[GRASS-SVN] r67743 - grass/branches/releasebranch_7_0/vector/v.in.ogr
Sat Feb 6 09:53:59 PST 2016
Author: martinl
Date: 2016-02-06 09:53:59 -0800 (Sat, 06 Feb 2016)
New Revision: 67743
   grass/branches/releasebranch_7_0/vector/v.in.ogr/main.c
v.in.ogr not supporting OFTInteger64 field type (#2769)
         add support also for Integer64List
         (merge r66564, r66565 from trunk)
Modified: grass/branches/releasebranch_7_0/vector/v.in.ogr/main.c
--- grass/branches/releasebranch_7_0/vector/v.in.ogr/main.c	2016-02-06 17:43:21 UTC (rev 67742)
+++ grass/branches/releasebranch_7_0/vector/v.in.ogr/main.c	2016-02-06 17:53:59 UTC (rev 67743)
@@ -1086,11 +1086,30 @@
 		/**                                          OFTDate = 9           **/
 		/**                                          OFTTime = 10          **/
 		/**                                          OFTDateTime = 11      **/
+                /** GDAL 2.0+                                                      **/
+                /** Simple 64bit integer                     OFTInteger64 = 12     **/
+                /** List of 64bit integers                   OFTInteger64List = 13 **/
 		if (Ogr_ftype == OFTInteger) {
 		    sprintf(buf, ", %s integer", Ogr_fieldname);
-		else if (Ogr_ftype == OFTIntegerList) {
+#if GDAL_VERSION_NUM >= 2000000
+		else if (Ogr_ftype == OFTInteger64) {
+                    if (strcmp(Fi->driver, "pg") == 0)
+                        sprintf(buf, ", %s bigint", Ogr_fieldname);
+                    else {
+                        sprintf(buf, ", %s integer", Ogr_fieldname);
+                        if (strcmp(Fi->driver, "sqlite") != 0)
+                            G_warning(_("Writing column <%s> with integer 64 as integer 32"),
+                                      Ogr_fieldname);
+#endif
+		else if (Ogr_ftype == OFTIntegerList
+                         || Ogr_ftype == OFTInteger64List
+#endif
 		    /* hack: treat as string */
 		    sprintf(buf, ", %s varchar ( %d )", Ogr_fieldname,
 			    OFTIntegerListlength);
@@ -1133,8 +1152,8 @@
 			      Ogr_fieldname, OFTIntegerListlength);
 		else {
-		    G_warning(_("Column type not supported (%s)"),
-			      Ogr_fieldname);
+		    G_warning(_("Column type (Ogr_ftype: %d) not supported (Ogr_fieldname: %s)"),
+			      Ogr_ftype, Ogr_fieldname);
 		    buf[0] = 0;
 		db_append_string(&sql, buf);
@@ -1218,7 +1237,11 @@
 		    Ogr_field = OGR_FD_GetFieldDefn(Ogr_featuredefn, i);
 		    Ogr_ftype = OGR_Fld_GetType(Ogr_field);
 		    if (OGR_F_IsFieldSet(Ogr_feature, i)) {
-			if (Ogr_ftype == OFTInteger || Ogr_ftype == OFTReal) {
+			if (Ogr_ftype == OFTInteger ||
+                            Ogr_ftype == OFTInteger64 ||
+#endif
+                            Ogr_ftype == OFTReal) {
 			    sprintf(buf, ", %s",
 				    OGR_F_GetFieldAsString(Ogr_feature, i));
@@ -1239,7 +1262,11 @@
 #endif
 			else if (Ogr_ftype == OFTString ||
 			         Ogr_ftype == OFTStringList ||
-				 Ogr_ftype == OFTIntegerList) {
+				 Ogr_ftype == OFTIntegerList
+#endif
 			    db_set_string(&strval, (char *)
 								 i));
@@ -1269,7 +1296,11 @@
 #endif
+#endif
 			    sprintf(buf, ", NULL");
 			else {
