[GRASS-SVN] r67861 - grass/trunk/lib/python/temporal
svn_grass at osgeo.org
Wed Feb 17 02:20:09 PST 2016
Author: neteler
Date: 2016-02-17 02:20:09 -0800 (Wed, 17 Feb 2016)
New Revision: 67861
grass/trunk/lib/python/temporal/list_stds.py
temporal lib: minor doc typos fixed
Modified: grass/trunk/lib/python/temporal/list_stds.py
--- grass/trunk/lib/python/temporal/list_stds.py 2016-02-17 10:08:38 UTC (rev 67860)
+++ grass/trunk/lib/python/temporal/list_stds.py 2016-02-17 10:20:09 UTC (rev 67861)
@@ -10,9 +10,9 @@
tgis.register_maps_in_space_time_dataset(type, name, maps)
-(C) 2012-2013 by the GRASS Development Team
+(C) 2012-2016 by the GRASS Development Team
This program is free software under the GNU General Public
-License (>=v2). Read the file COPYING that comes with GRASS
+License (>=v2). Read the file COPYING that comes with GRASS GIS
for details.
:authors: Soeren Gebbert
@@ -116,7 +116,7 @@
def list_maps_of_stds(type, input, columns, order, where, separator,
method, no_header=False, gran=None, dbif=None,
outpath=None):
- """ List the maps of a space time dataset using diffetent methods
+ """ List the maps of a space time dataset using different methods
:param type: The type of the maps raster, raster3d or vector
:param input: Name of a space time raster dataset
@@ -136,15 +136,15 @@
end time, relative length of intervals and the relative
distance to the begin
- "deltagaps" Same as "delta" with additional listing of gaps.
- Gaps can be simply identified as the id is "None"
+ Gaps can be easily identified as the id is "None"
- "gran" List map using the granularity of the space time dataset,
- columns are identical to deltagaps
+ columns are identical to deltagaps
:param no_header: Supress the printing of column names
:param gran: The user defined granule to be used if method=gran is
set, in case gran=None the granule of the space time
dataset is used
- :param outpath: Tha path to output file where save info
+ :param outpath: The path to file where to save output
dbif, connected = init_dbif(dbif)
