[GRASS-SVN] r67880 - in grass/branches/releasebranch_7_0: lib/python/temporal temporal/t.list temporal/t.rast.list temporal/t.rast3d.list temporal/t.vect.list
svn_grass at osgeo.org
Thu Feb 18 03:19:25 PST 2016
Author: lucadelu
Date: 2016-02-18 03:19:25 -0800 (Thu, 18 Feb 2016)
New Revision: 67880
grass/branches/releasebranch_7_0/lib/python/temporal/list_stds.py
grass/branches/releasebranch_7_0/temporal/t.list/t.list.py
grass/branches/releasebranch_7_0/temporal/t.rast.list/t.rast.list.py
grass/branches/releasebranch_7_0/temporal/t.rast3d.list/t.rast3d.list.py
grass/branches/releasebranch_7_0/temporal/t.vect.list/t.vect.list.py
temporal: backported changes to support output parameter [#2319]
Modified: grass/branches/releasebranch_7_0/lib/python/temporal/list_stds.py
--- grass/branches/releasebranch_7_0/lib/python/temporal/list_stds.py 2016-02-18 11:14:10 UTC (rev 67879)
+++ grass/branches/releasebranch_7_0/lib/python/temporal/list_stds.py 2016-02-18 11:19:25 UTC (rev 67880)
@@ -10,9 +10,9 @@
tgis.register_maps_in_space_time_dataset(type, name, maps)
-(C) 2012-2013 by the GRASS Development Team
+(C) 2012-2016 by the GRASS Development Team
This program is free software under the GNU General Public
-License (>=v2). Read the file COPYING that comes with GRASS
+License (>=v2). Read the file COPYING that comes with GRASS GIS
for details.
:authors: Soeren Gebbert
@@ -51,7 +51,8 @@
>>> tgis.init()
>>> name = "list_stds_test"
>>> sp = tgis.open_new_stds(name=name, type="strds",
- ... temporaltype="absolute", title="title", descr="descr", semantic="mean", dbif=None, overwrite=True)
+ ... temporaltype="absolute", title="title", descr="descr",
+ ... semantic="mean", dbif=None, overwrite=True)
>>> mapset = tgis.get_current_mapset()
>>> stds_list = tgis.get_dataset_list("strds", "absolute", columns="name")
>>> rows = stds_list[mapset]
@@ -59,7 +60,8 @@
... if row["name"] == name:
... print True
True
- >>> stds_list = tgis.get_dataset_list("strds", "absolute", columns="name,mapset", where="mapset = '%s'"%(mapset))
+ >>> stds_list = tgis.get_dataset_list("strds", "absolute",
+ ... columns="name,mapset", where="mapset = '%s'"%(mapset))
>>> for row in rows:
... if row["name"] == name and row["mapset"] == mapset:
@@ -111,8 +113,9 @@
def list_maps_of_stds(type, input, columns, order, where, separator,
- method, no_header=False, gran=None):
- """ List the maps of a space time dataset using diffetent methods
+ method, no_header=False, gran=None,
+ outpath=None):
+ """ List the maps of a space time dataset using different methods
:param type: The type of the maps raster, raster3d or vector
:param input: Name of a space time raster dataset
@@ -131,14 +134,15 @@
end time, relative length of intervals and the relative
distance to the begin
- "deltagaps" Same as "delta" with additional listing of gaps.
- Gaps can be simply identified as the id is "None"
+ Gaps can be easily identified as the id is "None"
- "gran" List map using the granularity of the space time dataset,
- columns are identical to deltagaps
+ columns are identical to deltagaps
:param no_header: Supress the printing of column names
:param gran: The user defined granule to be used if method=gran is
set, in case gran=None the granule of the space time
dataset is used
+ :param outpath: The path to file where to save output
dbif, connected = init_dbif(None)
@@ -149,6 +153,9 @@
if separator is None or separator == "":
separator = "\t"
+ if outpath:
+ outfile = open(outpath, 'w')
# This method expects a list of objects for gap detection
if method == "delta" or method == "deltagaps" or method == "gran":
if type == "stvds":
@@ -180,7 +187,10 @@
string += "%s%s" % ("end_time", separator)
string += "%s%s" % ("interval_length", separator)
string += "%s" % ("distance_from_begin")
- print string
+ if outpath:
+ outfile.write('{st}\n'.format(st=string))
+ else:
+ print string
if maps and len(maps) > 0:
@@ -225,7 +235,10 @@
string += "%s%s" % (end, separator)
string += "%s%s" % (delta, separator)
string += "%s" % (delta_first)
- print string
+ if outpath:
+ else:
+ print string
else:
# In comma separated mode only map ids are needed
@@ -244,7 +257,10 @@
else:
string += ",%s" % row["id"]
count += 1
- print string
+ if outpath:
+ else:
+ print string
elif method == "cols":
# Print the column names if requested
@@ -260,7 +276,10 @@
else:
output += str(key)
count += 1
- print output
+ if outpath:
+ outfile.write('{st}\n'.format(st=output))
+ else:
+ print output
for row in rows:
output = ""
@@ -271,8 +290,12 @@
else:
output += str(col)
count += 1
- print output
+ if outpath:
+ else:
+ print output
+ if outpath:
+ outfile.close()
if connected:
dbif.close()
Modified: grass/branches/releasebranch_7_0/temporal/t.list/t.list.py
--- grass/branches/releasebranch_7_0/temporal/t.list/t.list.py 2016-02-18 11:14:10 UTC (rev 67879)
+++ grass/branches/releasebranch_7_0/temporal/t.list/t.list.py 2016-02-18 11:19:25 UTC (rev 67880)
@@ -71,6 +71,10 @@
#% guisection: Formatting
#%end
+#%option G_OPT_F_OUTPUT
+#% required: no
+#%end
#%flag
#% key: c
#% description: Print the column names as first row
@@ -93,6 +97,7 @@
order = options["order"]
where = options["where"]
separator = gscript.separator(options["separator"])
+ outpath = options["output"]
colhead = flags['c']
# Make sure the temporal database exists
@@ -100,8 +105,8 @@
sp = tgis.dataset_factory(type, None)
first = True
- if gscript.verbosity() > 0:
+ if gscript.verbosity() > 0 and not outpath:
sys.stderr.write("----------------------------------------------\n")
for ttype in temporal_type.split(","):
@@ -116,13 +121,16 @@
# alphabetic ordering
mapsets = tgis.get_tgis_c_library_interface().available_mapsets()
+ if outpath:
# Print for each mapset separately
for key in mapsets:
if key in stds_list.keys():
rows = stds_list[key]
if rows:
if issubclass(sp.__class__, tgis.AbstractMapDataset):
sys.stderr.write(_("Time stamped %s maps with %s available in mapset <%s>:\n")%\
(sp.get_type(), time, key))
@@ -140,9 +148,12 @@
else:
output += str(key)
count += 1
- print output
+ if outpath:
+ outfile.write("{st}\n".format(st=output))
+ else:
+ print output
first = False
for row in rows:
output = ""
count = 0
@@ -152,8 +163,12 @@
else:
output += str(col)
count += 1
- print output
+ if outpath:
+ else:
+ print output
+ if outpath:
+ outfile.close()
if __name__ == "__main__":
options, flags = gscript.parser()
Modified: grass/branches/releasebranch_7_0/temporal/t.rast.list/t.rast.list.py
--- grass/branches/releasebranch_7_0/temporal/t.rast.list/t.rast.list.py 2016-02-18 11:14:10 UTC (rev 67879)
+++ grass/branches/releasebranch_7_0/temporal/t.rast.list/t.rast.list.py 2016-02-18 11:19:25 UTC (rev 67880)
@@ -75,6 +75,10 @@
#%end
+#% required: no
+#%end
#%flag
#% key: s
#% description: Suppress printing of column names
@@ -98,12 +102,13 @@
method = options["method"]
granule = options["granule"]
header = flags["s"]
+ output = options["output"]
tgis.init()
- tgis.list_maps_of_stds(
- "strds", input, columns, order, where, separator, method, header, granule)
+ tgis.list_maps_of_stds("strds", input, columns, order, where, separator,
+ method, header, granule, outpath=output)
options, flags = grass.parser()
Modified: grass/branches/releasebranch_7_0/temporal/t.rast3d.list/t.rast3d.list.py
--- grass/branches/releasebranch_7_0/temporal/t.rast3d.list/t.rast3d.list.py 2016-02-18 11:14:10 UTC (rev 67879)
+++ grass/branches/releasebranch_7_0/temporal/t.rast3d.list/t.rast3d.list.py 2016-02-18 11:19:25 UTC (rev 67880)
@@ -67,6 +67,10 @@
#%end
+#% required: no
+#%end
#%flag
#% key: s
@@ -89,12 +93,13 @@
separator = grass.separator(options["separator"])
header = flags["s"]
tgis.init()
- "str3ds", input, columns, order, where, separator, method, header)
+ tgis.list_maps_of_stds("str3ds", input, columns, order, where, separator,
+ method, header, outpath=output)
Modified: grass/branches/releasebranch_7_0/temporal/t.vect.list/t.vect.list.py
--- grass/branches/releasebranch_7_0/temporal/t.vect.list/t.vect.list.py 2016-02-18 11:14:10 UTC (rev 67879)
+++ grass/branches/releasebranch_7_0/temporal/t.vect.list/t.vect.list.py 2016-02-18 11:19:25 UTC (rev 67880)
@@ -67,6 +67,10 @@
#%end
+#% required: no
+#%end
#%flag
#% key: s
@@ -89,12 +93,13 @@
header = flags["s"]
tgis.init()
- "stvds", input, columns, order, where, separator, method, header)
+ tgis.list_maps_of_stds("stvds", input, columns, order, where, separator,
