[GRASS-SVN] r70166 - grass/branches/releasebranch_7_2/gui/icons
Wed Dec 28 10:15:36 PST 2016
Author: neteler
Date: 2016-12-28 10:15:36 -0800 (Wed, 28 Dec 2016)
New Revision: 70166
   grass/branches/releasebranch_7_2/gui/icons/Makefile
grass.desktop: fix broken grass.png icon filename (trac #3233)
Modified: grass/branches/releasebranch_7_2/gui/icons/Makefile
--- grass/branches/releasebranch_7_2/gui/icons/Makefile	2016-12-28 18:13:35 UTC (rev 70165)
+++ grass/branches/releasebranch_7_2/gui/icons/Makefile	2016-12-28 18:15:36 UTC (rev 70166)
@@ -21,37 +21,37 @@
 	$(MKDIR) $(ARCH_DISTDIR)/share/applications
 	$(INSTALL_DATA) grass.desktop $(ARCH_DISTDIR)/share/applications
 	$(MKDIR) $(ARCH_DISTDIR)/share/icons/hicolor/8x8/apps
-	$(INSTALL_DATA) grass-8x8.png $(ARCH_DISTDIR)/share/icons/hicolor/8x8/apps/grass71.png
+	$(INSTALL_DATA) grass-8x8.png $(ARCH_DISTDIR)/share/icons/hicolor/8x8/apps/grass.png
 	$(MKDIR) $(ARCH_DISTDIR)/share/icons/hicolor/16x16/apps
-	$(INSTALL_DATA) grass-16x16.png $(ARCH_DISTDIR)/share/icons/hicolor/16x16/apps/grass71.png
+	$(INSTALL_DATA) grass-16x16.png $(ARCH_DISTDIR)/share/icons/hicolor/16x16/apps/grass.png
 	$(MKDIR) $(ARCH_DISTDIR)/share/icons/hicolor/22x22/apps
-	$(INSTALL_DATA) grass-22x22.png $(ARCH_DISTDIR)/share/icons/hicolor/22x22/apps/grass71.png
+	$(INSTALL_DATA) grass-22x22.png $(ARCH_DISTDIR)/share/icons/hicolor/22x22/apps/grass.png
 	$(MKDIR) $(ARCH_DISTDIR)/share/icons/hicolor/24x24/apps
-	$(INSTALL_DATA) grass-24x24.png $(ARCH_DISTDIR)/share/icons/hicolor/24x24/apps/grass71.png
+	$(INSTALL_DATA) grass-24x24.png $(ARCH_DISTDIR)/share/icons/hicolor/24x24/apps/grass.png
 	$(MKDIR) $(ARCH_DISTDIR)/share/icons/hicolor/32x32/apps
-	$(INSTALL_DATA) grass-32x32.png $(ARCH_DISTDIR)/share/icons/hicolor/32x32/apps/grass71.png
+	$(INSTALL_DATA) grass-32x32.png $(ARCH_DISTDIR)/share/icons/hicolor/32x32/apps/grass.png
 	$(MKDIR) $(ARCH_DISTDIR)/share/icons/hicolor/36x36/apps
-	$(INSTALL_DATA) grass-36x36.png $(ARCH_DISTDIR)/share/icons/hicolor/36x36/apps/grass71.png
+	$(INSTALL_DATA) grass-36x36.png $(ARCH_DISTDIR)/share/icons/hicolor/36x36/apps/grass.png
 	$(MKDIR) $(ARCH_DISTDIR)/share/icons/hicolor/40x40/apps
-	$(INSTALL_DATA) grass-40x40.png $(ARCH_DISTDIR)/share/icons/hicolor/40x40/apps/grass71.png
+	$(INSTALL_DATA) grass-40x40.png $(ARCH_DISTDIR)/share/icons/hicolor/40x40/apps/grass.png
 	$(MKDIR) $(ARCH_DISTDIR)/share/icons/hicolor/42x42/apps
-	$(INSTALL_DATA) grass-42x42.png $(ARCH_DISTDIR)/share/icons/hicolor/42x42/apps/grass71.png
+	$(INSTALL_DATA) grass-42x42.png $(ARCH_DISTDIR)/share/icons/hicolor/42x42/apps/grass.png
 	$(MKDIR) $(ARCH_DISTDIR)/share/icons/hicolor/48x48/apps
-	$(INSTALL_DATA) grass-48x48.png $(ARCH_DISTDIR)/share/icons/hicolor/48x48/apps/grass71.png
+	$(INSTALL_DATA) grass-48x48.png $(ARCH_DISTDIR)/share/icons/hicolor/48x48/apps/grass.png
 	$(MKDIR) $(ARCH_DISTDIR)/share/icons/hicolor/64x64/apps
-	$(INSTALL_DATA) grass-64x64.png $(ARCH_DISTDIR)/share/icons/hicolor/64x64/apps/grass71.png
+	$(INSTALL_DATA) grass-64x64.png $(ARCH_DISTDIR)/share/icons/hicolor/64x64/apps/grass.png
 	$(MKDIR) $(ARCH_DISTDIR)/share/icons/hicolor/72x72/apps
-	$(INSTALL_DATA) grass-72x72.png $(ARCH_DISTDIR)/share/icons/hicolor/72x72/apps/grass71.png
+	$(INSTALL_DATA) grass-72x72.png $(ARCH_DISTDIR)/share/icons/hicolor/72x72/apps/grass.png
 	$(MKDIR) $(ARCH_DISTDIR)/share/icons/hicolor/80x80/apps
-	$(INSTALL_DATA) grass-80x80.png $(ARCH_DISTDIR)/share/icons/hicolor/80x80/apps/grass71.png
+	$(INSTALL_DATA) grass-80x80.png $(ARCH_DISTDIR)/share/icons/hicolor/80x80/apps/grass.png
 	$(MKDIR) $(ARCH_DISTDIR)/share/icons/hicolor/96x96/apps
-	$(INSTALL_DATA) grass-96x96.png $(ARCH_DISTDIR)/share/icons/hicolor/96x96/apps/grass71.png
+	$(INSTALL_DATA) grass-96x96.png $(ARCH_DISTDIR)/share/icons/hicolor/96x96/apps/grass.png
 	$(MKDIR) $(ARCH_DISTDIR)/share/icons/hicolor/128x128/apps
-	$(INSTALL_DATA) grass-128x128.png $(ARCH_DISTDIR)/share/icons/hicolor/128x128/apps/grass71.png
+	$(INSTALL_DATA) grass-128x128.png $(ARCH_DISTDIR)/share/icons/hicolor/128x128/apps/grass.png
 	$(MKDIR) $(ARCH_DISTDIR)/share/icons/hicolor/192x192/apps
-	$(INSTALL_DATA) grass-192x192.png $(ARCH_DISTDIR)/share/icons/hicolor/192x192/apps/grass71.png
+	$(INSTALL_DATA) grass-192x192.png $(ARCH_DISTDIR)/share/icons/hicolor/192x192/apps/grass.png
 	$(MKDIR) $(ARCH_DISTDIR)/share/icons/hicolor/scalable/apps
-	$(INSTALL_DATA) grass.svg $(ARCH_DISTDIR)/share/icons/hicolor/scalable/apps/grass71.svg
+	$(INSTALL_DATA) grass.svg $(ARCH_DISTDIR)/share/icons/hicolor/scalable/apps/grass.svg
 	$(MKDIR) $(ARCH_DISTDIR)/share/appdata
 	$(INSTALL_DATA) grass.appdata.xml $(ARCH_DISTDIR)/share/appdata
 ### disable special 64bit icons (using different icons can be confusing for the user)
