[GRASS-SVN] r67507 - grass-addons/grass7/imagery/i.spec.sam
svn_grass at osgeo.org
Wed Jan 6 12:38:16 PST 2016
Author: ychemin
Date: 2016-01-06 12:38:16 -0800 (Wed, 06 Jan 2016)
New Revision: 67507
grass-addons/grass7/imagery/i.spec.sam/main.c
grass-addons/grass7/imagery/i.spec.sam/open.c
send to verbose mode as much as possible, and beautify information sent to user
Modified: grass-addons/grass7/imagery/i.spec.sam/main.c
--- grass-addons/grass7/imagery/i.spec.sam/main.c 2016-01-06 20:22:40 UTC (rev 67506)
+++ grass-addons/grass7/imagery/i.spec.sam/main.c 2016-01-06 20:38:16 UTC (rev 67507)
@@ -105,39 +105,37 @@
result_prefix = parm.output->answer;
- G_message("%s",result_prefix);
/*Creating A, the spectral signature matrix here*/
A = open_files(parm.matrixfile->answer, parm.group->answer);
/* Spectral Matrix is stored in A now */
- G_message("Your incoming spectral signature matrix");
+ G_verbose_message("Your incoming spectral signature matrix");
for (i=0; i<A->cols; i++)
for (j=0; j<A->rows; j++)
- G_message("%f ", A->vals[i*A->rows+j]);
+ G_verbose_message("%f ", A->vals[i*A->rows+j]);
- G_message("\n");
+ G_verbose_message("\n");
/* Check matrix orthogonality
* Ref: Youngsinn Sohn, Roger M. McCoy 1997: Mapping desert shrub rangeland
* using spectral unmixing and modeling spectral mixtrues with
* TM data. Photogrammetric Engineering & Remote Sensing, Vol.63, No6.
- G_message("/* Check matrix orthogonality*/");
+ G_verbose_message("/* Check matrix orthogonality*/");
for (i = 0; i < A->cols; i++) /* Number of spectral signatures in matrix input file*/
Avector = G_matvect_get_column(A, i); /* go columnwise through matrix*/
- G_message("Avector rows:%d cols:%d, vals %f %f %f %f",Avector->rows,Avector->cols, Avector->vals[0], Avector->vals[1],Avector->vals[2],Avector->vals[3]);
+ G_verbose_message("Avector rows:%d cols:%d, vals %f %f %f %f",Avector->rows,Avector->cols, Avector->vals[0], Avector->vals[1],Avector->vals[2],Avector->vals[3]);
for (j = 0; j < A->cols ; j++)/* Number of spectral signatures in matrix input file*/
if (j !=i)
b = G_matvect_get_column(A, j); /* compare with next col in A */
- G_message("b rows:%d cols:%d, vals %f %f %f %f",b->rows,b->cols,b->vals[0],b->vals[1],b->vals[2],b->vals[3]);
- G_message("process spectangle %d %d %d",i,j, Ref.nfiles);
+ G_verbose_message("b rows:%d cols:%d, vals %f %f %f %f",b->rows,b->cols,b->vals[0],b->vals[1],b->vals[2],b->vals[3]);
+ G_verbose_message("process spectangle %d %d %d",i,j, Ref.nfiles);
spectangle = spectral_angle(Avector, b, RVEC);
- G_message("processed spectangle");
+ G_verbose_message("processed spectangle");
anglefield[i][j]= spectangle;
G_vector_free(b);
Modified: grass-addons/grass7/imagery/i.spec.sam/open.c
--- grass-addons/grass7/imagery/i.spec.sam/open.c 2016-01-06 20:22:40 UTC (rev 67506)
+++ grass-addons/grass7/imagery/i.spec.sam/open.c 2016-01-06 20:38:16 UTC (rev 67507)
@@ -30,33 +30,30 @@
G_fatal_error(_("Unable to read matrix file %s."), matrixfile);
fclose(fp);
- G_message("matrixfile read");
A = G_matrix_init(A_input.cols, A_input.rows, A_input.cols);/*changed r/c*/
if (A == NULL)
G_fatal_error(_("Unable to allocate memory for matrix"));
A = G_matrix_transpose(&A_input);/*transposed for spec angle process*/
- /*A = G_matrix_copy(&A_input);*//*for matrix orthogonality check*/
/*if(A->rows < A->cols)
G_fatal_error("Need m (rows) >= n (cols) to obtain least squares fit\n");*/
- G_message("Your spectral matrix has %i rows and %i cols",A->rows,A->cols);
+ /*Display a message confirming what came from the matrix text file, not as stored!*/
+ G_message("Your input spectral matrix has %i spectral signatures",A->cols);
int j;
/*For each spectral signature*/
- G_message("Col #%i",i);
+ G_verbose_message("Col #%i",i);
/*Display each value*/
- G_message("Col #%i Row #%i %f",i,j,A->vals[i*A->cols+j]);
+ G_verbose_message("Col #%i Row #%i %f",i,j,A->vals[i*A->cols+j]);
- G_message("\n");
matrixsize=A->rows;
- G_message("/* open input files from group */");
+ G_verbose_message("/* open input files from group */");
if (!I_find_group(img_grp))
@@ -79,7 +76,7 @@
G_fatal_error(" does not match matrix size (%i cols).\n", A->cols);
- G_message("/* get memory for input files */");
+ G_verbose_message("/* get memory for input files */");
cell = (DCELL **) G_malloc (Ref.nfiles * sizeof (DCELL *));
cellfd = (int *) G_malloc (Ref.nfiles * sizeof (int));
@@ -93,7 +90,7 @@
G_fatal_error("Unable to proceed\n");
- G_message("/* open files for results*/");
+ G_verbose_message("/* open files for results*/");
result_cell = (DCELL **) G_malloc (Ref.nfiles * sizeof (DCELL *));
resultfd = (int *) G_malloc (Ref.nfiles * sizeof (int));
@@ -105,7 +102,7 @@
resultfd[i] = Rast_open_new (result_name, DCELL_TYPE);
- G_message("open.c: Returning A");
+ G_verbose_message("open.c: Returning A");
return A; /* give back number of output files (= Ref.nfiles) */
@@ -130,9 +127,9 @@
return -1;
- G_message("Set Matrix rows:%d by cols:%d",rows,cols);
+ G_verbose_message("Set Matrix rows:%d by cols:%d",rows,cols);
err = G_matrix_set(out, rows, cols, rows);
- G_message("Set Matrix rows:%d by cols:%d is done (err:%d)",rows,cols,err);
+ G_verbose_message("Set Matrix rows:%d by cols:%d is done (err:%d)",rows,cols,err);
for (i = 0; i < rows; i++) {
