[GRASS-SVN] r67860 - in grass/trunk: lib/python/temporal temporal/t.rast.list temporal/t.rast3d.list temporal/t.vect.list
svn_grass at osgeo.org
Wed Feb 17 02:08:38 PST 2016
Author: lucadelu
Date: 2016-02-17 02:08:38 -0800 (Wed, 17 Feb 2016)
New Revision: 67860
grass/trunk/lib/python/temporal/list_stds.py
grass/trunk/temporal/t.rast.list/t.rast.list.py
grass/trunk/temporal/t.rast3d.list/t.rast3d.list.py
grass/trunk/temporal/t.vect.list/t.vect.list.py
temporal: add output file support for modules listing temporal information
Modified: grass/trunk/lib/python/temporal/list_stds.py
--- grass/trunk/lib/python/temporal/list_stds.py 2016-02-17 10:02:02 UTC (rev 67859)
+++ grass/trunk/lib/python/temporal/list_stds.py 2016-02-17 10:08:38 UTC (rev 67860)
@@ -114,7 +114,8 @@
def list_maps_of_stds(type, input, columns, order, where, separator,
- method, no_header=False, gran=None, dbif=None):
+ method, no_header=False, gran=None, dbif=None,
+ outpath=None):
""" List the maps of a space time dataset using diffetent methods
:param type: The type of the maps raster, raster3d or vector
@@ -143,6 +144,7 @@
:param gran: The user defined granule to be used if method=gran is
set, in case gran=None the granule of the space time
dataset is used
+ :param outpath: Tha path to output file where save info
dbif, connected = init_dbif(dbif)
@@ -153,6 +155,9 @@
if separator is None or separator == "":
separator = "\t"
+ if outpath:
+ outfile = open(outpath, 'w')
# This method expects a list of objects for gap detection
if method == "delta" or method == "deltagaps" or method == "gran":
if type == "stvds":
@@ -184,7 +189,10 @@
string += "%s%s" % ("end_time", separator)
string += "%s%s" % ("interval_length", separator)
string += "%s" % ("distance_from_begin")
- print string
+ if outpath:
+ outfile.write('{st}\n'.format(st=string))
+ else:
+ print string
if maps and len(maps) > 0:
@@ -229,7 +237,10 @@
string += "%s%s" % (end, separator)
string += "%s%s" % (delta, separator)
string += "%s" % (delta_first)
- print string
+ if outpath:
+ else:
+ print string
else:
# In comma separated mode only map ids are needed
@@ -248,7 +259,10 @@
else:
string += ",%s" % row["id"]
count += 1
- print string
+ if outpath:
+ else:
+ print string
elif method == "cols":
# Print the column names if requested
@@ -264,7 +278,10 @@
else:
output += str(key)
count += 1
- print output
+ if outpath:
+ outfile.write('{st}\n'.format(st=output))
+ else:
+ print output
for row in rows:
output = ""
@@ -275,8 +292,10 @@
else:
output += str(col)
count += 1
- print output
+ if outpath:
+ else:
+ print output
if connected:
dbif.close()
Modified: grass/trunk/temporal/t.rast.list/t.rast.list.py
--- grass/trunk/temporal/t.rast.list/t.rast.list.py 2016-02-17 10:02:02 UTC (rev 67859)
+++ grass/trunk/temporal/t.rast.list/t.rast.list.py 2016-02-17 10:08:38 UTC (rev 67860)
@@ -75,6 +75,10 @@
#% guisection: Formatting
#%end
+#%option G_OPT_F_OUTPUT
+#% required: no
+#%end
#%flag
#% key: s
#% description: Suppress printing of column names
@@ -98,12 +102,13 @@
method = options["method"]
granule = options["granule"]
header = flags["s"]
+ output = options["output"]
# Make sure the temporal database exists
tgis.init()
- tgis.list_maps_of_stds(
- "strds", input, columns, order, where, separator, method, header, granule)
+ tgis.list_maps_of_stds("strds", input, columns, order, where, separator,
+ method, header, granule, outpath=output)
if __name__ == "__main__":
options, flags = grass.parser()
Modified: grass/trunk/temporal/t.rast3d.list/t.rast3d.list.py
--- grass/trunk/temporal/t.rast3d.list/t.rast3d.list.py 2016-02-17 10:02:02 UTC (rev 67859)
+++ grass/trunk/temporal/t.rast3d.list/t.rast3d.list.py 2016-02-17 10:08:38 UTC (rev 67860)
@@ -67,6 +67,10 @@
#%end
+#% required: no
+#%end
#%flag
#% key: s
@@ -89,12 +93,13 @@
separator = grass.separator(options["separator"])
header = flags["s"]
tgis.init()
- "str3ds", input, columns, order, where, separator, method, header)
+ tgis.list_maps_of_stds("str3ds", input, columns, order, where, separator,
+ method, header, outpath=output)
Modified: grass/trunk/temporal/t.vect.list/t.vect.list.py
--- grass/trunk/temporal/t.vect.list/t.vect.list.py 2016-02-17 10:02:02 UTC (rev 67859)
+++ grass/trunk/temporal/t.vect.list/t.vect.list.py 2016-02-17 10:08:38 UTC (rev 67860)
@@ -67,6 +67,10 @@
#%end
+#% required: no
+#%end
#%flag
#% key: s
@@ -89,12 +93,13 @@
header = flags["s"]
tgis.init()
- "stvds", input, columns, order, where, separator, method, header)
+ tgis.list_maps_of_stds("stvds", input, columns, order, where, separator,
