id="flowPara7549"
+ id="flowPara7551" /><flowPara
+ id="flowPara7553"
+ id="flowPara7555"
+ id="flowPara7557"
+ id="flowPara7559"
+ id="flowPara7561"
+ id="flowPara7563" /><flowPara
+ id="flowPara7565" /><flowPara
+ id="flowPara7567" /><flowPara
+ id="flowPara7569" /><flowPara
+ id="flowPara7571" /><flowPara
+ id="flowPara7573" /><flowPara
+ id="flowPara7575" /><flowPara
+ id="flowPara7577" /><flowPara
+ id="flowPara7579" /></flowRoot> <flowRoot
+ transform="translate(267.32284,435.87045)"
+ id="flowRoot7587"
+ id="flowRegion7589"><rect
+ ry="0"
+ y="56.338501"
+ x="48.401169"
+ height="52.153984"
+ width="372.24411"
+ id="rect7591" /></flowRegion><flowPara
+ id="flowPara7595"
+ style="font-style:normal;font-variant:normal;font-weight:500;font-stretch:normal;font-size:14px;line-height:125%;font-family:'Fira Sans';-inkscape-font-specification:'Fira Sans Medium';text-align:start;writing-mode:lr-tb;text-anchor:start;fill:#008f00">Licenza</flowPara><flowPara
+ id="flowPara7631">GNU General Public License (Free Software Foundation)</flowPara><flowPara
+ id="flowPara7597" /><flowPara
+ id="flowPara7599"
+ id="flowPara7601" /><flowPara
+ id="flowPara7603" /><flowPara
+ id="flowPara7605" /><flowPara
+ id="flowPara7607" /><flowPara
+ id="flowPara7609" /><flowPara
+ id="flowPara7611"
+ id="flowPara7613"
+ id="flowPara7615"
+ id="flowPara7617"
+ id="flowPara7619"
+ id="flowPara7621"
+ id="flowPara7623"
+ id="flowPara7625"
+ id="flowPara7627"
+ id="flowRoot7633"
+ id="flowRegion7635"><rect
+ id="rect7637"
+ width="99.370537"
+ height="24.205645"
+ x="1366.9819"
+ y="62.514515" /></flowRegion><flowPara
+ id="flowPara7639" /></flowRoot> <path
+ style="display:none;fill:#909090;fill-opacity:1;stroke:none"
+ d="m 119.30661,493.4594 1.39821,1.41911 0.47688,-0.51181 -0.85241,-6.35128 0.0725,-1.02557 0.4351,-1.53319 0.45581,-1.40887 0.49725,-1.10846 1.61606,2.71416 1.57462,2.86954 0.34963,1.68404 2.19746,-2.15604 1.10975,-8.34382 2.33086,-11.2917 1.50211,-7.66593 3.04565,-6.03951 0.45581,-1.25348 0.16575,-0.73552 0.0622,-1.19133 -0.18647,-0.95306 -0.43509,-0.85982 -0.79767,-0.79768 0.0414,0.21755 0.39366,0.40402 0.36258,0.84946 0.0414,0.68372 -0.49724,1.36744 -0.64229,1.47103 -1.37779,2.47589 0.76659,-5.71837 0.21755,-3.00422 -0.2797,-0.0518 -1.54355,10.27649 -0.29006,0.51797 -2.53805,4.77567 -3.24248,6.4228 -2.72451,5.57334 -1.51247,3.88476 -0.85982,-1.47103 0.53868,-1.10845 2.96278,-5.68729 3.00422,-5.01393 1.25348,-2.44481 1.03594,-2.03044 0.2797,-0.69407 0.0622,-0.67336 -0.12432,-0.51797 -0.12431,0 -0.0932,0.45581 -0.51797,1.19133 -1.25349,2.11331 -3.58434,5.51118 -2.04079,3.02493 -1.39851,2.47589 0.85982,-8.52576 0.32114,-3.63613 0.13467,-7.68665 -0.0207,0 0.0622,-0.25898 0.196
83,-0.47653 0.15539,-0.4351 0.18647,-0.32114 0,-0.63192 -0.0622,-0.79767 0.2797,-0.51797 -0.12431,-0.75623 0,-0.56977 0.10359,-0.32114 0.21755,-0.71479 0.15539,-0.3833 -0.29006,-0.47653 0.24862,-0.47653 -0.39365,-0.2797 -0.23827,-0.7148 0.34186,-0.55941 -0.47653,-0.15539 -0.20719,-0.37293 0,-0.32114 -0.21754,-0.36258 -0.21755,-0.19683 0.0207,-0.30042 0,-0.3315 -0.10359,-0.90126 -0.0725,-0.51797 -0.32114,-0.23827 -0.15539,-0.2797 -0.36258,-0.17611 -0.21755,-0.39366 0.0414,-0.44545 -0.0414,-0.45581 -0.23826,-0.39366 -0.41438,-0.0829 -0.38329,-0.13467 -0.19683,-0.27971 -0.13467,-0.30042 -0.30042,0.19683 -0.12432,0.3833 -0.0622,0.41437 -0.19683,0.65264 -0.13467,-0.21755 0.0622,0.79768 -0.0414,0.1761 0,0.30043 0.11395,0.23826 0.10359,0.32114 0.19683,0.25899 0.0829,0.11395 0.0622,0.30042 -0.24862,0.18647 0.10359,0.26934 -0.23826,0.30042 0.0414,0.23827 0.0622,0.23827 0.19683,0.23826 0.17611,0.21755 0.23826,0.20718 0.0414,0.17611 -0.0829,0.25899 -0.19683,0.17611 -0.0932,0.14503 0.0311,0.372
94 0.30043,0.19682 0.17611,0.18647 0.10359,0.37294 -0.32114,0.3833 -0.0518,0.26934 0.13467,0.30042 0.19683,0.23827 0,0.23826 0.14503,0.18647 0.13467,0.15539 0.1036,0.17611 -0.0622,0.30042 0.19683,0.2797 0.17611,0.0414 0.0622,0.13467 -0.0622,0.23827 0.16575,0.34186 0.17611,0.13467 0.13467,0.2797 -0.13467,0.47653 0.19683,0.4351 0.18646,0.0829 0.0932,0.19683 0.0414,0.5594 -0.1036,0.23827 -0.0932,0.2797 0.2797,1.40888 0.49725,0.32114 -0.0414,6.11202 -0.58012,6.59891 -0.34186,3.82261 -0.55941,4.64099 -0.21754,0.55941 -1.84397,-3.15961 -0.63192,-4.23698 -0.81839,-6.87861 -0.97378,-6.38137 0.0725,5.82196 0.34188,4.8171 0.59048,4.5892 -4.11266,-6.51604 -5.90484,-8.85725 -1.35708,-1.8854 -0.11395,0 0.39365,1.12917 0.73552,1.8336 1.07737,2.44481 1.88541,4.04016 1.13953,2.03043 1.40887,2.44481 2.91098,4.60991 2.63128,4.18519 0.40402,3.75009 1.25348,8.56719 -6.6e-4,-0.005 -1.44954,-4.50099 -3.06637,-7.55198 -2.44481,-5.07609 -3.24248,-5.27292 -1.64714,-2.1651 -1.31564,-1.31564 -2.14438,-1.989 0
.8909,1.0981 1.43995,1.47102 0.84947,0.95306 0.55941,0.97378 0.67335,1.07738 1.0981,1.8854 0.95306,1.75073 0.97378,2.16511 1.19133,2.89026 2.33085,6.02915 2.44481,6.36065 1.47103,4.49597 z m -4.2898,-4.27103 -0.42661,-1.14186 -0.78731,-1.49175 -1.71965,-3.28392 -2.4241,-4.37165 -1.70929,-2.80739 -1.58498,-2.42409 -0.85983,-1.19132 -0.7148,-0.7148 1.23277,2.34122 1.12917,2.62092 1.69893,3.86404 0.74588,1.70929 0.74717,2.22201 z m -10.22657,-17.42678 -0.0207,-0.0414 -0.0622,-0.0414 z m 26.01237,-7.8006 -0.41438,1.73001 -1.87504,7.50018 -0.91163,4.2577 -0.95306,5.1486 -1.05665,3.35644 -0.37294,-0.87019 -2.40337,-4.45452 0.80803,-1.87505 2.63128,-5.51118 1.40887,-2.96278 1.8854,-3.978 z m 2.33085,5.5837 -0.34186,1.98899 -0.97378,3.30464 -0.97378,2.44481 -1.07737,3.18033 -0.56976,3.12852 -0.53869,3.32601 1.94756,-1.97929 0.0829,-1.01522 0.21755,-1.76109 0.51797,-2.48625 1.12917,-4.44416 0.51797,-3.29428 z m -13.9437,9.06444 0.78731,1.31564 -0.16575,3.06637 -0.12431,0.0932 z m 1.326,2.206
54 0.45581,0.75624 -0.35222,0.82875 -0.25898,0.18647 z"
+ id="path4580" />
+ <path
+ id="path4582"
+ d="m 95.998958,472.43902 -0.994499,0.9945 7.469101,7.4691 -0.98414,0.98414 7.45874,7.45874 -0.9945,0.9945 12.75238,12.75238 12.76274,-12.75238 -0.9945,-0.9945 7.45874,-7.45874 -0.98414,-0.98414 7.4691,-7.4691 -0.99449,-0.9945 -24.71745,24.70708 -24.707082,-24.70708 z"
+ style="color:#000000;display:none;overflow:visible;visibility:visible;fill:#000000;fill-opacity:1;stroke:none;stroke-width:0.82688445;marker:none;enable-background:accumulate"
+ inkscape:connector-curvature="0" />
+ <path
+ id="path4584"
+ d="m 120.70604,433.20811 -30.953779,30.96414 30.953779,30.96414 30.96414,-30.96414 -30.96414,-30.96414 z m 0,0.54904 30.4151,30.4151 -30.4151,30.41509 -30.415092,-30.41509 30.415092,-30.4151 z"
+ style="color:#000000;display:none;overflow:visible;visibility:visible;fill:#000000;fill-opacity:1;stroke:none;stroke-width:0.80000001;marker:none;enable-background:accumulate"
+ <path
+ id="path4588"
+ d="m 96.632099,500.68901 0,0.41437 19.993571,0 0,-0.41437 -19.993571,0 z"
+ style="color:#000000;font-style:normal;font-variant:normal;font-weight:normal;font-stretch:normal;font-size:medium;line-height:normal;font-family:Sans;-inkscape-font-specification:Sans;text-indent:0;text-align:start;text-decoration:none;text-decoration-line:none;letter-spacing:normal;word-spacing:normal;text-transform:none;direction:ltr;block-progression:tb;writing-mode:lr-tb;baseline-shift:baseline;text-anchor:start;display:none;overflow:visible;visibility:visible;fill:#000000;fill-opacity:1;stroke:none;stroke-width:1.25;marker:none;enable-background:accumulate" />
+ <path
+ d="m 124.79677,500.68901 0,0.41437 19.99357,0 0,-0.41437 -19.99357,0 z"
+ id="path4590"
+ <path
+ id="path4594"
+ style="display:none;fill:#000000;fill-opacity:0.44075832;stroke:none"
+ <path
+ id="path4596" />
+ <path
+ id="path4598" />
+ <path
+ id="path4602"
+ <path
+ id="path4604"
+ <rect
+ sodipodi:insensitive="true"
+ ry="5.0041995"
+ rx="5.0041995"
+ y="395.58936"
+ x="8.1167259"
+ height="145.12178"
+ width="225.189"
+ id="rect4608"
+ style="color:#000000;display:none;overflow:visible;visibility:visible;fill:#c6c6c6;fill-opacity:1;fill-rule:nonzero;stroke:none;stroke-width:0.125;marker:none;enable-background:accumulate" />
+ <path
+ id="path4610"
+ style="display:none;fill:#ffffff;fill-opacity:0.43668123;stroke:none"
+ <path
+ style="color:#000000;display:none;overflow:visible;visibility:visible;fill:#ffffff;fill-opacity:1;stroke:none;stroke-width:0.82688445;marker:none;enable-background:accumulate"
+ id="path4612" />
+ <path
+ style="color:#000000;display:none;overflow:visible;visibility:visible;fill:#ffffff;fill-opacity:1;stroke:none;stroke-width:0.80000001;marker:none;enable-background:accumulate"
+ id="path4614" />
+ <path
+ style="color:#000000;font-style:normal;font-variant:normal;font-weight:normal;font-stretch:normal;font-size:medium;line-height:normal;font-family:Sans;-inkscape-font-specification:Sans;text-indent:0;text-align:start;text-decoration:none;text-decoration-line:none;letter-spacing:normal;word-spacing:normal;text-transform:none;direction:ltr;block-progression:tb;writing-mode:lr-tb;baseline-shift:baseline;text-anchor:start;display:none;overflow:visible;visibility:visible;fill:#ffffff;fill-opacity:1;stroke:none;stroke-width:1.25;marker:none;enable-background:accumulate"
+ id="path4618"
+ <path
+ id="path4620"
+ style="color:#000000;font-style:normal;font-variant:normal;font-weight:normal;font-stretch:normal;font-size:medium;line-height:normal;font-family:Sans;-inkscape-font-specification:Sans;text-indent:0;text-align:start;text-decoration:none;text-decoration-line:none;letter-spacing:normal;word-spacing:normal;text-transform:none;direction:ltr;block-progression:tb;writing-mode:lr-tb;baseline-shift:baseline;text-anchor:start;display:none;overflow:visible;visibility:visible;fill:#ffffff;fill-opacity:1;stroke:none;stroke-width:1.25;marker:none;enable-background:accumulate" />
+ <rect
+ id="rect4624"
+ width="225.189"
+ x="8.1167259"
+ y="395.58936"
+ rx="5.0041995"
+ ry="5.0041995"
+ sodipodi:insensitive="true" />
+ <path
+ style="display:none;fill:#ffffff;fill-opacity:1;stroke:none"
+ id="path4626" />
+ <path
+ id="path4628"
+ <path
+ id="path4630"
+ <path
+ id="path4634"
+ <path
+ id="path4636"
+ <flowRoot
+ transform="translate(25.883476,474.13302)"
+ style="font-style:normal;font-variant:normal;font-weight:normal;font-stretch:normal;font-size:22px;line-height:125%;font-family:Fontin;-inkscape-font-specification:Fontin;text-align:center;letter-spacing:0px;word-spacing:0px;writing-mode:lr-tb;text-anchor:middle;fill:#000000;fill-opacity:1;stroke:none"
+ id="flowRoot3901-8"
+ inkscape:export-filename="/home/vincent/Bureau/recto.png"
+ inkscape:export-xdpi="300"
+ id="flowRegion3903-7"><rect
+ ry="0"
+ y="56.338501"
+ x="48.401169"
+ height="19.545349"
+ width="190.57059"
+ id="rect3905-9"
+ style="text-align:center;text-anchor:middle" /></flowRegion><flowPara
+ id="flowPara3909-8"
+ style="font-style:italic;font-variant:normal;font-weight:normal;font-stretch:normal;font-size:13px;font-family:'Fira Sans';-inkscape-font-specification:'Fira Sans Italic';text-align:center;text-anchor:middle">http://grass.osgeo.org </flowPara><flowPara
+ id="flowPara3911-4"
+ style="font-style:normal;font-variant:normal;font-weight:normal;font-stretch:normal;font-size:12px;font-family:'Fira Sans';-inkscape-font-specification:'Fira Sans';text-align:center;text-anchor:middle" /><flowPara
+ id="flowPara3913-5"
+ id="flowPara3915-5"
+ id="flowPara3917-6"
+ id="flowPara3919-6" /><flowPara
+ id="flowPara3921-0"
+ style="font-size:10px;text-align:center;text-anchor:middle"
+ id="flowPara3923-6" /><flowPara
+ id="flowPara3925-0" /><flowPara
+ id="flowPara3927-2" /><flowPara
+ id="flowPara3929-9" /><flowPara
+ id="flowPara3931-5" /><flowPara
+ id="flowPara3933-3"
+ style="font-size:10px;text-align:center;text-anchor:middle" /><flowPara
+ id="flowPara3935-5"
+ id="flowPara3937-2"
+ id="flowPara3939-7"
+ id="flowPara3941-0"
+ id="flowPara3943-0"
+ id="flowPara3945-6"
+ id="flowPara3947-5"
+ id="flowPara3949-4"
+ id="flowPara3951-0"
+ id="flowPara3953-4" /><flowPara
+ id="flowPara3955-0" /></flowRoot> <g
+ id="g6073"
+ transform="matrix(0.81887677,0,0,0.81887677,71.131591,101.08169)"
+ <path
+ style="display:inline;fill:#8f8f8f;fill-opacity:1;stroke:none"
9683,-0.47653 0.15539,-0.4351 0.18647,-0.32114 0,-0.63192 -0.0622,-0.79767 0.2797,-0.51797 -0.12431,-0.75623 0,-0.56977 0.10359,-0.32114 0.21755,-0.71479 0.15539,-0.3833 -0.29006,-0.47653 0.24862,-0.47653 -0.39365,-0.2797 -0.23827,-0.7148 0.34186,-0.55941 -0.47653,-0.15539 -0.20719,-0.37293 0,-0.32114 -0.21754,-0.36258 -0.21755,-0.19683 0.0207,-0.30042 0,-0.3315 -0.10359,-0.90126 -0.0725,-0.51797 -0.32114,-0.23827 -0.15539,-0.2797 -0.36258,-0.17611 -0.21755,-0.39366 0.0414,-0.44545 -0.0414,-0.45581 -0.23826,-0.39366 -0.41438,-0.0829 -0.38329,-0.13467 -0.19683,-0.27971 -0.13467,-0.30042 -0.30042,0.19683 -0.12432,0.3833 -0.0622,0.41437 -0.19683,0.65264 -0.13467,-0.21755 0.0622,0.79768 -0.0414,0.1761 0,0.30043 0.11395,0.23826 0.10359,0.32114 0.19683,0.25899 0.0829,0.11395 0.0622,0.30042 -0.24862,0.18647 0.10359,0.26934 -0.23826,0.30042 0.0414,0.23827 0.0622,0.23827 0.19683,0.23826 0.17611,0.21755 0.23826,0.20718 0.0414,0.17611 -0.0829,0.25899 -0.19683,0.17611 -0.0932,0.14503 0.0311,0.3
7294 0.30043,0.19682 0.17611,0.18647 0.10359,0.37294 -0.32114,0.3833 -0.0518,0.26934 0.13467,0.30042 0.19683,0.23827 0,0.23826 0.14503,0.18647 0.13467,0.15539 0.1036,0.17611 -0.0622,0.30042 0.19683,0.2797 0.17611,0.0414 0.0622,0.13467 -0.0622,0.23827 0.16575,0.34186 0.17611,0.13467 0.13467,0.2797 -0.13467,0.47653 0.19683,0.4351 0.18646,0.0829 0.0932,0.19683 0.0414,0.5594 -0.1036,0.23827 -0.0932,0.2797 0.2797,1.40888 0.49725,0.32114 -0.0414,6.11202 -0.58012,6.59891 -0.34186,3.82261 -0.55941,4.64099 -0.21754,0.55941 -1.84397,-3.15961 -0.63192,-4.23698 -0.81839,-6.87861 -0.97378,-6.38137 0.0725,5.82196 0.34188,4.8171 0.59048,4.5892 -4.11266,-6.51604 -5.90484,-8.85725 -1.35708,-1.8854 -0.11395,0 0.39365,1.12917 0.73552,1.8336 1.07737,2.44481 1.88541,4.04016 1.13953,2.03043 1.40887,2.44481 2.91098,4.60991 2.63128,4.18519 0.40402,3.75009 1.25348,8.56719 -6.6e-4,-0.005 -1.44954,-4.50099 -3.06637,-7.55198 -2.44481,-5.07609 -3.24248,-5.27292 -1.64714,-2.1651 -1.31564,-1.31564 -2.14438,-1.989
0.8909,1.0981 1.43995,1.47102 0.84947,0.95306 0.55941,0.97378 0.67335,1.07738 1.0981,1.8854 0.95306,1.75073 0.97378,2.16511 1.19133,2.89026 2.33085,6.02915 2.44481,6.36065 1.47103,4.49597 z m -4.2898,-4.27103 -0.42661,-1.14186 -0.78731,-1.49175 -1.71965,-3.28392 -2.4241,-4.37165 -1.70929,-2.80739 -1.58498,-2.42409 -0.85983,-1.19132 -0.7148,-0.7148 1.23277,2.34122 1.12917,2.62092 1.69893,3.86404 0.74588,1.70929 0.74717,2.22201 z m -10.22657,-17.42678 -0.0207,-0.0414 -0.0622,-0.0414 z m 26.01237,-7.8006 -0.41438,1.73001 -1.87504,7.50018 -0.91163,4.2577 -0.95306,5.1486 -1.05665,3.35644 -0.37294,-0.87019 -2.40337,-4.45452 0.80803,-1.87505 2.63128,-5.51118 1.40887,-2.96278 1.8854,-3.978 z m 2.33085,5.5837 -0.34186,1.98899 -0.97378,3.30464 -0.97378,2.44481 -1.07737,3.18033 -0.56976,3.12852 -0.53869,3.32601 1.94756,-1.97929 0.0829,-1.01522 0.21755,-1.76109 0.51797,-2.48625 1.12917,-4.44416 0.51797,-3.29428 z m -13.9437,9.06444 0.78731,1.31564 -0.16575,3.06637 -0.12431,0.0932 z m 1.326,2.2
0654 0.45581,0.75624 -0.35222,0.82875 -0.25898,0.18647 z"
+ id="path4566" />
+ <path
+ id="path4568"
+ style="color:#000000;display:inline;overflow:visible;visibility:visible;fill:#000000;fill-opacity:1;stroke:none;stroke-width:0.82688445;marker:none;enable-background:accumulate"
+ <path
+ id="path4570"
+ style="color:#000000;display:inline;overflow:visible;visibility:visible;fill:#000000;fill-opacity:1;stroke:none;stroke-width:0.80000001;marker:none;enable-background:accumulate"
+ <path
+ id="path4574"
+ <path
+ id="path4576"
+ <g
+ style="display:inline"
+ id="g4549"
+ transform="matrix(0.88454173,0,0,0.88454173,-209.97959,22.086839)"
+ inkscape:export-filename="/home/vincent/Documents/developpement/grass/grass_splash/logo/logo_variant_bw_bg.png"
+ <flowRoot
+ id="flowRoot5356"
+ transform="translate(-5.5223396,0)"><flowRegion
+ id="flowRegion5358"
+ y="543.79785"
+ x="335.34653"
+ width="70.314125"
+ id="rect5360" /></flowRegion><flowPara
+ id="flowPara5362"
+ id="flowSpan4547"
+ id="flowRoot6517"
+ transform="matrix(0.78531774,0,0,0.78531774,106.84321,438.46065)"
+ id="flowRegion6519"><rect
+ id="rect6521"
+ width="89.535889"
+ x="358.83777"
+ y="134.13319"
+ id="flowPara6523">GIS</flowPara></flowRoot> </g>
+ </g>
+ <flowRoot
+ transform="translate(760.03427,475.45512)"
+ id="flowRoot3901"
+ id="flowRegion3903"><rect
+ ry="0"
+ y="56.338501"
+ x="48.401169"
+ height="17.045349"
+ width="161.07059"
+ id="rect3905"
+ id="flowPara3909"
+ style="font-style:italic;font-variant:normal;font-weight:normal;font-stretch:normal;font-size:13px;font-family:'Fira Sans';-inkscape-font-specification:'Fira Sans Italic';text-align:center;text-anchor:middle">http://www.osgeo.org</flowPara><flowPara
+ id="flowPara3911"
+ id="flowPara3913"
+ id="flowPara3915"
+ id="flowPara3917"
+ id="flowPara3919" /><flowPara
+ id="flowPara3921"
+ id="flowPara3923" /><flowPara
+ id="flowPara3925" /><flowPara
+ id="flowPara3927" /><flowPara
+ id="flowPara3929" /><flowPara
+ id="flowPara3931" /><flowPara
+ id="flowPara3933"
+ id="flowPara3935"
+ id="flowPara3937"
+ id="flowPara3939"
+ id="flowPara3941"
+ id="flowPara3943"
+ id="flowPara3945"
+ id="flowPara3947"
+ id="flowPara3949"
+ id="flowPara3951"
+ id="flowPara3953" /><flowPara
+ id="flowPara3955" /></flowRoot> <flowRoot
+ xml:space="preserve"
+ id="flowRoot9798"
+ transform="translate(1164.4439,543.46206)"
+ inkscape:export-filename="/home/vincent/Bureau/verso.png"
+ inkscape:export-ydpi="300"><flowRegion
+ id="flowRegion9800"><rect
+ id="rect9802"
+ width="237.93361"
+ height="123.76111"
+ x="48.401169"
+ y="56.338501"
+ id="flowPara9822"
+ style="font-style:italic;font-variant:normal;font-weight:normal;font-stretch:normal;font-size:12px;line-height:125%;font-family:'Fira Sans';-inkscape-font-specification:'Fira Sans Italic';text-align:start;writing-mode:lr-tb;text-anchor:start">Gestione dei dati</flowPara><flowPara
+ id="flowPara9885">- Analisi di dati Raster / Vector / Voxel</flowPara><flowPara
+ id="flowPara9887">- 2D / 3D Raster / Vector modeling</flowPara><flowPara
+ id="flowPara9889">- Manipolazione di immagini</flowPara><flowPara
+ id="flowPara9891">- Vettoriali topologici </flowPara><flowPara
+ id="flowPara5067">- Analisi di reti</flowPara><flowPara
+ id="flowPara9893">- Geostatistica (Interfaccia a R)</flowPara><flowPara
+ id="flowPara9895">- Dataset temporali</flowPara><flowPara
+ id="flowPara9848"
+ style="font-style:normal;font-variant:normal;font-weight:normal;font-stretch:normal;font-size:12px;font-family:'Fira Sans';-inkscape-font-specification:'Fira Sans'" /></flowRoot> <flowRoot
+ id="flowRoot9916"
+ transform="translate(1168.0489,403.67728)"
+ id="flowRegion9918"><rect
+ id="rect9920"
+ width="234.20609"
+ height="135.578"
+ x="48.401169"
+ y="56.338501"
+ style="font-style:normal;font-variant:normal;font-weight:bold;font-stretch:normal;font-size:14px;font-family:'Fira Sans';-inkscape-font-specification:'Fira Sans Bold'"
+ id="flowPara9922" /><flowPara
+ id="flowPara9967">Linguaggi di programmazione</flowPara><flowPara
+ id="flowPara5583">- ANSI C</flowPara><flowPara
+ id="flowPara9969">- Interfaccia GRASS-SWIG</flowPara><flowPara
+ id="flowPara9971">- Python: API, libreria di scripting e GUI</flowPara><flowPara
+ id="flowPara9934"
+ id="flowPara9936"
+ id="flowPara9938"
+ id="flowPara9940"
+ style="font-style:normal;font-variant:normal;font-weight:bold;font-stretch:normal;font-size:12px;font-family:'Fira Sans';-inkscape-font-specification:'Fira Sans Bold'" /><flowPara
+ id="flowPara9942"
+ id="flowPara9944"
+ id="flowPara9946"
+ id="flowPara9948"
+ id="flowPara9950"
+ id="flowPara9952"
+ id="flowPara9954"
+ id="flowPara9956"
+ style="font-size:10px" /></flowRoot> <g
+ style="display:inline;filter:url(#filter5962-7-1-6)"
+ id="g5929-4-5-6"
+ transform="translate(952.84297,-608.21423)">
+ <flowRoot
+ id="flowRoot4976-7-3-1"
+ id="flowRegion4978-2-5-9"><rect
+ id="rect4980-7-1-2"
+ width="284.66568"
+ x="463.03217"
+ id="flowPara4982-5-4-1"
+ style="font-style:normal;font-variant:normal;font-weight:300;font-stretch:normal;font-size:18.48817253px;line-height:125%;font-family:'Fira Sans';-inkscape-font-specification:'Fira Sans Light';text-align:start;writing-mode:lr-tb;text-anchor:start;fill:#008f00" /></flowRoot> </g>
+ <g
+ id="layer1-1"
+ inkscape:label="Calque 1"
+ transform="matrix(0.28124707,0,0,0.28124707,778.06351,372.55615)"
+ <g
+ transform="matrix(1.25,0,0,-1.25,309.911,475.81882)"
+ id="g21">
+ <path
+ id="path23"
+ style="fill:#000000;fill-opacity:1;fill-rule:nonzero;stroke:none"
+ d="m 0,0 c -2.13,3.634 -3.21,8.231 -3.21,13.663 0,5.647 1.053,10.163 3.123,13.423 2.051,3.226 5.085,4.858 9.016,4.858 9.046,0 13.441,-5.978 13.441,-18.281 C 22.37,7.63 21.205,2.883 18.908,-0.442 16.634,-3.736 13.274,-5.404 8.929,-5.404 5.108,-5.404 2.106,-3.586 0,0 m -5.357,31.244 c -3.491,-4.698 -5.262,-10.612 -5.262,-17.581 0,-7.401 1.734,-13.557 5.163,-18.297 3.445,-4.77 8.283,-7.189 14.382,-7.189 6.678,0 11.882,2.289 15.47,6.801 3.572,4.496 5.386,10.782 5.386,18.685 0,7.715 -1.808,13.816 -5.374,18.147 -3.574,4.347 -8.783,6.55 -15.482,6.55 -5.967,0 -10.769,-2.395 -14.283,-7.116"
+ </g>
+ <g
+ transform="matrix(1.25,0,0,-1.25,357.65638,432.38132)"
+ id="g25">
+ <path
+ id="path27"
+ d="m 0,0 c -2.586,-2.399 -3.895,-5.466 -3.895,-9.111 0,-2.982 0.668,-5.579 1.991,-7.709 1.318,-2.132 3.664,-3.995 6.976,-5.538 l 3.862,-1.807 c 3.408,-1.606 5.56,-3.1 6.392,-4.439 0.832,-1.338 1.252,-2.81 1.252,-4.372 0,-2.076 -0.75,-3.808 -2.236,-5.147 -1.488,-1.347 -3.494,-2.031 -5.971,-2.031 -1.402,0 -3.017,0.296 -4.805,0.889 -1.785,0.586 -3.293,1.328 -4.484,2.207 l -0.279,0.207 -2.592,-6.545 0.176,-0.117 c 3.045,-2.031 6.763,-3.06 11.056,-3.06 4.891,0 8.852,1.291 11.782,3.837 2.941,2.553 4.435,5.708 4.435,9.378 0,3.354 -0.68,6.159 -2.025,8.345 -1.346,2.188 -3.707,4.09 -7.02,5.657 l -3.935,1.868 c -2.508,1.212 -4.188,2.157 -4.985,2.819 -0.785,0.648 -1.408,1.465 -1.845,2.429 -0.444,0.969 -0.666,2.057 -0.666,3.239 0,1.906 0.621,3.49 1.843,4.701 1.225,1.214 2.94,1.826 5.094,1.826 1.496,0 3.15,-0.297 4.916,-0.875 1.762,-0.584 3.086,-1.191 3.943,-1.808 l 0.288,-0.215 2.113,6.218 -0.139,0.116 C 19.121,2.719 15.33,3.61 9.969,3.61 5.934,3.61 2.578,2.396 0,0"
+ </g>
+ <g
+ transform="matrix(1.25,0,0,-1.25,400.92537,436.64157)"
+ id="g29">
+ <path
+ id="path31"
+ d="m 0,0 c -4.223,-4.647 -6.365,-10.792 -6.365,-18.251 0,-7.48 1.953,-13.564 5.806,-18.084 3.866,-4.53 9.202,-6.83 15.864,-6.83 2.951,0 6.039,0.466 9.17,1.374 3.142,0.911 5.63,2.14 7.396,3.644 l 0.096,0.076 0,21.3 -13.711,0 0,-6.083 6.633,0 0,-10.875 c -2.09,-1.997 -4.848,-3.017 -8.209,-3.017 -4.805,0 -8.647,1.677 -11.428,4.989 -2.791,3.322 -4.203,7.778 -4.203,13.24 0,5.748 1.439,10.428 4.285,13.905 2.832,3.463 6.752,5.216 11.658,5.216 3.086,0 6.287,-1.216 9.518,-3.609 l 0.254,-0.187 2.947,5.865 -0.156,0.135 C 26.377,5.601 22.217,7.021 17.182,7.021 10.01,7.021 4.229,4.655 0,0"
+ </g>
+ <g
+ transform="matrix(1.25,0,0,-1.25,460.65199,454.69569)"
+ id="g33">
+ <path
+ id="path35"
+ d="m 0,0 c 1.814,1.733 4.098,2.612 6.783,2.612 2.875,0 5.178,-0.894 6.84,-2.663 1.455,-1.559 2.18,-3.539 2.236,-5.841 l -18.742,0 C -2.598,-3.573 -1.662,-1.575 0,0 m -4.854,3.604 c -3.55,-3.531 -5.351,-8.276 -5.351,-14.106 0,-5.62 1.756,-10.154 5.219,-13.49 3.115,-3.027 6.951,-4.561 11.41,-4.561 3.074,0 5.898,0.472 8.408,1.406 2.006,0.71 3.527,1.574 4.512,2.569 l 0.142,0.143 -2.884,4.932 -0.239,-0.215 c -2.316,-2.045 -5.25,-3.083 -8.724,-3.083 -3.039,0 -5.549,0.947 -7.475,2.809 -2.133,2.095 -3.221,5.134 -3.269,9.011 l 25.205,0 0.052,0.195 c 0.332,1.178 0.5,2.48 0.5,3.873 0,4.531 -1.412,8.225 -4.205,10.973 C 15.57,6.916 11.551,8.366 6.502,8.366 2.146,8.366 -1.67,6.763 -4.854,3.604"
+ </g>
+ <g
+ transform="matrix(1.25,0,0,-1.25,503.27886,467.21044)"
+ id="g37">
+ <path
+ id="path39"
+ d="m 0,0 c 0,3.992 0.838,7.162 2.488,9.422 1.633,2.233 3.848,3.365 6.588,3.365 6.084,0 9.043,-4.181 9.043,-12.787 0,-4.015 -0.814,-7.22 -2.428,-9.526 -1.587,-2.276 -3.812,-3.426 -6.615,-3.426 C 2.969,-12.952 0,-8.717 0,0 M -2.641,13.292 C -5.586,9.927 -7.08,5.458 -7.08,0 c 0,-5.627 1.432,-10.174 4.258,-13.504 2.834,-3.343 6.836,-5.037 11.898,-5.037 4.951,0 8.918,1.677 11.799,4.985 2.869,3.303 4.322,7.861 4.322,13.556 0,5.714 -1.42,10.253 -4.224,13.487 -2.815,3.244 -6.815,4.891 -11.897,4.891 -4.818,0 -8.763,-1.711 -11.717,-5.086"
+ </g>
+ <g
+ transform="matrix(1.25,0,0,-1.25,278.2985,512.61695)"
+ id="g41">
+ <path
+ id="path43"
+ style="fill:#636363;fill-opacity:1;fill-rule:nonzero;stroke:none"
+ d="m 0,0 -0.851,-4.646 -1.666,0 0.851,4.646 -2.295,8.265 1.739,0 1.149,-4.365 c 0.203,-0.761 0.37,-1.508 0.517,-2.234 l 0.02,0 c 0.428,0.782 0.962,1.623 1.499,2.485 l 2.591,4.114 1.869,0 L 0,0"
+ </g>
+ <g
+ transform="matrix(1.25,0,0,-1.25,288.72937,508.14669)"
+ id="g45">
+ <path
+ id="path47"
+ d="m 0,0 c -2.018,0 -3.367,-2.332 -3.367,-4.725 0,-1.414 0.556,-2.199 1.943,-2.199 1.795,0 3.369,1.99 3.369,4.765 C 1.945,-0.764 1.333,0 0,0 m -1.701,-8.395 c -2.317,0 -3.37,1.204 -3.37,3.385 0,3.787 2.331,6.465 5.331,6.465 2.426,0 3.424,-1.415 3.424,-3.424 0,-3.922 -2.612,-6.426 -5.385,-6.426"
+ </g>
+ <g
+ transform="matrix(1.25,0,0,-1.25,303.85875,518.42382)"
+ id="g49">
+ <path
+ id="path51"
+ d="m 0,0 -1.627,0 c 0.129,0.63 0.371,1.72 1.016,3.746 l -0.035,0 c -0.872,-2.009 -2.313,-3.938 -4.239,-3.938 -1.701,0 -2.295,1.241 -1.924,3.231 l 1.185,6.464 1.645,0 -1.126,-6.081 c -0.28,-1.492 -0.019,-2.144 0.794,-2.144 1.704,0 3.609,3.733 4.036,6.084 l 0.386,2.141 1.627,0 L 0,0"
+ </g>
+ <g
+ transform="matrix(1.25,0,0,-1.25,314.98675,508.40794)"
+ id="g53">
+ <path
+ id="path55"
+ d="m 0,0 c -1.7,0.498 -3.517,-3.232 -3.998,-5.875 l -0.388,-2.138 -1.631,0 1.741,9.504 1.593,0 C -2.832,0.67 -3.09,-0.344 -3.628,-2.01 l 0.036,-0.018 c 1.038,2.313 2.15,3.997 3.925,3.692 L 0,0"
+ </g>
+ <g
+ transform="matrix(1.25,0,0,-1.25,329.44587,503.98407)"
+ id="g57">
+ <path
+ id="path59"
+ d="m 0,0 c -2.959,0 -5.07,-3.136 -5.07,-6.792 0,-2.083 0.997,-3.383 2.904,-3.383 2.831,0 5.145,3.002 5.145,6.827 C 2.979,-1.302 2.019,0 0,0 m -2.405,-11.746 c -3.018,0 -4.462,1.76 -4.462,4.707 0,4.667 3.071,8.586 7.144,8.586 2.905,0 4.494,-1.72 4.494,-4.705 0,-4.912 -3.218,-8.588 -7.176,-8.588"
+ </g>
+ <g
+ transform="matrix(1.25,0,0,-1.25,344.15537,508.14669)"
+ id="g61">
+ <path
+ id="path63"
+ d="m 0,0 c -1.738,0 -3.607,-3.807 -4.034,-6.043 l -0.148,-0.728 c 0.389,-0.132 0.945,-0.227 1.334,-0.227 2.703,0 3.793,2.909 3.793,5.258 C 0.945,-0.497 0.576,0 0,0 m -3.164,-8.357 c -0.462,0 -0.87,0.039 -1.295,0.115 l -0.854,-4.706 -1.625,0 2.608,14.231 1.63,0 c -0.166,-0.822 -0.407,-1.76 -1.037,-3.808 l 0.039,-0.018 c 0.942,2.238 2.387,4.016 4.274,4.016 1.33,0 2.053,-0.88 2.053,-2.888 0,-3.5 -1.76,-6.942 -5.793,-6.942"
+ </g>
+ <g
+ transform="matrix(1.25,0,0,-1.25,355.07575,507.95382)"
+ id="g65">
+ <path
+ id="path67"
+ d="M 0,0 C -1.463,0 -2.443,-1.322 -2.867,-2.926 -0.018,-2.812 1.242,-2.22 1.242,-1.07 1.242,-0.381 0.74,0 0,0 m -3.072,-4.187 c -0.055,-0.29 -0.092,-0.766 -0.092,-1.11 0,-1.474 0.5,-1.855 1.98,-1.855 0.868,0 1.795,0.211 2.59,0.552 l 0,-1.378 c -0.888,-0.362 -1.961,-0.571 -3.164,-0.571 -2.109,0 -3.09,0.934 -3.09,3.078 0,3.694 1.981,6.772 5.034,6.772 1.96,0 2.701,-1.033 2.701,-2.162 0,-2.047 -2.018,-3.174 -5.959,-3.326"
+ </g>
+ <g
+ transform="matrix(1.25,0,0,-1.25,369.14075,518.42382)"
+ id="g69">
+ <path
+ id="path71"
+ d="M 0,0 -1.627,0 -0.5,6.082 c 0.279,1.491 0.02,2.14 -0.813,2.14 -1.703,0 -3.591,-3.728 -4.015,-6.083 L -5.717,0 -7.346,0 -6.42,4.972 c 0.24,1.356 0.572,3.136 0.811,4.531 l 1.613,0 C -4.109,8.872 -4.365,7.784 -5.014,5.755 l 0.037,0 c 0.868,2.009 2.331,3.939 4.254,3.939 1.702,0 2.278,-1.243 1.928,-3.23 L 0,0"
+ </g>
+ <g
+ transform="matrix(1.25,0,0,-1.25,387.08999,504.25019)"
+ id="g73">
+ <path
+ id="path75"
+ d="m 0,0 c -0.609,0.229 -1.273,0.308 -1.738,0.308 -1.85,0 -2.684,-1.091 -2.684,-2.123 0,-2.334 3.813,-2.414 3.813,-5.472 0,-2.39 -2.036,-4.246 -4.94,-4.246 -0.666,0 -1.445,0.078 -2.055,0.268 l 0.315,1.685 c 0.519,-0.231 1.258,-0.403 1.887,-0.403 1.925,0 3.017,0.977 3.017,2.41 0,2.237 -3.795,2.256 -3.795,5.355 0,2.121 1.61,3.979 4.61,3.979 0.629,0 1.183,-0.038 1.886,-0.19 L 0,0"
+ </g>
+ <g
+ transform="matrix(1.25,0,0,-1.25,394.72911,508.14669)"
+ id="g77">
+ <path
+ id="path79"
+ d="m 0,0 c -2.018,0 -3.369,-2.332 -3.369,-4.725 0,-1.414 0.553,-2.199 1.941,-2.199 1.795,0 3.367,1.99 3.367,4.765 C 1.939,-0.764 1.332,0 0,0 m -1.703,-8.395 c -2.315,0 -3.371,1.204 -3.371,3.385 0,3.787 2.334,6.465 5.332,6.465 2.426,0 3.424,-1.415 3.424,-3.424 0,-3.922 -2.61,-6.426 -5.385,-6.426"
+ </g>
+ <g
+ transform="matrix(1.25,0,0,-1.25,409.85612,518.42382)"
+ id="g81">
+ <path
+ id="path83"
+ d="m 0,0 -1.629,0 c 0.131,0.63 0.371,1.72 1.018,3.746 l -0.035,0 c -0.872,-2.009 -2.317,-3.938 -4.239,-3.938 -1.705,0 -2.297,1.241 -1.926,3.231 l 1.184,6.464 1.648,0 -1.128,-6.081 c -0.28,-1.492 -0.02,-2.144 0.796,-2.144 1.702,0 3.61,3.733 4.034,6.084 l 0.386,2.141 1.631,0 L 0,0"
+ </g>
+ <g
+ transform="matrix(1.25,0,0,-1.25,420.95961,508.40794)"
+ id="g85">
+ <path
+ id="path87"
+ d="m 0,0 c -1.701,0.498 -3.516,-3.232 -4,-5.875 l -0.383,-2.138 -1.633,0 1.741,9.504 1.591,0 C -2.83,0.67 -3.09,-0.344 -3.627,-2.01 l 0.037,-0.018 c 1.035,2.313 2.147,3.997 3.924,3.692 L 0,0"
+ </g>
+ <g
+ transform="matrix(1.25,0,0,-1.25,429.79499,508.57519)"
+ id="g89">
+ <path
+ id="path91"
+ d="m 0,0 c -0.5,0.229 -1.033,0.364 -1.684,0.364 -2.332,0 -3.421,-2.717 -3.421,-4.879 0,-0.992 0.312,-2.009 1.923,-2.009 0.721,0 1.498,0.173 2.075,0.459 l -0.114,-1.509 c -0.646,-0.249 -1.498,-0.459 -2.425,-0.459 -2.385,0 -3.2,1.337 -3.2,3.136 0,3.634 1.981,6.675 5.274,6.675 0.759,0 1.369,-0.114 1.943,-0.285 L 0,0"
+ </g>
+ <g
+ transform="matrix(1.25,0,0,-1.25,436.89711,507.95382)"
+ id="g93">
+ <path
+ id="path95"
+ d="M 0,0 C -1.461,0 -2.441,-1.322 -2.867,-2.926 -0.02,-2.812 1.24,-2.22 1.24,-1.07 1.24,-0.381 0.74,0 0,0 m -3.072,-4.187 c -0.055,-0.29 -0.092,-0.766 -0.092,-1.11 0,-1.474 0.5,-1.855 1.982,-1.855 0.866,0 1.793,0.211 2.59,0.552 l 0,-1.378 c -0.887,-0.362 -1.963,-0.571 -3.166,-0.571 -2.107,0 -3.088,0.934 -3.088,3.078 0,3.694 1.979,6.772 5.032,6.772 1.96,0 2.703,-1.033 2.703,-2.162 0,-2.047 -2.018,-3.174 -5.961,-3.326"
+ </g>
+ <g
+ transform="matrix(1.25,0,0,-1.25,459.17486,504.63107)"
+ id="g97">
+ <path
+ id="path99"
+ d="m 0,0 c -0.869,0.326 -1.74,0.459 -2.592,0.459 -3.625,0 -5.088,-3.672 -5.088,-6.924 0,-1.854 0.742,-3.156 3.147,-3.156 1.035,0 2.053,0.229 2.904,0.632 l -0.074,-1.589 c -0.996,-0.381 -2.164,-0.61 -3.328,-0.61 -3.573,0 -4.498,2.162 -4.498,4.436 0,4.515 2.459,8.742 7.177,8.742 1.057,0 1.944,-0.154 2.758,-0.386 L 0,0"
+ </g>
+ <g
+ transform="matrix(1.25,0,0,-1.25,465.76912,508.14669)"
+ id="g101">
+ <path
+ id="path103"
+ d="m 0,0 c -2.018,0 -3.367,-2.332 -3.367,-4.725 0,-1.414 0.554,-2.199 1.941,-2.199 1.797,0 3.367,1.99 3.367,4.765 C 1.941,-0.764 1.334,0 0,0 m -1.701,-8.395 c -2.315,0 -3.369,1.204 -3.369,3.385 0,3.787 2.33,6.465 5.33,6.465 2.424,0 3.424,-1.415 3.424,-3.424 0,-3.922 -2.608,-6.426 -5.385,-6.426"
+ </g>
+ <g
+ transform="matrix(1.25,0,0,-1.25,487.88587,518.42382)"
+ id="g105">
+ <path
+ id="path107"
+ d="m 0,0 -1.648,0 1.13,6.082 C -0.24,7.573 -0.5,8.243 -1.26,8.243 -2.832,8.243 -4.756,4.722 -5.238,2.139 L -5.625,0 -7.256,0 -6.127,6.082 c 0.279,1.491 0.037,2.161 -0.76,2.161 -1.552,0 -3.478,-3.521 -3.959,-6.104 L -11.234,0 l -1.627,0 0.922,4.972 c 0.261,1.415 0.576,3.136 0.814,4.531 l 1.611,0 C -9.621,8.872 -9.883,7.764 -10.531,5.755 l 0.037,0 c 0.849,1.99 2.295,3.939 4.183,3.939 1.184,0 1.85,-0.668 1.85,-1.853 0,-0.593 -0.148,-1.149 -0.443,-2.104 l 0.037,-0.019 c 0.849,2.046 2.295,3.976 4.181,3.976 1.666,0 2.241,-1.243 1.868,-3.23 L 0,0"
+ </g>
+ <g
+ transform="matrix(1.25,0,0,-1.25,498.94537,508.14669)"
+ id="g109">
+ <path
+ id="path111"
+ d="m 0,0 c -1.742,0 -3.611,-3.807 -4.037,-6.043 l -0.149,-0.728 c 0.389,-0.132 0.946,-0.227 1.332,-0.227 2.706,0 3.797,2.909 3.797,5.258 C 0.943,-0.497 0.572,0 0,0 m -3.166,-8.357 c -0.463,0 -0.871,0.039 -1.295,0.115 l -0.853,-4.706 -1.627,0 2.609,14.231 1.627,0 C -2.869,0.461 -3.113,-0.477 -3.74,-2.525 l 0.035,-0.018 c 0.947,2.238 2.389,4.016 4.277,4.016 1.332,0 2.053,-0.88 2.053,-2.888 0,-3.5 -1.756,-6.942 -5.791,-6.942"
+ </g>
+ <g
+ transform="matrix(1.25,0,0,-1.25,510.60074,508.05144)"
+ id="g113">
+ <path
+ id="path115"
+ d="m 0,0 c -2.738,0 -3.811,-2.924 -3.811,-5.277 0,-1.244 0.372,-1.743 0.944,-1.743 1.738,0 3.627,3.808 4.053,6.084 l 0.132,0.763 C 0.945,-0.076 0.521,0 0,0 m 1.463,-8.298 -1.647,0 c 0.168,0.819 0.518,2.084 1.075,3.862 l -0.039,0.017 c -0.666,-1.47 -2.053,-4.073 -4.291,-4.073 -1.332,0 -2.057,0.883 -2.057,2.888 0,3.502 1.758,6.963 5.775,6.963 1.055,0 2.035,-0.114 2.889,-0.289 C 2.186,-4.247 1.852,-6.023 1.463,-8.298"
+ </g>
+ <g
+ transform="matrix(1.25,0,0,-1.25,522.95662,508.24195)"
+ id="g117">
+ <path
+ id="path119"
+ d="m 0,0 c -0.447,0.152 -0.926,0.23 -1.387,0.23 -1.205,0 -1.834,-0.591 -1.834,-1.396 0,-1.512 2.793,-1.912 2.793,-4.056 0,-1.587 -1.349,-3.096 -3.959,-3.096 -0.611,0 -1.111,0.035 -1.574,0.133 l 0.297,1.529 c 0.48,-0.153 0.978,-0.248 1.498,-0.248 1.203,0 2.016,0.496 2.016,1.492 0,1.51 -2.776,1.761 -2.776,4.056 0,1.627 1.26,2.886 3.647,2.886 0.648,0 1.113,-0.057 1.576,-0.133 L 0,0"
+ </g>
+ <g
+ transform="matrix(1.25,0,0,-1.25,531.65536,508.24195)"
+ id="g121">
+ <path
+ id="path123"
+ d="m 0,0 c -0.447,0.152 -0.926,0.23 -1.391,0.23 -1.203,0 -1.832,-0.591 -1.832,-1.396 0,-1.512 2.795,-1.912 2.795,-4.056 0,-1.587 -1.349,-3.096 -3.959,-3.096 -0.609,0 -1.113,0.035 -1.574,0.133 l 0.297,1.529 c 0.48,-0.153 0.98,-0.248 1.496,-0.248 1.203,0 2.022,0.496 2.022,1.492 0,1.51 -2.78,1.761 -2.78,4.056 0,1.627 1.26,2.886 3.647,2.886 0.648,0 1.109,-0.057 1.572,-0.133 L 0,0"
+ </g>
+ <g
+ transform="matrix(1.25,0,0,-1.25,237.06925,447.07119)"
+ id="g125">
+ <path
+ id="path127"
+ style="fill:#646464;fill-opacity:1;fill-rule:evenodd;stroke:none"
+ d="m 0,0 17.893,5.752 -16.295,-9.135 9.334,-6.34 -10.619,2.807 5.941,-18.463 -9.404,16.9 -5.688,-9.453 2.135,10.875 -17.781,-5.935 16.347,9.4 -10.282,5.85 11.716,-2.43 -6.584,17.391 L -3.389,1.246 2.41,11.334 0,0 Z"
+ </g>
+ <g
+ transform="matrix(1.25,0,0,-1.25,233.01038,391.70994)"
+ id="g129">
+ <path
+ id="path131"
+ d="m 0,0 c 18.144,0 33.927,-10.073 42.085,-24.928 l 3.402,0.497 C 36.944,-8.01 19.79,3.215 0,3.215 c -5.536,0 -10.863,-0.889 -15.858,-2.512 l 1.988,-2.746 C -9.478,-0.72 -4.823,0 0,0"
+ </g>
+ <g
+ transform="matrix(1.25,0,0,-1.25,260.774,513.58857)"
+ id="g133">
+ <path
+ id="path135"
+ d="m 0,0 -28.781,33.65 -43.373,-6.333 32.799,28.005 0.447,0.383 -11.249,55.417 33.51,-45.9 L 26.767,71.56 -6.334,43.383 0,0 Z m -22.211,1.519 c -18.143,0 -33.932,10.07 -42.09,24.923 l 16.735,2.444 c 5.872,-7.41 14.944,-12.17 25.133,-12.17 1.753,0 3.471,0.146 5.147,0.417 L -6.26,4.241 C -11.251,2.481 -16.617,1.519 -22.211,1.519 m -25.701,88.513 3.616,-17.826 c -6.269,-5.852 -10.193,-14.184 -10.193,-23.435 0,-1.208 0.072,-2.396 0.202,-3.568 l -13.408,-11.449 0.117,0.1 c -1.693,4.909 -2.626,10.172 -2.626,15.657 0,17.049 8.896,32.009 22.292,40.521 M 9.622,48.771 c 0,1.773 -0.15,3.509 -0.427,5.205 L 33.356,74.544 1.651,69.914 c -5.875,6.689 -14.483,10.915 -24.084,10.915 -0.996,0 -1.979,-0.052 -2.952,-0.141 l -28.662,39.583 5.449,-26.862 c -14.906,-8.967 -24.88,-25.297 -24.88,-43.961 0,-6.293 1.139,-12.316 3.214,-17.886 l -8.461,-7.225 10.961,1.601 c 8.525,-16.482 25.716,-27.755 45.553,-27.755 6.434,0 12.583,1.199 18.254,3.366 l 6.936,-8.11 -4.53,31.023 C 5.286,30.341 9.622,39.
047 9.622,48.771"
+ </g>
+ <g
+ transform="matrix(1.25,0,0,-1.25,176.0695,481.16669)"
+ id="g137">
+ <path
+ id="path139"
+ d="m 0,0 c 8.524,-16.481 25.716,-27.755 45.553,-27.755 6.433,0 12.583,1.199 18.254,3.366 l -2.303,2.693 c -4.991,-1.76 -10.358,-2.723 -15.951,-2.723 -18.144,0 -33.932,10.07 -42.09,24.924 L 0,0 Z M 19.166,67.472 C 4.26,58.505 -5.714,42.175 -5.714,23.511 c 0,-6.293 1.139,-12.317 3.214,-17.887 l 2.686,2.293 c -1.694,4.908 -2.626,10.172 -2.626,15.656 0,17.049 8.896,32.009 22.292,40.522 l -0.686,3.377 z"
+ </g>
+ </g>
+ <g
+ id="g4729"
+ transform="translate(-411.47928,496.99505)"
+ <image
+ sodipodi:absref="/home/lucadelu/compilati/grass-promo/grassflyer/flyer_2016/it/../images/largedataset.png"
+ xlink:href="../images/largedataset.png"
+ y="331.20322"
+ x="2209.6113"
+ id="image4378"
+ preserveAspectRatio="none"
+ height="177.03552"
+ width="397.52524" />
+ <flowRoot
+ id="flowRoot3548-3"
+ style="font-style:normal;font-variant:normal;font-weight:normal;font-stretch:normal;font-size:22px;line-height:125%;font-family:Fontin;-inkscape-font-specification:Fontin;text-align:start;letter-spacing:0px;word-spacing:0px;writing-mode:lr-tb;text-anchor:start;display:inline;fill:#8f8f8f;fill-opacity:1;stroke:none"
+ transform="translate(2039.4582,503.85667)"><flowRegion
+ id="flowRegion3550-6"><rect
+ style="fill:#8f8f8f;fill-opacity:1"
+ id="rect3552-7"
+ width="404.5321"
+ height="31.612198"
+ x="168.55138"
+ y="12.585855"
+ style="font-style:italic;font-variant:normal;font-weight:normal;font-stretch:normal;font-size:10px;line-height:125%;font-family:'Fira Sans';-inkscape-font-specification:'Fira Sans, Italic';text-align:start;writing-mode:lr-tb;text-anchor:start;fill:#8f8f8f;fill-opacity:1"
+ id="flowPara3588-7">Visualizzazione e gestione facile dei più complessi datasets: grosse geometrie collegate a complessi DBMSs sono supportate.</flowPara></flowRoot> </g>
+ <flowRoot
+ id="flowRoot4227"
+ style="font-style:normal;font-variant:normal;font-weight:normal;font-stretch:normal;font-size:20px;line-height:125%;font-family:'EB Garamond';-inkscape-font-specification:'EB Garamond';text-align:start;letter-spacing:0px;word-spacing:0px;writing-mode:lr-tb;text-anchor:start;fill:#000000;fill-opacity:1;stroke:none;stroke-width:1px;stroke-linecap:butt;stroke-linejoin:miter;stroke-opacity:1"><flowRegion
+ id="flowRegion4229"><rect
+ id="rect4231"
+ width="50.447083"
+ height="28.826904"
+ x="1945.816"
+ y="789.13654" /></flowRegion><flowPara
+ id="flowPara4233" /></flowRoot> <g
+ id="g4681"
+ transform="translate(13.333333,0)"
+ <g
+ id="g4705">
+ <flowRoot
+ transform="translate(1484.8417,503.81581)"
+ style="font-style:normal;font-variant:normal;font-weight:normal;font-stretch:normal;font-size:22px;line-height:125%;font-family:Fontin;-inkscape-font-specification:Fontin;text-align:center;letter-spacing:0px;word-spacing:0px;writing-mode:lr-tb;text-anchor:middle;display:inline;fill:#8f8f8f;fill-opacity:1;stroke:none"
+ id="flowRoot3548-3-3-3"
+ xml:space="preserve"><flowRegion
+ id="flowRegion3550-6-6-6"><rect
+ ry="0"
+ y="12.585855"
+ x="168.55138"
+ height="38.993835"
+ width="284.91425"
+ id="rect3552-7-7-7"
+ style="text-align:center;text-anchor:middle;fill:#8f8f8f;fill-opacity:1" /></flowRegion><flowPara
+ style="font-style:italic;font-variant:normal;font-weight:normal;font-stretch:normal;font-size:10px;line-height:125%;font-family:'Fira Sans';-inkscape-font-specification:'Fira Sans, Italic';text-align:center;writing-mode:lr-tb;text-anchor:middle;fill:#8f8f8f;fill-opacity:1"
+ id="flowPara3599-5-5-5">La GUI offre molti potenti strumenti grafici. Map Swipe permette di comparare facilmente mappe raster. </flowPara><flowPara
+ id="flowPara6224-6-3-3" /><flowPara
+ id="flowPara3601-2-5-5" /><flowPara
+ id="flowPara3560-9-6-6"
+ style="font-style:italic;font-variant:normal;font-weight:normal;font-stretch:normal;font-size:10px;line-height:125%;font-family:'Fira Sans';-inkscape-font-specification:'Fira Sans, Italic';text-align:center;writing-mode:lr-tb;text-anchor:middle;fill:#8f8f8f;fill-opacity:1" /><flowPara
+ id="flowPara3562-1-2-2" /><flowPara
+ id="flowPara3564-2-9-9" /><flowPara
+ id="flowPara3566-7-1-1" /><flowPara
+ id="flowPara3568-0-2-2" /><flowPara
+ id="flowPara3570-9-7-7" /><flowPara
+ id="flowPara3572-3-0-0"
+ id="flowPara3574-6-9-9"
+ id="flowPara3576-0-3-3"
+ id="flowPara3578-6-6-6"
+ id="flowPara3580-2-0-0"
+ id="flowPara3582-6-6-6"
+ id="flowPara3584-1-2-2"
+ id="flowPara3586-8-6-6"
+ id="flowPara3588-7-1-1"
+ style="font-style:italic;font-variant:normal;font-weight:normal;font-stretch:normal;font-size:10px;line-height:125%;font-family:'Fira Sans';-inkscape-font-specification:'Fira Sans, Italic';text-align:center;writing-mode:lr-tb;text-anchor:middle;fill:#8f8f8f;fill-opacity:1" /></flowRoot> <image
+ sodipodi:absref="/home/lucadelu/compilati/grass-promo/grassflyer/flyer_2016/it/../images/mapswipe.png"
+ xlink:href="../images/mapswipe.png"
+ width="240"
+ height="180"
+ id="image4527"
+ x="1673.9125"
+ y="328.19818" />
+ </g>
+ </g>
+ <g
+ id="g4658"
+ transform="translate(-11.621728,0.04054559)"
+ <flowRoot
+ id="flowRoot3548-3-3"
+ style="font-style:italic;font-variant:normal;font-weight:normal;font-stretch:normal;font-size:10px;line-height:125%;font-family:'Fira Sans';-inkscape-font-specification:'Fira Sans, Italic';text-align:center;letter-spacing:0px;word-spacing:0px;writing-mode:lr-tb;text-anchor:middle;display:inline;fill:#8f8f8f;fill-opacity:1;stroke:none"
+ transform="translate(1820.6462,503.81612)"><flowRegion
+ id="flowRegion3550-6-6"><rect
+ id="rect3552-7-7"
+ width="219.58232"
+ height="36.051727"
+ x="168.55138"
+ y="12.585855"
+ id="flowPara3588-7-1">Combina, visualizza e anima dati 3D grazie allo strumento di visualizzazione NVIZ.</flowPara></flowRoot> <image
+ sodipodi:absref="/home/lucadelu/compilati/grass-promo/grassflyer/flyer_2016/it/../images/nviz.png"
+ xlink:href="../images/nviz.png"
+ y="328.19818"
+ x="1997.079"
+ id="image4651"
+ height="180"
+ width="208.2" />
+ </g>
+ <rect
+ y="560.14978"
+ x="1479.4957"
+ height="230.1391"
+ width="442.91339"
+ id="rect4582"
+ style="color:#000000;display:inline;overflow:visible;visibility:visible;fill:none;stroke:#8f8f8f;stroke-width:0.25;stroke-miterlimit:4;stroke-dasharray:none;stroke-opacity:1;marker:none;enable-background:accumulate"
+ inkscape:export-ydpi="300" />
+ <flowRoot
+ transform="translate(-219.87532,566.71982)"
+ id="flowRoot4588-3"
+ id="flowRegion4590-3"><rect
+ id="rect4592-0"
+ width="198.65118"
+ height="42.050251"
+ x="1821.2109"
+ y="95.940605"
+ style="fill:#8f8f8f;fill-opacity:1" /></flowRegion><flowPara
+ id="flowPara4594-8"
+ style="font-style:italic;font-variant:normal;font-weight:300;font-stretch:normal;font-size:22px;line-height:125%;font-family:'Fira Sans';-inkscape-font-specification:'Fira Sans Light Italic';text-align:center;writing-mode:lr-tb;text-anchor:middle;fill:#8f8f8f;fill-opacity:1">illustr. 3</flowPara></flowRoot> <text
+ style="font-style:normal;font-weight:normal;font-size:40px;line-height:125%;font-family:sans-serif;letter-spacing:0px;word-spacing:0px;fill:#000000;fill-opacity:1;stroke:none;stroke-width:1px;stroke-linecap:butt;stroke-linejoin:miter;stroke-opacity:1"
+ x="340"
+ y="988.36218"
+ id="text6577"
+ sodipodi:linespacing="125%"><tspan
+ sodipodi:role="line"
+ id="tspan6579"
+ x="340"
+ y="988.36218" /></text>
+ <flowRoot
+ transform="translate(329.86353,475.15298)"
+ style="font-style:normal;font-variant:normal;font-weight:normal;font-stretch:normal;font-size:22px;line-height:125%;font-family:Fontin;-inkscape-font-specification:Fontin;text-align:center;letter-spacing:0px;word-spacing:0px;writing-mode:lr-tb;text-anchor:middle;display:inline;fill:#000000;fill-opacity:1;stroke:none;enable-background:new"
+ id="flowRoot3901-8-0"
+ id="flowRegion3903-7-7"><rect
+ ry="0"
+ y="56.338501"
+ x="48.401169"
+ height="21.045349"
+ width="272.07059"
+ id="rect3905-9-5"
+ id="flowPara3909-8-8"
+ style="font-style:italic;font-variant:normal;font-weight:normal;font-stretch:normal;font-size:13px;font-family:'Fira Sans';-inkscape-font-specification:'Fira Sans Italic';text-align:center;text-anchor:middle">https://www.gnu.org/licenses/gpl.html</flowPara><flowPara
+ id="flowPara3911-4-7"
+ id="flowPara3913-5-0"
+ id="flowPara3915-5-4"
+ id="flowPara3917-6-8"
+ id="flowPara3919-6-0" /><flowPara
+ id="flowPara3921-0-4"
+ id="flowPara3923-6-2" /><flowPara
+ id="flowPara3925-0-9" /><flowPara
+ id="flowPara3927-2-6" /><flowPara
+ id="flowPara3929-9-1" /><flowPara
+ id="flowPara3931-5-0" /><flowPara
+ id="flowPara3933-3-4"
+ id="flowPara3935-5-2"
+ id="flowPara3937-2-2"
+ id="flowPara3939-7-2"
+ id="flowPara3941-0-0"
+ id="flowPara3943-0-5"
+ id="flowPara3945-6-5"
+ id="flowPara3947-5-2"
+ id="flowPara3949-4-9"
+ id="flowPara3951-0-0"
+ id="flowPara3953-4-2" /><flowPara
+ id="flowPara3955-0-8" /></flowRoot> </g>
+</svg>
