[GRASS-SVN] r69307 - grass/trunk/display/d.vect.thematic
Tue Aug 30 20:05:21 PDT 2016
Author: annakrat
Date: 2016-08-30 20:05:21 -0700 (Tue, 30 Aug 2016)
New Revision: 69307
   grass/trunk/display/d.vect.thematic/legend.c
   grass/trunk/display/d.vect.thematic/local_proto.h
   grass/trunk/display/d.vect.thematic/main.c
d.vect.thematic: show correct number of features for classes, make legendfile and -e flag deprecated
Modified: grass/trunk/display/d.vect.thematic/legend.c
--- grass/trunk/display/d.vect.thematic/legend.c	2016-08-30 22:48:04 UTC (rev 69306)
+++ grass/trunk/display/d.vect.thematic/legend.c	2016-08-31 03:05:21 UTC (rev 69307)
@@ -17,7 +17,7 @@
 void write_into_legend_file(const char *legfile, const char *icon, const char *title, double stats_min, double stats_max,
                             double *breakpoints, int nbreaks, int size, struct color_rgb bcolor,
-                            struct color_rgb *colors, int default_width, int nfeatures, const char *topo)
+                            struct color_rgb *colors, int default_width, int* frequencies, const char *topo)
     FILE *fd;
     int i;
@@ -40,14 +40,14 @@
     fprintf(fd, "%s|%d|%d:%d:%d|%d:%d:%d|%d|%s|%d\n",
             icon, size, bcolor.r, bcolor.g, bcolor.b,
             colors[0].r, colors[0].g, colors[0].b, default_width,
-            topo, nfeatures);
+            topo, frequencies[0]);
     /* Middle lines */
     for (i = 1; i < nbreaks; i++){
         fprintf(fd, "%.2f - %.2f|%s|%d|%d:%d:%d|%d:%d:%d|%d|%s|%d\n",
                 breakpoints[i-1],breakpoints[i],
                 colors[i].r, colors[i].g, colors[i].b, default_width,
-                topo, nfeatures);
+                topo, frequencies[i]);
     /* Last one */
     if(stats_max < breakpoints[nbreaks-1]){
@@ -59,7 +59,7 @@
             colors[nbreaks].r, colors[nbreaks].g, colors[nbreaks].b, default_width,
-            topo, nfeatures);
+            topo, frequencies[nbreaks]);
     fclose(fd);
Modified: grass/trunk/display/d.vect.thematic/local_proto.h
--- grass/trunk/display/d.vect.thematic/local_proto.h	2016-08-30 22:48:04 UTC (rev 69306)
+++ grass/trunk/display/d.vect.thematic/local_proto.h	2016-08-31 03:05:21 UTC (rev 69307)
@@ -31,4 +31,4 @@
 /* legend.c */
 void write_into_legend_file(const char *, const char *, const char *, double, double,
                             double *, int, int, struct color_rgb,
-                            struct color_rgb *, int, int, const char *);
+                            struct color_rgb *, int, int*, const char *);
Modified: grass/trunk/display/d.vect.thematic/main.c
--- grass/trunk/display/d.vect.thematic/main.c	2016-08-30 22:48:04 UTC (rev 69306)
+++ grass/trunk/display/d.vect.thematic/main.c	2016-08-31 03:05:21 UTC (rev 69307)
@@ -60,7 +60,7 @@
     struct Option *size_opt;
     struct Option *title_opt;
     struct Flag *legend_flag, *algoinfo_flag, *nodraw_flag;
-    char *desc;
+    char *desc, *deprecated;
     struct cat_list *Clist;
     int *cats, ncat, nrec, ctype;
@@ -208,8 +208,12 @@
     legend_file_opt = G_define_standard_option(G_OPT_F_OUTPUT);
     legend_file_opt->key = "legendfile";
-    legend_file_opt->description =
-    _("Output legend file");
+    deprecated = NULL;
+    G_asprintf(&deprecated,
+	        "[%s] %s",
+	        _("DEPRECATED"),
+	        _("Output legend file"));
+    legend_file_opt->description = deprecated;
     legend_file_opt->required = NO;
     legend_file_opt->guisection = _("Legend");
@@ -219,16 +223,20 @@
 	_("Create legend information and send to stdout");
     legend_flag->guisection = _("Legend");
+    nodraw_flag = G_define_flag();
+    nodraw_flag->key = 'n';
+    nodraw_flag->description = _("Do not draw map, only output the legend information");
+    nodraw_flag->guisection = _("Legend");
     algoinfo_flag = G_define_flag();
     algoinfo_flag->key = 'e';
-    algoinfo_flag->description =
-	_("When printing legend info, include extended statistical info from classification algorithm");
+	        "[%s] %s",
+	        _("DEPRECATED"),
+	        _("When printing legend info, include extended statistical info from classification algorithm"));
+    algoinfo_flag->description = deprecated;
     algoinfo_flag->guisection = _("Legend");
-    nodraw_flag = G_define_flag();
-    nodraw_flag->key = 'n';
-    nodraw_flag->description = _("Do not draw map, only output the legend");
-    nodraw_flag->guisection = _("Legend");
     G_option_required(algo_opt, breaks_opt, NULL);
     G_option_exclusive(algo_opt, breaks_opt, NULL);
@@ -238,6 +246,15 @@
     if (G_parser(argc, argv))
 	exit(EXIT_FAILURE);
+    if (algoinfo_flag->answer)
+        G_warning(_("Flag -e is deprecated, set verbose mode with --v to get the extended statistical info."));
+    if (legend_file_opt->answer)
+        G_warning(_("Option legendfile is deprecated, either use flag -l "
+                    "to print legend to standard output, "
+                    "or set GRASS_LEGEND_FILE environment variable "
+                    "(see d.legend.vect for details)."));
     if (G_verbose() > G_verbose_std())
 	verbose = TRUE;
@@ -496,36 +513,33 @@
     /*Get basic statistics about the data */
     AS_basic_stats(data, nrec, &stats);
-    /* Print legfile to stdout */
+    /* Print statistics */
+    G_verbose_message(_("\nTotal number of records: %.0f\n"),
+                      stats.count);
+    G_verbose_message(_("Classification of %s into %i classes\n"),
+                      column_opt->answer, nbreaks + 1);
+    G_verbose_message(_("Using algorithm: *** %s ***\n"),
+                      algo_opt->answer);
+    G_verbose_message(_("Mean: %f\tStandard deviation = %f\n"),
+                      stats.mean, stats.stdev);
+    if (G_strcasecmp(algo_opt->answer, "dis") == 0)
+        G_verbose_message(_("Last chi2 = %f\n"), class_info);
+    if (G_strcasecmp(algo_opt->answer, "std") == 0)
+        G_verbose_message(_("Stdev multiplied by %.4f to define step\n"),
+                          class_info);
+    G_verbose_message("\n");
+	/* Print legfile to stdout */
     if ((legend_flag->answer) ||
             ((legend_file_opt->answer) && (strcmp(legend_file_opt->answer,"-") == 0))) {
-    /* Print statistics */
-	if (algoinfo_flag->answer) {
-	    fprintf(stdout, _("\nTotal number of records: %.0f\n"),
-		    stats.count);
-	    fprintf(stdout, _("Classification of %s into %i classes\n"),
-		    column_opt->answer, nbreaks + 1);
-	    fprintf(stdout, _("Using algorithm: *** %s ***\n"),
-		    algo_opt->answer);
-	    fprintf(stdout, _("Mean: %f\tStandard deviation = %f\n"),
-		    stats.mean, stats.stdev);
-	    if (G_strcasecmp(algo_opt->answer, "dis") == 0)
-		fprintf(stdout, _("Last chi2 = %f\n"), class_info);
-	    if (G_strcasecmp(algo_opt->answer, "std") == 0)
-		fprintf(stdout,
-			_("Stdev multiplied by %.4f to define step\n"),
-			class_info);
-	    fprintf(stdout, "\n");
     while (TRUE) {
     nfeatures = Vect_get_num_primitives(&Map, GV_POINT);
         if (nfeatures > 0) {
             write_into_legend_file("stdout", icon_opt->answer,
                                    title, stats.min, stats.max, breakpoints,
                                    nbreaks, size, bcolor, colors, default_width,
-                                   nfeatures, "point");
+                                   frequencies, "point");
             break;
         nfeatures = Vect_get_num_primitives(&Map, GV_LINE);
@@ -533,7 +547,7 @@
             write_into_legend_file("stdout", icon_line_opt->answer,
-                                   nfeatures, "line");
+                                   frequencies, "line");
             break;
         nfeatures = Vect_get_num_primitives(&Map, GV_BOUNDARY);
@@ -541,7 +555,7 @@
             write_into_legend_file("stdout", icon_area_opt->answer,
-                                   nfeatures, "area");
+                                   frequencies, "area");
             break;
@@ -556,7 +570,7 @@
                 write_into_legend_file(leg_file, icon_opt->answer,
                 break;
@@ -564,7 +578,7 @@
                 write_into_legend_file(leg_file, icon_line_opt->answer,
                 break;
@@ -572,13 +586,11 @@
                 write_into_legend_file(leg_file, icon_area_opt->answer,
                 break;
-    else
-        G_fatal_error(_("Unable to open legend file %s."), leg_file);
     /* Write into user-specified output file */
@@ -589,7 +601,7 @@
                 write_into_legend_file(legend_file_opt->answer, icon_opt->answer,
                 break;
@@ -597,7 +609,7 @@
                 write_into_legend_file(legend_file_opt->answer, icon_line_opt->answer,
                 break;
@@ -605,7 +617,7 @@
                 write_into_legend_file(legend_file_opt->answer, icon_area_opt->answer,
                 break;
