[GRASS-SVN] r70102 - grass-addons/grass7/raster/r.subdayprecip.design
Tue Dec 20 06:01:28 PST 2016
Author: martinl
Date: 2016-12-20 06:01:28 -0800 (Tue, 20 Dec 2016)
New Revision: 70102
   grass-addons/grass7/raster/r.subdayprecip.design/r.subdayprecip.design.html
   grass-addons/grass7/raster/r.subdayprecip.design/r.subdayprecip.design.py
r.subdayprecip.design: parameter 'raster' renamed to 'return_period'
                       options renamed to NX
Modified: grass-addons/grass7/raster/r.subdayprecip.design/r.subdayprecip.design.html
--- grass-addons/grass7/raster/r.subdayprecip.design/r.subdayprecip.design.html	2016-12-20 13:54:25 UTC (rev 70101)
+++ grass-addons/grass7/raster/r.subdayprecip.design/r.subdayprecip.design.html	2016-12-20 14:01:28 UTC (rev 70102)
@@ -22,9 +22,9 @@
 <p>
 First automatization has been implemented by well-known method
 which is based on reduction of 24 hours design precipitation to
-shorter time. GIS is used for spatial supervised classification of
+shorter time. GIS can used for spatial supervised classification of
 point values of specified return periods (2, 10, 20, 50 and 100
-years) over the area of the Czech Republic.
+years).
 <center>
 <table>
@@ -41,14 +41,14 @@
 <img src="r_subdayprecip_design_result.png">
 <p>
-<em>Figure: IV.order basins colored by mean H_002_60 value (in millimeters)</em>
+<em>Figure: IV.order basins colored by mean H_N2T60 value (in millimeters)</em>
 </center>
 <h2>EXAMPLE</h2>
 <div class="code"><pre>
-r.subdayprecip.design map=basin raster=H_002,H_005,H_010,H_020 rainlength=60
+r.subdayprecip.design map=basin return_period=N2,N5,N10,N20 rainlength=60
 </pre></div>
 <h2>REFERENCES</h2>
@@ -74,7 +74,8 @@
 <h3>Acknowledgement</h3>
-This work has been supported by the <a href="http://rain.fsv.cvut.cz">research project QJ1520265</a> -
+This work has been supported by
+the <a href="http://rain.fsv.cvut.cz">research project QJ1520265</a> -
 "Variability of Short-term Precipitation and Runoff in Small
 Czech Drainage Basins and its Influence on Water Resources
 Management".
@@ -88,9 +89,11 @@
 <h2>AUTHORS</h2>
-Martin Landa, OSGeoREL, Czech Technical University in Prague, Czech
-Republic<br> The module is inspired by Python script developed for
-Esri ArcGIS platform by M. Tomasu in 2013.
+Martin Landa, GeoForAll (OSGeoREL) Lab, Czech Technical University in Prague, Czech
+Republic<br>
+The module is inspired by Python script developed for Esri ArcGIS
+platform by M. Tomasu in 2013.
 <p>
 <i>Last changed: $Date$</i>
Modified: grass-addons/grass7/raster/r.subdayprecip.design/r.subdayprecip.design.py
--- grass-addons/grass7/raster/r.subdayprecip.design/r.subdayprecip.design.py	2016-12-20 13:54:25 UTC (rev 70101)
+++ grass-addons/grass7/raster/r.subdayprecip.design/r.subdayprecip.design.py	2016-12-20 14:01:28 UTC (rev 70102)
@@ -28,9 +28,9 @@
 #%end
 #%option G_OPT_R_INPUTS
-#% key: raster
+#% key: return_period
 #% description: Rainfall raster maps of required return period
-#% options: H_002,H_005,H_010,H_020,H_050,H_100
+#% options: N2,N5,N10,N20,N50,N100
 #%end
 #%option
@@ -50,7 +50,7 @@
 def coeff(name, rl):
     a = c = None
-    if name == 'H_002':
+    if name == 'N2':
         if rl < 40:
             a = 0.166
             c = 0.701
@@ -60,7 +60,7 @@
         elif rl < 1440:
             a = 0.235
             c = 0.801
-    elif name == 'H_005':
+    elif name == 'N5':
         if rl < 40:
             a = 0.171
             c = 0.688
@@ -70,7 +70,7 @@
         elif rl < 1440:
             a = 0.324
             c = 0.845
-    elif name == 'H_010':
+    elif name == 'N10':
         if rl < 40:
             a = 0.163
             c = 0.656
@@ -80,7 +80,7 @@
         elif rl < 1440:
             a = 0.380
             c = 0.867
-    elif name == 'H_020':
+    elif name == 'N20':
         if rl < 40:
             a = 0.169
             c = 0.648
@@ -90,7 +90,7 @@
         elif rl < 1440:
             a = 0.463
             c = 0.894
-    elif name == 'H_050':
+    elif name == 'N50':
         if rl < 40:
             a = 0.174
             c = 0.638
@@ -100,7 +100,7 @@
         elif rl < 1440:
             a = 0.580
             c = 0.925
-    elif name == 'H_100':
+    elif name == 'N100':
         if rl < 40:
             a = 0.173
             c = 0.625
@@ -125,7 +125,7 @@
     except CalledModuleError as e:
         return 1
-    allowed_rasters = ('H_002', 'H_005', 'H_010', 'H_020', 'H_050', 'H_100')
+    allowed_rasters = ('N2', 'N5', 'N10', 'N20', 'N50', 'N100')
     # test input feature type
     vinfo = grass.vector_info_topo(opt['map'])
@@ -133,7 +133,7 @@
         grass.fatal(_("No points or areas found in input vector map <{}>").format(opt['map']))
     # extract multi values to points
-    for rast in opt['raster'].split(','):
+    for rast in opt['return_period'].split(','):
         # check valid rasters
         name = grass.find_file(rast, element='cell')['name']
         if not name:
@@ -169,7 +169,7 @@
         # add column to the attribute table if not exists
         rl = float(opt['rainlength'])
-        field_name='{}_{}'.format(name, opt['rainlength'])
+        field_name='H_{}T{}'.format(name, opt['rainlength'])
         if field_name not in columns:
             Module('v.db.addcolumn', map=opt['map'],
                    columns='{} double precision'.format(field_name))
