[GRASS-SVN] r67741 - in grass/branches/releasebranch_7_0: db/db.login db/drivers/mysql db/drivers/postgres include include/defs lib/db/dbmi_base lib/vector/Vlib
svn_grass at osgeo.org
Sat Feb 6 07:25:05 PST 2016
Author: martinl
Date: 2016-02-06 07:25:05 -0800 (Sat, 06 Feb 2016)
New Revision: 67741
grass/branches/releasebranch_7_0/db/db.login/db.login.html
grass/branches/releasebranch_7_0/db/db.login/main.c
grass/branches/releasebranch_7_0/db/drivers/mysql/db.c
grass/branches/releasebranch_7_0/db/drivers/postgres/db.c
grass/branches/releasebranch_7_0/db/drivers/postgres/listdb.c
grass/branches/releasebranch_7_0/include/dbmi.h
grass/branches/releasebranch_7_0/include/defs/dbmi.h
grass/branches/releasebranch_7_0/lib/db/dbmi_base/connect.c
grass/branches/releasebranch_7_0/lib/db/dbmi_base/login.c
grass/branches/releasebranch_7_0/lib/vector/Vlib/open_pg.c
db.login + pg & mysql driver: support hostname and port
dbmi: add db_get|set_login2() which supports also hostname and port
(merge r65332, r65056, and r65057 from trunk)
Modified: grass/branches/releasebranch_7_0/db/db.login/db.login.html
--- grass/branches/releasebranch_7_0/db/db.login/db.login.html 2016-02-06 15:03:37 UTC (rev 67740)
+++ grass/branches/releasebranch_7_0/db/db.login/db.login.html 2016-02-06 15:25:05 UTC (rev 67741)
@@ -1,12 +1,12 @@
<h2>DESCRIPTION</h2>
<em>db.login</em> sets login parameters such an user name and
-optionally also a password for the connection to
+optionally also a password, a hostname or a port for the connection to
the selected <b>database</b> through the DB <b>driver</b>.
<h2>NOTE</h2>
-This command is only related to SQL database
+Options <b>host</b> and <b>port</b> are related to only SQL database
backends like <a href="grass-pg.html">PostgreSQL</a>,
<a href="grass-mysql.html">MySQL</a> or <a href="grass-odbc.html">ODBC</a>.
@@ -31,16 +31,15 @@
</pre></div>
<p>
-Username and password specified (note that the command lines
+Username, password and hostname specified (note that the command lines
history will store the password in this way):
<div class="code"><pre>
-db.login user=bacava password=secret
+db.login driver=pg database=mydb user=bacava password=secret host=db.example.com
</pre></div>
<p>
-Username and empty password specified (note that the command
-lines history will store the password in this way):
+Username and empty password specified:
db.login driver=pg database=mydb user=bacava password=""
@@ -60,7 +59,8 @@
<h2>AUTHOR</h2>
-Radim Blazek
+Radim Blazek<br>
+Support for hostname and port by Martin Landa, OSGeoREL, Czech Technical University in Prague, Czech Republic
<p>
<i>Last changed: $Date$</i>
Modified: grass/branches/releasebranch_7_0/db/db.login/main.c
--- grass/branches/releasebranch_7_0/db/db.login/main.c 2016-02-06 15:03:37 UTC (rev 67740)
+++ grass/branches/releasebranch_7_0/db/db.login/main.c 2016-02-06 15:25:05 UTC (rev 67741)
@@ -6,7 +6,7 @@
* Glynn Clements <glynn gclements.plus.com>
* Markus Neteler <neteler itc.it>
* PURPOSE: Store db login settings
- * COPYRIGHT: (C) 2004-2014 by the GRASS Development Team
+ * COPYRIGHT: (C) 2004-2015 by the GRASS Development Team
* This program is free software under the GNU General
* Public License (>=v2). Read the file COPYING that
@@ -29,7 +29,7 @@
int main(int argc, char *argv[])
- struct Option *driver, *database, *user, *password;
+ struct Option *driver, *database, *user, *password, *host, *port;
struct Flag *print;
struct GModule *module;
@@ -40,7 +40,8 @@
G_add_keyword(_("database"));
G_add_keyword(_("connection settings"));
module->description = _("Sets user/password for DB driver/database.");
+ module->overwrite = TRUE;
driver = G_define_standard_option(G_OPT_DB_DRIVER);
driver->options = db_list_drivers();
driver->required = YES;
@@ -55,7 +56,7 @@
user->type = TYPE_STRING;
user->required = NO;
user->multiple = NO;
- user->description = _("Username to set for DB connection");
+ user->description = _("Username");
user->guisection = _("Settings");
password = G_define_option();
@@ -63,9 +64,27 @@
password->type = TYPE_STRING;
password->required = NO;
password->multiple = NO;
- password->description = _("Password to set for DB connection");
+ password->description = _("Password");
password->guisection = _("Settings");
+ host = G_define_option();
+ host->key = "host";
+ host->type = TYPE_STRING;
+ host->required = NO;
+ host->multiple = NO;
+ host->label = _("Hostname");
+ host->description = _("Relevant only for pg and mysql driver");
+ host->guisection = _("Settings");
+ port = G_define_option();
+ port->key = "port";
+ port->type = TYPE_STRING;
+ port->required = NO;
+ port->multiple = NO;
+ port->label = _("Port");
+ port->description = _("Relevant only for pg and mysql driver");
+ port->guisection = _("Settings");
print = G_define_flag();
print->key = 'p';
print->description = _("Print connection settings and exit");
@@ -80,13 +99,15 @@
exit(EXIT_SUCCESS);
- if (db_set_login(driver->answer, database->answer, user->answer,
- password->answer) == DB_FAILED) {
+ if (db_set_login2(driver->answer, database->answer, user->answer,
+ password->answer, host->answer, port->answer,
+ G_get_overwrite()) == DB_FAILED) {
G_fatal_error(_("Unable to set user/password"));
if (password->answer)
- G_important_message(_("The password was stored in file (%s%cdblogin)"), G_config_path(), HOST_DIRSEP);
+ G_important_message(_("The password was stored in file (%s%cdblogin)"),
+ G_config_path(), HOST_DIRSEP);
exit(EXIT_SUCCESS);
Modified: grass/branches/releasebranch_7_0/db/drivers/mysql/db.c
--- grass/branches/releasebranch_7_0/db/drivers/mysql/db.c 2016-02-06 15:03:37 UTC (rev 67740)
+++ grass/branches/releasebranch_7_0/db/drivers/mysql/db.c 2016-02-06 15:25:05 UTC (rev 67741)
@@ -37,7 +37,7 @@
/* Client version */
- const char *user, *password;
+ const char *user, *password, *host, *port;
CONNPAR connpar;
if (parse_conn(name, &connpar) == DB_FAILED) {
@@ -50,11 +50,11 @@
connpar.host, connpar.port, connpar.dbname,
connpar.user, connpar.password);
- db_get_login("mysql", name, &user, &password);
+ db_get_login2("mysql", name, &user, &password, &host, &port);
connection = mysql_init(NULL);
- res = mysql_real_connect(connection, connpar.host, user, password,
- connpar.dbname, connpar.port, NULL, 0);
+ res = mysql_real_connect(connection, host, user, password,
+ connpar.dbname, port, NULL, 0);
if (res == NULL) {
db_d_append_error("%s\n%s",
Modified: grass/branches/releasebranch_7_0/db/drivers/postgres/db.c
--- grass/branches/releasebranch_7_0/db/drivers/postgres/db.c 2016-02-06 15:03:37 UTC (rev 67740)
+++ grass/branches/releasebranch_7_0/db/drivers/postgres/db.c 2016-02-06 15:25:05 UTC (rev 67741)
@@ -32,7 +32,7 @@
int db__driver_open_database(dbHandle * handle)
char buf[500];
- const char *name, *schema, *user, *password;
+ const char *name, *schema, *user, *password, *host, *port;
dbConnection connection;
PGCONN pgconn;
PGresult *res;
@@ -56,14 +56,15 @@
G_debug(3,
"db_driver_open_database(): host = %s, port = %s, options = %s, tty = %s, "
- "dbname = %s, user = %s, password = %s, "
+ "dbname = %s, user = %s, password = %s, host = %s, port = %s "
"schema = %s", pgconn.host, pgconn.port, pgconn.options,
pgconn.tty, pgconn.dbname, pgconn.user, pgconn.password,
+ pgconn.host, pgconn.port,
pgconn.schema);
- db_get_login("pg", name, &user, &password);
+ db_get_login2("pg", name, &user, &password, &host, &port);
- pg_conn = PQsetdbLogin(pgconn.host, pgconn.port, pgconn.options, pgconn.tty,
+ pg_conn = PQsetdbLogin(host, port, pgconn.options, pgconn.tty,
pgconn.dbname, user, password);
if (PQstatus(pg_conn) == CONNECTION_BAD) {
@@ -221,7 +222,7 @@
int create_delete_db(dbHandle *handle, int create)
dbString stmt;
- const char *template_db, *name, *user, *password;
+ const char *template_db, *name, *user, *password, *host, *port;
PGCONN pgconn;
PGresult *res;
@@ -237,13 +238,14 @@
G_debug(3,
"db_driver_create_database(): host = %s, port = %s, options = %s, tty = %s, "
+ "dbname = %s, user = %s, password = %s, host = %s, port = %s"
pgconn.schema);
- db_get_login("pg", template_db, &user, &password);
+ db_get_login2("pg", template_db, &user, &password, &host, &port);
db_d_append_error(_("Connection failed."));
Modified: grass/branches/releasebranch_7_0/db/drivers/postgres/listdb.c
--- grass/branches/releasebranch_7_0/db/drivers/postgres/listdb.c 2016-02-06 15:03:37 UTC (rev 67740)
+++ grass/branches/releasebranch_7_0/db/drivers/postgres/listdb.c 2016-02-06 15:25:05 UTC (rev 67741)
@@ -19,7 +19,7 @@
dbHandle ** dblist, int *dbcount)
int i;
- const char *user, *passwd;
+ const char *user, *passwd, *host, *port;
PGCONN pgconn;
PGresult *res;
int rec_num = 0;
@@ -42,20 +42,21 @@
return DB_FAILED;
- G_debug(1, "db = %s, user = %s, pass = %s, host = %s, port = %s, options = %s, tty = %s",
+ G_debug(1, "db = %s, user = %s, pass = %s, "
+ "host = %s, port = %s, options = %s, tty = %s",
pgconn.dbname, pgconn.user, pgconn.password, pgconn.host,
pgconn.port, pgconn.options, pgconn.tty);
- db_get_login("pg", NULL, &user, &passwd);
+ db_get_login2("pg", NULL, &user, &passwd, &host, &port);
G_debug(1, "user = %s, passwd = %s", user, passwd ? "xxx" : "");
if (user || passwd) {
"template1", user, passwd);
else {
pg_conn =
- PQsetdb(pgconn.host, pgconn.port, pgconn.options, pgconn.tty,
+ PQsetdb(host, port, pgconn.options, pgconn.tty,
"template1");
Modified: grass/branches/releasebranch_7_0/include/dbmi.h
--- grass/branches/releasebranch_7_0/include/dbmi.h 2016-02-06 15:03:37 UTC (rev 67740)
+++ grass/branches/releasebranch_7_0/include/dbmi.h 2016-02-06 15:25:05 UTC (rev 67741)
@@ -293,10 +293,10 @@
typedef struct _db_connection
char *driverName;
- /* char *hostName; */
+ char *hostName;
char *databaseName;
char *schemaName;
- char *location;
+ char *port;
char *user;
char *password;
char *keycol; /* name of default key column */
Modified: grass/branches/releasebranch_7_0/include/defs/dbmi.h
--- grass/branches/releasebranch_7_0/include/defs/dbmi.h 2016-02-06 15:03:37 UTC (rev 67740)
+++ grass/branches/releasebranch_7_0/include/defs/dbmi.h 2016-02-06 15:25:05 UTC (rev 67741)
@@ -411,7 +411,11 @@
void db_zero_string(dbString *);
unsigned int db_sizeof_string(const dbString *);
int db_set_login(const char *, const char *, const char *, const char *);
+int db_set_login2(const char *, const char *, const char *, const char *,
+ const char *, const char *, int);
int db_get_login(const char *, const char *, const char **, const char **);
+int db_get_login2(const char *, const char *, const char **, const char **,
+ const char **, const char **);
int db_get_login_dump(FILE *);
#endif
Modified: grass/branches/releasebranch_7_0/lib/db/dbmi_base/connect.c
--- grass/branches/releasebranch_7_0/lib/db/dbmi_base/connect.c 2016-02-06 15:03:37 UTC (rev 67740)
+++ grass/branches/releasebranch_7_0/lib/db/dbmi_base/connect.c 2016-02-06 15:25:05 UTC (rev 67741)
@@ -80,17 +80,12 @@
connection->schemaName = (char *)G_getenv_nofatal2("DB_SCHEMA", G_VAR_MAPSET);
connection->group = (char *)G_getenv_nofatal2("DB_GROUP", G_VAR_MAPSET);
- /* below commented due to new mechanism: see db_get_login()
- connection->hostName = G_getenv_nofatal("DB_HOST");
- connection->location = G_getenv_nofatal("DB_LOCATION");
- connection->user = G_getenv_nofatal("DB_USER");
- connection->password = G_getenv_nofatal("DB_PASSWORD");
/* try to get user/password */
- db_get_login(connection->driverName, connection->databaseName,
- (const char **) &(connection->user),
- (const char **) &(connection->password));
+ db_get_login2(connection->driverName, connection->databaseName,
+ (const char **) &(connection->user),
+ (const char **) &(connection->password),
+ (const char **) &(connection->hostName),
+ (const char **) &(connection->port));
return DB_OK;
Modified: grass/branches/releasebranch_7_0/lib/db/dbmi_base/login.c
--- grass/branches/releasebranch_7_0/lib/db/dbmi_base/login.c 2016-02-06 15:03:37 UTC (rev 67740)
+++ grass/branches/releasebranch_7_0/lib/db/dbmi_base/login.c 2016-02-06 15:25:05 UTC (rev 67741)
@@ -3,7 +3,7 @@
\brief DBMI Library (base) - login settings
- (C) 1999-2014 by the GRASS Development Team
+ (C) 1999-2015 by the GRASS Development Team
This program is free software under the GNU General Public
License (>=v2). Read the file COPYING that comes with GRASS
@@ -29,6 +29,8 @@
char *database;
char *user;
char *password;
+ char *host;
+ char *port;
} DATA;
typedef struct
@@ -57,19 +59,28 @@
static void add_login(LOGIN * login, const char *dr, const char *db, const char *usr,
- const char *pwd)
+ const char *pwd, const char *host, const char *port, int idx)
+ int login_idx;
if (login->n == login->a) {
login->a += 10;
login->data =
(DATA *) realloc((void *)login->data, login->a * sizeof(DATA));
- login->data[login->n].driver = G_store(dr);
- login->data[login->n].database = G_store(db);
- login->data[login->n].user = G_store(usr ? usr : "");
- login->data[login->n].password = G_store(pwd ? pwd : "");
- login->n++;
+ if (idx > -1 && idx < login->n) {
+ login_idx = idx;
+ else {
+ login_idx = login->n;
+ login->n++;
+ login->data[login_idx].driver = G_store(dr);
+ login->data[login_idx].database = G_store(db);
+ login->data[login_idx].user = G_store(usr ? usr : "");
+ login->data[login_idx].password = G_store(pwd ? pwd : "");
+ login->data[login_idx].host = G_store(host ? host : "");
+ login->data[login_idx].port = G_store(port ? port : "");
@@ -82,7 +93,7 @@
int ret;
const char *file;
FILE *fd;
- char buf[2001], dr[500], db[500], usr[500], pwd[500];
+ char buf[2001], dr[500], db[500], usr[500], pwd[500], host[500], port[500];
login->n = 0;
file = login_filename();
@@ -103,18 +114,19 @@
while (G_getl2(buf, 2000, fd)) {
G_chop(buf);
- usr[0] = pwd[0] = '\0';
- ret = sscanf(buf, "%[^|]|%[^|]|%[^|]|%[^\n]", dr, db, usr, pwd);
+ usr[0] = pwd[0] = host[0] = port[0] = '\0';
+ ret = sscanf(buf, "%[^|]|%[^|]|%[^|]|%[^|]|%[^|]|%[^\n]",
+ dr, db, usr, pwd, host, port);
- G_debug(3, "ret = %d : drv=[%s] db=[%s] usr=[%s] pwd=[%s]",
- ret, dr, db, usr, pwd);
+ G_debug(3, "ret = %d : drv=[%s] db=[%s] usr=[%s] pwd=[%s] host=[%s], port=[%s]",
+ ret, dr, db, usr, pwd, host, port);
if (ret < 2) {
G_warning(_("Login file (%s) corrupted (line: %s)"), file, buf);
continue;
- add_login(login, dr, db, usr, pwd);
+ add_login(login, dr, db, usr, pwd, host, port, -1);
fclose(fd);
@@ -155,7 +167,12 @@
if (login->data[i].password)
fprintf(fd, "|%s", login->data[i].password);
- fprintf(fd, "\n");
+ if (login->data[i].host)
+ fprintf(fd, "|%s", login->data[i].host);
+ if (login->data[i].port)
+ fprintf(fd, "|%s", login->data[i].port);
+ fprintf(fd, "\n");
fclose(fd);
@@ -163,32 +180,22 @@
return 0;
- \brief Set user/password for driver/database
- \param driver driver name
- \param database database name
- \param user user name
- \param password password string
- \return DB_OK on success
- \return DB_FAILED on failure
-int db_set_login(const char *driver, const char *database, const char *user,
- const char *password)
+static int set_login(const char *driver, const char *database, const char *user,
+ const char *password, const char *host, const char *port,
+ int overwrite)
int i, found;
LOGIN login;
- G_debug(3, "db_set_login(): drv=[%s] db=[%s] usr=[%s] pwd=[%s]",
- driver, database, user, password);
+ G_debug(3, "db_set_login(): drv=[%s] db=[%s] usr=[%s] pwd=[%s] host=[%s] port=[%s]",
+ driver, database, user, password, host, port);
init_login(&login);
if (read_file(&login) == -1)
return DB_FAILED;
- found = 0;
+ found = FALSE;
for (i = 0; i < login.n; i++) {
if (strcmp(login.data[i].driver, driver) == 0 &&
strcmp(login.data[i].database, database) == 0) {
@@ -202,13 +209,25 @@
else
login.data[i].password = G_store("");
- found = 1;
+ found = TRUE;
break;
+ if (found) {
+ if (overwrite)
+ G_warning(_("DB connection <%s/%s> already exists and will be overwritten"),
+ driver, database ? database : "");
+ else
+ G_fatal_error(_("DB connection <%s/%s> already exists. "
+ "Re-run '%s' with '--%s' flag to overwrite existing settings."),
+ driver, database ? database : "", G_program_name(), "overwrite");
if (!found)
- add_login(&login, driver, database, user, password);
+ add_login(&login, driver, database, user, password, host, port, -1);
+ else
+ add_login(&login, driver, database, user, password, host, port, i);
if (write_file(&login) == -1)
return DB_FAILED;
@@ -216,21 +235,53 @@
return DB_OK;
- \brief Get user/password for driver/database if driver/database
- is not found, user/password are set to NULL
+ \brief Set login parameters for driver/database
+ \deprecated Use db_set_login2() instead.
+ \todo: GRASS 8: to be replaced by db_set_login2().
- \param database database name (can be NULL)
- \param[out] user name
- \param[out] password string
+ \param database database name
+ \param user user name
+ \param password password string
-int db_get_login(const char *driver, const char *database, const char **user,
- const char **password)
+int db_set_login(const char *driver, const char *database, const char *user,
+ const char *password)
+ return set_login(driver, database, user,
+ password, NULL, NULL, FALSE);
+ \param driver driver name
+ \param host host name
+ \param port
+ \param overwrite TRUE to overwrite exising connections
+ \return DB_OK on success
+ \return DB_FAILED on failure
+int db_set_login2(const char *driver, const char *database, const char *user,
+ int overwrite)
+ password, host, port, overwrite);
+static int get_login(const char *driver, const char *database, const char **user,
+ const char **password, const char **host, const char **port)
int i;
LOGIN login;
@@ -238,7 +289,9 @@
user[0] = '\0';
password[0] = '\0';
+ host[0] = '\0';
+ port[0] = '\0';
init_login(&login);
@@ -257,6 +310,16 @@
else
*password = NULL;
+ if (login.data[i].host && strlen(login.data[i].host) > 0 && host)
+ *host = G_store(login.data[i].host);
+ else
+ *host = NULL;
+ if (login.data[i].port && strlen(login.data[i].port) > 0 && port)
+ *port = G_store(login.data[i].port);
+ else
+ *port = NULL;
break;
@@ -265,6 +328,52 @@
+ \brief Get login parameters for driver/database
+ If driver/database is not found, output arguments are set to NULL.
+ \param database database name (can be NULL)
+ \param[out] user name
+ \param[out] password string
+int db_get_login(const char *driver, const char *database, const char **user,
+ const char **password)
+ return get_login(driver, database, user,
+ password, NULL, NULL);
+ \param[out] host name
+ \param[out] port
+int db_get_login2(const char *driver, const char *database, const char **user,
+ password, host, port);
\brief Print all connection settings to file
\param fd file where to print settings
@@ -284,11 +393,13 @@
return DB_FAILED;
- fprintf(fd, "%s|%s|%s|%s\n",
+ fprintf(fd, "%s|%s|%s|%s|%s|%s\n",
login.data[i].user,
- login.data[i].password);
+ login.data[i].password,
+ login.data[i].host,
+ login.data[i].port);
return DB_OK;
Modified: grass/branches/releasebranch_7_0/lib/vector/Vlib/open_pg.c
--- grass/branches/releasebranch_7_0/lib/vector/Vlib/open_pg.c 2016-02-06 15:03:37 UTC (rev 67740)
+++ grass/branches/releasebranch_7_0/lib/vector/Vlib/open_pg.c 2016-02-06 15:25:05 UTC (rev 67741)
@@ -507,7 +507,7 @@
if (!strstr(pg_info->conninfo, "user")) {
char dbname[GNAME_MAX];
char *p;
dbname[0] = '\0';
p = strstr(pg_info->conninfo, "dbname");
@@ -521,11 +521,11 @@
/* try connection settings for given database first, then try
* any settings defined for pg driver */
- db_get_login("pg", dbname, &user, &passwd);
+ db_get_login2("pg", dbname, &user, &passwd, &host, &port);
if (strlen(dbname) > 0 && !user && !passwd)
- if (user || passwd) {
+ if (user || passwd || host || port) {
char conninfo[DB_SQL_MAX];
sprintf(conninfo, "%s", pg_info->conninfo);
@@ -537,6 +537,14 @@
strcat(conninfo, " password=");
strcat(conninfo, passwd);
+ if (host) {
+ strcat(conninfo, " host=");
+ strcat(conninfo, host);
+ if (port) {
+ strcat(conninfo, " port=");
+ strcat(conninfo, port);
G_free(pg_info->conninfo);
pg_info->conninfo = G_store(conninfo);
