[GRASS-SVN] r69312 - in grass/trunk: lib/python/temporal temporal/t.select
svn_grass at osgeo.org
Tue Aug 30 23:53:57 PDT 2016
Author: huhabla
Date: 2016-08-30 23:53:57 -0700 (Tue, 30 Aug 2016)
New Revision: 69312
grass/trunk/lib/python/temporal/temporal_algebra.py
grass/trunk/lib/python/temporal/temporal_raster_base_algebra.py
grass/trunk/temporal/t.select/t.select.py
temporal framework: Adding dry run to map algebra (merge from relbr72)
Modified: grass/trunk/lib/python/temporal/temporal_algebra.py
--- grass/trunk/lib/python/temporal/temporal_algebra.py 2016-08-31 06:50:18 UTC (rev 69311)
+++ grass/trunk/lib/python/temporal/temporal_algebra.py 2016-08-31 06:53:57 UTC (rev 69312)
@@ -737,9 +737,15 @@
('left', 'AND', 'OR', 'T_COMP_OPERATOR'), #2
- def __init__(self, pid=None, run = True, debug = False, spatial = False,
- null = False, register_null = False, nprocs = 1):
+ def __init__(self, pid=None, run=True, debug=False, spatial=False,
+ null=False, register_null=False, dry_run=False, nprocs=1):
self.run = run
+ self.dry_run = dry_run # Compute the processes and output but Do not start the processes
+ self.process_chain_dict = {} # This dictionary stores all processes, as well as the maps to register and remove
+ self.process_chain_dict["processes"] = []
+ self.process_chain_dict["insert"] = []
+ self.process_chain_dict["update"] = []
+ self.process_chain_dict["remove"] = []
self.debug = debug
self.pid = pid
# Intermediate vector map names
@@ -768,11 +774,11 @@
space time datasets in the expression to generate the map lists.
This function will analyze the expression to detect space time datasets
- and computes the common granularity from all granularities.
+ and computes the common granularity from all granularities of the input space time datasets.
This granularity is then be used to generate the map lists. Hence, all
maps from all STDS will have equidistant temporal extents. The only meaningful
- temporal relation is "equal".
+ temporal relation is therefore "equal".
:param expression: The algebra expression to analyze
@@ -848,8 +854,19 @@
return True
- def parse(self, expression, stdstype = 'strds', maptype = 'rast', mapclass = RasterDataset,
- basename = None, overwrite=False):
+ def parse(self, expression, stdstype='strds',
+ maptype='rast', mapclass=RasterDataset,
+ basename=None, overwrite=False):
+ """Parse the algebra expression and run the computation
+ :param expression:
+ :param stdstype:
+ :param maptype:
+ :param mapclass:
+ :param basename:
+ :param overwrite:
+ :return: The process chain dictionary
self.lexer = TemporalAlgebraLexer()
self.lexer.build()
self.parser = yacc.yacc(module=self, debug=self.debug)
@@ -863,6 +880,8 @@
self.expression = expression
self.parser.parse(expression)
+ return self.process_chain_dict
def generate_map_name(self):
"""Generate an unique map name and register it in the objects map list
@@ -878,8 +897,9 @@
self.names[name] = name
return name
- def generate_new_map(self, base_map, bool_op = 'and', copy = True, rename = True,
- remove = False):
+ def generate_new_map(self, base_map, bool_op='and',
+ copy=True, rename=True,
+ remove=False):
"""Generate a new map using the spatio-temporal extent of the base map
:param base_map: This map is used to create the new map
@@ -988,7 +1008,7 @@
other map list and given temporal operator.
:param maplist: List of map objects for which relations has been build
- correctely.
+ correctly.
:param topolist: List of strings of temporal relations.
:param temporal: The temporal operator specifying the temporal
extent operation (intersection, union, disjoint
@@ -1002,26 +1022,26 @@
# Loop over temporal related maps and create overlay modules.
tbrelations = map_i.get_temporal_relations()
# Generate an intermediate map for the result map list.
- map_new = self.generate_new_map(base_map=map_i, bool_op = 'and',
- copy = True, rename = True)
+ map_new = self.generate_new_map(base_map=map_i, bool_op='and',
+ copy=True, rename=True)
# Combine temporal and spatial extents of intermediate map with related maps.
for topo in topolist:
if topo in tbrelations.keys():
for map_j in (tbrelations[topo]):
if temporal == 'r':
# Create overlayed map extent.
- returncode = self.overlay_map_extent(map_new, map_j, 'and', \
- temp_op = temporal)
+ returncode = self.overlay_map_extent(map_new, map_j, 'and',
+ temp_op=temporal)
# Stop the loop if no temporal or spatial relationship exist.
if returncode == 0:
break
# Append map to result map list.
elif returncode == 1:
- print(map_new.get_id() + " " + str(map_new.get_temporal_extent_as_tuple()))
- print(map_new.condition_value)
+ # print(map_new.get_id() + " " + str(map_new.get_temporal_extent_as_tuple()))
+ # print(map_new.condition_value)
# print(map_new.cmd_list)
# resultlist.append(map_new)
resultdict[map_new.get_id()] = map_new
@@ -1079,10 +1099,10 @@
m.inputs["type"].value = map_type
m.inputs["name"].value = stringlist
m.flags["f"].value = True
- print(m.get_bash())
+ # print(m.get_bash())
m.run()
- def check_stds(self, input, clear = False, stds_type = None, check_type=True):
+ def check_stds(self, input, clear=False, stds_type=None, check_type=True):
""" Check if input space time dataset exist in database and return its map list.
:param input: Name of space time data set as string or list of maps.
@@ -1115,7 +1135,8 @@
if self.use_granularity:
# We create the maplist out of the map array from none-gap objects
maplist = []
- map_array = stds.get_registered_maps_as_objects_by_granularity(gran=self.granularity, dbif=self.dbif)
+ map_array = stds.get_registered_maps_as_objects_by_granularity(gran=self.granularity,
+ dbif=self.dbif)
for entry in map_array:
# Ignore gap objects
if entry[0].get_id() is not None:
@@ -1838,13 +1859,13 @@
# Get topology of then statement map list in relation to the other maplist
# and assign boolean values of the maplist to the thenlist.
containlist = self.perform_temporal_selection(thenlist, maplist,
- assign_val = True,
- topolist = topolist)
+ assign_val=True,
+ topolist=topolist)
# Inverse selection of maps from thenlist and assigning False values.
#excludelist = self.perform_temporal_selection(thenlist, maplist,
- # assign_val = True,
- # inverse = True,
- # topolist = topolist)
+ # assign_val = True,
+ # inverse = True,
+ # topolist = topolist)
# Combining the selection and inverse selection list.
resultlist = containlist# + excludelist
@@ -1895,10 +1916,6 @@
resultlist = self.eval_map_list(tvarexpr, thenlist, topolist)
elif len(tvarexpr) % 2 != 0:
# Define variables for map list comparisons.
- left_obj = []
- operator = []
- right_obj =[]
- count = 0
#self.msgr.fatal("Condition list is not complete. Elements missing")
for iter in range(len(tvarexpr)):
expr = tvarexpr[iter]
@@ -2017,14 +2034,16 @@
if self.run:
dbif, connected = init_dbif(self.dbif)
- map_stds_type = None
map_type = None
if isinstance(t[3], list):
num = len(t[3])
count = 0
register_list = []
if num > 0:
- process_queue = pymod.ParallelModuleQueue(int(self.nprocs))
+ if self.dry_run is False:
+ process_queue = pymod.ParallelModuleQueue(int(self.nprocs))
for map_i in t[3]:
# Test if temporal extents have been changed by temporal
# relation operators (i|r).
@@ -2032,28 +2051,27 @@
maps_stds_type = map_i.get_new_stds_instance(None).get_type()
map_type = map_i.get_type()
if maps_stds_type != self.stdstype:
- self.msgr.warning(_("The resulting space time dataset type <%(a)s> is "\
- "different from the requested type <%(b)s>"\
- %({"a":maps_stds_type, "b":self.stdstype})))
+ self.msgr.warning(_("The resulting space time dataset type <%(a)s> is "
+ "different from the requested type <%(b)s>"
+ %({"a":maps_stds_type, "b":self.stdstype})))
else:
map_type_2 = map_i.get_type()
if map_type != map_type_2:
self.msgr.fatal(_("Maps that should be registered in the "\
- "resulting space time dataset have different types."))
+ "resulting space time dataset have different types."))
- map_i_extent = map_i.get_temporal_extent_as_tuple()
- map_test = map_i.get_new_instance(map_i.get_id())
- map_test.select(dbif)
- map_test_extent = map_test.get_temporal_extent_as_tuple()
- if map_test_extent != map_i_extent:
+ map_a_extent = map_i.get_temporal_extent_as_tuple()
+ map_b = map_i.get_new_instance(map_i.get_id())
+ map_b.select(dbif)
+ map_b_extent = map_b.get_temporal_extent_as_tuple()
+ if map_a_extent != map_b_extent:
# Create new map with basename
newident = self.basename + "_" + str(count)
map_result = map_i.get_new_instance(newident + "@" + self.mapset)
- if map_test.map_exists() and self.overwrite == False:
- self.msgr.fatal("Error raster maps with basename %s exist. "\
- "Use --o flag to overwrite existing file" \
- %(mapname))
+ if map_b.map_exists() and self.overwrite == False:
+ self.msgr.fatal("Error raster maps with basename %s exist. "
+ "Use --o flag to overwrite existing file"%map_i.get_id())
map_result.set_temporal_extent(map_i.get_temporal_extent())
map_result.set_spatial_extent(map_i.get_spatial_extent())
@@ -2062,34 +2080,36 @@
register_list.append(map_result)
# Copy the map
+ m = copy.deepcopy(self.m_copy)
+ m.flags["overwrite"].value = self.overwrite
if map_i.get_type() == 'raster':
- m = copy.deepcopy(self.m_copy)
m.inputs["raster"].value = map_i.get_id(), newident
- m.flags["overwrite"].value = self.overwrite
- process_queue.put(m)
elif map_i.get_type() == 'raster3d':
m.inputs["raster_3d"].value = map_i.get_id(), newident
elif map_i.get_type() == 'vector':
m.inputs["vector"].value = map_i.get_id(), newident
+ # Add the process description to the dict
+ self.process_chain_dict["processes"].append(m.get_dict())
else:
register_list.append(map_i)
- count += 1
+ count += 1
# Wait for running processes
- process_queue.wait()
+ process_queue.wait()
# Open connection to temporal database.
# Create result space time dataset based on the map stds type
- resultstds = open_new_stds(t[1],maps_stds_type, \
- 'absolute', t[1], t[1], \
- 'mean', self.dbif, \
- overwrite = self.overwrite)
+ resultstds = open_new_stds(t[1],maps_stds_type,
+ 'absolute', t[1], t[1],
+ 'mean', self.dbif,
+ overwrite=self.overwrite)
for map_i in register_list:
# Get meta data from grass database.
map_i.load()
@@ -2102,29 +2122,39 @@
if not self.register_null:
self.removable_maps[map_i.get_name()] = map_i
continue
+ start, end = map_i.get_temporal_extent_as_tuple()
if map_i.is_in_db(dbif) and self.overwrite:
# Update map in temporal database.
- map_i.update_all(dbif)
+ self.process_chain_dict["update"].append((map_i.get_name(), str(start), str(end)))
+ map_i.update_all(dbif)
elif map_i.is_in_db(dbif) and self.overwrite == False:
# Raise error if map exists and no overwrite flag is given.
self.msgr.fatal("Error map %s exist in temporal database. "
- "Use overwrite flag. : \n%s" \
- %(map_i.get_map_id(), cmd.popen.stderr))
+ "Use overwrite flag."%map_i.get_map_id())
else:
# Insert map into temporal database.
- map_i.insert(dbif)
+ self.process_chain_dict["insert"].append((map_i.get_name(), str(start), str(end)))
+ map_i.insert(dbif)
# Register map in result space time dataset.
- success = resultstds.register_map(map_i, dbif)
- resultstds.update_from_registered_maps(dbif)
+ success = resultstds.register_map(map_i, dbif)
+ resultstds.update_from_registered_maps(dbif)
elif num == 0:
- self.msgr.warning("Empty result space time dataset. "\
- "No map has been registered in %s" %(t[1] ))
+ self.msgr.warning("Empty result space time dataset. "
+ "No map has been registered in %s"%(t[1]))
# Create result space time dataset.
- resultstds = open_new_stds(t[1], self.stdstype, \
- 'mean', dbif, \
+ resultstds = open_new_stds(t[1], self.stdstype,
+ 'mean', dbif,
if connected:
dbif.close()
t[0] = t[3]
@@ -2214,14 +2244,13 @@
# Check for occurrence of space time dataset.
if map_i.map_exists() == False:
raise FatalError(_("%s map <%s> not found in GRASS spatial database") %
- (map_i.get_type(), id_input))
+ (map_i.get_type(), id_input))
else:
# Select dataset entry from database.
map_i.select(dbif=self.dbif)
else:
- raise FatalError(_("Wrong map type <%s> . TMAP only supports single "\
- "maps that are registered in the temporal GRASS database")\
- %(map_i.get_type()))
+ raise FatalError(_("Wrong map type. TMAP only supports single "
+ "maps that are registered in the temporal GRASS database"))
# Return map object.
t[0] = [map_i]
else:
@@ -2466,7 +2495,6 @@
t[0] = resultlist
if self.debug:
print(t[1], t[3], t[5], t[6])
@@ -2591,7 +2619,7 @@
maplistA = self.check_stds(t[1])
maplistB = self.check_stds(t[3])
# Evaluate temporal operator.
- operators = self.eval_toperator(t[2], optype = 'select')
+ operators = self.eval_toperator(t[2], optype='select')
# Check for negative selection.
if operators[2] == "!:":
negation = True
@@ -2599,7 +2627,8 @@
negation = False
# Perform selection.
selectlist = self.perform_temporal_selection(maplistA, maplistB,
- topolist = operators[0], inverse = negation)
+ topolist=operators[0],
+ inverse=negation)
selectlist = self.set_granularity(selectlist, maplistB, operators[1],
operators[0])
# Return map list.
@@ -2647,7 +2676,7 @@
thenlist = self.check_stds(t[7])
# Get temporal conditional statement.
tvarexpr = t[5]
- topolist = self.eval_toperator(t[3], optype = 'relation')[0]
+ topolist = self.eval_toperator(t[3], optype='relation')[0]
thencond = self.build_condition_list(tvarexpr, thenlist, topolist)
thenresult = self.eval_condition_list(thencond)
# Clear the map and conditional values of the map list.
Modified: grass/trunk/lib/python/temporal/temporal_raster_base_algebra.py
--- grass/trunk/lib/python/temporal/temporal_raster_base_algebra.py 2016-08-31 06:50:18 UTC (rev 69311)
+++ grass/trunk/lib/python/temporal/temporal_raster_base_algebra.py 2016-08-31 06:53:57 UTC (rev 69312)
@@ -530,13 +530,16 @@
def p_statement_assign(self, t):
- # The expression should always return a list of maps.
+ # This function executes the processing of raster/raster3d algebra
+ # that was build based on the expression
statement : stds EQUALS expr
if self.run:
# Create the process queue for parallel mapcalc processing
num = len(t[3])
count = 0
@@ -550,8 +553,8 @@
else:
new_map = Raster3DDataset(map_name)
if new_map.map_exists() and self.overwrite == False:
- self.msgr.fatal("Error maps with basename %s exist. Use --o flag to overwrite existing file" \
- %(map_name))
+ self.msgr.fatal("Error maps with basename %s exist. "
+ "Use --o flag to overwrite existing file"%map_name)
map_test_list = []
for map_i in t[3]:
@@ -569,8 +572,10 @@
m_expression = newident + "=" + map_i.cmd_list
m.inputs["expression"].value = str(m_expression)
+ process_queue.put(m)
elif map_i.map_exists():
# Copy map if it exists
map_test = map_i.get_new_instance(newident + "@" + self.mapset)
@@ -582,14 +587,16 @@
m_expression = newident + "=" + map_i.get_map_id()
else:
- self.msgr.error(_("Error computing map <%s>"%(map_i.get_id()) ))
+ self.msgr.error(_("Error computing map <%s>"%map_i.get_id()))
count += 1
for map_i in map_test_list:
@@ -597,10 +604,12 @@
dbif, connect = init_dbif(self.dbif)
+ overwrite = self.overwrite)
map_i.load()
@@ -614,20 +623,25 @@
- self.msgr.fatal("Error raster map %s exist in temporal database. Use overwrite flag. : \n%s" \
+ self.msgr.fatal("Error raster map %s exist in temporal database. "
else:
dbif.close()
t[0] = register_list
+ # Remove intermediate maps
self.remove_maps()
def p_expr_spmap_function(self, t):
Modified: grass/trunk/temporal/t.select/t.select.py
--- grass/trunk/temporal/t.select/t.select.py 2016-08-31 06:50:18 UTC (rev 69311)
+++ grass/trunk/temporal/t.select/t.select.py 2016-08-31 06:53:57 UTC (rev 69312)
@@ -40,7 +40,12 @@
#% description: Activate spatial topology
#%end
+#%flag
+#% key: d
+#% description: Perform a dry run, compute all depenencies and module calls but don't run them
+#%end
import grass.script as grass
import grass.temporal as tgis
import sys
@@ -51,6 +56,7 @@
expression = options['expression']
spatial = flags["s"]
+ dry_run = flags["d"]
stdstype = options["type"]
# Check for PLY istallation
@@ -61,9 +67,15 @@
grass.fatal(_("Please install PLY (Lex and Yacc Python implementation) to use the temporal algebra modules."))
tgis.init(True)
- p = tgis.TemporalAlgebraParser(run=True, debug=False, spatial = spatial)
- p.parse(expression, stdstype, overwrite=grass.overwrite)
+ p = tgis.TemporalAlgebraParser(run=True, debug=False, spatial=spatial, dry_run=dry_run)
+ pc = p.parse(expression, stdstype, overwrite=grass.overwrite)
+ if dry_run is True:
+ import simplejson
+ s = simplejson.dumps(pc)
+ print(s)
if __name__ == "__main__":
options, flags = grass.parser()
sys.exit(main())
