[GRASS-SVN] r67746 - in grass/branches/releasebranch_7_0/scripts: r.import v.import
svn_grass at osgeo.org
Sat Feb 6 11:37:33 PST 2016
Author: martinl
Date: 2016-02-06 11:37:33 -0800 (Sat, 06 Feb 2016)
New Revision: 67746
grass/branches/releasebranch_7_0/scripts/r.import/r.import.py
grass/branches/releasebranch_7_0/scripts/v.import/v.import.py
r.import + v.import: add -o flag
(merge r67632 + r67634 from trunk)
Modified: grass/branches/releasebranch_7_0/scripts/r.import/r.import.py
--- grass/branches/releasebranch_7_0/scripts/r.import/r.import.py 2016-02-06 19:31:54 UTC (rev 67745)
+++ grass/branches/releasebranch_7_0/scripts/r.import/r.import.py 2016-02-06 19:37:33 UTC (rev 67746)
@@ -8,7 +8,7 @@
# PURPOSE: Import and reproject on the fly
-# COPYRIGHT: (C) 2015 GRASS development team
+# COPYRIGHT: (C) 2015-2016 GRASS development team
# This program is free software under the GNU General
# Public License (>=v2). Read the file COPYING that
@@ -103,8 +103,12 @@
#% key: l
#% description: Force Lat/Lon maps to fit into geographic coordinates (90N,S; 180E,W)
#%end
+#%flag
+#% key: o
+#% label: Override projection check (use current location's projection)
+#% description: Assume that the dataset has same projection as the current location
+#%end
import sys
import os
import atexit
@@ -188,8 +192,10 @@
# try r.in.gdal directly first
additional_flags = 'l' if flags['l'] else ''
- if grass.run_command('r.in.gdal', input=GDALdatasource, flags='j',
- errors='status', quiet=True) == 0:
+ if flags['o']:
+ additional_flags += 'o'
+ if flags['o'] or grass.run_command('r.in.gdal', input=GDALdatasource, flags='j',
+ errors='status', quiet=True) == 0:
parameters = dict(input=GDALdatasource, output=output,
memory=memory, flags='k' + additional_flags)
if bands:
Modified: grass/branches/releasebranch_7_0/scripts/v.import/v.import.py
--- grass/branches/releasebranch_7_0/scripts/v.import/v.import.py 2016-02-06 19:31:54 UTC (rev 67745)
+++ grass/branches/releasebranch_7_0/scripts/v.import/v.import.py 2016-02-06 19:37:33 UTC (rev 67746)
@@ -86,8 +86,12 @@
#% key: l
#% description: List available OGR layers in data source and exit
#%end
+#%flag
+#% key: o
+#%end
import sys
import os
import atexit
@@ -129,9 +133,12 @@
output = options['output']
layers = options['layer']
- vflags = None
+ vflags = ''
if options['extent'] == 'region':
- vflags = 'r'
+ vflags += 'r'
+ if flags['o']:
+ vflags += 'o'
vopts = {}
if options['encoding']:
vopts['encoding'] = options['encoding']
@@ -188,8 +195,8 @@
os.environ['GISRC'] = str(tgtgisrc)
# try v.in.ogr directly
- if grass.run_command('v.in.ogr', input=OGRdatasource, flags='j',
+ if flags['o'] or grass.run_command('v.in.ogr', input=OGRdatasource, flags='j',
try:
flags=vflags, **vopts)
