[GRASS-SVN] r70165 - grass/trunk/gui/icons
svn_grass at osgeo.org
Wed Dec 28 10:13:35 PST 2016
Author: neteler
Date: 2016-12-28 10:13:35 -0800 (Wed, 28 Dec 2016)
New Revision: 70165
grass/trunk/gui/icons/Makefile
grass.desktop: fix broken grass.png icon filename (trac #3233)
Modified: grass/trunk/gui/icons/Makefile
--- grass/trunk/gui/icons/Makefile 2016-12-28 17:06:19 UTC (rev 70164)
+++ grass/trunk/gui/icons/Makefile 2016-12-28 18:13:35 UTC (rev 70165)
@@ -21,37 +21,37 @@
$(MKDIR) $(ARCH_DISTDIR)/share/applications
$(INSTALL_DATA) grass.desktop $(ARCH_DISTDIR)/share/applications
$(MKDIR) $(ARCH_DISTDIR)/share/icons/hicolor/8x8/apps
- $(INSTALL_DATA) grass-8x8.png $(ARCH_DISTDIR)/share/icons/hicolor/8x8/apps/grass71.png
+ $(INSTALL_DATA) grass-8x8.png $(ARCH_DISTDIR)/share/icons/hicolor/8x8/apps/grass.png
$(MKDIR) $(ARCH_DISTDIR)/share/icons/hicolor/16x16/apps
- $(INSTALL_DATA) grass-16x16.png $(ARCH_DISTDIR)/share/icons/hicolor/16x16/apps/grass71.png
+ $(INSTALL_DATA) grass-16x16.png $(ARCH_DISTDIR)/share/icons/hicolor/16x16/apps/grass.png
$(MKDIR) $(ARCH_DISTDIR)/share/icons/hicolor/22x22/apps
- $(INSTALL_DATA) grass-22x22.png $(ARCH_DISTDIR)/share/icons/hicolor/22x22/apps/grass71.png
+ $(INSTALL_DATA) grass-22x22.png $(ARCH_DISTDIR)/share/icons/hicolor/22x22/apps/grass.png
$(MKDIR) $(ARCH_DISTDIR)/share/icons/hicolor/24x24/apps
- $(INSTALL_DATA) grass-24x24.png $(ARCH_DISTDIR)/share/icons/hicolor/24x24/apps/grass71.png
+ $(INSTALL_DATA) grass-24x24.png $(ARCH_DISTDIR)/share/icons/hicolor/24x24/apps/grass.png
$(MKDIR) $(ARCH_DISTDIR)/share/icons/hicolor/32x32/apps
- $(INSTALL_DATA) grass-32x32.png $(ARCH_DISTDIR)/share/icons/hicolor/32x32/apps/grass71.png
+ $(INSTALL_DATA) grass-32x32.png $(ARCH_DISTDIR)/share/icons/hicolor/32x32/apps/grass.png
$(MKDIR) $(ARCH_DISTDIR)/share/icons/hicolor/36x36/apps
- $(INSTALL_DATA) grass-36x36.png $(ARCH_DISTDIR)/share/icons/hicolor/36x36/apps/grass71.png
+ $(INSTALL_DATA) grass-36x36.png $(ARCH_DISTDIR)/share/icons/hicolor/36x36/apps/grass.png
$(MKDIR) $(ARCH_DISTDIR)/share/icons/hicolor/40x40/apps
- $(INSTALL_DATA) grass-40x40.png $(ARCH_DISTDIR)/share/icons/hicolor/40x40/apps/grass71.png
+ $(INSTALL_DATA) grass-40x40.png $(ARCH_DISTDIR)/share/icons/hicolor/40x40/apps/grass.png
$(MKDIR) $(ARCH_DISTDIR)/share/icons/hicolor/42x42/apps
- $(INSTALL_DATA) grass-42x42.png $(ARCH_DISTDIR)/share/icons/hicolor/42x42/apps/grass71.png
+ $(INSTALL_DATA) grass-42x42.png $(ARCH_DISTDIR)/share/icons/hicolor/42x42/apps/grass.png
$(MKDIR) $(ARCH_DISTDIR)/share/icons/hicolor/48x48/apps
- $(INSTALL_DATA) grass-48x48.png $(ARCH_DISTDIR)/share/icons/hicolor/48x48/apps/grass71.png
+ $(INSTALL_DATA) grass-48x48.png $(ARCH_DISTDIR)/share/icons/hicolor/48x48/apps/grass.png
$(MKDIR) $(ARCH_DISTDIR)/share/icons/hicolor/64x64/apps
- $(INSTALL_DATA) grass-64x64.png $(ARCH_DISTDIR)/share/icons/hicolor/64x64/apps/grass71.png
+ $(INSTALL_DATA) grass-64x64.png $(ARCH_DISTDIR)/share/icons/hicolor/64x64/apps/grass.png
$(MKDIR) $(ARCH_DISTDIR)/share/icons/hicolor/72x72/apps
- $(INSTALL_DATA) grass-72x72.png $(ARCH_DISTDIR)/share/icons/hicolor/72x72/apps/grass71.png
+ $(INSTALL_DATA) grass-72x72.png $(ARCH_DISTDIR)/share/icons/hicolor/72x72/apps/grass.png
$(MKDIR) $(ARCH_DISTDIR)/share/icons/hicolor/80x80/apps
- $(INSTALL_DATA) grass-80x80.png $(ARCH_DISTDIR)/share/icons/hicolor/80x80/apps/grass71.png
+ $(INSTALL_DATA) grass-80x80.png $(ARCH_DISTDIR)/share/icons/hicolor/80x80/apps/grass.png
$(MKDIR) $(ARCH_DISTDIR)/share/icons/hicolor/96x96/apps
- $(INSTALL_DATA) grass-96x96.png $(ARCH_DISTDIR)/share/icons/hicolor/96x96/apps/grass71.png
+ $(INSTALL_DATA) grass-96x96.png $(ARCH_DISTDIR)/share/icons/hicolor/96x96/apps/grass.png
$(MKDIR) $(ARCH_DISTDIR)/share/icons/hicolor/128x128/apps
- $(INSTALL_DATA) grass-128x128.png $(ARCH_DISTDIR)/share/icons/hicolor/128x128/apps/grass71.png
+ $(INSTALL_DATA) grass-128x128.png $(ARCH_DISTDIR)/share/icons/hicolor/128x128/apps/grass.png
$(MKDIR) $(ARCH_DISTDIR)/share/icons/hicolor/192x192/apps
- $(INSTALL_DATA) grass-192x192.png $(ARCH_DISTDIR)/share/icons/hicolor/192x192/apps/grass71.png
+ $(INSTALL_DATA) grass-192x192.png $(ARCH_DISTDIR)/share/icons/hicolor/192x192/apps/grass.png
$(MKDIR) $(ARCH_DISTDIR)/share/icons/hicolor/scalable/apps
- $(INSTALL_DATA) grass.svg $(ARCH_DISTDIR)/share/icons/hicolor/scalable/apps/grass71.svg
+ $(INSTALL_DATA) grass.svg $(ARCH_DISTDIR)/share/icons/hicolor/scalable/apps/grass.svg
$(MKDIR) $(ARCH_DISTDIR)/share/appdata
$(INSTALL_DATA) grass.appdata.xml $(ARCH_DISTDIR)/share/appdata
### disable special 64bit icons (using different icons can be confusing for the user)
