[GRASS-SVN] r70131 - in grass/trunk/doc/python: . script
svn_grass at osgeo.org
Mon Dec 26 08:20:33 PST 2016
Author: wenzeslaus
Date: 2016-12-26 08:20:33 -0800 (Mon, 26 Dec 2016)
New Revision: 70131
Added:
grass/trunk/doc/python/script/
grass/trunk/doc/python/script/Makefile
grass/trunk/doc/python/script/r.example.html
grass/trunk/doc/python/script/r.example.py
doc: add python raster module example to source code
Added: grass/trunk/doc/python/script/Makefile
--- grass/trunk/doc/python/script/Makefile (rev 0)
+++ grass/trunk/doc/python/script/Makefile 2016-12-26 16:20:33 UTC (rev 70131)
@@ -0,0 +1,7 @@
+MODULE_TOPDIR = ../..
+PGM = r.example
+include $(MODULE_TOPDIR)/include/Make/Script.make
+default: script
Added: grass/trunk/doc/python/script/r.example.html
--- grass/trunk/doc/python/script/r.example.html (rev 0)
+++ grass/trunk/doc/python/script/r.example.html 2016-12-26 16:20:33 UTC (rev 70131)
@@ -0,0 +1,18 @@
+<h2>DESCRIPTION</h2>
+<em>r.example</em> selects values from raster above value of mean plus
+standard deviation
+<h2>SEE ALSO</h2>
+<em>
+<a href="r.univar.html">r.univar</a>,
+<a href="r.mapcalc.html">r.mapcalc</a>
+</em>
+<h2>AUTHOR</h2>
+GRASS Development Team
+<p><i>Last changed: $Date: 2014-08-05 17:45:01 -0400 (Tue, 05 Aug 2014) $</i>
Added: grass/trunk/doc/python/script/r.example.py
--- grass/trunk/doc/python/script/r.example.py (rev 0)
+++ grass/trunk/doc/python/script/r.example.py 2016-12-26 16:20:33 UTC (rev 70131)
@@ -0,0 +1,39 @@
+#!/usr/bin/env python
+#%module
+#% description: Selects values from raster above value of mean plus standard deviation
+#% keyword: raster
+#% keyword: select
+#% keyword: standard deviation
+#%end
+#%option G_OPT_R_INPUT
+#%end
+#%option G_OPT_R_OUTPUT
+#%end
+import sys
+import grass.script as gscript
+from grass.exceptions import CalledModuleError
+def main():
+ options, flags = gscript.parser()
+ input_raster = options['input']
+ output_raster = options['output']
+ try:
+ stats = gscript.parse_command('r.univar', map=input_raster, flags='g')
+ except CalledModuleError as e:
+ gscript.fatal('{}'.format(e))
+ raster_mean = float(stats['mean'])
+ raster_stddev = float(stats['stddev'])
+ raster_high = raster_mean + raster_stddev
+ gscript.mapcalc('{r} = {i} > {v}'.format(r=output_raster, i=input_raster,
+ v=raster_high))
+ return 0
+if __name__ == "__main__":
+ sys.exit(main())
