[GRASS-SVN] r67890 - grass/trunk/raster/r.compress
svn_grass at osgeo.org
Fri Feb 19 15:40:12 PST 2016
Author: mmetz
Date: 2016-02-19 15:40:12 -0800 (Fri, 19 Feb 2016)
New Revision: 67890
grass/trunk/raster/r.compress/main.c
grass/trunk/raster/r.compress/r.compress.html
r.compress: raster map must be in current mapset, support recompression
Modified: grass/trunk/raster/r.compress/main.c
--- grass/trunk/raster/r.compress/main.c 2016-02-19 14:37:05 UTC (rev 67889)
+++ grass/trunk/raster/r.compress/main.c 2016-02-19 23:40:12 UTC (rev 67890)
@@ -22,7 +22,7 @@
* RLE:
* - Array of addresses pointing to the internal start of each row
- * First byte of each row is the nuber of bytes per cell for that row
+ * First byte of each row is the number of bytes per cell for that row
* Remainder of the row is a series of byte groups that describe the data:
* First byte: number of cells that contain the category given by second
* Next byte(s): category number. The number of bytes is determined
@@ -30,7 +30,7 @@
* The normal G_open_cell(), and Rast_put_row() do the compression
* This program must only check that the file is not a reclass file and
- * is not already compressed.
+ * is not a GDAL-linked map.
* The only trick is to preserve the support files
@@ -38,15 +38,15 @@
#include <stdlib.h>
#include <limits.h>
+#include <string.h>
#include <sys/types.h>
#include <unistd.h>
#include <grass/gis.h>
#include <grass/raster.h>
#include <grass/glocale.h>
-static off_t newsize, oldsize;
static int process(char *, int);
-static int pprint(char *, int);
+static int pprint(char *);
static int doit(char *, int, RASTER_MAP_TYPE);
int main(int argc, char *argv[])
@@ -85,16 +85,16 @@
if (G_parser(argc, argv))
exit(EXIT_FAILURE);
- if(pflag->answer) {
+ if (pflag->answer) {
for (n = 0; (name = map->answers[n]); n++)
- pprint(name, pflag->answer);
+ pprint(name);
exit(EXIT_SUCCESS);
- stat = 0;
+ stat = EXIT_FAILURE;
if (process(name, uncompress->answer))
- stat = 1;
+ stat = EXIT_SUCCESS;
exit(stat);
@@ -108,13 +108,21 @@
int colr_ok;
int hist_ok;
int cats_ok;
- int quant_ok=0;
- off_t diff;
+ int quant_ok = 0;
+ off_t newsize, oldsize, diff;
RASTER_MAP_TYPE map_type;
char rname[GNAME_MAX], rmapset[GMAPSET_MAX];
+ const char *mapset;
+ int data_fd;
+ char *sizestr;
- if (G_find_raster(name, G_mapset()) == NULL) {
- G_warning(_("Raster map <%s> not found"), name);
+ mapset = G_find_raster(name, G_mapset());
+ if (mapset == NULL) {
+ G_warning(_("Raster map <%s> not found"), name);
+ return 1;
+ if (strcmp(mapset, G_mapset())) {
+ G_warning(_("Raster map <%s> is not in the current mapset"), name);
return 1;
if (Rast_is_reclass(name, G_mapset(), rname, rmapset) > 0) {
@@ -133,7 +141,6 @@
map_type = Rast_map_type(name, G_mapset());
- G_suppress_warnings(1);
colr_ok = Rast_read_colors(name, G_mapset(), &colr) > 0;
hist_ok = Rast_read_history(name, G_mapset(), &hist) >= 0;
cats_ok = Rast_read_cats(name, G_mapset(), &cats) >= 0;
@@ -142,8 +149,15 @@
Rast_quant_init(&quant);
quant_ok = Rast_read_quant(name, G_mapset(), &quant);
G_suppress_warnings(0);
+ data_fd = G_open_old("fcell", name, G_mapset());
+ else
+ data_fd = G_open_old("cell", name, G_mapset());
+ oldsize = lseek(data_fd, (off_t) 0, SEEK_END);
+ close(data_fd);
if (doit(name, uncompress, map_type))
return 1;
@@ -161,6 +175,32 @@
if (map_type != CELL_TYPE && quant_ok)
Rast_write_quant(name, G_mapset(), &quant);
+ if (map_type != CELL_TYPE) {
+ else
+ newsize = lseek(data_fd, (off_t) 0, SEEK_END);
+ close(data_fd);
+ sizestr = "bytes";
+ if (newsize > 100 * 1024 && oldsize > 100 * 1024) {
+ newsize /= 1024;
+ oldsize /= 1024;
+ sizestr = "KB";
+ newsize /= 1024;
+ oldsize /= 1024;
+ sizestr = "MB";
+ newsize /= 1024;
+ oldsize /= 1024;
+ sizestr = "GB";
diff = newsize - oldsize;
if (diff < 0)
diff = -diff;
@@ -169,16 +209,16 @@
if (newsize < oldsize)
G_message(uncompress
- ? _("DONE: uncompressed file is %lu bytes smaller")
- : _("DONE: compressed file is %lu bytes smaller"),
- (unsigned long)diff);
+ ? _("DONE: uncompressed file is %lu %s (%.2f%) smaller")
+ : _("DONE: compressed file is %lu %s (%.2f%) smaller"),
+ (unsigned long)diff, sizestr, (double) 100.0 - 100.0 * newsize / oldsize);
else if (newsize > oldsize)
- ? _("DONE: uncompressed file is %lu bytes bigger")
- : _("DONE: compressed file is %lu bytes bigger"),
+ ? _("DONE: uncompressed file is %lu %s (%.2f%) larger")
+ : _("DONE: compressed file is %lu %s (%.2f%) larger"),
+ (unsigned long)diff, sizestr, (double) 100.0 * newsize / oldsize - 100.0);
else
- G_message("same size");
+ G_message(_("same size"));
return 0;
@@ -192,17 +232,25 @@
Rast_get_cellhd(name, G_mapset(), &cellhd);
/* check if already compressed/decompressed */
- if (uncompress && cellhd.compressed == 0) {
- G_warning(_("<%s> already uncompressed"), name);
- return 1;
+ if (uncompress) {
+ if (cellhd.compressed == 0) {
+ G_warning(_("<%s> already uncompressed"), name);
+ return 1;
+ G_verbose_message(_("Uncompressing <%s>"), name);
- else if (!uncompress && cellhd.compressed > 0) {
- G_warning(_("<%s> already compressed"), name);
- return 1;
+ else /* uncompress == 0 */ {
+ if (cellhd.compressed > 0) {
+ G_warning(_("[%s] already compressed"), name);
+ return 1;
+ G_message(_("Re-compressing <%s>"), name);
+ else
+ G_message(_("Compressing <%s>"), name);
- G_message(_("\n%sCOMPRESS <%s>"), uncompress ? "UN" : "", name);
Rast_set_window(&cellhd);
old = Rast_open_old(name, G_mapset());
@@ -223,8 +271,6 @@
nrows = Rast_window_rows();
rast = Rast_allocate_buf(map_type);
- oldsize = lseek(old, (off_t) 0, SEEK_END);
/* the null file is written automatically */
for (row = 0; row < nrows; row++) {
G_percent(row, nrows, 2);
@@ -238,60 +284,60 @@
return 1;
Rast_close(new);
- newsize = 0;
- old = Rast_open_old(name, G_mapset());
- newsize = lseek(old, (off_t) 0, SEEK_END);
- Rast_close(old);
return 0;
-static int pprint(char *name, int printstyle)
+static int pprint(char *name)
struct Cell_head cellhd;
- int done;
return 1;
+ return 1;
if (G_find_file2_misc("cell_misc", "gdal", name, G_mapset())) {
G_message(_("<%s> is a GDAL-linked map"), name);
return 1;
- Rast_get_cellhd(name, G_mapset(), &cellhd);
- map_type = Rast_map_type(name, G_mapset());
- done = 0;
G_message(_("<%s> is a reclass file of map <%s> in mapset <%s>"),
name, rname, rmapset);
- done = 1;
+ return 1;
- if (G_find_file2_misc("cell_misc", "gdal", name, G_mapset())) {
- G_message(_("<%s> is a GDAL-linked map"), name);
- done = 1;
+ Rast_get_cellhd(name, G_mapset(), &cellhd);
+ map_type = Rast_map_type(name, G_mapset());
/* Integer (CELL) compression:
* cellhd.compressed == 0: uncompressed
* cellhd.compressed == 1: RLE compressed
* cellhd.compressed == 2: DEFLATE compressed
- if (!done && cellhd.compressed == 0) {
- G_message(_("<%s> is uncompressed (level %i: %s). Data type: <%s>"), name, cellhd.compressed,
+ /* No RLE compression for fp maps */
+ if (cellhd.compressed == 1 && map_type != CELL_TYPE)
+ cellhd.compressed = 2;
+ G_message(_("<%s> is uncompressed (method %i: %s). Data type: %s"), name, cellhd.compressed,
"NONE",
(map_type == CELL_TYPE ? "CELL" :
(map_type == DCELL_TYPE ? "DCELL" :
(map_type == FCELL_TYPE ? "FCELL" : "??"))));
- else if (!done && cellhd.compressed > 0) {
- G_message(_("<%s> is compressed (level %i: %s). Data type: <%s>"), name, cellhd.compressed,
- cellhd.compressed == 1 ? "RLE" : "DEFLATE",
+ else if (cellhd.compressed > 0) {
+ G_message(_("<%s> is compressed (method %i: %s). Data type: %s"), name, cellhd.compressed,
+ G_compressor_name(cellhd.compressed),
Modified: grass/trunk/raster/r.compress/r.compress.html
--- grass/trunk/raster/r.compress/r.compress.html 2016-02-19 14:37:05 UTC (rev 67889)
+++ grass/trunk/raster/r.compress/r.compress.html 2016-02-19 23:40:12 UTC (rev 67890)
@@ -2,7 +2,7 @@
<em>r.compress</em> can be used to compress and decompress
raster map layers. Additionally, it prints information about the
-map compression and data type of the input raster map(s).
+compression method and data type of the input raster map(s).
<p>
During compression, this program reformats raster maps using a run-length-encoding
@@ -24,14 +24,18 @@
(25351 bytes smaller).
<p>
-Raster files may be decompressed manually to return them to their
-original format, using the <b>-u</b> flag of
-<em>r.compress</em>. If <em>r.compress</em> is asked to
-compress a raster map which is already compressed (or to
-decompress an already decompressed raster map), it simply informs
-the user the map is already (de)compressed and exits.
+Raster maps that are already compressed are again compressed. This is
+useful if either the compression method (RLE or ZLIB) is changed or if
+the ZLIB compression level is manually changed by setting the
+environment variable GRASS_ZLIB_LEVEL.
+<p>
+Raster files may be decompressed manually to return them to their
+original format, using the <b>-u</b> flag of <em>r.compress</em>. If a
+raster map is already decompressed, it simply informs the user the map
+is already compressed and exits.
<h3>TERMINOLOGY</h3>
<ul>
@@ -153,10 +157,10 @@
single byte preceding each row.
<p>
-Since GRASS GIS 7.0.0, the default compression method for
- Integer (CELL) maps is deflate and not any more the RLE compression.
+Since GRASS GIS 7.0.0, the default compression method for
+Integer (CELL) maps is ZLIB and not any more the RLE compression.
-<h4>DEFLATE compression level</h4>
+<h4>ZLIB compression level</h4>
If the environment variable <tt>GRASS_ZLIB_LEVEL</tt> exists and
its value can be parsed as an integer, it determines the compression
@@ -172,7 +176,7 @@
Printing of current compression state:
<div class="code"><pre>
r.compress compressed_no -p
- <compressed_no> (level 0: NONE). Data type: <CELL>
+ <compressed_no> (method 0: NONE). Data type: <CELL>
</pre></div>
<p>
@@ -184,20 +188,20 @@
export GRASS_INT_ZLIB=0 # RLE
r.compress compressed_RLE
r.compress compressed_RLE -p
- <compressed_RLE> is compressed (level 1: RLE). Data type: <CELL>
+ <compressed_RLE> is compressed (method 1: RLE). Data type: <CELL>
unset GRASS_INT_ZLIB
</pre></div>
<p>
-Applying DEFLATE (ZLIB) compression to a copy of the uncompressed map:
+Applying ZLIB compression to a copy of the uncompressed map:
-# compression of map using DEFLATE compression
-g.copy raster=compressed_no,compressed_DEFLATE
+# compression of map using ZLIB compression
+g.copy raster=compressed_no,compressed_ZLIB
-export GRASS_INT_ZLIB=1 # deflate
-r.compress compressed_DEFLATE
-r.compress compressed_DEFLATE -p
- <compressed_DEFLATE> is compressed (level 2: DEFLATE). Data type: <CELL>
+export GRASS_INT_ZLIB=1 # ZLIB
+r.compress compressed_ZLIB
+r.compress compressed_ZLIB -p
+ <compressed_ZLIB> is compressed (method 2: ZLIB). Data type: <CELL>
</pre></div>
