[GRASS-SVN] r69313 - in grass/trunk/lib/python/temporal: . testsuite
Tue Aug 30 23:55:24 PDT 2016
Author: huhabla
Date: 2016-08-30 23:55:24 -0700 (Tue, 30 Aug 2016)
New Revision: 69313
   grass/trunk/lib/python/temporal/temporal_algebra.py
   grass/trunk/lib/python/temporal/testsuite/unittests_temporal_algebra.py
temporal framework: More dry-run test for the temporal algebra (merge from relbr72)
Modified: grass/trunk/lib/python/temporal/temporal_algebra.py
--- grass/trunk/lib/python/temporal/temporal_algebra.py	2016-08-31 06:53:57 UTC (rev 69312)
+++ grass/trunk/lib/python/temporal/temporal_algebra.py	2016-08-31 06:55:24 UTC (rev 69313)
@@ -742,10 +742,11 @@
         self.run = run
         self.dry_run = dry_run              # Compute the processes and output but Do not start the processes
         self.process_chain_dict = {}        # This dictionary stores all processes, as well as the maps to register and remove
-        self.process_chain_dict["processes"] = []
-        self.process_chain_dict["insert"] = []
-        self.process_chain_dict["update"] = []
-        self.process_chain_dict["remove"] = []
+        self.process_chain_dict["processes"] = []       # process decsription
+        self.process_chain_dict["register"] = []        # Maps that must be registered/updated or inserted in a new STDS
+        self.process_chain_dict["remove"] = []          # Maps that must be removed
+        self.process_chain_dict["STDS"] = {}            # The STDS that must be created
         self.debug = debug
         self.pid = pid
         # Intermediate vector map names
@@ -2045,8 +2046,7 @@
                         process_queue = pymod.ParallelModuleQueue(int(self.nprocs))
                     for map_i in t[3]:
-                        # Test if temporal extents have been changed by temporal
-                        # relation operators (i|r).
+                        # Check if the map type and stds type are compatible
                         if count == 0:
                             maps_stds_type = map_i.get_new_stds_instance(None).get_type()
                             map_type = map_i.get_type()
@@ -2059,7 +2059,11 @@
                             if map_type != map_type_2:
                                 self.msgr.fatal(_("Maps that should be registered in the "\
                                                   "resulting space time dataset have different types."))
+                        count += 1
+                        # Test if temporal extents was been modified by temporal
+                        # relation operators (i|r).
+                        # If it was modified, then the map will be copied
                         map_a_extent = map_i.get_temporal_extent_as_tuple()
                         map_b = map_i.get_new_instance(map_i.get_id())
                         map_b.select(dbif)
@@ -2069,7 +2073,7 @@
                             newident = self.basename + "_" + str(count)
                             map_result = map_i.get_new_instance(newident + "@" + self.mapset)
-                            if map_b.map_exists() and self.overwrite == False:
+                            if map_result.map_exists() and self.overwrite == False:
                                 self.msgr.fatal("Error raster maps with basename %s exist. "
                                                 "Use --o flag to overwrite existing file"%map_i.get_id())
@@ -2098,52 +2102,65 @@
                         else:
                             register_list.append(map_i)
-                        count += 1
                     # Wait for running processes
                     if self.dry_run is False:
                         process_queue.wait()
                     # Open connection to temporal database.
                     # Create result space time dataset based on the map stds type
-                    resultstds = open_new_stds(t[1],maps_stds_type,
-                                               'absolute', t[1], t[1],
-                                               'mean', self.dbif,
-                                               overwrite=self.overwrite)
+                    if self.dry_run is False:
+                        resultstds = open_new_stds(t[1],maps_stds_type,
+                                                   'absolute', t[1], t[1],
+                                                   'mean', self.dbif,
+                                                   overwrite=self.overwrite)
                     for map_i in register_list:
                         # Get meta data from grass database.
                         map_i.load()
+                        # Put the map into the process dictionary
+                        start, end = map_i.get_temporal_extent_as_tuple()
+                        self.process_chain_dict["register"].append((map_i.get_name(), str(start), str(end)))
                         # Check if temporal extents have changed and a new map was created
-                        if hasattr(map_i,  "is_new") is True:
+                        if hasattr(map_i, "is_new") is True:
                             # Do not register empty maps if not required
                             # In case of a null map continue, do not register null maps
-                            if map_i.metadata.get_min() is None and \
-                               map_i.metadata.get_max() is None:
-                                if not self.register_null:
-                                    self.removable_maps[map_i.get_name()] = map_i
-                                    continue
-                            start, end = map_i.get_temporal_extent_as_tuple()
+                            if map_i.get_type() is "raster" or map_i.get_type() is "raster3d":
+                                if map_i.metadata.get_min() is None and \
+                                   map_i.metadata.get_max() is None:
+                                    if not self.register_null:
+                                        self.removable_maps[map_i.get_name()] = map_i
+                                        continue
                             if map_i.is_in_db(dbif) and self.overwrite:
                                 # Update map in temporal database.
-                                self.process_chain_dict["update"].append((map_i.get_name(), str(start), str(end)))
                                     map_i.update_all(dbif)
-                            elif map_i.is_in_db(dbif) and self.overwrite == False:
+                            elif map_i.is_in_db(dbif) and self.overwrite is False:
                                 # Raise error if map exists and no overwrite flag is given.
                                 self.msgr.fatal("Error map %s exist in temporal database. "
-                                                        "Use overwrite flag."%map_i.get_map_id())
+                                                "Use overwrite flag."%map_i.get_map_id())
                             else:
                                 # Insert map into temporal database.
-                                self.process_chain_dict["insert"].append((map_i.get_name(), str(start), str(end)))
                                     map_i.insert(dbif)
                         # Register map in result space time dataset.
                             success = resultstds.register_map(map_i, dbif)
+                            if not success:
+                                self.msgr.warning("Unabe to register map layers "
+                                                  "in STDS %s"%(t[1]))
                         resultstds.update_from_registered_maps(dbif)
+                    self.process_chain_dict["STDS"]["name"] = t[1]
+                    self.process_chain_dict["STDS"]["stdstype"] = self.stdstype
+                    self.process_chain_dict["STDS"]["temporal_type"] = 'absolute'
                 elif num == 0:
                     self.msgr.warning("Empty result space time dataset. "
                                       "No map has been registered in %s"%(t[1]))
Modified: grass/trunk/lib/python/temporal/testsuite/unittests_temporal_algebra.py
--- grass/trunk/lib/python/temporal/testsuite/unittests_temporal_algebra.py	2016-08-31 06:53:57 UTC (rev 69312)
+++ grass/trunk/lib/python/temporal/testsuite/unittests_temporal_algebra.py	2016-08-31 06:55:24 UTC (rev 69313)
@@ -55,7 +55,7 @@
                                                  start="2001-01-02", increment="2 day", interval=True)
         tgis.register_maps_in_space_time_dataset(type="raster", name="D", maps="d1,d2,d3",
                                                  start="2001-01-03", increment="1 day", interval=True)
-        tgis.register_maps_in_space_time_dataset(type="raster", name=None,  maps="singletmap",
+        tgis.register_maps_in_space_time_dataset(type="raster", name=None,  maps="singletmap",
                                                  start="2001-01-03", end="2001-01-04")
     def tearDown(self):
@@ -70,14 +70,14 @@
     def test_temporal_select1(self):
         """Testing the temporal select operator with equal relations. """
-        ta = tgis.TemporalAlgebraParser(run = True, debug = True)
+        ta = tgis.TemporalAlgebraParser(run=True, debug=True)
         ta.parse(expression="R = A : A",  stdstype = 'strds', basename="r", overwrite=True)
         D = tgis.open_old_stds("R", type="strds")
         D.select()
         self.assertEqual(D.metadata.get_number_of_maps(), 4)
-        self.assertEqual(D.metadata.get_min_min(), 1)
-        self.assertEqual(D.metadata.get_max_max(), 4)
+        self.assertEqual(D.metadata.get_min_min(), 1)
+        self.assertEqual(D.metadata.get_max_max(), 4)
         start, end = D.get_absolute_time()
         self.assertEqual(start, datetime.datetime(2001, 1, 1))
         self.assertEqual(end, datetime.datetime(2001, 1, 5))
@@ -86,14 +86,14 @@
     def test_temporal_select2(self):
         ta.parse(expression="R = A : D",  stdstype = 'strds', basename="r", overwrite=True)
         D.select()
         self.assertEqual(D.metadata.get_number_of_maps(), 2)
-        self.assertEqual(D.metadata.get_min_min(), 3)
+        self.assertEqual(D.metadata.get_min_min(), 3)
         self.assertEqual(start, datetime.datetime(2001, 1, 3))
@@ -102,14 +102,14 @@
     def test_temporal_select3(self):
         ta.parse(expression="R = A !: D",  stdstype = 'strds', basename="r", overwrite=True)
         D.select()
-        self.assertEqual(D.metadata.get_max_max(), 2)
+        self.assertEqual(D.metadata.get_max_max(), 2)
         self.assertEqual(end, datetime.datetime(2001, 1, 3))
@@ -118,14 +118,14 @@
     def test_temporal_select_operators1(self):
         """Testing the temporal select operator. Including temporal relations. """
         ta.parse(expression="R = A {:,during} C",  stdstype = 'strds', basename="r", overwrite=True)
         D.select()
-        self.assertEqual(D.metadata.get_min_min(), 2)
-        self.assertEqual(D.metadata.get_max_max(), 3)
+        self.assertEqual(D.metadata.get_min_min(), 2)
+        self.assertEqual(D.metadata.get_max_max(), 3)
         self.assertEqual(start, datetime.datetime(2001, 1, 2))
         self.assertEqual(end, datetime.datetime(2001, 1, 4))
@@ -134,14 +134,14 @@
     def test_temporal_select_operators2(self):
         ta.parse(expression="R = A {:,equal|during} C",  stdstype = 'strds', basename="r", overwrite=True)
         D.select()
@@ -149,16 +149,16 @@
         self.assertEqual(D.get_granularity(),  u'1 day')
     def test_temporal_select_operators3(self):
-        """Testing the temporal select operator. Including temporal relations
+        """Testing the temporal select operator. Including temporal relations
             and negation operation. """
         ta.parse(expression="R = A {!:,during} C",  stdstype = 'strds', basename="r", overwrite=True)
         D.select()
@@ -166,9 +166,9 @@
     def test_temporal_select_operators4(self):
-        """Testing the temporal select operator. Including temporal relations and
+        """Testing the temporal select operator. Including temporal relations and
             temporal operators. """
         ta.parse(expression="R = A {:,during,d} C",  stdstype = 'strds', basename="r", overwrite=True)
@@ -179,8 +179,8 @@
             self.assertEqual(start_map, datetime.datetime(2001, 1, 2))
             self.assertEqual(end_map, datetime.datetime(2001, 1, 4))
@@ -188,9 +188,9 @@
         self.assertEqual(D.get_granularity(),  u'2 days')
     def test_temporal_select_operators5(self):
         ta.parse(expression="R = C {:,contains} A",  stdstype = 'strds', basename="r", overwrite=True)
@@ -201,8 +201,8 @@
         self.assertEqual(D.metadata.get_number_of_maps(), 1)
-        self.assertEqual(D.metadata.get_min_min(), 7)
-        self.assertEqual(D.metadata.get_max_max(), 7)
+        self.assertEqual(D.metadata.get_min_min(), 7)
+        self.assertEqual(D.metadata.get_max_max(), 7)
@@ -211,15 +211,15 @@
     def test_temporal_extent1(self):
         """Testing the temporal extent operators. """
         ta.parse(expression="R = A {:,during,r} C",  stdstype = 'strds', basename="r", overwrite=True)
         D.select()
         maplist = D.get_registered_maps_as_objects()
@@ -228,15 +228,15 @@
     def test_temporal_extent2(self):
         D.select()
-        maplist = D.get_registered_maps_as_objects()
+        maplist = D.get_registered_maps_as_objects()
@@ -245,7 +245,7 @@
     def test_temporal_extent3(self):
         ta.parse(expression="R = A {:,during,u} C",  stdstype = 'strds', basename="r", overwrite=True)
@@ -254,10 +254,10 @@
         for map_i in maplist:
             start_map, end_map = map_i.get_absolute_time()
-            self.assertEqual(end_map, datetime.datetime(2001, 1, 4))
+            self.assertEqual(end_map, datetime.datetime(2001, 1, 4))
@@ -266,15 +266,15 @@
     def test_temporal_hash1(self):
         """Testing the hash function in conditional statement. """
         ta.parse(expression="R = if(A # D == 1, A)",  stdstype = 'strds', basename="r", overwrite=True)
         D.select()
@@ -283,16 +283,16 @@
     def test_temporal_hash_operator1(self):
         """Testing the hash operator function in conditional statement. """
-        ta.parse(expression="R = if(A {#,during} C == 1, A)",  stdstype = 'strds',
+        ta.parse(expression="R = if(A {#,during} C == 1, A)",  stdstype = 'strds',
         D.select()
@@ -301,33 +301,33 @@
     def test_temporal_hash_operator2(self):
-        ta.parse(expression="R = if({during}, C {#,contains} A == 2, A)",
+        ta.parse(expression="R = if({during}, C {#,contains} A == 2, A)",
         D.select()
         self.assertEqual( D.check_temporal_topology(),  True)
     def test_tmap_function1(self):
         """Testing the tmap function. """
         ta.parse(expression='R = tmap(singletmap)',  stdstype = 'strds', basename="r", overwrite=True)
         D.select()
-        self.assertEqual(D.metadata.get_min_min(), 99)
-        self.assertEqual(D.metadata.get_max_max(), 99)
+        self.assertEqual(D.metadata.get_min_min(), 99)
+        self.assertEqual(D.metadata.get_max_max(), 99)
@@ -336,15 +336,15 @@
     def test_tmap_function2(self):
         ta.parse(expression='R = A : tmap(singletmap)',  stdstype = 'strds', basename="r", overwrite=True)
         D.select()
@@ -353,15 +353,15 @@
     def test_merge_function1(self):
         """Testing the merge function. """
         ta.parse(expression='R = merge(A,D)',  stdstype = 'strds', basename="r", overwrite=True)
         D.select()
         self.assertEqual(D.metadata.get_number_of_maps(), 7)
-        self.assertEqual(D.metadata.get_max_max(), 10)
+        self.assertEqual(D.metadata.get_max_max(), 10)
         self.assertEqual(end, datetime.datetime(2001, 1, 6))
@@ -370,20 +370,148 @@
     def test_merge_function2(self):
         ta.parse(expression='R = merge(A, B {!:,contains} A)',  stdstype = 'strds', basename="r", overwrite=True)
         D.select()
+class TestTemporalAlgebraDryRun(TestCase):
+    @classmethod
+    def setUpClass(cls):
+        """Initiate the temporal GIS and set the region
+        tgis.init(True) # Raise on error instead of exit(1)
+        cls.use_temp_region()
+        cls.runModule("g.region", n=80.0, s=0.0, e=120.0,
+                                       w=0.0, t=1.0, b=0.0, res=10.0)
+        cls.runModule("r.mapcalc", overwrite=True, quiet=True, expression="a1 = 1")
+        cls.runModule("r.mapcalc", overwrite=True, quiet=True, expression="a2 = 2")
+        cls.runModule("r.mapcalc", overwrite=True, quiet=True, expression="a3 = 3")
+        cls.runModule("r.mapcalc", overwrite=True, quiet=True, expression="a4 = 4")
+        cls.runModule("r.mapcalc", overwrite=True, quiet=True, expression="b1 = 5")
+        cls.runModule("r.mapcalc", overwrite=True, quiet=True, expression="b2 = 6")
+        cls.runModule("r.mapcalc", overwrite=True, quiet=True, expression="c1 = 7")
+        cls.runModule("r.mapcalc", overwrite=True, quiet=True, expression="d1 = 8")
+        cls.runModule("r.mapcalc", overwrite=True, quiet=True, expression="d2 = 9")
+        cls.runModule("r.mapcalc", overwrite=True, quiet=True, expression="d3 = 10")
+        cls.runModule("r.mapcalc", overwrite=True, quiet=True, expression="singletmap = 99")
+        tgis.open_new_stds(name="A", type="strds", temporaltype="absolute",
+                           title="A", descr="A", semantic="field", overwrite=True)
+        tgis.open_new_stds(name="B", type="strds", temporaltype="absolute",
+                           title="B", descr="B", semantic="field", overwrite=True)
+        tgis.open_new_stds(name="C", type="strds", temporaltype="absolute",
+                           title="C", descr="C", semantic="field", overwrite=True)
+        tgis.open_new_stds(name="D", type="strds", temporaltype="absolute",
+                           title="D", descr="D", semantic="field", overwrite=True)
+        tgis.register_maps_in_space_time_dataset(type="raster", name="A", maps="a1,a2,a3,a4",
+                                                 start="2001-01-01", increment="1 day", interval=True)
+        tgis.register_maps_in_space_time_dataset(type="raster", name="B", maps="b1,b2",
+                                                 start="2001-01-01", increment="2 day", interval=True)
+        tgis.register_maps_in_space_time_dataset(type="raster", name="C", maps="c1",
+                                                 start="2001-01-02", increment="2 day", interval=True)
+        tgis.register_maps_in_space_time_dataset(type="raster", name="D", maps="d1,d2,d3",
+                                                 start="2001-01-03", increment="1 day", interval=True)
+                                                 start="2001-01-03", end="2001-01-04")
+    @classmethod
+    def tearDownClass(cls):
+        """Remove the temporary region
+        cls.runModule("t.remove", flags="rf", inputs="A,B,C,D", quiet=True)
+        cls.del_temp_region()
+    def test_merge_function1(self):
+        """Testing the merge function. """
+        ta = tgis.TemporalAlgebraParser(run=True, debug=False, dry_run=True)
+        pc = ta.parse(expression='R = merge(A, B {:,contains} A)',
+                      stdstype = 'strds', basename="r",
+                      overwrite=True)
+        self.assertEqual(len(pc["register"]), 6)
+        self.assertEqual(pc["STDS"]["name"], "R")
+        self.assertEqual(pc["STDS"]["stdstype"], "strds")
+    def test_merge_function2(self):
+        pc = ta.parse(expression='R = merge(A, B {!:,contains} A)',
+                      overwrite=True)
+        self.assertEqual(len(pc["register"]), 4)
+    def test_merge_function3(self):
+        pc = ta.parse(expression='R = merge(A, D {!:,equal} A)',
+                      overwrite=True)
+        self.assertEqual(len(pc["register"]), 5)
+    def test_shift1(self):
+        """Testing the shift function. """
+        pc = ta.parse(expression='R = tshift(A, "3 days")',
+                      overwrite=True)
+        print(pc["register"])
+    def test_shift2(self):
+        pc = ta.parse(expression='R = tshift(A, "2 days") {:,during,l} C',
+                      overwrite=True)
+        self.assertEqual(len(pc["register"]), 1)
+    def test_buffer1(self):
+        pc = ta.parse(expression='R = buff_t(A, "1 day") ',
+                      overwrite=True)
+    def test_buff2(self):
+        pc = ta.parse(expression='R = buff_t(A, "1 day") {:,contains,l} C',
+                      overwrite=True)
+        self.assertEqual(len(pc["register"]), 2)
 if __name__ == '__main__':
     test()
