[GRASS-SVN] r67745 - in grass/branches/releasebranch_7_0: gui/wxpython/core lib/python/script
svn_grass at osgeo.org
Sat Feb 6 11:31:54 PST 2016
Author: martinl
Date: 2016-02-06 11:31:54 -0800 (Sat, 06 Feb 2016)
New Revision: 67745
grass/branches/releasebranch_7_0/gui/wxpython/core/debug.py
grass/branches/releasebranch_7_0/gui/wxpython/core/gconsole.py
grass/branches/releasebranch_7_0/lib/python/script/core.py
fix pythonlib and GUI when debug/wx_debug value is invalid (do not fail, just print warning message)
(merge r67609 from trunk)
Modified: grass/branches/releasebranch_7_0/gui/wxpython/core/debug.py
--- grass/branches/releasebranch_7_0/gui/wxpython/core/debug.py 2016-02-06 18:10:33 UTC (rev 67744)
+++ grass/branches/releasebranch_7_0/gui/wxpython/core/debug.py 2016-02-06 19:31:54 UTC (rev 67745)
@@ -39,7 +39,13 @@
def SetLevel(self):
"""Initialize gui debug level
- self.debuglevel = int(grass.gisenv().get('WX_DEBUG', 0))
+ try:
+ self.debuglevel = int(grass.gisenv().get('WX_DEBUG', 0))
+ if self.debuglevel < 0 or self.debuglevel > 5:
+ raise ValueError(_("Wx debug level {}.").format(self.debuglevel))
+ except ValueError as e:
+ self.debuglevel = 0
+ sys.stderr.write(_("WARNING: Ignoring unsupported wx debug level (must be >=0 and <=5). {}\n").format(e))
def msg(self, level, message, *args):
"""Print debug message
Modified: grass/branches/releasebranch_7_0/gui/wxpython/core/gconsole.py
--- grass/branches/releasebranch_7_0/gui/wxpython/core/gconsole.py 2016-02-06 18:10:33 UTC (rev 67744)
+++ grass/branches/releasebranch_7_0/gui/wxpython/core/gconsole.py 2016-02-06 19:31:54 UTC (rev 67745)
@@ -381,7 +381,7 @@
def Redirect(self):
"""Redirect stdout/stderr
- if Debug.GetLevel() == 0 and int(grass.gisenv().get('DEBUG', 0)) == 0:
+ if Debug.GetLevel() == 0 and grass.debug_level(force=True) == 0:
# don't redirect when debugging is enabled
sys.stdout = self.cmdStdOut
sys.stderr = self.cmdStdErr
Modified: grass/branches/releasebranch_7_0/lib/python/script/core.py
--- grass/branches/releasebranch_7_0/lib/python/script/core.py 2016-02-06 18:10:33 UTC (rev 67744)
+++ grass/branches/releasebranch_7_0/lib/python/script/core.py 2016-02-06 19:31:54 UTC (rev 67745)
@@ -1508,13 +1508,20 @@
_debug_level = None
-def debug_level():
+def debug_level(force=False):
global _debug_level
- if _debug_level is not None:
+ if not force and _debug_level is not None:
return _debug_level
_debug_level = 0
if find_program('g.gisenv', '--help'):
- _debug_level = int(gisenv().get('DEBUG', 0))
+ try:
+ _debug_level = int(gisenv().get('DEBUG', 0))
+ if _debug_level < 0 or _debug_level > 5:
+ raise ValueError(_("Debug level {}").format(_debug_level))
+ _debug_level = 0
+ sys.stderr.write(_("WARNING: Ignoring unsupported debug level (must be >=0 and <=5). {}\n").format(e))
return _debug_level
