[GRASS-SVN] r67742 - grass/branches/releasebranch_7_0/vector/v.in.ogr
Sat Feb 6 09:43:21 PST 2016
Author: martinl
Date: 2016-02-06 09:43:21 -0800 (Sat, 06 Feb 2016)
New Revision: 67742
   grass/branches/releasebranch_7_0/vector/v.in.ogr/main.c
v.in.ogr: Support int64 for key column too, see #2769
          (merge r66726, r66729 from trunk)
Modified: grass/branches/releasebranch_7_0/vector/v.in.ogr/main.c
--- grass/branches/releasebranch_7_0/vector/v.in.ogr/main.c	2016-02-06 15:25:05 UTC (rev 67741)
+++ grass/branches/releasebranch_7_0/vector/v.in.ogr/main.c	2016-02-06 17:43:21 UTC (rev 67742)
@@ -1000,8 +1000,13 @@
                 /* check if the field is integer */
                 Ogr_field = OGR_FD_GetFieldDefn(Ogr_featuredefn, key_idx);
                 Ogr_ftype = OGR_Fld_GetType(Ogr_field);
-                if (Ogr_ftype != OFTInteger)
+                if (!(Ogr_ftype == OFTInteger
+#if GDAL_VERSION_NUM >= 2000000
+                      || Ogr_ftype == OFTInteger64
+#endif
                     G_fatal_error(_("Key column '%s' is not integer"), param.key->answer);
                 key_column = G_store(OGR_Fld_GetNameRef(Ogr_field));
@@ -1248,7 +1253,11 @@
 		    else {
 			/* G_warning (_("Column value not set" )); */
-			if (Ogr_ftype == OFTInteger || Ogr_ftype == OFTReal) {
+			if (Ogr_ftype == OFTInteger ||
+                            Ogr_ftype == OFTInteger64 ||
+#endif
+                            Ogr_ftype == OFTReal) {
 			    sprintf(buf, ", NULL");
 #if GDAL_VERSION_NUM >= 1320
