[GRASS-SVN] r70132 - in grass/trunk/raster3d/r3.to.rast: . testsuite
Mon Dec 26 14:22:39 PST 2016
Author: wenzeslaus
Date: 2016-12-26 14:22:38 -0800 (Mon, 26 Dec 2016)
New Revision: 70132
Added:
   grass/trunk/raster3d/r3.to.rast/testsuite/test_integer_rounding.py
   grass/trunk/raster3d/r3.to.rast/r3.to.rast.html
r3.to.rast: test and doc for multiply, add and type options
Modified: grass/trunk/raster3d/r3.to.rast/r3.to.rast.html
--- grass/trunk/raster3d/r3.to.rast/r3.to.rast.html	2016-12-26 16:20:33 UTC (rev 70131)
+++ grass/trunk/raster3d/r3.to.rast/r3.to.rast.html	2016-12-26 22:22:38 UTC (rev 70132)
@@ -15,13 +15,51 @@
 </table>
 </center>
+<h3>Map type conversions</h3>
+Type of resulting 2D raster maps is determined by the type of the
+input 3D raster, i.e. 3D raster of type DCELL (double) will result in
+DCELL 2D rasters. A specific type for 2D rasters can be requested using
+the <b>type</b> option.
+<p>
+The <b>type</b> option is especially advantageous when the 3D raster
+map stores categories (which need to be stored as floating point numbers)
+and the 2D raster map should be also categorical, i.e. use integers.
+The type is set to <tt>CELL</tt> in this case.
+<h3>Modifying the values</h3>
+The values in the 3D raster map can be modified prior to storing in
+the 2D raster map. The values can be scaled using the option <b>multiply</b>
+and a constant value can be added using the option <b>add</b>.
+The new value is computed using the following equation:
+<pre>
+y = ax + b
+</pre>
+where <em>x</em> is the original value, <em>a</em> is the value of
+<b>multiply</b> option, <em>b</em> is the value of <b>add</b> option,
+and <em>y</em> is the new value. When <b>multiply</b> is not provided,
+the value of <em>a</em> is 1. When <b>add</b> is not provided, the value
+of <em>b</em> is 0.
 <h2>NOTES</h2>
 Every slice of the 3D raster map is copied to one 2D raster map. The maps
 are named like <b>output</b><em>_slicenumber</em>. Slices are counted from bottom
 to the top, so the bottom slice has number 1.
+<p>
 The number of slices is equal to the number of depths.
+<p>
+To round floating point values to integers when using <tt>type=CELL</tt>,
+the <b>add</b> option should be set to 0.5.
 <h2>SEE ALSO</h2>
 <em>
@@ -33,5 +71,6 @@
 <h2>AUTHOR</h2>
 Sören Gebbert
+Vaclav Petras, <a href="http://geospatial.ncsu.edu/osgeorel/">NCSU GeoForAll Lab</a>
 <p><i>Last changed: $Date$</i>
Copied: grass/trunk/raster3d/r3.to.rast/testsuite/test_integer_rounding.py (from rev 68864, grass/trunk/raster3d/r3.to.rast/testsuite/test_small_data.py)
--- grass/trunk/raster3d/r3.to.rast/testsuite/test_integer_rounding.py	                        (rev 0)
+++ grass/trunk/raster3d/r3.to.rast/testsuite/test_integer_rounding.py	2016-12-26 22:22:38 UTC (rev 70132)
@@ -0,0 +1,160 @@
+#!/usr/bin/env python
+# MODULE:        test_integer_rounding
+# AUTHOR:        Vaclav Petras
+# PURPOSE:       Fast test of rounding integers based on a small example
+# COPYRIGHT:     (C) 2016 by Vaclav Petras and the GRASS Development Team
+#                This program is free software under the GNU General Public
+#                License (>=v2). Read the file COPYING that comes with GRASS
+#                for details.
+from grass.gunittest.case import TestCase
+from grass.gunittest.main import test
+from grass.script import list_strings
+# generated by
+# g.region n=12 s=9 e=21 w=18 t=8 b=4 res=1 res3=1 -p3
+# r3.mapcalc "x = rand(0,5.)" seed=100 && r3.out.ascii x prec=2
+INPUT = """\
+version: grass7
+order: nsbt
+north: 12.000000
+south: 9.000000
+east: 21.000000
+west: 18.000000
+top: 8.000000
+bottom: 4.000000
+rows: 3
+cols: 3
+levels: 4
+1.26 1.04 4.70
+2.11 1.98 1.91
+1.16 2.68 2.67
+4.31 4.81 1.58
+3.68 3.27 0.25
+2.27 4.03 3.28
+4.06 4.15 0.40
+1.02 3.40 3.26
+4.88 0.43 1.02
+1.16 0.07 0.78
+0.07 3.52 0.45
+2.86 4.79 1.43
+# created from the above and template from
+# r.mapcalc "x = rand(0,10)" seed=100 && r.out.ascii x prec=0
+OUTPUTS = [
+north: 12
+south: 9
+east: 21
+west: 18
+rows: 3
+cols: 3
+1 1 5
+2 2 2
+1 3 3
+north: 12
+south: 9
+east: 21
+west: 18
+rows: 3
+cols: 3
+4 5 2
+4 3 0
+2 4 3
+north: 12
+south: 9
+east: 21
+west: 18
+rows: 3
+cols: 3
+4 4 0
+1 3 3
+5 0 1
+north: 12
+south: 9
+east: 21
+west: 18
+rows: 3
+cols: 3
+1 0 1
+0 4 0
+3 5 1
+class TestR3ToRastIntegerRounding(TestCase):
+    # TODO: replace by unified handing of maps
+    # mixing class and object attributes
+    to_remove_3d = []
+    to_remove_2d = []
+    rast3d = 'r3_to_rast_test_int_round'
+    rast2d = 'r3_to_rast_test_int_round'
+    rast2d_ref = 'r3_to_rast_test_int_round_ref'
+    rast2d_refs = []
+    def setUp(self):
+        self.use_temp_region()
+        self.runModule('r3.in.ascii', input='-', stdin_=INPUT,
+                       output=self.rast3d)
+        self.to_remove_3d.append(self.rast3d)
+        self.runModule('g.region', raster_3d=self.rast3d)
+        for i, data in enumerate(OUTPUTS):
+            rast = "%s_%d" % (self.rast2d_ref, i)
+            self.runModule('r.in.ascii', input='-', stdin_=data,
+                           output=rast, type='CELL')
+            self.to_remove_2d.append(rast)
+            self.rast2d_refs.append(rast)
+    def tearDown(self):
+        if self.to_remove_3d:
+            self.runModule('g.remove', flags='f', type='raster_3d',
+                           name=','.join(self.to_remove_3d), verbose=True)
+        if self.to_remove_2d:
+            self.runModule('g.remove', flags='f', type='raster',
+                           name=','.join(self.to_remove_2d), verbose=True)
+        self.del_temp_region()
+    def test_rounding(self):
+        self.assertModule('r3.to.rast', input=self.rast3d,
+                          output=self.rast2d, type='CELL', add=0.5)
+        rasts = list_strings('raster', mapset=".",
+                             pattern="%s_*" % self.rast2d,
+                             exclude="%s_*" % self.rast2d_ref)
+        self.assertEquals(len(rasts), 4,
+                          msg="Wrong number of 2D rasters present"
+                              " in the mapset")
+        ref_info = dict(cells=9)
+        ref_univar = dict(cells=9, null_cells=0)
+        for rast in rasts:
+            self.assertRasterExists(rast)
+            # the following doesn't make much sense because we just listed them
+            self.assertRasterFitsInfo(raster=rast, reference=ref_info,
+                                      precision=0)
+            self.assertRasterFitsUnivar(raster=rast, reference=ref_univar,
+                                        precision=0)
+        # check the actual values
+        for rast_ref, rast in zip(self.rast2d_refs, rasts):
+            self.assertRastersNoDifference(actual=rast,
+                                           reference=rast_ref,
+                                           precision=0.1)
+if __name__ == '__main__':
+    test()
