[GRASS-SVN] r67881 - grass-addons/grass7/raster/r.green/r.green.install
svn_grass at osgeo.org
Thu Feb 18 05:10:14 PST 2016
Author: zarch
Date: 2016-02-18 05:10:14 -0800 (Thu, 18 Feb 2016)
New Revision: 67881
grass-addons/grass7/raster/r.green/r.green.install/r.green.install.py
r.green: remove the -m flag and ask to the user to manually download the wheel file under windows
Modified: grass-addons/grass7/raster/r.green/r.green.install/r.green.install.py
--- grass-addons/grass7/raster/r.green/r.green.install/r.green.install.py 2016-02-18 11:19:25 UTC (rev 67880)
+++ grass-addons/grass7/raster/r.green/r.green.install/r.green.install.py 2016-02-18 13:10:14 UTC (rev 67881)
@@ -24,10 +24,6 @@
#% description: Install missing libraries
#%end
#%flag
-#% key: m
-#% description: Move r.green libraries in the right place
-#%end
-#%flag
#% key: x
#% description: Add r.green menu to the GRASS GUI
#%end
@@ -53,16 +49,17 @@
# import grass libraries
from grass.script import core as gcore
-from grass.pygrass.utils import set_path
Pkg = namedtuple('Pkg', ['name', 'version', 'py', 'un', 'platform'])
+# list packages required by the module
CHECK_LIBRARIES = ['scipy', 'numexpr']
CHECK_RGREENLIB = [('libgreen', '..'),
('libhydro', os.path.join('..', 'r.green.hydro'))]
PATHSYSXML = []
PATHLOCXML = []
@@ -223,19 +220,21 @@
def check_install_pip(install=False):
"""Check if pip is available"""
# run pip and check return code
- popen_pip = subprocess.Popen(['pip', '--help'], stdout=subprocess.PIPE)
+ popen_pip = subprocess.Popen(['pip', '--help'],
+ stdout=subprocess.PIPE, shell=True)
if popen_pip.wait():
print('pip is not available')
if install:
print('Downloading pip')
# download get_pip.py
response = urllib2.urlopen('https://bootstrap.pypa.io/get-pip.py')
- with open('get_pip.py', mode='w') as getpip:
+ dst = os.path.join(tempfile.gettempdir(), 'get_pip.py')
+ with open(dst, mode='w') as getpip:
getpip.write(response.read())
# install pip
print('Installing pip')
- popen_py = subprocess.Popen([sys.executable, 'get_pip.py'])
+ popen_py = subprocess.Popen([sys.executable, dst])
if popen_py.returncode:
print('Something wrong during the installation of pip,'
' perhaps permissions')
@@ -248,6 +247,7 @@
available in the current path."""
urlwin = 'http://www.lfd.uci.edu/~gohlke/pythonlibs'
+ urlwhl = 'http://www.lfd.uci.edu/~gohlke/pythonlibs/bofhrmxk/'
def get_url(lib, _parser=[None, ]):
"""Return the complete url to download the wheel file for windows"""
@@ -255,11 +255,12 @@
def match():
"""Match platform with available wheel files on the web page"""
pkgs = parser.packages[lib]
- cppy = 'cp' + str(sys.version_info.major) + str(sys.version_info.minor)
- pltf = 'win_amd64.whl' if platform.architecture() == '64bit' else 'win32.whl'
+ cppy = 'cp%d%d' % (sys.version_info.major, sys.version_info.minor)
+ pltf = ('win_amd64.whl'
+ if platform.architecture()[0] == '64bit' else 'win32.whl')
result = None
for pki in pkgs[::-1]:
- pkk = Pkg(*pkg.split('-'))
+ pkk = Pkg(*pki.split('-'))
if pkk.py == cppy and pkk.platform == pltf:
result = pki
break
@@ -287,26 +288,59 @@
sys.exit(1)
pkg = match()
- return ('http://www.lfd.uci.edu/~gohlke/pythonlibs/bofhrmxk/' + pkg,
- pkg)
+ return (urlwhl + pkg, pkg)
- def win_install(lib):
+ def win_install(libs):
"""Download and install missing libraries under windows"""
- # get wheel url
- urlwhl, pkg = get_url(lib)
- dst = os.path.join(tempfile.gettempdir(), pkg)
- print('Downloading:', urlwhl, 'file in:', dst)
- response = urllib2.urlopen(urlwhl)
- with open(dst, mode='w') as getwhl:
- getwhl.write(response.read())
- cmd = ['pip', 'install', dst, '--user']
- popen_pip = subprocess.Popen(cmd)
- if popen_pip.wait():
- print('Something went wrong during the installation, '
- 'please fix this manually')
- print(cmd)
- sys.exit(1)
+ def get_user_input():
+ """Ask what to do to the user"""
+ key = raw_input("press ENTER to continue or q to exit.\n")
+ if key in ('', 'q'):
+ return key
+ else:
+ print("{key} is not supported!\n".format(key=key))
+ return get_user_input()
+ def pip_install(whl, *pipargs):
+ """Install a whl using pip"""
+ cmd = ['pip', 'install', whl]
+ cmd.extend(pipargs)
+ popen_pip = subprocess.Popen(cmd, shell=True)
+ if popen_pip.wait():
+ print(('Something went wrong during the installation, '
+ 'of {whl} please fix this '
+ 'manually. Running: ').format(whl=whl))
+ print(' '.join(cmd))
+ sys.exit(1)
+ # dst = os.path.join(tempfile.gettempdir(), pkg)
+ dst = os.environ['GISBASE']
+ print("Please download:")
+ dlibs = {lib: get_url(lib) for lib in libs}
+ get_url('numpy')
+ msg = """- {lib}: {pkg}
+ from: {urlwhl}"""
+ for lib in dlibs:
+ print(msg.format(lib=lib, urlwhl=dlibs[lib][1], pkg=dlibs[lib][0]))
+ print(('\nDownload the aforementioned files with your browser'
+ ' and save them in the following directory:\n '
+ '{dst}\n').format(dst=dst))
+ print("\nOnce you have done ", end='')
+ key = get_user_input()
+ if key == 'q':
+ sys.exit()
+ for lib in libs:
+ whlpath = join(dst, dlibs[lib][1])
+ if not os.path.exists(whlpath):
+ print("Wheel file: {whl} not found! Exit.".format(whl=whlpath))
+ sys.exit(1)
+ pip_install(whlpath, '--user', '--upgrade')
to_be_installed = []
for lib in CHECK_LIBRARIES:
try:
@@ -321,12 +355,13 @@
print('- ', lib)
if install:
- if sys.platform.startswith('win') or sys.platform.startswith('cyg'):
+ if 'win' in sys.platform:
# download precompiled wheel and install them
print('Download the wheel file manually for your platform from:')
- # http://www.lfd.uci.edu/~gohlke/pythonlibs/bofhrmxk/numexpr-2.4.6-cp27-none-win_amd64.whl
- for lib in to_be_installed:
- win_install(lib)
+ # add numpy+mkl
+ to_be_installed.insert(0, 'numpy')
+ win_install(to_be_installed)
+ # win_install(lib)
else:
cmd = ['pip', 'install'].extend(to_be_installed)
cmd.append('--user')
@@ -338,57 +373,6 @@
sys.exit(1)
-def fix_rgreen_libraries(move=False):
- """Check if r.green libraries are correctly positioned
- move from addos into etc/r.green directory:
- ~/.grass7/addons/libgreen => ~/.grass7/addons/etc/r.green/libgreen
- ~/.grass7/addons/libhydro => ~/.grass7/addons/etc/r.green/libhydro
- gaddons = os.environ['GRASS_ADDON_BASE']
- if not gaddons:
- print('Environmental variable GRASS_ADDON_BASE not set!')
- return
- def mvlibs(lib):
- """Move r.green libraries directories into the GRASS addons
- standard directory"""
- wrongpath = os.path.join(gaddons, lib)
- greendir = os.path.join(gaddons, 'etc', 'r.green', lib)
- if os.path.exists(wrongpath):
- if not os.path.exists(greendir):
- os.makedirs(greendir)
- print('You should (manually or using "-m" flag) move the:')
- msg = 'r.green library (%s) from: %s to: %s'
- print(msg % (lib, wrongpath, greendir))
- if move:
- if os.path.exists(greendir):
- shutil.rmtree(greendir)
- shutil.move(wrongpath, greendir)
- else:
- print(lib, 'already in the right place:', greendir)
- mvlibs('libgreen')
- mvlibs('libhydro')
- path_problems = False
- # finally import the module in the library
- for lib, relativepath in CHECK_RGREENLIB:
- set_path('r.green', lib, relativepath)
- try:
- imp.find_module(lib)
- except ImportError:
- print('Not able to import %s' % lib)
- path_problems = True
- if path_problems:
- print('Some libraries seem not available in the current path:')
- for path in sys.path:
- print('- ', path)
def add_rgreen_menu():
"""Add/Update the xml used to define the GRASS GUI"""
@@ -396,62 +380,63 @@
"""Trnsform a list of toolbox elements into a dictionary"""
return {toolbox.find('label').text: toolbox for toolbox in toolboxes}
- main = 'main_menu.xml'
- tool = 'toolboxes.xml'
- grass_toolboxes_path = join(os.getenv('GISBASE'), 'gui', 'wxpython', 'xml')
- user_toolboxes_path = join(get_settings_path(), 'toolboxes')
+ def get_or_create(xmlfile, sysdir, usrdir):
+ """Check if XML files already exist"""
+ xml_path = join(usrdir, xmlfile)
- # check if XML files already exist
- main_path = join(user_toolboxes_path, main)
- tool_path = join(user_toolboxes_path, tool)
+ if not os.path.exists(xml_path):
+ print('Copying %s to %s' % (join(sysdir, xmlfile),
+ xml_path))
+ shutil.copyfile(join(sysdir, xmlfile), xml_path)
+ return xml_path
- if not os.path.exists(main_path):
- print('Copying %s to %s' % (join(grass_toolboxes_path, main),
- main_path))
- shutil.copyfile(join(grass_toolboxes_path, main), main_path)
+ def read_update_xml(main_path, tool_path):
+ """Read XML files and update toolboxes acordingly"""
+ main_tree = ET.parse(main_path)
+ main_root = main_tree.getroot()
+ tool_tree = ET.parse(tool_path)
+ tool_root = tool_tree.getroot()
- if not os.path.exists(tool_path):
- print('Copying %s to %s' % (join(grass_toolboxes_path, tool),
- tool_path))
- shutil.copyfile(join(grass_toolboxes_path, tool), tool_path)
+ # check if the update of the main xml it is necessary
+ main_items = main_root.find('items')
+ update_main = True
+ for item in main_items:
+ if item.attrib['name'] == XMLMAINMENU:
+ update_main = False
- # read XML input files
- main_tree = ET.parse(main_path)
- main_root = main_tree.getroot()
- tool_tree = ET.parse(tool_path)
- tool_root = tool_tree.getroot()
+ if update_main:
+ print("Updating", main_path)
+ menrg = main_items[0].copy()
+ menrg.attrib['name'] = XMLMAINMENU
+ main_items.insert(-1, menrg)
+ main_tree.write(main_path)
- # check if the update of the main xml it is necessary
- main_items = main_root.find('items')
- update_main = True
- for item in main_items:
- if item.attrib['name'] == XMLMAINMENU:
- update_main = False
+ toolboxes = toolboxes2dict(tool_root.findall('toolbox'))
+ enrg_tools = toolboxes2dict(ET.fromstring(XMLENERGYTOOLBOX))
- if update_main:
- print("Updating", main_path)
- menrg = main_items[0].copy()
- menrg.attrib['name'] = XMLMAINMENU
- main_items.append(menrg)
- main_tree.write(main_path)
+ # update the energy toolboxes
+ print("Updating", tool_path)
+ for key in enrg_tools:
+ if key in toolboxes:
+ tool_root.remove(toolboxes[key])
+ tool_root.append(enrg_tools[key])
+ tool_tree.write(tool_path)
- toolboxes = toolboxes2dict(tool_root.findall('toolbox'))
- enrg_tools = toolboxes2dict(ET.fromstring(XMLENERGYTOOLBOX))
+ grass_tool_path = join(os.getenv('GISBASE'), 'gui', 'wxpython', 'xml')
+ user_tool_path = join(get_settings_path(), 'toolboxes')
- # update the energy toolboxes
- print("Updating", tool_path)
- for key in enrg_tools:
- if key in toolboxes:
- tool_root.remove(toolboxes[key])
- tool_root.append(enrg_tools[key])
- tool_tree.write(tool_path)
+ # read XML input files
+ main_path = get_or_create('main_menu.xml', grass_tool_path, user_tool_path)
+ tool_path = get_or_create('toolboxes.xml', grass_tool_path, user_tool_path)
+ read_update_xml(main_path, tool_path)
if __name__ == "__main__":
opts, flgs = gcore.parser()
check_install_pip(flgs['i'])
fix_missing_libraries(flgs['i'])
- fix_rgreen_libraries(flgs['m'])
if flgs['x']:
add_rgreen_menu()
