[GRASS-SVN] r70101 - grass-addons/grass7/raster/r.modis/r.modis.import
svn_grass at osgeo.org
Tue Dec 20 05:54:25 PST 2016
Author: lucadelu
Date: 2016-12-20 05:54:25 -0800 (Tue, 20 Dec 2016)
New Revision: 70101
grass-addons/grass7/raster/r.modis/r.modis.import/r.modis.import.py
improved r.modis.import to create mosaic with gdal
Modified: grass-addons/grass7/raster/r.modis/r.modis.import/r.modis.import.py
--- grass-addons/grass7/raster/r.modis/r.modis.import/r.modis.import.py 2016-12-19 05:46:02 UTC (rev 70100)
+++ grass-addons/grass7/raster/r.modis/r.modis.import/r.modis.import.py 2016-12-20 13:54:25 UTC (rev 70101)
@@ -87,7 +87,7 @@
import glob
import shutil
import grass.script as grass
-from datetime import date
+from datetime import datetime
from datetime import timedelta
from grass.pygrass.utils import get_lib_path
import tempfile
@@ -102,7 +102,20 @@
from convertmodis_gdal import createMosaicGDAL, convertModisGDAL
from parsemodis import parseModis
+class grassParseModis:
+ """Class to reproduce parseModis class when VRT is used for mosaic
+ :param str filename: the name of MODIS hdf file
+ def __init__(self, filename, date):
+ self.hdfname = filename
+ self.date = date
+ def retRangeTime(self):
+ return {'RangeBeginningDate': self.date}
def list_files(opt, mosaik=False):
"""If used in function single(): Return a list of HDF files from the file
list. If used in function mosaic(): Return a dictionary with a list of HDF
@@ -202,7 +215,7 @@
# timestamp
rangetime = pars.retRangeTime()
data = rangetime['RangeBeginningDate'].split('-')
- dataobj = date(int(data[0]), int(data[1]), int(data[2]))
+ dataobj = datetime(int(data[0]), int(data[1]), int(data[2]))
grass.run_command('r.timestamp', map=mapp, quiet=True,
date=dataobj.strftime("%d %b %Y"))
return dataobj
@@ -288,6 +301,13 @@
grass.warning(_("Raster map <%s> not found") % (pref + suff))
+def doy2date(modis):
+ """From he MODIS code to YYYY-MM-DD string date"""
+ year = modis[:4]
+ doy = modis[-3:]
+ dat = datetime.strptime('{ye} {doy}'.format(ye=year, doy=doy), '%Y %j')
+ return dat.strftime('%Y-%m-%d')
def single(options, remove, an, ow, fil):
"""Convert the HDF file to TIF and import it
@@ -342,7 +362,7 @@
prod = product().fromcode(pref.split('.')[0])
spectr = spectral(options, prod, an)
spectr = spectr.lstrip('( ').rstrip(' )')
- outname = "%s.%s.mosaic" % (pref.split('.')[0], pref.split('.')[1])
+ outname = "%s.%s_mosaic" % (pref.split('.')[0], pref.split('.')[1])
outname = outname.replace(' ', '_')
# create mosaic
if options['mrtpath']:
@@ -356,30 +376,36 @@
cm = createMosaic(tempfile.name, outname, options['mrtpath'],
spectr)
cm.run()
+ hdfiles = glob.glob1(basedir, outname + "*.hdf")
else:
basedir = targetdir
listfiles = [os.path.join(basedir, i) for i in listfiles]
cm = createMosaicGDAL(listfiles, spectr)
cm.write_vrt(outname)
- # list of hdf files
- hdfiles = glob.glob1(basedir, outname + "*.hdf")
+ hdfiles = glob.glob1(basedir, outname + "*.vrt")
for i in hdfiles:
# the full path to hdf file
hdf = os.path.join(basedir, i)
- pm = parseModis(hdf)
+ try:
+ pm = parseModis(hdf)
+ except:
+ out = i.replace('.vrt', '')
+ data = doy2date(dat[1:])
+ pm = grassParseModis(out, data)
# create convertModis class and convert it in tif file
# create conf file fro mrt tools
confname = confile(pm, options, an, True)
execmodis = convertModis(hdf, confname, options['mrtpath'])
else:
+ confname = None
projwkt = get_proj('w')
projObj = projection()
- if projwkt.returned() != 'GEO':
+ if projObj.returned() != 'GEO':
res = int(prod['res']) * int(projObj.proj['meters'])
else:
res = None
- execmodis = convertModisGDAL(hdf, outname, res, wkt=projwkt,
+ execmodis = convertModisGDAL(hdf, out, spectr, res, wkt=projwkt,
vrt=True)
execmodis.run()
# remove hdf
@@ -387,8 +413,11 @@
# import tif files
import_tif(basedir=basedir, rem=remove, write=ow,
pm=pm, listfile=fil, prod=prod)
- os.remove(hdf)
- os.remove(hdf + '.xml')
+ try:
+ os.remove(hdf)
+ os.remove(hdf + '.xml')
+ except OSError:
+ pass
# move the hdf and hdf.xml to the dir where are the original files
else:
# import tif files
@@ -397,10 +426,13 @@
try:
shutil.move(hdf, targetdir)
shutil.move(hdf + '.xml', targetdir)
- except:
+ except OSError:
pass
# remove the conf file
- os.remove(confname)
+ try:
+ os.remove(confname)
+ except (OSError, TypeError) as e:
+ pass
grass.try_remove(tempfile.name)
grass.try_remove(os.path.join(targetdir, 'mosaic', pid))
