[GRASS-SVN] r67508 - in grass/trunk: gui/wxpython/vdigit include/defs lib/python/pygrass/vector lib/vector/Vlib
Thu Jan 7 00:34:28 PST 2016
Author: martinl
Date: 2016-01-07 00:34:28 -0800 (Thu, 07 Jan 2016)
New Revision: 67508
   grass/trunk/gui/wxpython/vdigit/wxdigit.py
   grass/trunk/include/defs/vector.h
   grass/trunk/lib/python/pygrass/vector/__init__.py
   grass/trunk/lib/vector/Vlib/write.c
   grass/trunk/lib/vector/Vlib/write_nat.c
digitizer crashes, leaves vector broken (#2814)
          fix restore logic broken by r64214
Modified: grass/trunk/gui/wxpython/vdigit/wxdigit.py
--- grass/trunk/gui/wxpython/vdigit/wxdigit.py	2016-01-06 20:38:16 UTC (rev 67507)
+++ grass/trunk/gui/wxpython/vdigit/wxdigit.py	2016-01-07 08:34:28 UTC (rev 67508)
@@ -419,6 +419,7 @@
             action = actions[i]
             line = action['line']
             if action['offset'] > 0:
+                # feature previously added -> to be deleted
                 if Vect_line_alive(self.poMapInfo, line):
                     Debug.msg(3, "IVDigit._applyChangeset(): changeset=%d, action=add, line=%d -> deleted",
                               changeset, line)
@@ -428,14 +429,15 @@
                 else:
                     Debug.msg(3, "Digit.ApplyChangeset(): changeset=%d, action=add, line=%d dead",
                               changeset, line)
-            else: # delete
+            else:
+                # feature previously deleted -> to be added
                 offset = abs(action['offset'])
                 if not Vect_line_alive(self.poMapInfo, line):
                     Debug.msg(3, "Digit.ApplyChangeset(): changeset=%d, action=delete, line=%d -> added",
                               changeset, line)
-                    if Vect_restore_line(self.poMapInfo, line, offset) < 0:
+                    if Vect_restore_line(self.poMapInfo, offset, line) < 0:
                         return -1
                     ret = 1
                 else:
Modified: grass/trunk/include/defs/vector.h
--- grass/trunk/include/defs/vector.h	2016-01-06 20:38:16 UTC (rev 67507)
+++ grass/trunk/include/defs/vector.h	2016-01-07 08:34:28 UTC (rev 67508)
@@ -260,7 +260,7 @@
 off_t Vect_rewrite_line(struct Map_info *, off_t, int, const struct line_pnts *,
                       const struct line_cats *);
 int Vect_delete_line(struct Map_info *, off_t);
-int Vect_restore_line(struct Map_info *, off_t);
+int Vect_restore_line(struct Map_info *, off_t, off_t);
 int Vect_get_num_dblinks(const struct Map_info *);
@@ -557,8 +557,8 @@
 int V2_delete_line_nat(struct Map_info *, off_t);
 int V2_delete_line_sfa(struct Map_info *, off_t);
 int V2_delete_line_pg(struct Map_info *, off_t);
-int V1_restore_line_nat(struct Map_info *, off_t);
-int V2_restore_line_nat(struct Map_info *, off_t);
+int V1_restore_line_nat(struct Map_info *, off_t, off_t);
+int V2_restore_line_nat(struct Map_info *, off_t, off_t);
 off_t V1_write_line_nat(struct Map_info *, int, const struct line_pnts *,
 off_t V1_write_line_ogr(struct Map_info *, int, const struct line_pnts *,
Modified: grass/trunk/lib/python/pygrass/vector/__init__.py
--- grass/trunk/lib/python/pygrass/vector/__init__.py	2016-01-06 20:38:16 UTC (rev 67507)
+++ grass/trunk/lib/python/pygrass/vector/__init__.py	2016-01-07 08:34:28 UTC (rev 67508)
@@ -559,8 +559,8 @@
     @must_be_open
     def restore(self, geo_obj):
         if hasattr(geo_obj, 'offset'):
-            if libvect.Vect_restore_line(self.c_mapinfo, geo_obj.id,
-                                         geo_obj.offset) == -1:
+            if libvect.Vect_restore_line(self.c_mapinfo, geo_obj.offset,
+                                         geo_obj.id) == -1:
                 raise GrassError("C funtion: Vect_restore_line.")
         else:
             raise ValueError("The value have not an offset attribute.")
Modified: grass/trunk/lib/vector/Vlib/write.c
--- grass/trunk/lib/vector/Vlib/write.c	2016-01-06 20:38:16 UTC (rev 67507)
+++ grass/trunk/lib/vector/Vlib/write.c	2016-01-07 08:34:28 UTC (rev 67508)
@@ -277,27 +277,27 @@
    A warning is printed on error.
    \param Map pointer to Map_info structure
-   \param line feature id to be restored
-   \param offset feature offset
+   \param offset feature offset to be restored
+   \param line feature id to be restored (used only on level 2)
    \return 0 on success
    \return -1 on error
-int Vect_restore_line(struct Map_info *Map, off_t line)
+int Vect_restore_line(struct Map_info *Map, off_t offset, off_t line)
     int ret;
-    G_debug(3, "Vect_restore_line(): name = %s, level = %d, line/offset = %"PRI_OFF_T,
-            Map->name, Map->level, line);
+    G_debug(3, "Vect_restore_line(): name = %s, level = %d, offset = %"PRI_OFF_T", line = %"PRI_OFF_T,
+            Map->name, Map->level, offset, line);
     if (!check_map(Map))
         return -1;
-    ret = (*Vect_restore_line_array[Map->format][Map->level]) (Map, line);
+    ret = (*Vect_restore_line_array[Map->format][Map->level]) (Map, offset, line);
     if (ret == -1)
-	G_warning(_("Unable to restore feature/offset %lu in vector map <%s>"),
-                  line, Vect_get_name(Map));
+	G_warning(_("Unable to restore feature/offset %"PRI_OFF_T" in vector map <%s>"),
+                  offset, Vect_get_name(Map));
     return ret;
Modified: grass/trunk/lib/vector/Vlib/write_nat.c
--- grass/trunk/lib/vector/Vlib/write_nat.c	2016-01-06 20:38:16 UTC (rev 67507)
+++ grass/trunk/lib/vector/Vlib/write_nat.c	2016-01-07 08:34:28 UTC (rev 67508)
@@ -332,16 +332,17 @@
+  \param line feature id (not used)
   \return -1 on error
-int V1_restore_line_nat(struct Map_info *Map, off_t offset)
+int V1_restore_line_nat(struct Map_info *Map, off_t offset, off_t line)
     char rhead;
     struct gvfile *dig_fp;
-    G_debug(3, "V1_restore_line_nat(): offset = %"PRI_OFF_T, offset);
+    G_debug(3, "V1_restore_line_nat(): offset = %"PRI_OFF_T", line (not used) = %"PRI_OFF_T, offset, line);
     dig_set_cur_port(&(Map->head.port));
     dig_fp = &(Map->dig_fp);
@@ -375,15 +376,15 @@
   Note: requires topology level >= GV_BUILD_BASE.
   \return -1 on error
-int V2_restore_line_nat(struct Map_info *Map, off_t line)
+int V2_restore_line_nat(struct Map_info *Map, off_t offset, off_t line)
     int type;
-    off_t offset;
     struct Plus_head *plus;
     struct P_line *Line;
     static struct line_cats *Cats = NULL;
@@ -391,14 +392,14 @@
     plus = &(Map->plus);
-    G_debug(3, "V2_restore_line_nat(): line = %d", (int)line);
+    G_debug(3, "V2_restore_line_nat(): offset = %"PRI_OFF_T", line = %"PRI_OFF_T, offset, line);
     if (line < 1 || line > plus->n_lines) {
-        G_warning(_("Attempt to access feature with invalid id (%d)"), (int)line);
+        G_warning(_("Attempt to access feature with invalid id (%"PRI_OFF_T")"), line);
         return -1;
-    Line = Map->plus.Line[line];
+    Line = Map->plus.Line[line]; /* we expect Line to be NULL, so offset is needed */
     if (Line != NULL) {
         G_warning(_("Attempt to access alive feature %d"), (int)line);
         return -1;
@@ -408,10 +409,8 @@
 	plus->cidx_up_to_date = 0;
-    offset = Line->offset;
     /* restore feature in 'coor' file */
-    if (0 != V1_restore_line_nat(Map, offset))
+    if (0 != V1_restore_line_nat(Map, offset, line))
 	return -1;
     /* read feature geometry */
@@ -859,9 +858,10 @@
     Note that 1) and 2) is done by the same code.
-    \param line feature id to be added
+    \param offset feature offset to be added
     \param points pointer to line_pnts structure (feature's geometry)
     \param cats pointer to line_cats structure (feature's categories)
+    \param restore_line feature id to be restored (>0) or added (<=0)
     \param external_routine pointer to external routine (used by PostGIS Topology)
     \return feature id to be added
