[GRASS-SVN] r67658 - in grass/trunk: include include/Make include/defs lib lib/calc raster/r.mapcalc
svn_grass at osgeo.org
Mon Jan 25 01:28:12 PST 2016
Author: glynn
Date: 2016-01-25 01:28:12 -0800 (Mon, 25 Jan 2016)
New Revision: 67658
Added:
grass/trunk/include/calc.h
grass/trunk/include/defs/calc.h
grass/trunk/lib/calc/
grass/trunk/lib/calc/Makefile
grass/trunk/lib/calc/calc.c
grass/trunk/lib/calc/check.c
grass/trunk/lib/calc/function.c
grass/trunk/lib/calc/xabs.c
grass/trunk/lib/calc/xacos.c
grass/trunk/lib/calc/xadd.c
grass/trunk/lib/calc/xand.c
grass/trunk/lib/calc/xand2.c
grass/trunk/lib/calc/xasin.c
grass/trunk/lib/calc/xatan.c
grass/trunk/lib/calc/xbitand.c
grass/trunk/lib/calc/xbitnot.c
grass/trunk/lib/calc/xbitor.c
grass/trunk/lib/calc/xbitxor.c
grass/trunk/lib/calc/xcos.c
grass/trunk/lib/calc/xdiv.c
grass/trunk/lib/calc/xdouble.c
grass/trunk/lib/calc/xeq.c
grass/trunk/lib/calc/xeval.c
grass/trunk/lib/calc/xexp.c
grass/trunk/lib/calc/xfloat.c
grass/trunk/lib/calc/xge.c
grass/trunk/lib/calc/xgraph.c
grass/trunk/lib/calc/xgt.c
grass/trunk/lib/calc/xif.c
grass/trunk/lib/calc/xint.c
grass/trunk/lib/calc/xisnull.c
grass/trunk/lib/calc/xle.c
grass/trunk/lib/calc/xlog.c
grass/trunk/lib/calc/xlt.c
grass/trunk/lib/calc/xmax.c
grass/trunk/lib/calc/xmedian.c
grass/trunk/lib/calc/xmin.c
grass/trunk/lib/calc/xmod.c
grass/trunk/lib/calc/xmode.c
grass/trunk/lib/calc/xmul.c
grass/trunk/lib/calc/xne.c
grass/trunk/lib/calc/xneg.c
grass/trunk/lib/calc/xnmax.c
grass/trunk/lib/calc/xnmedian.c
grass/trunk/lib/calc/xnmin.c
grass/trunk/lib/calc/xnmode.c
grass/trunk/lib/calc/xnot.c
grass/trunk/lib/calc/xnull.c
grass/trunk/lib/calc/xor.c
grass/trunk/lib/calc/xor2.c
grass/trunk/lib/calc/xpow.c
grass/trunk/lib/calc/xrand.c
grass/trunk/lib/calc/xround.c
grass/trunk/lib/calc/xshiftl.c
grass/trunk/lib/calc/xshiftr.c
grass/trunk/lib/calc/xshiftru.c
grass/trunk/lib/calc/xsin.c
grass/trunk/lib/calc/xsqrt.c
grass/trunk/lib/calc/xsub.c
grass/trunk/lib/calc/xtan.c
Removed:
grass/trunk/raster/r.mapcalc/check.c
grass/trunk/raster/r.mapcalc/xabs.c
grass/trunk/raster/r.mapcalc/xacos.c
grass/trunk/raster/r.mapcalc/xadd.c
grass/trunk/raster/r.mapcalc/xand.c
grass/trunk/raster/r.mapcalc/xand2.c
grass/trunk/raster/r.mapcalc/xasin.c
grass/trunk/raster/r.mapcalc/xatan.c
grass/trunk/raster/r.mapcalc/xbitand.c
grass/trunk/raster/r.mapcalc/xbitnot.c
grass/trunk/raster/r.mapcalc/xbitor.c
grass/trunk/raster/r.mapcalc/xbitxor.c
grass/trunk/raster/r.mapcalc/xcos.c
grass/trunk/raster/r.mapcalc/xdiv.c
grass/trunk/raster/r.mapcalc/xdouble.c
grass/trunk/raster/r.mapcalc/xeq.c
grass/trunk/raster/r.mapcalc/xeval.c
grass/trunk/raster/r.mapcalc/xexp.c
grass/trunk/raster/r.mapcalc/xfloat.c
grass/trunk/raster/r.mapcalc/xge.c
grass/trunk/raster/r.mapcalc/xgraph.c
grass/trunk/raster/r.mapcalc/xgt.c
grass/trunk/raster/r.mapcalc/xif.c
grass/trunk/raster/r.mapcalc/xint.c
grass/trunk/raster/r.mapcalc/xisnull.c
grass/trunk/raster/r.mapcalc/xle.c
grass/trunk/raster/r.mapcalc/xlog.c
grass/trunk/raster/r.mapcalc/xlt.c
grass/trunk/raster/r.mapcalc/xmax.c
grass/trunk/raster/r.mapcalc/xmedian.c
grass/trunk/raster/r.mapcalc/xmin.c
grass/trunk/raster/r.mapcalc/xmod.c
grass/trunk/raster/r.mapcalc/xmode.c
grass/trunk/raster/r.mapcalc/xmul.c
grass/trunk/raster/r.mapcalc/xne.c
grass/trunk/raster/r.mapcalc/xneg.c
grass/trunk/raster/r.mapcalc/xnmax.c
grass/trunk/raster/r.mapcalc/xnmedian.c
grass/trunk/raster/r.mapcalc/xnmin.c
grass/trunk/raster/r.mapcalc/xnmode.c
grass/trunk/raster/r.mapcalc/xnot.c
grass/trunk/raster/r.mapcalc/xnull.c
grass/trunk/raster/r.mapcalc/xor.c
grass/trunk/raster/r.mapcalc/xor2.c
grass/trunk/raster/r.mapcalc/xpow.c
grass/trunk/raster/r.mapcalc/xrand.c
grass/trunk/raster/r.mapcalc/xround.c
grass/trunk/raster/r.mapcalc/xshiftl.c
grass/trunk/raster/r.mapcalc/xshiftr.c
grass/trunk/raster/r.mapcalc/xshiftru.c
grass/trunk/raster/r.mapcalc/xsin.c
grass/trunk/raster/r.mapcalc/xsqrt.c
grass/trunk/raster/r.mapcalc/xsub.c
grass/trunk/raster/r.mapcalc/xtan.c
grass/trunk/include/Make/Grass.make
grass/trunk/lib/Makefile
grass/trunk/raster/r.mapcalc/Makefile
grass/trunk/raster/r.mapcalc/evaluate.c
grass/trunk/raster/r.mapcalc/expression.c
grass/trunk/raster/r.mapcalc/expression.h
grass/trunk/raster/r.mapcalc/func_proto.h
grass/trunk/raster/r.mapcalc/function.c
grass/trunk/raster/r.mapcalc/globals.h
grass/trunk/raster/r.mapcalc/main.c
grass/trunk/raster/r.mapcalc/map.c
grass/trunk/raster/r.mapcalc/map3.c
Move vectorised functions from r.mapcalc into a separate library
Modified: grass/trunk/include/Make/Grass.make
--- grass/trunk/include/Make/Grass.make 2016-01-25 09:27:55 UTC (rev 67657)
+++ grass/trunk/include/Make/Grass.make 2016-01-25 09:28:12 UTC (rev 67658)
@@ -114,6 +114,7 @@
BTREE:btree \
BTREE2:btree2 \
CAIRODRIVER:cairodriver \
+ CALC:calc \
CDHC:cdhc \
CCMATH:ccmath \
CLUSTER:cluster \
@@ -183,6 +184,7 @@
BITMAPDEPS = $(LINKMLIB)
BTREE2DEPS = $(GISLIB)
CAIRODRIVERDEPS = $(DRIVERLIB) $(GISLIB) $(CAIROLIB) $(FCLIB) $(ICONVLIB)
+CALCDEPS = $(RASTERLIB) $(GISLIB) $(MATHLIB)
CDHCDEPS = $(MATHLIB)
CLUSTERDEPS = $(IMAGERYLIB) $(RASTERLIB) $(GISLIB) $(MATHLIB)
DBMIBASEDEPS = $(GISLIB)
Added: grass/trunk/include/calc.h
--- grass/trunk/include/calc.h (rev 0)
+++ grass/trunk/include/calc.h 2016-01-25 09:28:12 UTC (rev 67658)
@@ -0,0 +1,45 @@
+#ifndef GRASS_CALC_H
+#define GRASS_CALC_H
+#include <grass/gis.h>
+#include <grass/raster.h>
+typedef int func_t(int argc, const int *argt, void **args);
+typedef int args_t(int argc, int *argt);
+enum {
+ E_ARG_LO = 1,
+ E_ARG_HI = 2,
+ E_ARG_TYPE = 3,
+ E_RES_TYPE = 4,
+ E_INV_TYPE = 5,
+ E_ARG_NUM = 6,
+ E_WTF = 99
+typedef struct func_desc
+ const char *name;
+ args_t *check_args;
+ func_t *func;
+} func_desc;
+#define IS_NULL_C(x) (Rast_is_c_null_value((x)))
+#define IS_NULL_F(x) (Rast_is_f_null_value((x)))
+#define IS_NULL_D(x) (Rast_is_d_null_value((x)))
+#define SET_NULL_C(x) (Rast_set_c_null_value((x),1))
+#define SET_NULL_F(x) (Rast_set_f_null_value((x),1))
+#define SET_NULL_D(x) (Rast_set_d_null_value((x),1))
+extern volatile int floating_point_exception;
+extern volatile int floating_point_exception_occurred;
+extern int columns;
+extern func_desc calc_func_descs[];
+#include <grass/defs/calc.h>
+#endif
Added: grass/trunk/include/defs/calc.h
--- grass/trunk/include/defs/calc.h (rev 0)
+++ grass/trunk/include/defs/calc.h 2016-01-25 09:28:12 UTC (rev 67658)
@@ -0,0 +1,107 @@
+#ifndef GRASS_CALCDEFS_H
+#define GRASS_CALCDEFS_H
+extern void calc_init(int);
+extern void pre_exec(void);
+extern void post_exec(void);
+extern func_t f_add;
+extern func_t f_sub;
+extern func_t f_mul;
+extern func_t f_div;
+extern func_t f_mod;
+extern func_t f_pow;
+extern args_t c_binop;
+extern func_t f_neg;
+extern func_t f_abs;
+extern args_t c_unop;
+extern func_t f_gt;
+extern func_t f_ge;
+extern func_t f_lt;
+extern func_t f_le;
+extern func_t f_eq;
+extern func_t f_ne;
+extern args_t c_cmpop;
+extern func_t f_and;
+extern func_t f_or;
+extern func_t f_and2;
+extern func_t f_or2;
+extern func_t f_bitand;
+extern func_t f_bitor;
+extern func_t f_bitxor;
+extern args_t c_logop;
+extern func_t f_shiftl;
+extern func_t f_shiftr;
+extern func_t f_shiftru;
+extern args_t c_shiftop;
+extern func_t f_not;
+extern func_t f_bitnot;
+extern args_t c_not;
+extern func_t f_sqrt;
+extern func_t f_sin;
+extern func_t f_cos;
+extern func_t f_tan;
+extern func_t f_acos;
+extern func_t f_asin;
+extern args_t c_double1;
+extern func_t f_exp;
+extern func_t f_log;
+extern func_t f_atan;
+extern args_t c_double12;
+extern func_t f_int;
+extern args_t c_int;
+extern func_t f_float;
+extern args_t c_float;
+extern func_t f_double;
+extern args_t c_double;
+extern func_t f_round;
+extern args_t c_round;
+extern func_t f_eval;
+extern args_t c_eval;
+extern func_t f_if;
+extern args_t c_if;
+extern func_t f_isnull;
+extern args_t c_isnull;
+extern func_t f_graph;
+extern func_t f_graph2;
+extern args_t c_graph;
+extern func_t f_min;
+extern func_t f_max;
+extern func_t f_nmin;
+extern func_t f_nmax;
+extern args_t c_varop;
+extern func_t f_median;
+extern func_t f_nmedian;
+extern args_t c_median;
+extern func_t f_mode;
+extern func_t f_nmode;
+extern args_t c_mode;
+extern func_t f_rand;
+extern func_t f_null;
+extern args_t c_int0;
+extern args_t c_double0;
+#endif
Modified: grass/trunk/lib/Makefile
--- grass/trunk/lib/Makefile 2016-01-25 09:27:55 UTC (rev 67657)
+++ grass/trunk/lib/Makefile 2016-01-25 09:28:12 UTC (rev 67658)
@@ -43,7 +43,8 @@
temporal \
python \
iostream \
- manage
+ manage \
+ calc
include $(MODULE_TOPDIR)/include/Make/Dir.make
include $(MODULE_TOPDIR)/include/Make/Doxygen.make
Property changes on: grass/trunk/lib/calc
___________________________________________________________________
Added: svn:ignore
+ OBJ.*
Added: grass/trunk/lib/calc/Makefile
--- grass/trunk/lib/calc/Makefile (rev 0)
+++ grass/trunk/lib/calc/Makefile 2016-01-25 09:28:12 UTC (rev 67658)
@@ -0,0 +1,8 @@
+MODULE_TOPDIR = ../..
+LIB = CALC
+include $(MODULE_TOPDIR)/include/Make/Lib.make
+default: lib
Added: grass/trunk/lib/calc/calc.c
--- grass/trunk/lib/calc/calc.c (rev 0)
+++ grass/trunk/lib/calc/calc.c 2016-01-25 09:28:12 UTC (rev 67658)
@@ -0,0 +1,62 @@
+#include <unistd.h>
+#include <signal.h>
+#include <grass/calc.h>
+volatile int floating_point_exception;
+volatile int floating_point_exception_occurred;
+int columns;
+static RETSIGTYPE handle_fpe(int n)
+ floating_point_exception = 1;
+ floating_point_exception_occurred = 1;
+void pre_exec(void)
+#ifndef __MINGW32__
+#ifdef SIGFPE
+ struct sigaction act;
+ act.sa_handler = &handle_fpe;
+ act.sa_flags = 0;
+ sigemptyset(&act.sa_mask);
+ sigaction(SIGFPE, &act, NULL);
+#endif
+#endif
+ floating_point_exception_occurred = 0;
+void post_exec(void)
+#ifdef SIGFPE
+ act.sa_handler = SIG_DFL;
+ act.sa_flags = 0;
+#endif
+#endif
+void calc_init(int cols)
+ columns = cols;
Copied: grass/trunk/lib/calc/check.c (from rev 67656, grass/trunk/raster/r.mapcalc/check.c)
--- grass/trunk/lib/calc/check.c (rev 0)
+++ grass/trunk/lib/calc/check.c 2016-01-25 09:28:12 UTC (rev 67658)
@@ -0,0 +1,159 @@
+int c_int0(int argc, int *argt)
+ if (argc > 0)
+ return E_ARG_HI;
+ argt[0] = CELL_TYPE;
+ return 0;
+int c_double0(int argc, int *argt)
+ if (argc > 0)
+ return E_ARG_HI;
+ argt[0] = DCELL_TYPE;
+ return 0;
+int c_double1(int argc, int *argt)
+ if (argc < 1)
+ return E_ARG_LO;
+ if (argc > 1)
+ return E_ARG_HI;
+ argt[1] = DCELL_TYPE;
+ return 0;
+int c_double12(int argc, int *argt)
+ if (argc < 1)
+ return E_ARG_LO;
+ if (argc > 2)
+ return E_ARG_HI;
+ if (argc == 2)
+ argt[2] = DCELL_TYPE;
+ return 0;
+int c_unop(int argc, int *argt)
+ if (argc < 1)
+ return E_ARG_LO;
+ if (argc > 1)
+ return E_ARG_HI;
+ argt[0] = argt[1];
+ return 0;
+int c_binop(int argc, int *argt)
+ if (argc < 2)
+ return E_ARG_LO;
+ if (argc > 2)
+ return E_ARG_HI;
+ if (argt[1] == FCELL_TYPE || argt[2] == FCELL_TYPE)
+ argt[0] = FCELL_TYPE;
+ if (argt[1] == DCELL_TYPE || argt[2] == DCELL_TYPE)
+ argt[1] = argt[0];
+ argt[2] = argt[0];
+ return 0;
+int c_varop(int argc, int *argt)
+ int i;
+ if (argc < 1)
+ return E_ARG_LO;
+ for (i = 1; i <= argc; i++)
+ if (argt[i] == FCELL_TYPE)
+ if (argt[i] == DCELL_TYPE)
+ argt[i] = argt[0];
+ return 0;
+int c_cmpop(int argc, int *argt)
+ int arg_type;
+ if (argc < 2)
+ return E_ARG_LO;
+ if (argc > 2)
+ return E_ARG_HI;
+ arg_type = CELL_TYPE;
+ arg_type = FCELL_TYPE;
+ arg_type = DCELL_TYPE;
+ argt[1] = arg_type;
+ argt[2] = arg_type;
+ return 0;
+int c_logop(int argc, int *argt)
+ int i;
+ if (argc < 1)
+ return E_ARG_LO;
+ if (argt[i] != CELL_TYPE)
+ return E_ARG_TYPE;
+ return 0;
+int c_shiftop(int argc, int *argt)
+ if (argc < 2)
+ return E_ARG_LO;
+ if (argc > 2)
+ return E_ARG_HI;
+ if (argt[1] != CELL_TYPE || argt[2] != CELL_TYPE)
+ return 0;
Copied: grass/trunk/lib/calc/function.c (from rev 67656, grass/trunk/raster/r.mapcalc/function.c)
--- grass/trunk/lib/calc/function.c (rev 0)
+++ grass/trunk/lib/calc/function.c 2016-01-25 09:28:12 UTC (rev 67658)
@@ -0,0 +1,79 @@
+func_desc calc_func_descs[] = {
+ {"add", c_varop, f_add},
+ {"sub", c_binop, f_sub},
+ {"mul", c_varop, f_mul},
+ {"div", c_binop, f_div},
+ {"mod", c_binop, f_mod},
+ {"pow", c_binop, f_pow},
+ {"neg", c_unop, f_neg},
+ {"abs", c_unop, f_abs},
+ {"gt", c_cmpop, f_gt},
+ {"ge", c_cmpop, f_ge},
+ {"lt", c_cmpop, f_lt},
+ {"le", c_cmpop, f_le},
+ {"eq", c_cmpop, f_eq},
+ {"ne", c_cmpop, f_ne},
+ {"and", c_logop, f_and},
+ {"or", c_logop, f_or},
+ {"and2", c_logop, f_and2},
+ {"or2", c_logop, f_or2},
+ {"not", c_not, f_not},
+ {"bitand", c_logop, f_bitand},
+ {"bitor", c_logop, f_bitor},
+ {"xor", c_logop, f_bitxor},
+ {"shiftl", c_shiftop, f_shiftl},
+ {"shiftr", c_shiftop, f_shiftr},
+ {"shiftru", c_shiftop, f_shiftru},
+ {"bitnot", c_not, f_bitnot},
+ {"sqrt", c_double1, f_sqrt},
+ {"sin", c_double1, f_sin},
+ {"cos", c_double1, f_cos},
+ {"tan", c_double1, f_tan},
+ {"acos", c_double1, f_acos},
+ {"asin", c_double1, f_asin},
+ {"exp", c_double12, f_exp},
+ {"log", c_double12, f_log},
+ {"atan", c_double12, f_atan},
+ {"int", c_int, f_int},
+ {"float", c_float, f_float},
+ {"double", c_double, f_double},
+ {"round", c_round, f_round},
+ {"eval", c_eval, f_eval},
+ {"if", c_if, f_if},
+ {"isnull", c_isnull, f_isnull},
+ {"max", c_varop, f_max},
+ {"min", c_varop, f_min},
+ {"median", c_varop, f_median},
+ {"mode", c_varop, f_mode},
+ {"nmax", c_varop, f_nmax},
+ {"nmin", c_varop, f_nmin},
+ {"nmedian", c_varop, f_nmedian},
+ {"nmode", c_varop, f_nmode},
+ {"graph", c_graph, f_graph},
+ {"graph2", c_graph, f_graph2},
+ {"rand", c_binop, f_rand},
+ {"null", c_int0, f_null},
+ {NULL, NULL, NULL}
Copied: grass/trunk/lib/calc/xabs.c (from rev 67656, grass/trunk/raster/r.mapcalc/xabs.c)
--- grass/trunk/lib/calc/xabs.c (rev 0)
+++ grass/trunk/lib/calc/xabs.c 2016-01-25 09:28:12 UTC (rev 67658)
@@ -0,0 +1,67 @@
+#include <math.h>
+abs(x)
+ absolute value. if x is negative returns -x
+int f_abs(int argc, const int *argt, void **args)
+ int i;
+ if (argc < 1)
+ return E_ARG_LO;
+ if (argc > 1)
+ return E_ARG_HI;
+ if (argt[0] != argt[1])
+ return E_RES_TYPE;
+ switch (argt[1]) {
+ case CELL_TYPE:
+ CELL *res = args[0];
+ CELL *arg1 = args[1];
+ for (i = 0; i < columns; i++)
+ if (IS_NULL_C(&arg1[i]))
+ SET_NULL_C(&res[i]);
+ else
+ res[i] = arg1[i] < 0 ? -arg1[i]
+ : arg1[i];
+ return 0;
+ case FCELL_TYPE:
+ FCELL *res = args[0];
+ FCELL *arg1 = args[1];
+ if (IS_NULL_F(&arg1[i]))
+ SET_NULL_F(&res[i]);
+ else
+ res[i] = (FCELL) fabs(arg1[i]);
+ return 0;
+ case DCELL_TYPE:
+ DCELL *res = args[0];
+ DCELL *arg1 = args[1];
+ if (IS_NULL_D(&arg1[i]))
+ SET_NULL_D(&res[i]);
+ else
+ res[i] = fabs(arg1[i]);
+ return 0;
+ default:
+ return E_INV_TYPE;
Copied: grass/trunk/lib/calc/xacos.c (from rev 67656, grass/trunk/raster/r.mapcalc/xacos.c)
--- grass/trunk/lib/calc/xacos.c (rev 0)
+++ grass/trunk/lib/calc/xacos.c 2016-01-25 09:28:12 UTC (rev 67658)
@@ -0,0 +1,48 @@
+#include <stdlib.h>
+#include <math.h>
+acos(x) [0 and PI]
+ if floating point exception occurs during the evaluation of acos(x)
+ the result is NULL
+ note: result is in degrees
+#define RADIANS_TO_DEGREES (180.0 / M_PI)
+int f_acos(int argc, const int *argt, void **args)
+ int i;
+ if (argc < 1)
+ return E_ARG_LO;
+ if (argc > 1)
+ return E_ARG_HI;
+ if (argt[0] != DCELL_TYPE)
+ if (argt[1] != DCELL_TYPE)
+ else {
+ floating_point_exception = 0;
+ res[i] = RADIANS_TO_DEGREES * acos(arg1[i]);
+ if (floating_point_exception)
+ return 0;
Copied: grass/trunk/lib/calc/xadd.c (from rev 67656, grass/trunk/raster/r.mapcalc/xadd.c)
--- grass/trunk/lib/calc/xadd.c (rev 0)
+++ grass/trunk/lib/calc/xadd.c 2016-01-25 09:28:12 UTC (rev 67658)
@@ -0,0 +1,76 @@
+add(a,b,c,...) = a + b + c + ...
+int f_add(int argc, const int *argt, void **args)
+ int i, j;
+ if (argc < 1)
+ return E_ARG_LO;
+ if (argt[i] != argt[0])
+ switch (argt[0]) {
+ case CELL_TYPE:
+ CELL **argz = (CELL **) args;
+ for (i = 0; i < columns; i++) {
+ res[i] = 0;
+ for (j = 1; j <= argc; j++) {
+ if (IS_NULL_C(&argz[j][i])) {
+ break;
+ res[i] += argz[j][i];
+ return 0;
+ case FCELL_TYPE:
+ FCELL **argz = (FCELL **) args;
+ res[i] = 0;
+ if (IS_NULL_F(&argz[j][i])) {
+ break;
+ return 0;
+ case DCELL_TYPE:
+ DCELL **argz = (DCELL **) args;
+ res[i] = 0;
+ if (IS_NULL_D(&argz[j][i])) {
+ break;
+ return 0;
+ default:
Copied: grass/trunk/lib/calc/xand.c (from rev 67656, grass/trunk/raster/r.mapcalc/xand.c)
--- grass/trunk/lib/calc/xand.c (rev 0)
+++ grass/trunk/lib/calc/xand.c 2016-01-25 09:28:12 UTC (rev 67658)
@@ -0,0 +1,39 @@
+and(a,b,c,...) = a && b && c && ...
+int f_and(int argc, const int *argt, void **args)
+ int i, j;
+ if (argc < 1)
+ return E_ARG_LO;
+ if (argt[0] != CELL_TYPE)
+ res[i] = 1;
+ break;
+ if (!argz[j][i])
+ res[i] = 0;
+ return 0;
Copied: grass/trunk/lib/calc/xand2.c (from rev 67656, grass/trunk/raster/r.mapcalc/xand2.c)
--- grass/trunk/lib/calc/xand2.c (rev 0)
+++ grass/trunk/lib/calc/xand2.c 2016-01-25 09:28:12 UTC (rev 67658)
@@ -0,0 +1,46 @@
+and2(a,b,c,...) = a && b && c && ...
+Differs from and() in that the boolean axioms:
+ false && x == false
+ x && false == false
+hold even when x is null.
+int f_and2(int argc, const int *argt, void **args)
+ int i, j;
+ if (argc < 1)
+ return E_ARG_LO;
+ res[i] = 1;
+ if (!IS_NULL_C(&argz[j][i]) && !argz[j][i]) {
+ res[i] = 0;
+ break;
+ return 0;
Copied: grass/trunk/lib/calc/xasin.c (from rev 67656, grass/trunk/raster/r.mapcalc/xasin.c)
--- grass/trunk/lib/calc/xasin.c (rev 0)
+++ grass/trunk/lib/calc/xasin.c 2016-01-25 09:28:12 UTC (rev 67658)
@@ -0,0 +1,48 @@
+#include <math.h>
+asin(x) range [-90,90]
+ if floating point exception occurs during the evaluation of asin(x)
+int f_asin(int argc, const int *argt, void **args)
+ int i;
+ if (argc < 1)
+ return E_ARG_LO;
+ if (argc > 1)
+ return E_ARG_HI;
+ else {
+ res[i] = RADIANS_TO_DEGREES * asin(arg1[i]);
+ return 0;
Copied: grass/trunk/lib/calc/xatan.c (from rev 67656, grass/trunk/raster/r.mapcalc/xatan.c)
--- grass/trunk/lib/calc/xatan.c (rev 0)
+++ grass/trunk/lib/calc/xatan.c 2016-01-25 09:28:12 UTC (rev 67658)
@@ -0,0 +1,64 @@
+#include <math.h>
+atan(x) range [-90,90]
+atan(x,y) = atan(y/x) range[0,360]
+ if floating point exception occurs during the evaluation of atan(x)
+int f_atan(int argc, const int *argt, void **args)
+ DCELL *arg2;
+ int i;
+ if (argc < 1)
+ return E_ARG_LO;
+ if (argc > 2)
+ return E_ARG_HI;
+ if (argc > 1 && argt[2] != DCELL_TYPE)
+ arg2 = (argc > 1) ? args[2] : NULL;
+ else if (argc > 1 && IS_NULL_D(&arg2[i]))
+ else {
+ if (argc == 1)
+ res[i] = RADIANS_TO_DEGREES * atan(arg1[i]);
+ else {
+ res[i] = RADIANS_TO_DEGREES * atan2(arg2[i], arg1[i]);
+ if (res[i] < 0)
+ res[i] += 360.0;
+ return 0;
Copied: grass/trunk/lib/calc/xbitand.c (from rev 67656, grass/trunk/raster/r.mapcalc/xbitand.c)
--- grass/trunk/lib/calc/xbitand.c (rev 0)
+++ grass/trunk/lib/calc/xbitand.c 2016-01-25 09:28:12 UTC (rev 67658)
@@ -0,0 +1,38 @@
+bitand(a,b,c,...) = a & b & c & ...
+int f_bitand(int argc, const int *argt, void **args)
+ int i, j;
+ if (argc < 1)
+ return E_ARG_LO;
+ res[i] = ~0;
+ break;
+ res[i] &= argz[j][i];
+ return 0;
Copied: grass/trunk/lib/calc/xbitnot.c (from rev 67656, grass/trunk/raster/r.mapcalc/xbitnot.c)
--- grass/trunk/lib/calc/xbitnot.c (rev 0)
+++ grass/trunk/lib/calc/xbitnot.c 2016-01-25 09:28:12 UTC (rev 67658)
@@ -0,0 +1,35 @@
+bitnot(a) = ~a
+int f_bitnot(int argc, const int *argt, void **args)
+ int i;
+ if (argc < 1)
+ return E_ARG_LO;
+ if (argc > 1)
+ return E_ARG_HI;
+ if (argt[1] != CELL_TYPE)
+ else
+ res[i] = ~arg1[i];
+ return 0;
Copied: grass/trunk/lib/calc/xbitor.c (from rev 67656, grass/trunk/raster/r.mapcalc/xbitor.c)
--- grass/trunk/lib/calc/xbitor.c (rev 0)
+++ grass/trunk/lib/calc/xbitor.c 2016-01-25 09:28:12 UTC (rev 67658)
@@ -0,0 +1,38 @@
+bitor(a,b,c,...) = a | b | c | ...
+int f_bitor(int argc, const int *argt, void **args)
+ int i, j;
+ if (argc < 1)
+ return E_ARG_LO;
+ res[i] = 0;
+ break;
+ res[i] |= argz[j][i];
+ return 0;
Copied: grass/trunk/lib/calc/xbitxor.c (from rev 67656, grass/trunk/raster/r.mapcalc/xbitxor.c)
--- grass/trunk/lib/calc/xbitxor.c (rev 0)
+++ grass/trunk/lib/calc/xbitxor.c 2016-01-25 09:28:12 UTC (rev 67658)
@@ -0,0 +1,38 @@
+bitxor(a,b,c,...) = a ^ b ^ c ^ ...
+int f_bitxor(int argc, const int *argt, void **args)
+ int i, j;
+ if (argc < 1)
+ return E_ARG_LO;
+ res[i] = 0;
+ break;
+ res[i] ^= argz[j][i];
+ return 0;
Copied: grass/trunk/lib/calc/xcos.c (from rev 67656, grass/trunk/raster/r.mapcalc/xcos.c)
--- grass/trunk/lib/calc/xcos.c (rev 0)
+++ grass/trunk/lib/calc/xcos.c 2016-01-25 09:28:12 UTC (rev 67658)
@@ -0,0 +1,47 @@
+#include <math.h>
+cos(x)
+ if floating point exception occurs during the evaluation of cos(x)
+ note: x is in degrees.
+#define DEGREES_TO_RADIANS (M_PI / 180.0)
+int f_cos(int argc, const int *argt, void **args)
+ int i;
+ if (argc < 1)
+ return E_ARG_LO;
+ if (argc > 1)
+ return E_ARG_HI;
+ else {
+ res[i] = cos(arg1[i] * DEGREES_TO_RADIANS);
+ return 0;
Copied: grass/trunk/lib/calc/xdiv.c (from rev 67656, grass/trunk/raster/r.mapcalc/xdiv.c)
--- grass/trunk/lib/calc/xdiv.c (rev 0)
+++ grass/trunk/lib/calc/xdiv.c 2016-01-25 09:28:12 UTC (rev 67658)
@@ -0,0 +1,79 @@
+div(a,b) = a / b
+int f_div(int argc, const int *argt, void **args)
+ int i;
+ if (argc < 2)
+ return E_ARG_LO;
+ if (argc > 2)
+ return E_ARG_HI;
+ if (argt[1] != argt[0] || argt[2] != argt[0])
+ case CELL_TYPE:
+ CELL *arg2 = args[2];
+ if (IS_NULL_C(&arg1[i]) || IS_NULL_C(&arg2[i]) ||
+ arg2[i] == 0)
+ else
+ res[i] = arg1[i] / arg2[i];
+ return 0;
+ case FCELL_TYPE:
+ FCELL *arg2 = args[2];
+ if (IS_NULL_F(&arg1[i]) || IS_NULL_F(&arg2[i]) ||
+ arg2[i] == 0.0f)
+ else {
+ return 0;
+ case DCELL_TYPE:
+ DCELL *arg2 = args[2];
+ if (IS_NULL_D(&arg1[i]) || IS_NULL_D(&arg2[i]) ||
+ arg2[i] == 0.0)
+ else {
+ return 0;
+ default:
Copied: grass/trunk/lib/calc/xdouble.c (from rev 67656, grass/trunk/raster/r.mapcalc/xdouble.c)
--- grass/trunk/lib/calc/xdouble.c (rev 0)
+++ grass/trunk/lib/calc/xdouble.c 2016-01-25 09:28:12 UTC (rev 67658)
@@ -0,0 +1,76 @@
+double(x)
+ converts x to double
+int f_double(int argc, const int *argt, void **args)
+ int i;
+ if (argc < 1)
+ return E_ARG_LO;
+ if (argc > 1)
+ return E_ARG_HI;
+ case CELL_TYPE:
+ else
+ res[i] = (DCELL) arg1[i];
+ return 0;
+ case FCELL_TYPE:
+ else
+ return 0;
+ case DCELL_TYPE:
+ else
+ return 0;
+ default:
+int c_double(int argc, int *argt)
+ if (argc < 1)
+ return E_ARG_LO;
+ if (argc > 1)
+ return E_ARG_HI;
+ /* argt[1] = argt[1]; */
+ return 0;
Copied: grass/trunk/lib/calc/xeq.c (from rev 67656, grass/trunk/raster/r.mapcalc/xeq.c)
--- grass/trunk/lib/calc/xeq.c (rev 0)
+++ grass/trunk/lib/calc/xeq.c 2016-01-25 09:28:12 UTC (rev 67658)
@@ -0,0 +1,70 @@
+eq(a,b) = a == b
+int f_eq(int argc, const int *argt, void **args)
+ int i;
+ if (argc < 2)
+ return E_ARG_LO;
+ if (argc > 2)
+ return E_ARG_HI;
+ for (i = 2; i <= argc; i++)
+ if (argt[i] != argt[1])
+ case CELL_TYPE:
+ if (IS_NULL_C(&arg1[i]) || IS_NULL_C(&arg2[i]))
+ else
+ res[i] = arg1[i] == arg2[i];
+ return 0;
+ case FCELL_TYPE:
+ if (IS_NULL_F(&arg1[i]) || IS_NULL_F(&arg2[i]))
+ else
+ return 0;
+ case DCELL_TYPE:
+ if (IS_NULL_D(&arg1[i]) || IS_NULL_D(&arg2[i]))
+ else
+ return 0;
+ default:
Copied: grass/trunk/lib/calc/xeval.c (from rev 67656, grass/trunk/raster/r.mapcalc/xeval.c)
--- grass/trunk/lib/calc/xeval.c (rev 0)
+++ grass/trunk/lib/calc/xeval.c 2016-01-25 09:28:12 UTC (rev 67658)
@@ -0,0 +1,73 @@
+eval(..,..,..,x) = x
+ return last argument
+int f_eval(int argc, const int *argt, void **args)
+ int i;
+ if (argc < 1)
+ return E_ARG_LO;
+ if (argt[0] != argt[argc])
+ switch (argt[argc]) {
+ case CELL_TYPE:
+ CELL *arg1 = args[argc];
+ else
+ res[i] = arg1[i];
+ return 0;
+ case FCELL_TYPE:
+ FCELL *arg1 = args[argc];
+ else
+ res[i] = arg1[i];
+ return 0;
+ case DCELL_TYPE:
+ DCELL *arg1 = args[argc];
+ else
+ res[i] = arg1[i];
+ return 0;
+ default:
+int c_eval(int argc, int *argt)
+ if (argc < 1)
+ return E_ARG_LO;
+ argt[0] = argt[argc];
+ return 0;
Copied: grass/trunk/lib/calc/xexp.c (from rev 67656, grass/trunk/raster/r.mapcalc/xexp.c)
--- grass/trunk/lib/calc/xexp.c (rev 0)
+++ grass/trunk/lib/calc/xexp.c 2016-01-25 09:28:12 UTC (rev 67658)
@@ -0,0 +1,53 @@
+#include <math.h>
+exp(x) computes e raised to power x
+exp(x,y) computes x raised to power y
+ if floating point exception occurs during the evaluation of exp(x)
+ or exp(x,y) the result is NULL
+int f_exp(int argc, const int *argt, void **args)
+ DCELL *arg2;
+ int i;
+ if (argc < 1)
+ return E_ARG_LO;
+ if (argc > 2)
+ return E_ARG_HI;
+ else if (argc > 1 && arg1[i] < 0 && arg2[i] != ceil(arg2[i]))
+ else {
+ res[i] = (argc > 1)
+ ? pow(arg1[i], arg2[i])
+ : exp(arg1[i]);
+ return 0;
Copied: grass/trunk/lib/calc/xfloat.c (from rev 67656, grass/trunk/raster/r.mapcalc/xfloat.c)
--- grass/trunk/lib/calc/xfloat.c (rev 0)
+++ grass/trunk/lib/calc/xfloat.c 2016-01-25 09:28:12 UTC (rev 67658)
@@ -0,0 +1,76 @@
+float(x)
+ converts x to float
+int f_float(int argc, const int *argt, void **args)
+ int i;
+ if (argc < 1)
+ return E_ARG_LO;
+ if (argc > 1)
+ return E_ARG_HI;
+ if (argt[0] != FCELL_TYPE)
+ case CELL_TYPE:
+ else
+ res[i] = (FCELL) arg1[i];
+ return 0;
+ case FCELL_TYPE:
+ else
+ return 0;
+ case DCELL_TYPE:
+ else
+ return 0;
+ default:
+int c_float(int argc, int *argt)
+ if (argc < 1)
+ return E_ARG_LO;
+ if (argc > 1)
+ return E_ARG_HI;
+ return 0;
Copied: grass/trunk/lib/calc/xge.c (from rev 67656, grass/trunk/raster/r.mapcalc/xge.c)
--- grass/trunk/lib/calc/xge.c (rev 0)
+++ grass/trunk/lib/calc/xge.c 2016-01-25 09:28:12 UTC (rev 67658)
@@ -0,0 +1,63 @@
+ge(a,b) = a >= b
+int f_ge(int argc, const int *argt, void **args)
+ int i;
+ if (argc < 2)
+ return E_ARG_LO;
+ if (argc > 2)
+ return E_ARG_HI;
+ case CELL_TYPE:
+ else
+ res[i] = arg1[i] >= arg2[i];
+ return 0;
+ case FCELL_TYPE:
+ else
+ return 0;
+ case DCELL_TYPE:
+ else
+ return 0;
+ default:
Copied: grass/trunk/lib/calc/xgraph.c (from rev 67656, grass/trunk/raster/r.mapcalc/xgraph.c)
--- grass/trunk/lib/calc/xgraph.c (rev 0)
+++ grass/trunk/lib/calc/xgraph.c 2016-01-25 09:28:12 UTC (rev 67658)
@@ -0,0 +1,178 @@
+graph(x, x1,y1, x2,y2, ... xn,yn) returns y value based on graph
+described by the x,y pairs.
+int c_graph(int argc, int *argt)
+ int i;
+ if (argc < 3)
+ return E_ARG_LO;
+ if (argc % 2 == 0)
+ return E_ARG_NUM;
+ for (i = 0; i <= argc; i++)
+ argt[i] = DCELL_TYPE;
+ return 0;
+int f_graph(int argc, const int *argt, void **args)
+ DCELL *res = argz[0];
+ int n = (argc - 1) / 2;
+ int i, j;
+ if (argc < 3)
+ return E_ARG_LO;
+ return E_ARG_NUM;
+ if (argt[i] != DCELL_TYPE)
+#define X(j) (argz[2 + 2 * (j) + 0][i])
+#define Y(j) (argz[2 + 2 * (j) + 1][i])
+#define x (argz[1][i])
+ if (IS_NULL_D(&x))
+ goto null;
+ for (j = 0; j < n; j++)
+ if (IS_NULL_D(&X(j)))
+ goto null;
+ for (j = 0; j < n - 1; j++)
+ if (X(j + 1) <= X(j))
+ goto null;
+ if (x <= X(0)) {
+ if (IS_NULL_D(&Y(0)))
+ goto null;
+ res[i] = Y(0);
+ continue;
+ if (x >= X(n - 1)) {
+ if (IS_NULL_D(&Y(n - 1)))
+ goto null;
+ res[i] = Y(n - 1);
+ continue;
+ for (j = 0; j < n - 1; j++) {
+ if (x > X(j + 1))
+ continue;
+ if (IS_NULL_D(&Y(j)) || IS_NULL_D(&Y(j + 1)))
+ goto null;
+ res[i] =
+ Y(j) + (x - X(j)) * (Y(j + 1) - Y(j)) / (X(j + 1) - X(j));
+ break;
+#undef X
+#undef Y
+#undef x
+ continue;
+ null:
+ return 0;
+int f_graph2(int argc, const int *argt, void **args)
+ int i, j;
+ if (argc < 3)
+ return E_ARG_LO;
+ return E_ARG_NUM;
+#define X(j) (argz[2 + (j) + 0][i])
+#define Y(j) (argz[2 + (j) + n][i])
+ goto null;
+ goto null;
+ goto null;
+ if (x <= X(0)) {
+ goto null;
+ res[i] = Y(0);
+ continue;
+ goto null;
+ continue;
+ if (x > X(j + 1))
+ continue;
+ goto null;
+ res[i] =
+ break;
+#undef X
+#undef Y
+#undef x
+ continue;
+ null:
+ return 0;
Copied: grass/trunk/lib/calc/xgt.c (from rev 67656, grass/trunk/raster/r.mapcalc/xgt.c)
--- grass/trunk/lib/calc/xgt.c (rev 0)
+++ grass/trunk/lib/calc/xgt.c 2016-01-25 09:28:12 UTC (rev 67658)
@@ -0,0 +1,63 @@
+gt(a,b) = a > b
+int f_gt(int argc, const int *argt, void **args)
+ int i;
+ if (argc < 2)
+ return E_ARG_LO;
+ if (argc > 2)
+ return E_ARG_HI;
+ case CELL_TYPE:
+ else
+ res[i] = arg1[i] > arg2[i];
+ return 0;
+ case FCELL_TYPE:
+ else
+ return 0;
+ case DCELL_TYPE:
+ else
+ return 0;
+ default:
Copied: grass/trunk/lib/calc/xif.c (from rev 67656, grass/trunk/raster/r.mapcalc/xif.c)
--- grass/trunk/lib/calc/xif.c (rev 0)
+++ grass/trunk/lib/calc/xif.c 2016-01-25 09:28:12 UTC (rev 67658)
@@ -0,0 +1,303 @@
+ if(a) 1,0,1 1 if a is non zero, 0 otherwise
+ if(a,b) b,0,b b if a is non zero, 0 otherwise
+ if(a,b,c) b,c,b b if a is non zero, c otherwise
+ if(a,b,c,d) d,c,b b if a is positive, c if a is zero, d if a is negative
+static int f_if_i(int argc, const int *argt, void **args)
+ CELL *arg2 = (argc >= 2) ? args[2] : NULL;
+ CELL *arg3 = (argc >= 3) ? args[3] : NULL;
+ CELL *arg4 = (argc >= 4) ? args[4] : NULL;
+ int i;
+ switch (argc) {
+ case 0:
+ return E_ARG_LO;
+ case 1:
+ else
+ res[i] = arg1[i] != 0.0 ? 1 : 0;
+ break;
+ case 2:
+ else if (arg1[i] == 0.0)
+ res[i] = 0;
+ else {
+ if (IS_NULL_C(&arg2[i]))
+ else
+ res[i] = arg2[i];
+ break;
+ case 3:
+ else if (arg1[i] == 0.0) {
+ if (IS_NULL_C(&arg3[i]))
+ else
+ res[i] = arg3[i];
+ else {
+ else
+ res[i] = arg2[i];
+ break;
+ case 4:
+ else
+ res[i] = arg3[i];
+ else if (arg1[i] > 0.0) {
+ else
+ res[i] = arg2[i];
+ else { /* (arg1[i] < 0.0) */
+ if (IS_NULL_C(&arg4[i]))
+ else
+ res[i] = arg4[i];
+ break;
+ default:
+ return E_ARG_HI;
+ return 0;
+static int f_if_f(int argc, const int *argt, void **args)
+ FCELL *arg2 = (argc >= 2) ? args[2] : NULL;
+ FCELL *arg3 = (argc >= 3) ? args[3] : NULL;
+ FCELL *arg4 = (argc >= 4) ? args[4] : NULL;
+ int i;
+ switch (argc) {
+ case 0:
+ return E_ARG_LO;
+ case 1:
+ case 2:
+ res[i] = 0.0;
+ else {
+ if (IS_NULL_F(&arg2[i]))
+ else
+ res[i] = arg2[i];
+ break;
+ case 3:
+ if (IS_NULL_F(&arg3[i]))
+ else
+ res[i] = arg3[i];
+ else {
+ else
+ res[i] = arg2[i];
+ break;
+ case 4:
+ else
+ res[i] = arg3[i];
+ else
+ res[i] = arg2[i];
+ if (IS_NULL_F(&arg4[i]))
+ else
+ res[i] = arg4[i];
+ break;
+ default:
+ return E_ARG_HI;
+ return 0;
+static int f_if_d(int argc, const int *argt, void **args)
+ DCELL *arg2 = (argc >= 2) ? args[2] : NULL;
+ DCELL *arg3 = (argc >= 3) ? args[3] : NULL;
+ DCELL *arg4 = (argc >= 4) ? args[4] : NULL;
+ int i;
+ switch (argc) {
+ case 0:
+ return E_ARG_LO;
+ case 1:
+ case 2:
+ res[i] = 0.0;
+ else {
+ if (IS_NULL_D(&arg2[i]))
+ else
+ res[i] = arg2[i];
+ break;
+ case 3:
+ if (IS_NULL_D(&arg3[i]))
+ else
+ res[i] = arg3[i];
+ else {
+ else
+ res[i] = arg2[i];
+ break;
+ case 4:
+ else
+ res[i] = arg3[i];
+ else
+ res[i] = arg2[i];
+ if (IS_NULL_D(&arg4[i]))
+ else
+ res[i] = arg4[i];
+ break;
+ default:
+ return E_ARG_HI;
+ return 0;
+int f_if(int argc, const int *argt, void **args)
+ if (argc < 1)
+ return E_ARG_LO;
+ if (argc > 4)
+ return E_ARG_HI;
+ if (argc >= 2 && argt[2] != argt[0])
+ if (argc >= 3 && argt[3] != argt[0])
+ if (argc >= 4 && argt[4] != argt[0])
+ case CELL_TYPE:
+ return f_if_i(argc, argt, args);
+ case FCELL_TYPE:
+ return f_if_f(argc, argt, args);
+ case DCELL_TYPE:
+ return f_if_d(argc, argt, args);
+ default:
+int c_if(int argc, int *argt)
+ if (argc < 1)
+ return E_ARG_LO;
+ if (argc > 4)
+ return E_ARG_HI;
+ if (argc >= 2 && argt[2] == FCELL_TYPE)
+ if (argc >= 3 && argt[3] == FCELL_TYPE)
+ if (argc >= 4 && argt[4] == FCELL_TYPE)
+ if (argc >= 2 && argt[2] == DCELL_TYPE)
+ if (argc >= 3 && argt[3] == DCELL_TYPE)
+ if (argc >= 4 && argt[4] == DCELL_TYPE)
+ if (argc >= 2)
+ if (argc >= 3)
+ argt[3] = argt[0];
+ if (argc >= 4)
+ argt[4] = argt[0];
+ return 0;
Copied: grass/trunk/lib/calc/xint.c (from rev 67656, grass/trunk/raster/r.mapcalc/xint.c)
--- grass/trunk/lib/calc/xint.c (rev 0)
+++ grass/trunk/lib/calc/xint.c 2016-01-25 09:28:12 UTC (rev 67658)
@@ -0,0 +1,76 @@
+int(x)
+ converts x to int
+int f_int(int argc, const int *argt, void **args)
+ int i;
+ if (argc < 1)
+ return E_ARG_LO;
+ if (argc > 1)
+ return E_ARG_HI;
+ case CELL_TYPE:
+ else
+ res[i] = (CELL) arg1[i];
+ return 0;
+ case FCELL_TYPE:
+ else
+ return 0;
+ case DCELL_TYPE:
+ else
+ return 0;
+ default:
+int c_int(int argc, int *argt)
+ if (argc < 1)
+ return E_ARG_LO;
+ if (argc > 1)
+ return E_ARG_HI;
+ return 0;
Copied: grass/trunk/lib/calc/xisnull.c (from rev 67656, grass/trunk/raster/r.mapcalc/xisnull.c)
--- grass/trunk/lib/calc/xisnull.c (rev 0)
+++ grass/trunk/lib/calc/xisnull.c 2016-01-25 09:28:12 UTC (rev 67658)
@@ -0,0 +1,64 @@
+isnull(x)
+ return 1 if x is null, 0 otherwise
+int f_isnull(int argc, const int *argt, void **args)
+ int *res = args[0];
+ int i;
+ if (argc < 1)
+ return E_ARG_LO;
+ if (argc > 1)
+ return E_ARG_HI;
+ case CELL_TYPE:
+ res[i] = IS_NULL_C(&arg1[i]) ? 1 : 0;
+ return 0;
+ case FCELL_TYPE:
+ res[i] = IS_NULL_F(&arg1[i]) ? 1 : 0;
+ return 0;
+ case DCELL_TYPE:
+ res[i] = IS_NULL_D(&arg1[i]) ? 1 : 0;
+ return 0;
+ default:
+int c_isnull(int argc, int *argt)
+ if (argc < 1)
+ return E_ARG_LO;
+ if (argc > 1)
+ return E_ARG_HI;
+ return 0;
Copied: grass/trunk/lib/calc/xle.c (from rev 67656, grass/trunk/raster/r.mapcalc/xle.c)
--- grass/trunk/lib/calc/xle.c (rev 0)
+++ grass/trunk/lib/calc/xle.c 2016-01-25 09:28:12 UTC (rev 67658)
@@ -0,0 +1,63 @@
+le(a,b) = a <= b
+int f_le(int argc, const int *argt, void **args)
+ int i;
+ if (argc < 2)
+ return E_ARG_LO;
+ if (argc > 2)
+ return E_ARG_HI;
+ case CELL_TYPE:
+ else
+ res[i] = arg1[i] <= arg2[i];
+ return 0;
+ case FCELL_TYPE:
+ else
+ return 0;
+ case DCELL_TYPE:
+ else
+ return 0;
+ default:
Copied: grass/trunk/lib/calc/xlog.c (from rev 67656, grass/trunk/raster/r.mapcalc/xlog.c)
--- grass/trunk/lib/calc/xlog.c (rev 0)
+++ grass/trunk/lib/calc/xlog.c 2016-01-25 09:28:12 UTC (rev 67658)
@@ -0,0 +1,59 @@
+#include <math.h>
+log(x)
+log(x,b)
+ first form computes the natural log of x = ln(x)
+ second form computes log of x base b = ln(x)/ln(b)
+ if x is non-positive, or floating point exception occurs while
+ computing ln(x), the result is NULL
+ if b is non-positive, or 1.0, or floating point exception occurs while
+ computing ln(b), the result is NULL
+int f_log(int argc, const int *argt, void **args)
+ DCELL *arg2 = (argc >= 2) ? args[2] : (DCELL *) 0;
+ int i;
+ if (argc < 1)
+ return E_ARG_LO;
+ if (argc > 2)
+ return E_ARG_HI;
+ if (IS_NULL_D(&arg1[i]) || (arg1[i] <= 0.0))
+ else if (argc > 1 && (IS_NULL_D(&arg2[i]) || (arg2[i] <= 0.0)))
+ else {
+ ? log(arg1[i]) / log(arg2[i])
+ : log(arg1[i]);
+ return 0;
Copied: grass/trunk/lib/calc/xlt.c (from rev 67656, grass/trunk/raster/r.mapcalc/xlt.c)
--- grass/trunk/lib/calc/xlt.c (rev 0)
+++ grass/trunk/lib/calc/xlt.c 2016-01-25 09:28:12 UTC (rev 67658)
@@ -0,0 +1,63 @@
+lt(a,b) = a < b
+int f_lt(int argc, const int *argt, void **args)
+ int i;
+ if (argc < 2)
+ return E_ARG_LO;
+ if (argc > 2)
+ return E_ARG_HI;
+ case CELL_TYPE:
+ else
+ res[i] = arg1[i] < arg2[i];
+ return 0;
+ case FCELL_TYPE:
+ else
+ return 0;
+ case DCELL_TYPE:
+ else
+ return 0;
+ default:
Copied: grass/trunk/lib/calc/xmax.c (from rev 67656, grass/trunk/raster/r.mapcalc/xmax.c)
--- grass/trunk/lib/calc/xmax.c (rev 0)
+++ grass/trunk/lib/calc/xmax.c 2016-01-25 09:28:12 UTC (rev 67658)
@@ -0,0 +1,98 @@
+max(x0,x1,...,xn) returns maximum value
+int f_max(int argc, const int *argt, void **args)
+ int i, j;
+ if (argc < 1)
+ return E_ARG_LO;
+ case CELL_TYPE:
+ int nul = 0;
+ CELL max;
+ nul = 1;
+ else if (j == 1)
+ max = argz[j][i];
+ else if (max < argz[j][i])
+ max = argz[j][i];
+ if (nul)
+ else
+ res[i] = max;
+ return 0;
+ case FCELL_TYPE:
+ int nul = 0;
+ FCELL max;
+ nul = 1;
+ else if (j == 1)
+ max = argz[j][i];
+ max = argz[j][i];
+ if (nul)
+ else
+ res[i] = max;
+ return 0;
+ case DCELL_TYPE:
+ int nul = 0;
+ DCELL max;
+ nul = 1;
+ else if (j == 1)
+ max = argz[j][i];
+ max = argz[j][i];
+ if (nul)
+ else
+ res[i] = max;
+ return 0;
+ default:
Copied: grass/trunk/lib/calc/xmedian.c (from rev 67656, grass/trunk/raster/r.mapcalc/xmedian.c)
--- grass/trunk/lib/calc/xmedian.c (rev 0)
+++ grass/trunk/lib/calc/xmedian.c 2016-01-25 09:28:12 UTC (rev 67658)
@@ -0,0 +1,153 @@
+median(x1,x2,..,xn)
+ return median of arguments
+static int icmp(const void *aa, const void *bb)
+ const CELL *a = aa;
+ const CELL *b = bb;
+ return *a - *b;
+static int fcmp(const void *aa, const void *bb)
+ const FCELL *a = aa;
+ const FCELL *b = bb;
+ if (*a < *b)
+ return -1;
+ if (*a > *b)
+ return 1;
+ return 0;
+static int dcmp(const void *aa, const void *bb)
+ const DCELL *a = aa;
+ const DCELL *b = bb;
+ if (*a < *b)
+ return -1;
+ if (*a > *b)
+ return 1;
+ return 0;
+int f_median(int argc, const int *argt, void **args)
+ static void *array;
+ static int alloc;
+ int size = argc * Rast_cell_size(argt[0]);
+ int i, j;
+ if (argc < 1)
+ return E_ARG_LO;
+ if (size > alloc) {
+ alloc = size;
+ array = G_realloc(array, size);
+ case CELL_TYPE:
+ CELL **argv = (CELL **) &args[1];
+ CELL *a = array;
+ CELL *a1 = &a[(argc - 1) / 2];
+ CELL *a2 = &a[argc / 2];
+ int nv = 0;
+ for (j = 0; j < argc && !nv; j++) {
+ if (IS_NULL_C(&argv[j][i]))
+ nv = 1;
+ else
+ a[j] = argv[j][i];
+ if (nv)
+ else {
+ qsort(a, argc, sizeof(CELL), icmp);
+ res[i] = (*a1 + *a2) / 2;
+ return 0;
+ case FCELL_TYPE:
+ FCELL **argv = (FCELL **) &args[1];
+ FCELL *a = array;
+ FCELL *a1 = &a[(argc - 1) / 2];
+ FCELL *a2 = &a[argc / 2];
+ int nv = 0;
+ if (IS_NULL_F(&argv[j][i]))
+ nv = 1;
+ else
+ if (nv)
+ else {
+ qsort(a, argc, sizeof(FCELL), fcmp);
+ return 0;
+ case DCELL_TYPE:
+ DCELL **argv = (DCELL **) &args[1];
+ DCELL *a = array;
+ DCELL *a1 = &a[(argc - 1) / 2];
+ DCELL *a2 = &a[argc / 2];
+ int nv = 0;
+ if (IS_NULL_D(&argv[j][i]))
+ nv = 1;
+ else
+ if (nv)
+ else {
+ qsort(a, argc, sizeof(DCELL), dcmp);
+ return 0;
+ default:
Copied: grass/trunk/lib/calc/xmin.c (from rev 67656, grass/trunk/raster/r.mapcalc/xmin.c)
--- grass/trunk/lib/calc/xmin.c (rev 0)
+++ grass/trunk/lib/calc/xmin.c 2016-01-25 09:28:12 UTC (rev 67658)
@@ -0,0 +1,98 @@
+min(x0,x1,...,xn) returns minimum value
+int f_min(int argc, const int *argt, void **args)
+ int i, j;
+ if (argc < 1)
+ return E_ARG_LO;
+ case CELL_TYPE:
+ int nul = 0;
+ CELL min;
+ nul = 1;
+ else if (j == 1)
+ min = argz[j][i];
+ else if (min > argz[j][i])
+ min = argz[j][i];
+ if (nul)
+ else
+ res[i] = min;
+ return 0;
+ case FCELL_TYPE:
+ int nul = 0;
+ FCELL min;
+ nul = 1;
+ else if (j == 1)
+ min = argz[j][i];
+ min = argz[j][i];
+ if (nul)
+ else
+ res[i] = min;
+ return 0;
+ case DCELL_TYPE:
+ int nul = 0;
+ DCELL min;
+ nul = 1;
+ else if (j == 1)
+ min = argz[j][i];
+ min = argz[j][i];
+ if (nul)
+ else
+ res[i] = min;
+ return 0;
+ default:
Copied: grass/trunk/lib/calc/xmod.c (from rev 67656, grass/trunk/raster/r.mapcalc/xmod.c)
--- grass/trunk/lib/calc/xmod.c (rev 0)
+++ grass/trunk/lib/calc/xmod.c 2016-01-25 09:28:12 UTC (rev 67658)
@@ -0,0 +1,78 @@
+#include <math.h>
+mod(a,b) = a % b
+int f_mod(int argc, const int *argt, void **args)
+ int i;
+ if (argc < 2)
+ return E_ARG_LO;
+ if (argc > 2)
+ return E_ARG_HI;
+ case CELL_TYPE:
+ else
+ res[i] = arg1[i] % arg2[i];
+ return 0;
+ case FCELL_TYPE:
+ else {
+ res[i] = (FCELL) fmod(arg1[i], arg2[i]);
+ return 0;
+ case DCELL_TYPE:
+ else {
+ res[i] = (DCELL) fmod(arg1[i], arg2[i]);
+ return 0;
+ default:
Copied: grass/trunk/lib/calc/xmode.c (from rev 67656, grass/trunk/raster/r.mapcalc/xmode.c)
--- grass/trunk/lib/calc/xmode.c (rev 0)
+++ grass/trunk/lib/calc/xmode.c 2016-01-25 09:28:12 UTC (rev 67658)
@@ -0,0 +1,142 @@
+mode(x1,x2,..,xn)
+ return mode of arguments
+ const double *a = aa;
+ const double *b = bb;
+ if (*a < *b)
+ return -1;
+ if (*a > *b)
+ return 1;
+ return 0;
+static double mode(double *value, int argc)
+ double mode_v;
+ int mode_n = 0;
+ int i;
+ qsort(value, argc, sizeof(double), dcmp);
+ for (i = 0; i < argc;) {
+ int n = 1;
+ double v = value[i];
+ for (i++; i < argc; i++) {
+ if (value[i] != v)
+ break;
+ n++;
+ if (n < mode_n)
+ continue;
+ mode_v = v;
+ mode_n = n;
+ return mode_v;
+int f_mode(int argc, const int *argt, void **args)
+ static double *value;
+ static int value_size;
+ int size = argc * sizeof(double);
+ int i, j;
+ if (argc < 1)
+ return E_ARG_LO;
+ if (size > value_size) {
+ value_size = size;
+ value = G_realloc(value, value_size);
+ case CELL_TYPE:
+ CELL **argv = (CELL **) & args[1];
+ int nv = 0;
+ nv = 1;
+ else
+ value[j] = (double)argv[j][i];
+ if (nv)
+ else
+ res[i] = (CELL) mode(value, argc);
+ return 0;
+ case FCELL_TYPE:
+ FCELL **argv = (FCELL **) & args[1];
+ int nv = 0;
+ nv = 1;
+ else
+ if (nv)
+ else
+ res[i] = (FCELL) mode(value, argc);
+ return 0;
+ case DCELL_TYPE:
+ DCELL **argv = (DCELL **) & args[1];
+ int nv = 0;
+ nv = 1;
+ else
+ if (nv)
+ else
+ res[i] = (DCELL) mode(value, argc);
+ return 0;
+ default:
Copied: grass/trunk/lib/calc/xmul.c (from rev 67656, grass/trunk/raster/r.mapcalc/xmul.c)
--- grass/trunk/lib/calc/xmul.c (rev 0)
+++ grass/trunk/lib/calc/xmul.c 2016-01-25 09:28:12 UTC (rev 67658)
@@ -0,0 +1,76 @@
+mul(a,b) = a * b
+int f_mul(int argc, const int *argt, void **args)
+ int i, j;
+ if (argc < 1)
+ return E_ARG_LO;
+ case CELL_TYPE:
+ res[i] = 1;
+ break;
+ res[i] *= argz[j][i];
+ return 0;
+ case FCELL_TYPE:
+ res[i] = 1;
+ break;
+ return 0;
+ case DCELL_TYPE:
+ res[i] = 1;
+ break;
+ return 0;
+ default:
Copied: grass/trunk/lib/calc/xne.c (from rev 67656, grass/trunk/raster/r.mapcalc/xne.c)
--- grass/trunk/lib/calc/xne.c (rev 0)
+++ grass/trunk/lib/calc/xne.c 2016-01-25 09:28:12 UTC (rev 67658)
@@ -0,0 +1,63 @@
+ne(a,b) = a != b
+int f_ne(int argc, const int *argt, void **args)
+ int i;
+ if (argc < 2)
+ return E_ARG_LO;
+ if (argc > 2)
+ return E_ARG_HI;
+ case CELL_TYPE:
+ else
+ res[i] = arg1[i] != arg2[i];
+ return 0;
+ case FCELL_TYPE:
+ else
+ return 0;
+ case DCELL_TYPE:
+ else
+ return 0;
+ default:
Copied: grass/trunk/lib/calc/xneg.c (from rev 67656, grass/trunk/raster/r.mapcalc/xneg.c)
--- grass/trunk/lib/calc/xneg.c (rev 0)
+++ grass/trunk/lib/calc/xneg.c 2016-01-25 09:28:12 UTC (rev 67658)
@@ -0,0 +1,62 @@
+neg(x) = -x
+int f_neg(int argc, const int *argt, void **args)
+ int i;
+ if (argc < 1)
+ return E_ARG_LO;
+ if (argc > 1)
+ return E_ARG_HI;
+ case CELL_TYPE:
+ else
+ res[i] = -arg1[i];
+ return 0;
+ case FCELL_TYPE:
+ else
+ return 0;
+ case DCELL_TYPE:
+ else
+ return 0;
+ default:
Copied: grass/trunk/lib/calc/xnmax.c (from rev 67656, grass/trunk/raster/r.mapcalc/xnmax.c)
--- grass/trunk/lib/calc/xnmax.c (rev 0)
+++ grass/trunk/lib/calc/xnmax.c 2016-01-25 09:28:12 UTC (rev 67658)
@@ -0,0 +1,98 @@
+int f_nmax(int argc, const int *argt, void **args)
+ int i, j;
+ if (argc < 1)
+ return E_ARG_LO;
+ case CELL_TYPE:
+ int nul = 1;
+ CELL max;
+ continue;
+ else if (nul)
+ max = argz[j][i], nul = 0;
+ if (nul)
+ else
+ res[i] = max;
+ return 0;
+ case FCELL_TYPE:
+ int nul = 1;
+ FCELL max;
+ continue;
+ else if (nul)
+ if (nul)
+ else
+ res[i] = max;
+ return 0;
+ case DCELL_TYPE:
+ int nul = 1;
+ DCELL max;
+ continue;
+ else if (nul)
+ if (nul)
+ else
+ res[i] = max;
+ return 0;
+ default:
Copied: grass/trunk/lib/calc/xnmedian.c (from rev 67656, grass/trunk/raster/r.mapcalc/xnmedian.c)
--- grass/trunk/lib/calc/xnmedian.c (rev 0)
+++ grass/trunk/lib/calc/xnmedian.c 2016-01-25 09:28:12 UTC (rev 67658)
@@ -0,0 +1,150 @@
+ return *a - *b;
+ if (*a < *b)
+ return -1;
+ if (*a > *b)
+ return 1;
+ return 0;
+ if (*a < *b)
+ return -1;
+ if (*a > *b)
+ return 1;
+ return 0;
+int f_nmedian(int argc, const int *argt, void **args)
+ static int alloc;
+ int i, j;
+ if (argc < 1)
+ return E_ARG_LO;
+ alloc = size;
+ case CELL_TYPE:
+ CELL *a = array;
+ int n = 0;
+ for (j = 0; j < argc; j++) {
+ continue;
+ a[n++] = argv[j][i];
+ if (!n)
+ else {
+ qsort(a, n, sizeof(CELL), icmp);
+ return 0;
+ case FCELL_TYPE:
+ FCELL *a = array;
+ int n = 0;
+ continue;
+ if (!n)
+ else {
+ qsort(a, n, sizeof(FCELL), fcmp);
+ return 0;
+ case DCELL_TYPE:
+ DCELL *a = array;
+ int n = 0;
+ continue;
+ if (!n)
+ else {
+ qsort(a, n, sizeof(DCELL), dcmp);
+ return 0;
+ default:
Copied: grass/trunk/lib/calc/xnmin.c (from rev 67656, grass/trunk/raster/r.mapcalc/xnmin.c)
--- grass/trunk/lib/calc/xnmin.c (rev 0)
+++ grass/trunk/lib/calc/xnmin.c 2016-01-25 09:28:12 UTC (rev 67658)
@@ -0,0 +1,98 @@
+int f_nmin(int argc, const int *argt, void **args)
+ int i, j;
+ if (argc < 1)
+ return E_ARG_LO;
+ case CELL_TYPE:
+ int nul = 1;
+ CELL min;
+ continue;
+ else if (nul)
+ min = argz[j][i], nul = 0;
+ if (nul)
+ else
+ res[i] = min;
+ return 0;
+ case FCELL_TYPE:
+ int nul = 1;
+ FCELL min;
+ continue;
+ else if (nul)
+ if (nul)
+ else
+ res[i] = min;
+ return 0;
+ case DCELL_TYPE:
+ int nul = 1;
+ DCELL min;
+ continue;
+ else if (nul)
+ if (nul)
+ else
+ res[i] = min;
+ return 0;
+ default:
Copied: grass/trunk/lib/calc/xnmode.c (from rev 67656, grass/trunk/raster/r.mapcalc/xnmode.c)
--- grass/trunk/lib/calc/xnmode.c (rev 0)
+++ grass/trunk/lib/calc/xnmode.c 2016-01-25 09:28:12 UTC (rev 67658)
@@ -0,0 +1,139 @@
+mode(x1,x2,..,xn)
+ if (*a < *b)
+ return -1;
+ if (*a > *b)
+ return 1;
+ return 0;
+ double mode_v;
+ int mode_n = 0;
+ int i;
+ int n = 1;
+ break;
+ n++;
+ if (n < mode_n)
+ continue;
+ mode_v = v;
+ mode_n = n;
+ return mode_v;
+int f_nmode(int argc, const int *argt, void **args)
+ int i, j;
+ if (argc < 1)
+ return E_ARG_LO;
+ case CELL_TYPE:
+ int n = 0;
+ continue;
+ value[n++] = (double)argv[j][i];
+ if (!n)
+ else
+ res[i] = (CELL) mode(value, n);
+ return 0;
+ case FCELL_TYPE:
+ int n = 0;
+ continue;
+ if (!n)
+ else
+ res[i] = (FCELL) mode(value, n);
+ return 0;
+ case DCELL_TYPE:
+ int n = 0;
+ continue;
+ if (!n)
+ else
+ res[i] = (DCELL) mode(value, n);
+ return 0;
+ default:
Copied: grass/trunk/lib/calc/xnot.c (from rev 67656, grass/trunk/raster/r.mapcalc/xnot.c)
--- grass/trunk/lib/calc/xnot.c (rev 0)
+++ grass/trunk/lib/calc/xnot.c 2016-01-25 09:28:12 UTC (rev 67658)
@@ -0,0 +1,50 @@
+not(a) = !a
+int f_not(int argc, const int *argt, void **args)
+ int i;
+ if (argc < 1)
+ return E_ARG_LO;
+ if (argc > 1)
+ return E_ARG_HI;
+ else
+ res[i] = !arg1[i];
+ return 0;
+int c_not(int argc, int *argt)
+ if (argc < 1)
+ return E_ARG_LO;
+ if (argc > 1)
+ return E_ARG_HI;
+ return 0;
Copied: grass/trunk/lib/calc/xnull.c (from rev 67656, grass/trunk/raster/r.mapcalc/xnull.c)
--- grass/trunk/lib/calc/xnull.c (rev 0)
+++ grass/trunk/lib/calc/xnull.c 2016-01-25 09:28:12 UTC (rev 67658)
@@ -0,0 +1,25 @@
+null() null values
+int f_null(int argc, const int *argt, void **args)
+ int i;
+ if (argc > 0)
+ return E_ARG_HI;
+ return 0;
Copied: grass/trunk/lib/calc/xor.c (from rev 67656, grass/trunk/raster/r.mapcalc/xor.c)
--- grass/trunk/lib/calc/xor.c (rev 0)
+++ grass/trunk/lib/calc/xor.c 2016-01-25 09:28:12 UTC (rev 67658)
@@ -0,0 +1,39 @@
+or(a,b,c,...) = a || b || c || ...
+int f_or(int argc, const int *argt, void **args)
+ int i, j;
+ if (argc < 1)
+ return E_ARG_LO;
+ res[i] = 0;
+ CELL *arg = args[j];
+ if (IS_NULL_C(&arg[i])) {
+ break;
+ if (arg[i])
+ res[i] = 1;
+ return 0;
Copied: grass/trunk/lib/calc/xor2.c (from rev 67656, grass/trunk/raster/r.mapcalc/xor2.c)
--- grass/trunk/lib/calc/xor2.c (rev 0)
+++ grass/trunk/lib/calc/xor2.c 2016-01-25 09:28:12 UTC (rev 67658)
@@ -0,0 +1,46 @@
+or2(a,b,c,...) = a || b || c || ...
+Differs from or() in that the boolean axioms:
+ true || x == true
+ x || true == true
+int f_or2(int argc, const int *argt, void **args)
+ int i, j;
+ if (argc < 1)
+ return E_ARG_LO;
+ res[i] = 0;
+ if (!IS_NULL_C(&arg[i]) && arg[i]) {
+ res[i] = 1;
+ break;
+ return 0;
Copied: grass/trunk/lib/calc/xpow.c (from rev 67656, grass/trunk/raster/r.mapcalc/xpow.c)
--- grass/trunk/lib/calc/xpow.c (rev 0)
+++ grass/trunk/lib/calc/xpow.c 2016-01-25 09:28:12 UTC (rev 67658)
@@ -0,0 +1,96 @@
+#include <math.h>
+pow(a,b)
+ a raised to the power b
+static int ipow(int x, int y)
+ int res = 1;
+ while (y) {
+ if (y & 1)
+ res *= x;
+ y >>= 1;
+ x *= x;
+ return res;
+int f_pow(int argc, const int *argt, void **args)
+ int i;
+ if (argc < 2)
+ return E_ARG_LO;
+ if (argc > 2)
+ return E_ARG_HI;
+ case CELL_TYPE:
+ if (IS_NULL_C(&arg1[i]) || IS_NULL_C(&arg2[i]) || arg2[i] < 0)
+ else
+ res[i] = ipow(arg1[i], arg2[i]);
+ return 0;
+ case FCELL_TYPE:
+ else if (arg1[i] < 0 && arg2[i] != ceil(arg2[i]))
+ else {
+ res[i] = pow(arg1[i], arg2[i]);
+ return 0;
+ case DCELL_TYPE:
+ else {
+ return 0;
+ default:
Copied: grass/trunk/lib/calc/xrand.c (from rev 67656, grass/trunk/raster/r.mapcalc/xrand.c)
--- grass/trunk/lib/calc/xrand.c (rev 0)
+++ grass/trunk/lib/calc/xrand.c 2016-01-25 09:28:12 UTC (rev 67658)
@@ -0,0 +1,89 @@
+#include <grass/config.h>
+rand(lo,hi) random values between a and b
+int f_rand(int argc, const int *argt, void **args)
+ int i;
+ if (argc < 2)
+ return E_ARG_LO;
+ if (argc > 2)
+ return E_ARG_HI;
+ case CELL_TYPE:
+ unsigned int x = (unsigned int)G_mrand48();
+ int lo = arg1[i];
+ int hi = arg2[i];
+ if (lo > hi) {
+ int tmp = lo;
+ lo = hi;
+ hi = tmp;
+ res[i] = (lo == hi) ? lo : lo + x % (unsigned int)(hi - lo);
+ return 0;
+ case FCELL_TYPE:
+ double x = G_drand48();
+ FCELL lo = arg1[i];
+ FCELL hi = arg2[i];
+ if (lo > hi) {
+ FCELL tmp = lo;
+ lo = hi;
+ hi = tmp;
+ res[i] = (FCELL) (lo + x * (hi - lo));
+ return 0;
+ case DCELL_TYPE:
+ DCELL lo = arg1[i];
+ DCELL hi = arg2[i];
+ if (lo > hi) {
+ DCELL tmp = lo;
+ lo = hi;
+ hi = tmp;
+ res[i] = lo + x * (hi - lo);
+ return 0;
+ default:
Copied: grass/trunk/lib/calc/xround.c (from rev 67656, grass/trunk/raster/r.mapcalc/xround.c)
--- grass/trunk/lib/calc/xround.c (rev 0)
+++ grass/trunk/lib/calc/xround.c 2016-01-25 09:28:12 UTC (rev 67658)
@@ -0,0 +1,203 @@
+#include <limits.h>
+#include <math.h>
+round(x, step, start)
+ rounds x to nearest value in the sequence
+ y[i] = i * step + start
+/* i_round(x) rounds x to nearest value, handles negative correctly */
+static double i_round(double x, double step, double start)
+ x -= start;
+ x /= step;
+ x = floor(x + 0.5);
+ x *= step;
+ x += start;
+ return x;
+int f_round(int argc, const int *argt, void **args)
+ const DCELL *arg1 = args[1];
+ int i;
+ if (argc < 1)
+ return E_ARG_LO;
+ if (argc > 3)
+ return E_ARG_HI;
+ if (argc == 1 && argt[0] != CELL_TYPE)
+ if (argc > 2 && argt[3] != DCELL_TYPE)
+ if (argc == 1) {
+ else {
+ DCELL x = i_round(arg1[i], 1.0, 0.0);
+ if (x > 2147483647.0 || x < -2147483647.0)
+ else
+ res[i] = (CELL) x;
+ return 0;
+ else if (argc == 2) {
+ const DCELL *arg2 = args[2];
+ case CELL_TYPE:
+ else if (IS_NULL_D(&arg2[i]))
+ else {
+ DCELL x = i_round(arg1[i], arg2[i], 0.0);
+ else
+ return 0;
+ case FCELL_TYPE:
+ else
+ res[i] = (FCELL) i_round(arg1[i], arg2[i], 0.0);
+ return 0;
+ case DCELL_TYPE:
+ else
+ res[i] = (DCELL) i_round(arg1[i], arg2[i], 0.0);
+ return 0;
+ default:
+ else if (argc == 3) {
+ const DCELL *arg3 = args[3];
+ case CELL_TYPE:
+ else if (IS_NULL_D(&arg3[i]))
+ else {
+ DCELL x = i_round(arg1[i], arg2[i], arg3[i]);
+ else
+ return 0;
+ case FCELL_TYPE:
+ else
+ res[i] = (FCELL) i_round(arg1[i], arg2[i], arg3[i]);
+ return 0;
+ case DCELL_TYPE:
+ else
+ res[i] = (DCELL) i_round(arg1[i], arg2[i], arg3[i]);
+ return 0;
+ default:
+ else
+ return E_WTF;
+int c_round(int argc, int *argt)
+ if (argc < 1)
+ return E_ARG_LO;
+ if (argc > 3)
+ return E_ARG_HI;
+ if (argc > 1 && argt[0] < argt[2])
+ argt[0] = argt[2];
+ if (argc > 2 && argt[0] < argt[3])
+ argt[0] = argt[3];
+ if (argc > 1)
+ if (argc > 2)
+ argt[3] = DCELL_TYPE;
+ return 0;
Copied: grass/trunk/lib/calc/xshiftl.c (from rev 67656, grass/trunk/raster/r.mapcalc/xshiftl.c)
--- grass/trunk/lib/calc/xshiftl.c (rev 0)
+++ grass/trunk/lib/calc/xshiftl.c 2016-01-25 09:28:12 UTC (rev 67658)
@@ -0,0 +1,36 @@
+shiftl(a,b) = a << b
+int f_shiftl(int argc, const int *argt, void **args)
+ int i;
+ if (argc < 2)
+ return E_ARG_LO;
+ if (argc > 2)
+ return E_ARG_HI;
+ else
+ res[i] = arg1[i] << arg2[i];
+ return 0;
Copied: grass/trunk/lib/calc/xshiftr.c (from rev 67656, grass/trunk/raster/r.mapcalc/xshiftr.c)
--- grass/trunk/lib/calc/xshiftr.c (rev 0)
+++ grass/trunk/lib/calc/xshiftr.c 2016-01-25 09:28:12 UTC (rev 67658)
@@ -0,0 +1,36 @@
+shiftr(a,b) = a >> b
+int f_shiftr(int argc, const int *argt, void **args)
+ int i;
+ if (argc < 2)
+ return E_ARG_LO;
+ if (argc > 2)
+ return E_ARG_HI;
+ else
+ res[i] = arg1[i] >> arg2[i];
+ return 0;
Copied: grass/trunk/lib/calc/xshiftru.c (from rev 67656, grass/trunk/raster/r.mapcalc/xshiftru.c)
--- grass/trunk/lib/calc/xshiftru.c (rev 0)
+++ grass/trunk/lib/calc/xshiftru.c 2016-01-25 09:28:12 UTC (rev 67658)
@@ -0,0 +1,36 @@
+shiftru(a,b) = (unsigned) a >> b
+int f_shiftru(int argc, const int *argt, void **args)
+ int i;
+ if (argc < 2)
+ return E_ARG_LO;
+ if (argc > 2)
+ return E_ARG_HI;
+ else
+ res[i] = ((unsigned int)arg1[i]) >> arg2[i];
+ return 0;
Copied: grass/trunk/lib/calc/xsin.c (from rev 67656, grass/trunk/raster/r.mapcalc/xsin.c)
--- grass/trunk/lib/calc/xsin.c (rev 0)
+++ grass/trunk/lib/calc/xsin.c 2016-01-25 09:28:12 UTC (rev 67658)
@@ -0,0 +1,47 @@
+#include <math.h>
+sin(x)
+ if floating point exception occurs during the evaluation of sin(x)
+int f_sin(int argc, const int *argt, void **args)
+ int i;
+ if (argc < 1)
+ return E_ARG_LO;
+ if (argc > 1)
+ return E_ARG_HI;
+ else {
+ res[i] = sin(arg1[i] * DEGREES_TO_RADIANS);
+ return 0;
Copied: grass/trunk/lib/calc/xsqrt.c (from rev 67656, grass/trunk/raster/r.mapcalc/xsqrt.c)
--- grass/trunk/lib/calc/xsqrt.c (rev 0)
+++ grass/trunk/lib/calc/xsqrt.c 2016-01-25 09:28:12 UTC (rev 67658)
@@ -0,0 +1,43 @@
+#include <math.h>
+sqrt(x)
+ if floating point exception occurs during the evaluation of sqrt(x)
+int f_sqrt(int argc, const int *argt, void **args)
+ int i;
+ if (argc < 1)
+ return E_ARG_LO;
+ if (argc > 1)
+ return E_ARG_HI;
+ if (IS_NULL_D(&arg1[i]) || (arg1[i] < 0.0))
+ else {
+ res[i] = sqrt(arg1[i]);
+ return 0;
Copied: grass/trunk/lib/calc/xsub.c (from rev 67656, grass/trunk/raster/r.mapcalc/xsub.c)
--- grass/trunk/lib/calc/xsub.c (rev 0)
+++ grass/trunk/lib/calc/xsub.c 2016-01-25 09:28:12 UTC (rev 67658)
@@ -0,0 +1,68 @@
+sub(a,b) = a - b
+int f_sub(int argc, const int *argt, void **args)
+ int i;
+ if (argc < 2)
+ return E_ARG_LO;
+ if (argc > 2)
+ return E_ARG_HI;
+ case CELL_TYPE:
+ else
+ res[i] = arg1[i] - arg2[i];
+ return 0;
+ case FCELL_TYPE:
+ else
+ return 0;
+ case DCELL_TYPE:
+ else
+ return 0;
+ default:
Copied: grass/trunk/lib/calc/xtan.c (from rev 67656, grass/trunk/raster/r.mapcalc/xtan.c)
--- grass/trunk/lib/calc/xtan.c (rev 0)
+++ grass/trunk/lib/calc/xtan.c 2016-01-25 09:28:12 UTC (rev 67658)
@@ -0,0 +1,48 @@
+#include <math.h>
+tan(x)
+ if floating point exception occurs during the evaluation of tan(x)
+int f_tan(int argc, const int *argt, void **args)
+ int i;
+ if (argc < 1)
+ return E_ARG_LO;
+ if (argc > 1)
+ return E_ARG_HI;
+ else {
+ res[i] = tan(arg1[i] * DEGREES_TO_RADIANS);
+ return 0;
Modified: grass/trunk/raster/r.mapcalc/Makefile
--- grass/trunk/raster/r.mapcalc/Makefile 2016-01-25 09:27:55 UTC (rev 67657)
+++ grass/trunk/raster/r.mapcalc/Makefile 2016-01-25 09:28:12 UTC (rev 67658)
@@ -12,8 +12,8 @@
include $(MODULE_TOPDIR)/include/Make/Multi.make
EXTRA_CFLAGS = $(READLINEINCPATH) $(PTHREADINCPATH)
-LIBES2 = $(GISLIB) $(RASTERLIB) $(BTREELIB) $(READLINELIBPATH) $(READLINELIB) $(HISTORYLIB) $(PTHREADLIBPATH) $(PTHREADLIB)
-LIBES3 = $(RASTER3DLIB) $(GISLIB) $(RASTERLIB) $(BTREELIB) $(READLINELIBPATH) $(READLINELIB) $(HISTORYLIB) $(PTHREADLIBPATH) $(PTHREADLIB)
+LIBES2 = $(CALCLIB) $(GISLIB) $(RASTERLIB) $(BTREELIB) $(READLINELIBPATH) $(READLINELIB) $(HISTORYLIB) $(PTHREADLIBPATH) $(PTHREADLIB)
+LIBES3 = $(CALCLIB) $(RASTER3DLIB) $(GISLIB) $(RASTERLIB) $(BTREELIB) $(READLINELIBPATH) $(READLINELIB) $(HISTORYLIB) $(PTHREADLIBPATH) $(PTHREADLIB)
default: multi
Deleted: grass/trunk/raster/r.mapcalc/check.c
--- grass/trunk/raster/r.mapcalc/check.c 2016-01-25 09:27:55 UTC (rev 67657)
+++ grass/trunk/raster/r.mapcalc/check.c 2016-01-25 09:28:12 UTC (rev 67658)
@@ -1,160 +0,0 @@
-#include "mapcalc.h"
-#include "func_proto.h"
-int c_int0(int argc, int *argt)
- if (argc > 0)
- return E_ARG_HI;
- argt[0] = CELL_TYPE;
- return 0;
-int c_double0(int argc, int *argt)
- if (argc > 0)
- return E_ARG_HI;
- argt[0] = DCELL_TYPE;
- return 0;
-int c_double1(int argc, int *argt)
- if (argc < 1)
- return E_ARG_LO;
- if (argc > 1)
- return E_ARG_HI;
- argt[1] = DCELL_TYPE;
- return 0;
-int c_double12(int argc, int *argt)
- if (argc < 1)
- return E_ARG_LO;
- if (argc > 2)
- return E_ARG_HI;
- if (argc == 2)
- argt[2] = DCELL_TYPE;
- return 0;
-int c_unop(int argc, int *argt)
- if (argc < 1)
- return E_ARG_LO;
- if (argc > 1)
- return E_ARG_HI;
- argt[0] = argt[1];
- return 0;
-int c_binop(int argc, int *argt)
- if (argc < 2)
- return E_ARG_LO;
- if (argc > 2)
- return E_ARG_HI;
- if (argt[1] == FCELL_TYPE || argt[2] == FCELL_TYPE)
- argt[0] = FCELL_TYPE;
- if (argt[1] == DCELL_TYPE || argt[2] == DCELL_TYPE)
- argt[1] = argt[0];
- argt[2] = argt[0];
- return 0;
-int c_varop(int argc, int *argt)
- int i;
- if (argc < 1)
- return E_ARG_LO;
- for (i = 1; i <= argc; i++)
- if (argt[i] == FCELL_TYPE)
- if (argt[i] == DCELL_TYPE)
- argt[i] = argt[0];
- return 0;
-int c_cmpop(int argc, int *argt)
- int arg_type;
- if (argc < 2)
- return E_ARG_LO;
- if (argc > 2)
- return E_ARG_HI;
- arg_type = CELL_TYPE;
- arg_type = FCELL_TYPE;
- arg_type = DCELL_TYPE;
- argt[1] = arg_type;
- argt[2] = arg_type;
- return 0;
-int c_logop(int argc, int *argt)
- int i;
- if (argc < 1)
- return E_ARG_LO;
- if (argt[i] != CELL_TYPE)
- return E_ARG_TYPE;
- return 0;
-int c_shiftop(int argc, int *argt)
- if (argc < 2)
- return E_ARG_LO;
- if (argc > 2)
- return E_ARG_HI;
- if (argt[1] != CELL_TYPE || argt[2] != CELL_TYPE)
- return 0;
Modified: grass/trunk/raster/r.mapcalc/evaluate.c
--- grass/trunk/raster/r.mapcalc/evaluate.c 2016-01-25 09:27:55 UTC (rev 67657)
+++ grass/trunk/raster/r.mapcalc/evaluate.c 2016-01-25 09:28:12 UTC (rev 67658)
@@ -13,7 +13,7 @@
int current_depth, current_row;
-int depths, rows, columns;
+int depths, rows;
Modified: grass/trunk/raster/r.mapcalc/expression.c
--- grass/trunk/raster/r.mapcalc/expression.c 2016-01-25 09:27:55 UTC (rev 67657)
+++ grass/trunk/raster/r.mapcalc/expression.c 2016-01-25 09:28:12 UTC (rev 67658)
@@ -19,10 +19,14 @@
int i;
- for (i = 0; func_descs[i].name; i++) {
- if (strcmp(name, func_descs[i].name) == 0)
- return &func_descs[i];
+ for (i = 0; local_func_descs[i].name; i++) {
+ if (strcmp(name, local_func_descs[i].name) == 0)
+ return &local_func_descs[i];
+ for (i = 0; calc_func_descs[i].name; i++) {
+ if (strcmp(name, calc_func_descs[i].name) == 0)
+ return &calc_func_descs[i];
return NULL;
Modified: grass/trunk/raster/r.mapcalc/expression.h
--- grass/trunk/raster/r.mapcalc/expression.h 2016-01-25 09:27:55 UTC (rev 67657)
+++ grass/trunk/raster/r.mapcalc/expression.h 2016-01-25 09:28:12 UTC (rev 67658)
@@ -2,19 +2,10 @@
#ifndef __EXPRESSION_H_
#define __EXPRESSION_H_
struct expr_list;
-typedef int func_t(int argc, const int *argt, void **args);
-typedef int args_t(int argc, int *argt);
-#define E_ARG_LO 1
-#define E_ARG_HI 2
-#define E_ARG_TYPE 3
-#define E_RES_TYPE 4
-#define E_INV_TYPE 5
-#define E_ARG_NUM 6
-#define E_WTF 99
typedef enum expr_t
expr_type_constant,
@@ -85,13 +76,6 @@
struct expr_list *next;
} expr_list;
-typedef struct func_desc
- const char *name;
- args_t *check_args;
- func_t *func;
-} func_desc;
extern int list_length(expr_list * l);
extern void define_variable(expression * e);
extern char *composite(const char *name, const char *mapset);
@@ -110,14 +94,6 @@
extern expression *function(const char *name, expr_list * args);
extern expression *binding(const char *var, expression * val);
-extern func_desc func_descs[];
+extern func_desc local_func_descs[];
-#define IS_NULL_C(x) (Rast_is_c_null_value((x)))
-#define IS_NULL_F(x) (Rast_is_f_null_value((x)))
-#define IS_NULL_D(x) (Rast_is_d_null_value((x)))
-#define SET_NULL_C(x) (Rast_set_c_null_value((x),1))
-#define SET_NULL_F(x) (Rast_set_f_null_value((x),1))
-#define SET_NULL_D(x) (Rast_set_d_null_value((x),1))
#endif /* __EXPRESSION_H_ */
Modified: grass/trunk/raster/r.mapcalc/func_proto.h
--- grass/trunk/raster/r.mapcalc/func_proto.h 2016-01-25 09:27:55 UTC (rev 67657)
+++ grass/trunk/raster/r.mapcalc/func_proto.h 2016-01-25 09:28:12 UTC (rev 67658)
@@ -1,104 +1,9 @@
#include "expression.h"
-extern func_t f_add;
-extern func_t f_sub;
-extern func_t f_mul;
-extern func_t f_div;
-extern func_t f_mod;
-extern func_t f_pow;
-extern args_t c_binop;
-extern func_t f_neg;
-extern func_t f_abs;
-extern args_t c_unop;
-extern func_t f_gt;
-extern func_t f_ge;
-extern func_t f_lt;
-extern func_t f_le;
-extern func_t f_eq;
-extern func_t f_ne;
-extern args_t c_cmpop;
-extern func_t f_and;
-extern func_t f_or;
-extern func_t f_and2;
-extern func_t f_or2;
-extern func_t f_bitand;
-extern func_t f_bitor;
-extern func_t f_bitxor;
-extern args_t c_logop;
-extern func_t f_shiftl;
-extern func_t f_shiftr;
-extern func_t f_shiftru;
-extern args_t c_shiftop;
-extern func_t f_not;
-extern func_t f_bitnot;
-extern args_t c_not;
-extern func_t f_sqrt;
-extern func_t f_sin;
-extern func_t f_cos;
-extern func_t f_tan;
-extern func_t f_acos;
-extern func_t f_asin;
-extern args_t c_double1;
-extern func_t f_exp;
-extern func_t f_log;
-extern func_t f_atan;
-extern args_t c_double12;
-extern func_t f_int;
-extern args_t c_int;
-extern func_t f_float;
-extern args_t c_float;
-extern func_t f_double;
-extern args_t c_double;
-extern func_t f_round;
-extern args_t c_round;
-extern func_t f_eval;
-extern args_t c_eval;
-extern func_t f_if;
-extern args_t c_if;
-extern func_t f_isnull;
-extern args_t c_isnull;
-extern func_t f_graph;
-extern func_t f_graph2;
-extern args_t c_graph;
-extern func_t f_min;
-extern func_t f_max;
-extern func_t f_nmin;
-extern func_t f_nmax;
-extern args_t c_varop;
-extern func_t f_median;
-extern func_t f_nmedian;
-extern args_t c_median;
-extern func_t f_mode;
-extern func_t f_nmode;
-extern args_t c_mode;
-extern func_t f_rand;
-extern func_t f_null;
extern func_t f_col;
extern func_t f_row;
extern func_t f_depth;
-extern args_t c_int0;
extern func_t f_x;
extern func_t f_y;
@@ -106,4 +11,3 @@
extern func_t f_ewres;
extern func_t f_nsres;
extern func_t f_tbres;
-extern args_t c_double0;
Modified: grass/trunk/raster/r.mapcalc/function.c
--- grass/trunk/raster/r.mapcalc/function.c 2016-01-25 09:27:55 UTC (rev 67657)
+++ grass/trunk/raster/r.mapcalc/function.c 2016-01-25 09:28:12 UTC (rev 67658)
@@ -7,79 +7,7 @@
-func_desc func_descs[] = {
- {"add", c_varop, f_add},
- {"sub", c_binop, f_sub},
- {"mul", c_varop, f_mul},
- {"div", c_binop, f_div},
- {"mod", c_binop, f_mod},
- {"pow", c_binop, f_pow},
- {"neg", c_unop, f_neg},
- {"abs", c_unop, f_abs},
- {"gt", c_cmpop, f_gt},
- {"ge", c_cmpop, f_ge},
- {"lt", c_cmpop, f_lt},
- {"le", c_cmpop, f_le},
- {"eq", c_cmpop, f_eq},
- {"ne", c_cmpop, f_ne},
- {"and", c_logop, f_and},
- {"or", c_logop, f_or},
- {"and2", c_logop, f_and2},
- {"or2", c_logop, f_or2},
- {"not", c_not, f_not},
- {"bitand", c_logop, f_bitand},
- {"bitor", c_logop, f_bitor},
- {"xor", c_logop, f_bitxor},
- {"shiftl", c_shiftop, f_shiftl},
- {"shiftr", c_shiftop, f_shiftr},
- {"shiftru", c_shiftop, f_shiftru},
- {"bitnot", c_not, f_bitnot},
- {"sqrt", c_double1, f_sqrt},
- {"sin", c_double1, f_sin},
- {"cos", c_double1, f_cos},
- {"tan", c_double1, f_tan},
- {"acos", c_double1, f_acos},
- {"asin", c_double1, f_asin},
- {"exp", c_double12, f_exp},
- {"log", c_double12, f_log},
- {"atan", c_double12, f_atan},
- {"int", c_int, f_int},
- {"float", c_float, f_float},
- {"double", c_double, f_double},
- {"round", c_round, f_round},
- {"eval", c_eval, f_eval},
- {"if", c_if, f_if},
- {"isnull", c_isnull, f_isnull},
- {"max", c_varop, f_max},
- {"min", c_varop, f_min},
- {"median", c_varop, f_median},
- {"mode", c_varop, f_mode},
- {"nmax", c_varop, f_nmax},
- {"nmin", c_varop, f_nmin},
- {"nmedian", c_varop, f_nmedian},
- {"nmode", c_varop, f_nmode},
- {"graph", c_graph, f_graph},
- {"graph2", c_graph, f_graph2},
- {"rand", c_binop, f_rand},
- {"null", c_int0, f_null},
+func_desc local_func_descs[] = {
{"col", c_int0, f_col},
{"row", c_int0, f_row},
{"depth", c_int0, f_depth},
@@ -87,9 +15,11 @@
{"x", c_double0, f_x},
{"y", c_double0, f_y},
{"z", c_double0, f_z},
{"ewres", c_double0, f_ewres},
{"nsres", c_double0, f_nsres},
{"tbres", c_double0, f_tbres},
{NULL, NULL, NULL}
@@ -98,7 +28,9 @@
int i;
fprintf(stderr, _("Known functions:"));
- fprintf(stderr, "%c%-10s", i % 7 ? ' ' : '\n', func_descs[i].name);
+ fprintf(stderr, "%c%-10s", i % 7 ? ' ' : '\n', calc_func_descs[i].name);
+ fprintf(stderr, "%c%-10s", i % 7 ? ' ' : '\n', local_func_descs[i].name);
fprintf(stderr, "\n");
Modified: grass/trunk/raster/r.mapcalc/globals.h
--- grass/trunk/raster/r.mapcalc/globals.h 2016-01-25 09:27:55 UTC (rev 67657)
+++ grass/trunk/raster/r.mapcalc/globals.h 2016-01-25 09:28:12 UTC (rev 67658)
@@ -2,14 +2,11 @@
#ifndef __GLOBALS_H_
#define __GLOBALS_H_
-extern volatile int floating_point_exception;
-extern volatile int floating_point_exception_occurred;
-extern int overflow_occurred;
extern int overwrite_flag;
extern long seed_value;
extern long seeded;
extern int current_depth, current_row;
-extern int depths, rows, columns;
+extern int depths, rows;
#endif /* __GLOBALS_H_ */
Modified: grass/trunk/raster/r.mapcalc/main.c
--- grass/trunk/raster/r.mapcalc/main.c 2016-01-25 09:27:55 UTC (rev 67657)
+++ grass/trunk/raster/r.mapcalc/main.c 2016-01-25 09:28:12 UTC (rev 67658)
@@ -14,7 +14,6 @@
#include <unistd.h>
-#include <signal.h>
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
@@ -25,12 +24,8 @@
-int overflow_occurred;
int overwrite_flag;
-volatile int floating_point_exception;
-volatile int floating_point_exception_occurred;
long seed_value;
long seeded;
@@ -40,47 +35,6 @@
-static RETSIGTYPE handle_fpe(int n)
- floating_point_exception = 1;
- floating_point_exception_occurred = 1;
-static void pre_exec(void)
-#ifndef __MINGW32__
-#ifdef SIGFPE
- struct sigaction act;
- act.sa_handler = &handle_fpe;
- act.sa_flags = 0;
- sigemptyset(&act.sa_mask);
- sigaction(SIGFPE, &act, NULL);
-#endif
-#endif
- floating_point_exception_occurred = 0;
- overflow_occurred = 0;
-static void post_exec(void)
-#ifdef SIGFPE
- act.sa_handler = SIG_DFL;
- act.sa_flags = 0;
-#endif
-#endif
static expr_list *parse_file(const char *filename)
expr_list *res;
@@ -206,11 +160,6 @@
all_ok = 0;
- if (overflow_occurred) {
- G_warning(_("Overflow occurred in the calculation"));
- all_ok = 0;
return all_ok ? EXIT_SUCCESS : EXIT_FAILURE;
Modified: grass/trunk/raster/r.mapcalc/map.c
--- grass/trunk/raster/r.mapcalc/map.c 2016-01-25 09:27:55 UTC (rev 67657)
+++ grass/trunk/raster/r.mapcalc/map.c 2016-01-25 09:28:12 UTC (rev 67658)
@@ -14,6 +14,7 @@
#include <grass/raster.h>
#include <grass/btree.h>
#include <grass/glocale.h>
#include "globals.h"
@@ -29,6 +30,7 @@
rows = Rast_window_rows();
columns = Rast_window_cols();
+ calc_init(columns);
depths = 1;
Modified: grass/trunk/raster/r.mapcalc/map3.c
--- grass/trunk/raster/r.mapcalc/map3.c 2016-01-25 09:27:55 UTC (rev 67657)
+++ grass/trunk/raster/r.mapcalc/map3.c 2016-01-25 09:28:12 UTC (rev 67658)
@@ -10,6 +10,7 @@
#include <grass/raster3d.h>
@@ -27,6 +28,7 @@
rows = current_region3.rows;
columns = current_region3.cols;
depths = current_region3.depths;
Deleted: grass/trunk/raster/r.mapcalc/xabs.c
--- grass/trunk/raster/r.mapcalc/xabs.c 2016-01-25 09:27:55 UTC (rev 67657)
+++ grass/trunk/raster/r.mapcalc/xabs.c 2016-01-25 09:28:12 UTC (rev 67658)
@@ -1,69 +0,0 @@
-#include <math.h>
-#include <grass/gis.h>
-#include <grass/raster.h>
-#include "globals.h"
-#include "expression.h"
-abs(x)
- absolute value. if x is negative returns -x
-int f_abs(int argc, const int *argt, void **args)
- int i;
- if (argc < 1)
- return E_ARG_LO;
- if (argc > 1)
- return E_ARG_HI;
- if (argt[0] != argt[1])
- return E_RES_TYPE;
- switch (argt[1]) {
- case CELL_TYPE:
- CELL *res = args[0];
- CELL *arg1 = args[1];
- for (i = 0; i < columns; i++)
- if (IS_NULL_C(&arg1[i]))
- SET_NULL_C(&res[i]);
- else
- res[i] = arg1[i] < 0 ? -arg1[i]
- : arg1[i];
- return 0;
- case FCELL_TYPE:
- FCELL *res = args[0];
- FCELL *arg1 = args[1];
- if (IS_NULL_F(&arg1[i]))
- SET_NULL_F(&res[i]);
- else
- res[i] = (FCELL) fabs(arg1[i]);
- return 0;
- case DCELL_TYPE:
- DCELL *res = args[0];
- DCELL *arg1 = args[1];
- if (IS_NULL_D(&arg1[i]))
- SET_NULL_D(&res[i]);
- else
- res[i] = fabs(arg1[i]);
- return 0;
- default:
- return E_INV_TYPE;
Deleted: grass/trunk/raster/r.mapcalc/xacos.c
--- grass/trunk/raster/r.mapcalc/xacos.c 2016-01-25 09:27:55 UTC (rev 67657)
+++ grass/trunk/raster/r.mapcalc/xacos.c 2016-01-25 09:28:12 UTC (rev 67658)
@@ -1,50 +0,0 @@
-#include <stdlib.h>
-#include <math.h>
-acos(x) [0 and PI]
- if floating point exception occurs during the evaluation of acos(x)
- the result is NULL
- note: result is in degrees
-#define RADIANS_TO_DEGREES (180.0 / M_PI)
-int f_acos(int argc, const int *argt, void **args)
- int i;
- if (argc < 1)
- return E_ARG_LO;
- if (argc > 1)
- return E_ARG_HI;
- if (argt[0] != DCELL_TYPE)
- if (argt[1] != DCELL_TYPE)
- else {
- floating_point_exception = 0;
- res[i] = RADIANS_TO_DEGREES * acos(arg1[i]);
- if (floating_point_exception)
- return 0;
Deleted: grass/trunk/raster/r.mapcalc/xadd.c
--- grass/trunk/raster/r.mapcalc/xadd.c 2016-01-25 09:27:55 UTC (rev 67657)
+++ grass/trunk/raster/r.mapcalc/xadd.c 2016-01-25 09:28:12 UTC (rev 67658)
@@ -1,78 +0,0 @@
-add(a,b,c,...) = a + b + c + ...
-int f_add(int argc, const int *argt, void **args)
- int i, j;
- if (argc < 1)
- return E_ARG_LO;
- if (argt[i] != argt[0])
- switch (argt[0]) {
- case CELL_TYPE:
- CELL **argz = (CELL **) args;
- for (i = 0; i < columns; i++) {
- res[i] = 0;
- for (j = 1; j <= argc; j++) {
- if (IS_NULL_C(&argz[j][i])) {
- break;
- res[i] += argz[j][i];
- return 0;
- case FCELL_TYPE:
- FCELL **argz = (FCELL **) args;
- res[i] = 0;
- if (IS_NULL_F(&argz[j][i])) {
- break;
- return 0;
- case DCELL_TYPE:
- DCELL **argz = (DCELL **) args;
- res[i] = 0;
- if (IS_NULL_D(&argz[j][i])) {
- break;
- return 0;
- default:
Deleted: grass/trunk/raster/r.mapcalc/xand.c
--- grass/trunk/raster/r.mapcalc/xand.c 2016-01-25 09:27:55 UTC (rev 67657)
+++ grass/trunk/raster/r.mapcalc/xand.c 2016-01-25 09:28:12 UTC (rev 67658)
@@ -1,41 +0,0 @@
-and(a,b,c,...) = a && b && c && ...
-int f_and(int argc, const int *argt, void **args)
- int i, j;
- if (argc < 1)
- return E_ARG_LO;
- if (argt[0] != CELL_TYPE)
- res[i] = 1;
- break;
- if (!argz[j][i])
- res[i] = 0;
- return 0;
Deleted: grass/trunk/raster/r.mapcalc/xand2.c
--- grass/trunk/raster/r.mapcalc/xand2.c 2016-01-25 09:27:55 UTC (rev 67657)
+++ grass/trunk/raster/r.mapcalc/xand2.c 2016-01-25 09:28:12 UTC (rev 67658)
@@ -1,48 +0,0 @@
-and2(a,b,c,...) = a && b && c && ...
-Differs from and() in that the boolean axioms:
- false && x == false
- x && false == false
-hold even when x is null.
-int f_and2(int argc, const int *argt, void **args)
- int i, j;
- if (argc < 1)
- return E_ARG_LO;
- res[i] = 1;
- if (!IS_NULL_C(&argz[j][i]) && !argz[j][i]) {
- res[i] = 0;
- break;
- return 0;
Deleted: grass/trunk/raster/r.mapcalc/xasin.c
--- grass/trunk/raster/r.mapcalc/xasin.c 2016-01-25 09:27:55 UTC (rev 67657)
+++ grass/trunk/raster/r.mapcalc/xasin.c 2016-01-25 09:28:12 UTC (rev 67658)
@@ -1,50 +0,0 @@
-#include <math.h>
-asin(x) range [-90,90]
- if floating point exception occurs during the evaluation of asin(x)
-int f_asin(int argc, const int *argt, void **args)
- int i;
- if (argc < 1)
- return E_ARG_LO;
- if (argc > 1)
- return E_ARG_HI;
- else {
- res[i] = RADIANS_TO_DEGREES * asin(arg1[i]);
- return 0;
Deleted: grass/trunk/raster/r.mapcalc/xatan.c
--- grass/trunk/raster/r.mapcalc/xatan.c 2016-01-25 09:27:55 UTC (rev 67657)
+++ grass/trunk/raster/r.mapcalc/xatan.c 2016-01-25 09:28:12 UTC (rev 67658)
@@ -1,66 +0,0 @@
-#include <math.h>
-atan(x) range [-90,90]
-atan(x,y) = atan(y/x) range[0,360]
- if floating point exception occurs during the evaluation of atan(x)
-int f_atan(int argc, const int *argt, void **args)
- DCELL *arg2;
- int i;
- if (argc < 1)
- return E_ARG_LO;
- if (argc > 2)
- return E_ARG_HI;
- if (argc > 1 && argt[2] != DCELL_TYPE)
- arg2 = (argc > 1) ? args[2] : NULL;
- else if (argc > 1 && IS_NULL_D(&arg2[i]))
- else {
- if (argc == 1)
- res[i] = RADIANS_TO_DEGREES * atan(arg1[i]);
- else {
- res[i] = RADIANS_TO_DEGREES * atan2(arg2[i], arg1[i]);
- if (res[i] < 0)
- res[i] += 360.0;
- return 0;
Deleted: grass/trunk/raster/r.mapcalc/xbitand.c
--- grass/trunk/raster/r.mapcalc/xbitand.c 2016-01-25 09:27:55 UTC (rev 67657)
+++ grass/trunk/raster/r.mapcalc/xbitand.c 2016-01-25 09:28:12 UTC (rev 67658)
@@ -1,40 +0,0 @@
-bitand(a,b,c,...) = a & b & c & ...
-int f_bitand(int argc, const int *argt, void **args)
- int i, j;
- if (argc < 1)
- return E_ARG_LO;
- res[i] = ~0;
- break;
- res[i] &= argz[j][i];
- return 0;
Deleted: grass/trunk/raster/r.mapcalc/xbitnot.c
--- grass/trunk/raster/r.mapcalc/xbitnot.c 2016-01-25 09:27:55 UTC (rev 67657)
+++ grass/trunk/raster/r.mapcalc/xbitnot.c 2016-01-25 09:28:12 UTC (rev 67658)
@@ -1,37 +0,0 @@
-bitnot(a) = ~a
-int f_bitnot(int argc, const int *argt, void **args)
- int i;
- if (argc < 1)
- return E_ARG_LO;
- if (argc > 1)
- return E_ARG_HI;
- if (argt[1] != CELL_TYPE)
- else
- res[i] = ~arg1[i];
- return 0;
Deleted: grass/trunk/raster/r.mapcalc/xbitor.c
--- grass/trunk/raster/r.mapcalc/xbitor.c 2016-01-25 09:27:55 UTC (rev 67657)
+++ grass/trunk/raster/r.mapcalc/xbitor.c 2016-01-25 09:28:12 UTC (rev 67658)
@@ -1,40 +0,0 @@
-bitor(a,b,c,...) = a | b | c | ...
-int f_bitor(int argc, const int *argt, void **args)
- int i, j;
- if (argc < 1)
- return E_ARG_LO;
- res[i] = 0;
- break;
- res[i] |= argz[j][i];
- return 0;
Deleted: grass/trunk/raster/r.mapcalc/xbitxor.c
--- grass/trunk/raster/r.mapcalc/xbitxor.c 2016-01-25 09:27:55 UTC (rev 67657)
+++ grass/trunk/raster/r.mapcalc/xbitxor.c 2016-01-25 09:28:12 UTC (rev 67658)
@@ -1,40 +0,0 @@
-bitxor(a,b,c,...) = a ^ b ^ c ^ ...
-int f_bitxor(int argc, const int *argt, void **args)
- int i, j;
- if (argc < 1)
- return E_ARG_LO;
- res[i] = 0;
- break;
- res[i] ^= argz[j][i];
- return 0;
Deleted: grass/trunk/raster/r.mapcalc/xcos.c
--- grass/trunk/raster/r.mapcalc/xcos.c 2016-01-25 09:27:55 UTC (rev 67657)
+++ grass/trunk/raster/r.mapcalc/xcos.c 2016-01-25 09:28:12 UTC (rev 67658)
@@ -1,49 +0,0 @@
-#include <math.h>
-cos(x)
- if floating point exception occurs during the evaluation of cos(x)
- note: x is in degrees.
-#define DEGREES_TO_RADIANS (M_PI / 180.0)
-int f_cos(int argc, const int *argt, void **args)
- int i;
- if (argc < 1)
- return E_ARG_LO;
- if (argc > 1)
- return E_ARG_HI;
- else {
- res[i] = cos(arg1[i] * DEGREES_TO_RADIANS);
- return 0;
Deleted: grass/trunk/raster/r.mapcalc/xdiv.c
--- grass/trunk/raster/r.mapcalc/xdiv.c 2016-01-25 09:27:55 UTC (rev 67657)
+++ grass/trunk/raster/r.mapcalc/xdiv.c 2016-01-25 09:28:12 UTC (rev 67658)
@@ -1,81 +0,0 @@
-div(a,b) = a / b
-int f_div(int argc, const int *argt, void **args)
- int i;
- if (argc < 2)
- return E_ARG_LO;
- if (argc > 2)
- return E_ARG_HI;
- if (argt[1] != argt[0] || argt[2] != argt[0])
- case CELL_TYPE:
- CELL *arg2 = args[2];
- if (IS_NULL_C(&arg1[i]) || IS_NULL_C(&arg2[i]) ||
- arg2[i] == 0)
- else
- res[i] = arg1[i] / arg2[i];
- return 0;
- case FCELL_TYPE:
- FCELL *arg2 = args[2];
- if (IS_NULL_F(&arg1[i]) || IS_NULL_F(&arg2[i]) ||
- arg2[i] == 0.0f)
- else {
- return 0;
- case DCELL_TYPE:
- DCELL *arg2 = args[2];
- if (IS_NULL_D(&arg1[i]) || IS_NULL_D(&arg2[i]) ||
- arg2[i] == 0.0)
- else {
- return 0;
- default:
Deleted: grass/trunk/raster/r.mapcalc/xdouble.c
--- grass/trunk/raster/r.mapcalc/xdouble.c 2016-01-25 09:27:55 UTC (rev 67657)
+++ grass/trunk/raster/r.mapcalc/xdouble.c 2016-01-25 09:28:12 UTC (rev 67658)
@@ -1,78 +0,0 @@
-double(x)
- converts x to double
-int f_double(int argc, const int *argt, void **args)
- int i;
- if (argc < 1)
- return E_ARG_LO;
- if (argc > 1)
- return E_ARG_HI;
- case CELL_TYPE:
- else
- res[i] = (DCELL) arg1[i];
- return 0;
- case FCELL_TYPE:
- else
- return 0;
- case DCELL_TYPE:
- else
- return 0;
- default:
-int c_double(int argc, int *argt)
- if (argc < 1)
- return E_ARG_LO;
- if (argc > 1)
- return E_ARG_HI;
- /* argt[1] = argt[1]; */
- return 0;
Deleted: grass/trunk/raster/r.mapcalc/xeq.c
--- grass/trunk/raster/r.mapcalc/xeq.c 2016-01-25 09:27:55 UTC (rev 67657)
+++ grass/trunk/raster/r.mapcalc/xeq.c 2016-01-25 09:28:12 UTC (rev 67658)
@@ -1,72 +0,0 @@
-eq(a,b) = a == b
-int f_eq(int argc, const int *argt, void **args)
- int i;
- if (argc < 2)
- return E_ARG_LO;
- if (argc > 2)
- return E_ARG_HI;
- for (i = 2; i <= argc; i++)
- if (argt[i] != argt[1])
- case CELL_TYPE:
- if (IS_NULL_C(&arg1[i]) || IS_NULL_C(&arg2[i]))
- else
- res[i] = arg1[i] == arg2[i];
- return 0;
- case FCELL_TYPE:
- if (IS_NULL_F(&arg1[i]) || IS_NULL_F(&arg2[i]))
- else
- return 0;
- case DCELL_TYPE:
- if (IS_NULL_D(&arg1[i]) || IS_NULL_D(&arg2[i]))
- else
- return 0;
- default:
Deleted: grass/trunk/raster/r.mapcalc/xeval.c
--- grass/trunk/raster/r.mapcalc/xeval.c 2016-01-25 09:27:55 UTC (rev 67657)
+++ grass/trunk/raster/r.mapcalc/xeval.c 2016-01-25 09:28:12 UTC (rev 67658)
@@ -1,75 +0,0 @@
-eval(..,..,..,x) = x
- return last argument
-int f_eval(int argc, const int *argt, void **args)
- int i;
- if (argc < 1)
- return E_ARG_LO;
- if (argt[0] != argt[argc])
- switch (argt[argc]) {
- case CELL_TYPE:
- CELL *arg1 = args[argc];
- else
- res[i] = arg1[i];
- return 0;
- case FCELL_TYPE:
- FCELL *arg1 = args[argc];
- else
- res[i] = arg1[i];
- return 0;
- case DCELL_TYPE:
- DCELL *arg1 = args[argc];
- else
- res[i] = arg1[i];
- return 0;
- default:
-int c_eval(int argc, int *argt)
- if (argc < 1)
- return E_ARG_LO;
- argt[0] = argt[argc];
- return 0;
Deleted: grass/trunk/raster/r.mapcalc/xexp.c
--- grass/trunk/raster/r.mapcalc/xexp.c 2016-01-25 09:27:55 UTC (rev 67657)
+++ grass/trunk/raster/r.mapcalc/xexp.c 2016-01-25 09:28:12 UTC (rev 67658)
@@ -1,55 +0,0 @@
-#include <math.h>
-exp(x) computes e raised to power x
-exp(x,y) computes x raised to power y
- if floating point exception occurs during the evaluation of exp(x)
- or exp(x,y) the result is NULL
-int f_exp(int argc, const int *argt, void **args)
- DCELL *arg2;
- int i;
- if (argc < 1)
- return E_ARG_LO;
- if (argc > 2)
- return E_ARG_HI;
- else if (argc > 1 && arg1[i] < 0 && arg2[i] != ceil(arg2[i]))
- else {
- res[i] = (argc > 1)
- ? pow(arg1[i], arg2[i])
- : exp(arg1[i]);
- return 0;
Deleted: grass/trunk/raster/r.mapcalc/xfloat.c
--- grass/trunk/raster/r.mapcalc/xfloat.c 2016-01-25 09:27:55 UTC (rev 67657)
+++ grass/trunk/raster/r.mapcalc/xfloat.c 2016-01-25 09:28:12 UTC (rev 67658)
@@ -1,78 +0,0 @@
-float(x)
- converts x to float
-int f_float(int argc, const int *argt, void **args)
- int i;
- if (argc < 1)
- return E_ARG_LO;
- if (argc > 1)
- return E_ARG_HI;
- if (argt[0] != FCELL_TYPE)
- case CELL_TYPE:
- else
- res[i] = (FCELL) arg1[i];
- return 0;
- case FCELL_TYPE:
- else
- return 0;
- case DCELL_TYPE:
- else
- return 0;
- default:
-int c_float(int argc, int *argt)
- if (argc < 1)
- return E_ARG_LO;
- if (argc > 1)
- return E_ARG_HI;
- return 0;
Deleted: grass/trunk/raster/r.mapcalc/xge.c
--- grass/trunk/raster/r.mapcalc/xge.c 2016-01-25 09:27:55 UTC (rev 67657)
+++ grass/trunk/raster/r.mapcalc/xge.c 2016-01-25 09:28:12 UTC (rev 67658)
@@ -1,65 +0,0 @@
-ge(a,b) = a >= b
-int f_ge(int argc, const int *argt, void **args)
- int i;
- if (argc < 2)
- return E_ARG_LO;
- if (argc > 2)
- return E_ARG_HI;
- case CELL_TYPE:
- else
- res[i] = arg1[i] >= arg2[i];
- return 0;
- case FCELL_TYPE:
- else
- return 0;
- case DCELL_TYPE:
- else
- return 0;
- default:
Deleted: grass/trunk/raster/r.mapcalc/xgraph.c
--- grass/trunk/raster/r.mapcalc/xgraph.c 2016-01-25 09:27:55 UTC (rev 67657)
+++ grass/trunk/raster/r.mapcalc/xgraph.c 2016-01-25 09:28:12 UTC (rev 67658)
@@ -1,180 +0,0 @@
-graph(x, x1,y1, x2,y2, ... xn,yn) returns y value based on graph
-described by the x,y pairs.
-int c_graph(int argc, int *argt)
- int i;
- if (argc < 3)
- return E_ARG_LO;
- if (argc % 2 == 0)
- return E_ARG_NUM;
- for (i = 0; i <= argc; i++)
- argt[i] = DCELL_TYPE;
- return 0;
-int f_graph(int argc, const int *argt, void **args)
- DCELL *res = argz[0];
- int n = (argc - 1) / 2;
- int i, j;
- if (argc < 3)
- return E_ARG_LO;
- return E_ARG_NUM;
- if (argt[i] != DCELL_TYPE)
-#define X(j) (argz[2 + 2 * (j) + 0][i])
-#define Y(j) (argz[2 + 2 * (j) + 1][i])
-#define x (argz[1][i])
- if (IS_NULL_D(&x))
- goto null;
- for (j = 0; j < n; j++)
- if (IS_NULL_D(&X(j)))
- goto null;
- for (j = 0; j < n - 1; j++)
- if (X(j + 1) <= X(j))
- goto null;
- if (x <= X(0)) {
- if (IS_NULL_D(&Y(0)))
- goto null;
- res[i] = Y(0);
- continue;
- if (x >= X(n - 1)) {
- if (IS_NULL_D(&Y(n - 1)))
- goto null;
- res[i] = Y(n - 1);
- continue;
- for (j = 0; j < n - 1; j++) {
- if (x > X(j + 1))
- continue;
- if (IS_NULL_D(&Y(j)) || IS_NULL_D(&Y(j + 1)))
- goto null;
- res[i] =
- Y(j) + (x - X(j)) * (Y(j + 1) - Y(j)) / (X(j + 1) - X(j));
- break;
-#undef X
-#undef Y
-#undef x
- continue;
- null:
- return 0;
-int f_graph2(int argc, const int *argt, void **args)
- int i, j;
- if (argc < 3)
- return E_ARG_LO;
- return E_ARG_NUM;
-#define X(j) (argz[2 + (j) + 0][i])
-#define Y(j) (argz[2 + (j) + n][i])
- goto null;
- goto null;
- goto null;
- if (x <= X(0)) {
- goto null;
- res[i] = Y(0);
- continue;
- goto null;
- continue;
- if (x > X(j + 1))
- continue;
- goto null;
- res[i] =
- break;
-#undef X
-#undef Y
-#undef x
- continue;
- null:
- return 0;
Deleted: grass/trunk/raster/r.mapcalc/xgt.c
--- grass/trunk/raster/r.mapcalc/xgt.c 2016-01-25 09:27:55 UTC (rev 67657)
+++ grass/trunk/raster/r.mapcalc/xgt.c 2016-01-25 09:28:12 UTC (rev 67658)
@@ -1,65 +0,0 @@
-gt(a,b) = a > b
-int f_gt(int argc, const int *argt, void **args)
- int i;
- if (argc < 2)
- return E_ARG_LO;
- if (argc > 2)
- return E_ARG_HI;
- case CELL_TYPE:
- else
- res[i] = arg1[i] > arg2[i];
- return 0;
- case FCELL_TYPE:
- else
- return 0;
- case DCELL_TYPE:
- else
- return 0;
- default:
Deleted: grass/trunk/raster/r.mapcalc/xif.c
--- grass/trunk/raster/r.mapcalc/xif.c 2016-01-25 09:27:55 UTC (rev 67657)
+++ grass/trunk/raster/r.mapcalc/xif.c 2016-01-25 09:28:12 UTC (rev 67658)
@@ -1,305 +0,0 @@
- if(a) 1,0,1 1 if a is non zero, 0 otherwise
- if(a,b) b,0,b b if a is non zero, 0 otherwise
- if(a,b,c) b,c,b b if a is non zero, c otherwise
- if(a,b,c,d) d,c,b b if a is positive, c if a is zero, d if a is negative
-static int f_if_i(int argc, const int *argt, void **args)
- CELL *arg2 = (argc >= 2) ? args[2] : NULL;
- CELL *arg3 = (argc >= 3) ? args[3] : NULL;
- CELL *arg4 = (argc >= 4) ? args[4] : NULL;
- int i;
- switch (argc) {
- case 0:
- return E_ARG_LO;
- case 1:
- else
- res[i] = arg1[i] != 0.0 ? 1 : 0;
- break;
- case 2:
- else if (arg1[i] == 0.0)
- res[i] = 0;
- else {
- if (IS_NULL_C(&arg2[i]))
- else
- res[i] = arg2[i];
- break;
- case 3:
- else if (arg1[i] == 0.0) {
- if (IS_NULL_C(&arg3[i]))
- else
- res[i] = arg3[i];
- else {
- else
- res[i] = arg2[i];
- break;
- case 4:
- else
- res[i] = arg3[i];
- else if (arg1[i] > 0.0) {
- else
- res[i] = arg2[i];
- else { /* (arg1[i] < 0.0) */
- if (IS_NULL_C(&arg4[i]))
- else
- res[i] = arg4[i];
- break;
- default:
- return E_ARG_HI;
- return 0;
-static int f_if_f(int argc, const int *argt, void **args)
- FCELL *arg2 = (argc >= 2) ? args[2] : NULL;
- FCELL *arg3 = (argc >= 3) ? args[3] : NULL;
- FCELL *arg4 = (argc >= 4) ? args[4] : NULL;
- int i;
- switch (argc) {
- case 0:
- return E_ARG_LO;
- case 1:
- case 2:
- res[i] = 0.0;
- else {
- if (IS_NULL_F(&arg2[i]))
- else
- res[i] = arg2[i];
- break;
- case 3:
- if (IS_NULL_F(&arg3[i]))
- else
- res[i] = arg3[i];
- else {
- else
- res[i] = arg2[i];
- break;
- case 4:
- else
- res[i] = arg3[i];
- else
- res[i] = arg2[i];
- if (IS_NULL_F(&arg4[i]))
- else
- res[i] = arg4[i];
- break;
- default:
- return E_ARG_HI;
- return 0;
-static int f_if_d(int argc, const int *argt, void **args)
- DCELL *arg2 = (argc >= 2) ? args[2] : NULL;
- DCELL *arg3 = (argc >= 3) ? args[3] : NULL;
- DCELL *arg4 = (argc >= 4) ? args[4] : NULL;
- int i;
- switch (argc) {
- case 0:
- return E_ARG_LO;
- case 1:
- case 2:
- res[i] = 0.0;
- else {
- if (IS_NULL_D(&arg2[i]))
- else
- res[i] = arg2[i];
- break;
- case 3:
- if (IS_NULL_D(&arg3[i]))
- else
- res[i] = arg3[i];
- else {
- else
- res[i] = arg2[i];
- break;
- case 4:
- else
- res[i] = arg3[i];
- else
- res[i] = arg2[i];
- if (IS_NULL_D(&arg4[i]))
- else
- res[i] = arg4[i];
- break;
- default:
- return E_ARG_HI;
- return 0;
-int f_if(int argc, const int *argt, void **args)
- if (argc < 1)
- return E_ARG_LO;
- if (argc > 4)
- return E_ARG_HI;
- if (argc >= 2 && argt[2] != argt[0])
- if (argc >= 3 && argt[3] != argt[0])
- if (argc >= 4 && argt[4] != argt[0])
- case CELL_TYPE:
- return f_if_i(argc, argt, args);
- case FCELL_TYPE:
- return f_if_f(argc, argt, args);
- case DCELL_TYPE:
- return f_if_d(argc, argt, args);
- default:
-int c_if(int argc, int *argt)
- if (argc < 1)
- return E_ARG_LO;
- if (argc > 4)
- return E_ARG_HI;
- if (argc >= 2 && argt[2] == FCELL_TYPE)
- if (argc >= 3 && argt[3] == FCELL_TYPE)
- if (argc >= 4 && argt[4] == FCELL_TYPE)
- if (argc >= 2 && argt[2] == DCELL_TYPE)
- if (argc >= 3 && argt[3] == DCELL_TYPE)
- if (argc >= 4 && argt[4] == DCELL_TYPE)
- if (argc >= 2)
- if (argc >= 3)
- argt[3] = argt[0];
- if (argc >= 4)
- argt[4] = argt[0];
- return 0;
Deleted: grass/trunk/raster/r.mapcalc/xint.c
--- grass/trunk/raster/r.mapcalc/xint.c 2016-01-25 09:27:55 UTC (rev 67657)
+++ grass/trunk/raster/r.mapcalc/xint.c 2016-01-25 09:28:12 UTC (rev 67658)
@@ -1,78 +0,0 @@
-int(x)
- converts x to int
-int f_int(int argc, const int *argt, void **args)
- int i;
- if (argc < 1)
- return E_ARG_LO;
- if (argc > 1)
- return E_ARG_HI;
- case CELL_TYPE:
- else
- res[i] = (CELL) arg1[i];
- return 0;
- case FCELL_TYPE:
- else
- return 0;
- case DCELL_TYPE:
- else
- return 0;
- default:
-int c_int(int argc, int *argt)
- if (argc < 1)
- return E_ARG_LO;
- if (argc > 1)
- return E_ARG_HI;
- return 0;
Deleted: grass/trunk/raster/r.mapcalc/xisnull.c
--- grass/trunk/raster/r.mapcalc/xisnull.c 2016-01-25 09:27:55 UTC (rev 67657)
+++ grass/trunk/raster/r.mapcalc/xisnull.c 2016-01-25 09:28:12 UTC (rev 67658)
@@ -1,66 +0,0 @@
-isnull(x)
- return 1 if x is null, 0 otherwise
-int f_isnull(int argc, const int *argt, void **args)
- int *res = args[0];
- int i;
- if (argc < 1)
- return E_ARG_LO;
- if (argc > 1)
- return E_ARG_HI;
- case CELL_TYPE:
- res[i] = IS_NULL_C(&arg1[i]) ? 1 : 0;
- return 0;
- case FCELL_TYPE:
- res[i] = IS_NULL_F(&arg1[i]) ? 1 : 0;
- return 0;
- case DCELL_TYPE:
- res[i] = IS_NULL_D(&arg1[i]) ? 1 : 0;
- return 0;
- default:
-int c_isnull(int argc, int *argt)
- if (argc < 1)
- return E_ARG_LO;
- if (argc > 1)
- return E_ARG_HI;
- return 0;
Deleted: grass/trunk/raster/r.mapcalc/xle.c
--- grass/trunk/raster/r.mapcalc/xle.c 2016-01-25 09:27:55 UTC (rev 67657)
+++ grass/trunk/raster/r.mapcalc/xle.c 2016-01-25 09:28:12 UTC (rev 67658)
@@ -1,65 +0,0 @@
-le(a,b) = a <= b
-int f_le(int argc, const int *argt, void **args)
- int i;
- if (argc < 2)
- return E_ARG_LO;
- if (argc > 2)
- return E_ARG_HI;
- case CELL_TYPE:
- else
- res[i] = arg1[i] <= arg2[i];
- return 0;
- case FCELL_TYPE:
- else
- return 0;
- case DCELL_TYPE:
- else
- return 0;
- default:
Deleted: grass/trunk/raster/r.mapcalc/xlog.c
--- grass/trunk/raster/r.mapcalc/xlog.c 2016-01-25 09:27:55 UTC (rev 67657)
+++ grass/trunk/raster/r.mapcalc/xlog.c 2016-01-25 09:28:12 UTC (rev 67658)
@@ -1,61 +0,0 @@
-#include <math.h>
-log(x)
-log(x,b)
- first form computes the natural log of x = ln(x)
- second form computes log of x base b = ln(x)/ln(b)
- if x is non-positive, or floating point exception occurs while
- computing ln(x), the result is NULL
- if b is non-positive, or 1.0, or floating point exception occurs while
- computing ln(b), the result is NULL
-int f_log(int argc, const int *argt, void **args)
- DCELL *arg2 = (argc >= 2) ? args[2] : (DCELL *) 0;
- int i;
- if (argc < 1)
- return E_ARG_LO;
- if (argc > 2)
- return E_ARG_HI;
- if (IS_NULL_D(&arg1[i]) || (arg1[i] <= 0.0))
- else if (argc > 1 && (IS_NULL_D(&arg2[i]) || (arg2[i] <= 0.0)))
- else {
- ? log(arg1[i]) / log(arg2[i])
- : log(arg1[i]);
- return 0;
Deleted: grass/trunk/raster/r.mapcalc/xlt.c
--- grass/trunk/raster/r.mapcalc/xlt.c 2016-01-25 09:27:55 UTC (rev 67657)
+++ grass/trunk/raster/r.mapcalc/xlt.c 2016-01-25 09:28:12 UTC (rev 67658)
@@ -1,65 +0,0 @@
-lt(a,b) = a < b
-int f_lt(int argc, const int *argt, void **args)
- int i;
- if (argc < 2)
- return E_ARG_LO;
- if (argc > 2)
- return E_ARG_HI;
- case CELL_TYPE:
- else
- res[i] = arg1[i] < arg2[i];
- return 0;
- case FCELL_TYPE:
- else
- return 0;
- case DCELL_TYPE:
- else
- return 0;
- default:
Deleted: grass/trunk/raster/r.mapcalc/xmax.c
--- grass/trunk/raster/r.mapcalc/xmax.c 2016-01-25 09:27:55 UTC (rev 67657)
+++ grass/trunk/raster/r.mapcalc/xmax.c 2016-01-25 09:28:12 UTC (rev 67658)
@@ -1,100 +0,0 @@
-max(x0,x1,...,xn) returns maximum value
-int f_max(int argc, const int *argt, void **args)
- int i, j;
- if (argc < 1)
- return E_ARG_LO;
- case CELL_TYPE:
- int nul = 0;
- CELL max;
- nul = 1;
- else if (j == 1)
- max = argz[j][i];
- else if (max < argz[j][i])
- max = argz[j][i];
- if (nul)
- else
- res[i] = max;
- return 0;
- case FCELL_TYPE:
- int nul = 0;
- FCELL max;
- nul = 1;
- else if (j == 1)
- max = argz[j][i];
- max = argz[j][i];
- if (nul)
- else
- res[i] = max;
- return 0;
- case DCELL_TYPE:
- int nul = 0;
- DCELL max;
- nul = 1;
- else if (j == 1)
- max = argz[j][i];
- max = argz[j][i];
- if (nul)
- else
- res[i] = max;
- return 0;
- default:
Deleted: grass/trunk/raster/r.mapcalc/xmedian.c
--- grass/trunk/raster/r.mapcalc/xmedian.c 2016-01-25 09:27:55 UTC (rev 67657)
+++ grass/trunk/raster/r.mapcalc/xmedian.c 2016-01-25 09:28:12 UTC (rev 67658)
@@ -1,155 +0,0 @@
-median(x1,x2,..,xn)
- return median of arguments
-static int icmp(const void *aa, const void *bb)
- const CELL *a = aa;
- const CELL *b = bb;
- return *a - *b;
-static int fcmp(const void *aa, const void *bb)
- const FCELL *a = aa;
- const FCELL *b = bb;
- if (*a < *b)
- return -1;
- if (*a > *b)
- return 1;
- return 0;
-static int dcmp(const void *aa, const void *bb)
- const DCELL *a = aa;
- const DCELL *b = bb;
- if (*a < *b)
- return -1;
- if (*a > *b)
- return 1;
- return 0;
-int f_median(int argc, const int *argt, void **args)
- static void *array;
- static int alloc;
- int size = argc * Rast_cell_size(argt[0]);
- int i, j;
- if (argc < 1)
- return E_ARG_LO;
- if (size > alloc) {
- alloc = size;
- array = G_realloc(array, size);
- case CELL_TYPE:
- CELL **argv = (CELL **) &args[1];
- CELL *a = array;
- CELL *a1 = &a[(argc - 1) / 2];
- CELL *a2 = &a[argc / 2];
- int nv = 0;
- for (j = 0; j < argc && !nv; j++) {
- if (IS_NULL_C(&argv[j][i]))
- nv = 1;
- else
- a[j] = argv[j][i];
- if (nv)
- else {
- qsort(a, argc, sizeof(CELL), icmp);
- res[i] = (*a1 + *a2) / 2;
- return 0;
- case FCELL_TYPE:
- FCELL **argv = (FCELL **) &args[1];
- FCELL *a = array;
- FCELL *a1 = &a[(argc - 1) / 2];
- FCELL *a2 = &a[argc / 2];
- int nv = 0;
- if (IS_NULL_F(&argv[j][i]))
- nv = 1;
- else
- if (nv)
- else {
- qsort(a, argc, sizeof(FCELL), fcmp);
- return 0;
- case DCELL_TYPE:
- DCELL **argv = (DCELL **) &args[1];
- DCELL *a = array;
- DCELL *a1 = &a[(argc - 1) / 2];
- DCELL *a2 = &a[argc / 2];
- int nv = 0;
- if (IS_NULL_D(&argv[j][i]))
- nv = 1;
- else
- if (nv)
- else {
- qsort(a, argc, sizeof(DCELL), dcmp);
- return 0;
- default:
Deleted: grass/trunk/raster/r.mapcalc/xmin.c
--- grass/trunk/raster/r.mapcalc/xmin.c 2016-01-25 09:27:55 UTC (rev 67657)
+++ grass/trunk/raster/r.mapcalc/xmin.c 2016-01-25 09:28:12 UTC (rev 67658)
@@ -1,100 +0,0 @@
-min(x0,x1,...,xn) returns minimum value
-int f_min(int argc, const int *argt, void **args)
- int i, j;
- if (argc < 1)
- return E_ARG_LO;
- case CELL_TYPE:
- int nul = 0;
- CELL min;
- nul = 1;
- else if (j == 1)
- min = argz[j][i];
- else if (min > argz[j][i])
- min = argz[j][i];
- if (nul)
- else
- res[i] = min;
- return 0;
- case FCELL_TYPE:
- int nul = 0;
- FCELL min;
- nul = 1;
- else if (j == 1)
- min = argz[j][i];
- min = argz[j][i];
- if (nul)
- else
- res[i] = min;
- return 0;
- case DCELL_TYPE:
- int nul = 0;
- DCELL min;
- nul = 1;
- else if (j == 1)
- min = argz[j][i];
- min = argz[j][i];
- if (nul)
- else
- res[i] = min;
- return 0;
- default:
Deleted: grass/trunk/raster/r.mapcalc/xmod.c
--- grass/trunk/raster/r.mapcalc/xmod.c 2016-01-25 09:27:55 UTC (rev 67657)
+++ grass/trunk/raster/r.mapcalc/xmod.c 2016-01-25 09:28:12 UTC (rev 67658)
@@ -1,80 +0,0 @@
-#include <math.h>
-mod(a,b) = a % b
-int f_mod(int argc, const int *argt, void **args)
- int i;
- if (argc < 2)
- return E_ARG_LO;
- if (argc > 2)
- return E_ARG_HI;
- case CELL_TYPE:
- else
- res[i] = arg1[i] % arg2[i];
- return 0;
- case FCELL_TYPE:
- else {
- res[i] = (FCELL) fmod(arg1[i], arg2[i]);
- return 0;
- case DCELL_TYPE:
- else {
- res[i] = (DCELL) fmod(arg1[i], arg2[i]);
- return 0;
- default:
Deleted: grass/trunk/raster/r.mapcalc/xmode.c
--- grass/trunk/raster/r.mapcalc/xmode.c 2016-01-25 09:27:55 UTC (rev 67657)
+++ grass/trunk/raster/r.mapcalc/xmode.c 2016-01-25 09:28:12 UTC (rev 67658)
@@ -1,144 +0,0 @@
-mode(x1,x2,..,xn)
- return mode of arguments
- const double *a = aa;
- const double *b = bb;
- if (*a < *b)
- return -1;
- if (*a > *b)
- return 1;
- return 0;
-static double mode(double *value, int argc)
- double mode_v;
- int mode_n = 0;
- int i;
- qsort(value, argc, sizeof(double), dcmp);
- for (i = 0; i < argc;) {
- int n = 1;
- double v = value[i];
- for (i++; i < argc; i++) {
- if (value[i] != v)
- break;
- n++;
- if (n < mode_n)
- continue;
- mode_v = v;
- mode_n = n;
- return mode_v;
-int f_mode(int argc, const int *argt, void **args)
- static double *value;
- static int value_size;
- int size = argc * sizeof(double);
- int i, j;
- if (argc < 1)
- return E_ARG_LO;
- if (size > value_size) {
- value_size = size;
- value = G_realloc(value, value_size);
- case CELL_TYPE:
- CELL **argv = (CELL **) & args[1];
- int nv = 0;
- nv = 1;
- else
- value[j] = (double)argv[j][i];
- if (nv)
- else
- res[i] = (CELL) mode(value, argc);
- return 0;
- case FCELL_TYPE:
- FCELL **argv = (FCELL **) & args[1];
- int nv = 0;
- nv = 1;
- else
- if (nv)
- else
- res[i] = (FCELL) mode(value, argc);
- return 0;
- case DCELL_TYPE:
- DCELL **argv = (DCELL **) & args[1];
- int nv = 0;
- nv = 1;
- else
- if (nv)
- else
- res[i] = (DCELL) mode(value, argc);
- return 0;
- default:
Deleted: grass/trunk/raster/r.mapcalc/xmul.c
--- grass/trunk/raster/r.mapcalc/xmul.c 2016-01-25 09:27:55 UTC (rev 67657)
+++ grass/trunk/raster/r.mapcalc/xmul.c 2016-01-25 09:28:12 UTC (rev 67658)
@@ -1,78 +0,0 @@
-mul(a,b) = a * b
-int f_mul(int argc, const int *argt, void **args)
- int i, j;
- if (argc < 1)
- return E_ARG_LO;
- case CELL_TYPE:
- res[i] = 1;
- break;
- res[i] *= argz[j][i];
- return 0;
- case FCELL_TYPE:
- res[i] = 1;
- break;
- return 0;
- case DCELL_TYPE:
- res[i] = 1;
- break;
- return 0;
- default:
Deleted: grass/trunk/raster/r.mapcalc/xne.c
--- grass/trunk/raster/r.mapcalc/xne.c 2016-01-25 09:27:55 UTC (rev 67657)
+++ grass/trunk/raster/r.mapcalc/xne.c 2016-01-25 09:28:12 UTC (rev 67658)
@@ -1,65 +0,0 @@
-ne(a,b) = a != b
-int f_ne(int argc, const int *argt, void **args)
- int i;
- if (argc < 2)
- return E_ARG_LO;
- if (argc > 2)
- return E_ARG_HI;
- case CELL_TYPE:
- else
- res[i] = arg1[i] != arg2[i];
- return 0;
- case FCELL_TYPE:
- else
- return 0;
- case DCELL_TYPE:
- else
- return 0;
- default:
Deleted: grass/trunk/raster/r.mapcalc/xneg.c
--- grass/trunk/raster/r.mapcalc/xneg.c 2016-01-25 09:27:55 UTC (rev 67657)
+++ grass/trunk/raster/r.mapcalc/xneg.c 2016-01-25 09:28:12 UTC (rev 67658)
@@ -1,64 +0,0 @@
-neg(x) = -x
-int f_neg(int argc, const int *argt, void **args)
- int i;
- if (argc < 1)
- return E_ARG_LO;
- if (argc > 1)
- return E_ARG_HI;
- case CELL_TYPE:
- else
- res[i] = -arg1[i];
- return 0;
- case FCELL_TYPE:
- else
- return 0;
- case DCELL_TYPE:
- else
- return 0;
- default:
Deleted: grass/trunk/raster/r.mapcalc/xnmax.c
--- grass/trunk/raster/r.mapcalc/xnmax.c 2016-01-25 09:27:55 UTC (rev 67657)
+++ grass/trunk/raster/r.mapcalc/xnmax.c 2016-01-25 09:28:12 UTC (rev 67658)
@@ -1,100 +0,0 @@
-int f_nmax(int argc, const int *argt, void **args)
- int i, j;
- if (argc < 1)
- return E_ARG_LO;
- case CELL_TYPE:
- int nul = 1;
- CELL max;
- continue;
- else if (nul)
- max = argz[j][i], nul = 0;
- if (nul)
- else
- res[i] = max;
- return 0;
- case FCELL_TYPE:
- int nul = 1;
- FCELL max;
- continue;
- else if (nul)
- if (nul)
- else
- res[i] = max;
- return 0;
- case DCELL_TYPE:
- int nul = 1;
- DCELL max;
- continue;
- else if (nul)
- if (nul)
- else
- res[i] = max;
- return 0;
- default:
Deleted: grass/trunk/raster/r.mapcalc/xnmedian.c
--- grass/trunk/raster/r.mapcalc/xnmedian.c 2016-01-25 09:27:55 UTC (rev 67657)
+++ grass/trunk/raster/r.mapcalc/xnmedian.c 2016-01-25 09:28:12 UTC (rev 67658)
@@ -1,152 +0,0 @@
- return *a - *b;
- if (*a < *b)
- return -1;
- if (*a > *b)
- return 1;
- return 0;
- if (*a < *b)
- return -1;
- if (*a > *b)
- return 1;
- return 0;
-int f_nmedian(int argc, const int *argt, void **args)
- static int alloc;
- int i, j;
- if (argc < 1)
- return E_ARG_LO;
- alloc = size;
- case CELL_TYPE:
- CELL *a = array;
- int n = 0;
- for (j = 0; j < argc; j++) {
- continue;
- a[n++] = argv[j][i];
- if (!n)
- else {
- qsort(a, n, sizeof(CELL), icmp);
- return 0;
- case FCELL_TYPE:
- FCELL *a = array;
- int n = 0;
- continue;
- if (!n)
- else {
- qsort(a, n, sizeof(FCELL), fcmp);
- return 0;
- case DCELL_TYPE:
- DCELL *a = array;
- int n = 0;
- continue;
- if (!n)
- else {
- qsort(a, n, sizeof(DCELL), dcmp);
- return 0;
- default:
Deleted: grass/trunk/raster/r.mapcalc/xnmin.c
--- grass/trunk/raster/r.mapcalc/xnmin.c 2016-01-25 09:27:55 UTC (rev 67657)
+++ grass/trunk/raster/r.mapcalc/xnmin.c 2016-01-25 09:28:12 UTC (rev 67658)
@@ -1,100 +0,0 @@
-int f_nmin(int argc, const int *argt, void **args)
- int i, j;
- if (argc < 1)
- return E_ARG_LO;
- case CELL_TYPE:
- int nul = 1;
- CELL min;
- continue;
- else if (nul)
- min = argz[j][i], nul = 0;
- if (nul)
- else
- res[i] = min;
- return 0;
- case FCELL_TYPE:
- int nul = 1;
- FCELL min;
- continue;
- else if (nul)
- if (nul)
- else
- res[i] = min;
- return 0;
- case DCELL_TYPE:
- int nul = 1;
- DCELL min;
- continue;
- else if (nul)
- if (nul)
- else
- res[i] = min;
- return 0;
- default:
Deleted: grass/trunk/raster/r.mapcalc/xnmode.c
--- grass/trunk/raster/r.mapcalc/xnmode.c 2016-01-25 09:27:55 UTC (rev 67657)
+++ grass/trunk/raster/r.mapcalc/xnmode.c 2016-01-25 09:28:12 UTC (rev 67658)
@@ -1,141 +0,0 @@
-mode(x1,x2,..,xn)
- if (*a < *b)
- return -1;
- if (*a > *b)
- return 1;
- return 0;
- double mode_v;
- int mode_n = 0;
- int i;
- int n = 1;
- break;
- n++;
- if (n < mode_n)
- continue;
- mode_v = v;
- mode_n = n;
- return mode_v;
-int f_nmode(int argc, const int *argt, void **args)
- int i, j;
- if (argc < 1)
- return E_ARG_LO;
- case CELL_TYPE:
- int n = 0;
- continue;
- value[n++] = (double)argv[j][i];
- if (!n)
- else
- res[i] = (CELL) mode(value, n);
- return 0;
- case FCELL_TYPE:
- int n = 0;
- continue;
- if (!n)
- else
- res[i] = (FCELL) mode(value, n);
- return 0;
- case DCELL_TYPE:
- int n = 0;
- continue;
- if (!n)
- else
- res[i] = (DCELL) mode(value, n);
- return 0;
- default:
Deleted: grass/trunk/raster/r.mapcalc/xnot.c
--- grass/trunk/raster/r.mapcalc/xnot.c 2016-01-25 09:27:55 UTC (rev 67657)
+++ grass/trunk/raster/r.mapcalc/xnot.c 2016-01-25 09:28:12 UTC (rev 67658)
@@ -1,52 +0,0 @@
-not(a) = !a
-int f_not(int argc, const int *argt, void **args)
- int i;
- if (argc < 1)
- return E_ARG_LO;
- if (argc > 1)
- return E_ARG_HI;
- else
- res[i] = !arg1[i];
- return 0;
-int c_not(int argc, int *argt)
- if (argc < 1)
- return E_ARG_LO;
- if (argc > 1)
- return E_ARG_HI;
- return 0;
Deleted: grass/trunk/raster/r.mapcalc/xnull.c
--- grass/trunk/raster/r.mapcalc/xnull.c 2016-01-25 09:27:55 UTC (rev 67657)
+++ grass/trunk/raster/r.mapcalc/xnull.c 2016-01-25 09:28:12 UTC (rev 67658)
@@ -1,27 +0,0 @@
-null() null values
-int f_null(int argc, const int *argt, void **args)
- int i;
- if (argc > 0)
- return E_ARG_HI;
- return 0;
Deleted: grass/trunk/raster/r.mapcalc/xor.c
--- grass/trunk/raster/r.mapcalc/xor.c 2016-01-25 09:27:55 UTC (rev 67657)
+++ grass/trunk/raster/r.mapcalc/xor.c 2016-01-25 09:28:12 UTC (rev 67658)
@@ -1,41 +0,0 @@
-or(a,b,c,...) = a || b || c || ...
-int f_or(int argc, const int *argt, void **args)
- int i, j;
- if (argc < 1)
- return E_ARG_LO;
- res[i] = 0;
- CELL *arg = args[j];
- if (IS_NULL_C(&arg[i])) {
- break;
- if (arg[i])
- res[i] = 1;
- return 0;
Deleted: grass/trunk/raster/r.mapcalc/xor2.c
--- grass/trunk/raster/r.mapcalc/xor2.c 2016-01-25 09:27:55 UTC (rev 67657)
+++ grass/trunk/raster/r.mapcalc/xor2.c 2016-01-25 09:28:12 UTC (rev 67658)
@@ -1,48 +0,0 @@
-or2(a,b,c,...) = a || b || c || ...
-Differs from or() in that the boolean axioms:
- true || x == true
- x || true == true
-int f_or2(int argc, const int *argt, void **args)
- int i, j;
- if (argc < 1)
- return E_ARG_LO;
- res[i] = 0;
- if (!IS_NULL_C(&arg[i]) && arg[i]) {
- res[i] = 1;
- break;
- return 0;
Deleted: grass/trunk/raster/r.mapcalc/xpow.c
--- grass/trunk/raster/r.mapcalc/xpow.c 2016-01-25 09:27:55 UTC (rev 67657)
+++ grass/trunk/raster/r.mapcalc/xpow.c 2016-01-25 09:28:12 UTC (rev 67658)
@@ -1,98 +0,0 @@
-#include <math.h>
-pow(a,b)
- a raised to the power b
-static int ipow(int x, int y)
- int res = 1;
- while (y) {
- if (y & 1)
- res *= x;
- y >>= 1;
- x *= x;
- return res;
-int f_pow(int argc, const int *argt, void **args)
- int i;
- if (argc < 2)
- return E_ARG_LO;
- if (argc > 2)
- return E_ARG_HI;
- case CELL_TYPE:
- if (IS_NULL_C(&arg1[i]) || IS_NULL_C(&arg2[i]) || arg2[i] < 0)
- else
- res[i] = ipow(arg1[i], arg2[i]);
- return 0;
- case FCELL_TYPE:
- else if (arg1[i] < 0 && arg2[i] != ceil(arg2[i]))
- else {
- res[i] = pow(arg1[i], arg2[i]);
- return 0;
- case DCELL_TYPE:
- else {
- return 0;
- default:
Deleted: grass/trunk/raster/r.mapcalc/xrand.c
--- grass/trunk/raster/r.mapcalc/xrand.c 2016-01-25 09:27:55 UTC (rev 67657)
+++ grass/trunk/raster/r.mapcalc/xrand.c 2016-01-25 09:28:12 UTC (rev 67658)
@@ -1,91 +0,0 @@
-#include <grass/config.h>
-rand(lo,hi) random values between a and b
-int f_rand(int argc, const int *argt, void **args)
- int i;
- if (argc < 2)
- return E_ARG_LO;
- if (argc > 2)
- return E_ARG_HI;
- case CELL_TYPE:
- unsigned int x = (unsigned int)G_mrand48();
- int lo = arg1[i];
- int hi = arg2[i];
- if (lo > hi) {
- int tmp = lo;
- lo = hi;
- hi = tmp;
- res[i] = (lo == hi) ? lo : lo + x % (unsigned int)(hi - lo);
- return 0;
- case FCELL_TYPE:
- double x = G_drand48();
- FCELL lo = arg1[i];
- FCELL hi = arg2[i];
- if (lo > hi) {
- FCELL tmp = lo;
- lo = hi;
- hi = tmp;
- res[i] = (FCELL) (lo + x * (hi - lo));
- return 0;
- case DCELL_TYPE:
- DCELL lo = arg1[i];
- DCELL hi = arg2[i];
- if (lo > hi) {
- DCELL tmp = lo;
- lo = hi;
- hi = tmp;
- res[i] = lo + x * (hi - lo);
- return 0;
- default:
Deleted: grass/trunk/raster/r.mapcalc/xround.c
--- grass/trunk/raster/r.mapcalc/xround.c 2016-01-25 09:27:55 UTC (rev 67657)
+++ grass/trunk/raster/r.mapcalc/xround.c 2016-01-25 09:28:12 UTC (rev 67658)
@@ -1,205 +0,0 @@
-#include <limits.h>
-#include <math.h>
-round(x, step, start)
- rounds x to nearest value in the sequence
- y[i] = i * step + start
-/* i_round(x) rounds x to nearest value, handles negative correctly */
-static double i_round(double x, double step, double start)
- x -= start;
- x /= step;
- x = floor(x + 0.5);
- x *= step;
- x += start;
- return x;
-int f_round(int argc, const int *argt, void **args)
- const DCELL *arg1 = args[1];
- int i;
- if (argc < 1)
- return E_ARG_LO;
- if (argc > 3)
- return E_ARG_HI;
- if (argc == 1 && argt[0] != CELL_TYPE)
- if (argc > 2 && argt[3] != DCELL_TYPE)
- if (argc == 1) {
- else {
- DCELL x = i_round(arg1[i], 1.0, 0.0);
- if (x > 2147483647.0 || x < -2147483647.0)
- else
- res[i] = (CELL) x;
- return 0;
- else if (argc == 2) {
- const DCELL *arg2 = args[2];
- case CELL_TYPE:
- else if (IS_NULL_D(&arg2[i]))
- else {
- DCELL x = i_round(arg1[i], arg2[i], 0.0);
- else
- return 0;
- case FCELL_TYPE:
- else
- res[i] = (FCELL) i_round(arg1[i], arg2[i], 0.0);
- return 0;
- case DCELL_TYPE:
- else
- res[i] = (DCELL) i_round(arg1[i], arg2[i], 0.0);
- return 0;
- default:
- else if (argc == 3) {
- const DCELL *arg3 = args[3];
- case CELL_TYPE:
- else if (IS_NULL_D(&arg3[i]))
- else {
- DCELL x = i_round(arg1[i], arg2[i], arg3[i]);
- else
- return 0;
- case FCELL_TYPE:
- else
- res[i] = (FCELL) i_round(arg1[i], arg2[i], arg3[i]);
- return 0;
- case DCELL_TYPE:
- else
- res[i] = (DCELL) i_round(arg1[i], arg2[i], arg3[i]);
- return 0;
- default:
- else
- return E_WTF;
-int c_round(int argc, int *argt)
- if (argc < 1)
- return E_ARG_LO;
- if (argc > 3)
- return E_ARG_HI;
- if (argc > 1 && argt[0] < argt[2])
- argt[0] = argt[2];
- if (argc > 2 && argt[0] < argt[3])
- argt[0] = argt[3];
- if (argc > 1)
- if (argc > 2)
- argt[3] = DCELL_TYPE;
- return 0;
Deleted: grass/trunk/raster/r.mapcalc/xshiftl.c
--- grass/trunk/raster/r.mapcalc/xshiftl.c 2016-01-25 09:27:55 UTC (rev 67657)
+++ grass/trunk/raster/r.mapcalc/xshiftl.c 2016-01-25 09:28:12 UTC (rev 67658)
@@ -1,38 +0,0 @@
-shiftl(a,b) = a << b
-int f_shiftl(int argc, const int *argt, void **args)
- int i;
- if (argc < 2)
- return E_ARG_LO;
- if (argc > 2)
- return E_ARG_HI;
- else
- res[i] = arg1[i] << arg2[i];
- return 0;
Deleted: grass/trunk/raster/r.mapcalc/xshiftr.c
--- grass/trunk/raster/r.mapcalc/xshiftr.c 2016-01-25 09:27:55 UTC (rev 67657)
+++ grass/trunk/raster/r.mapcalc/xshiftr.c 2016-01-25 09:28:12 UTC (rev 67658)
@@ -1,38 +0,0 @@
-shiftr(a,b) = a >> b
-int f_shiftr(int argc, const int *argt, void **args)
- int i;
- if (argc < 2)
- return E_ARG_LO;
- if (argc > 2)
- return E_ARG_HI;
- else
- res[i] = arg1[i] >> arg2[i];
- return 0;
Deleted: grass/trunk/raster/r.mapcalc/xshiftru.c
--- grass/trunk/raster/r.mapcalc/xshiftru.c 2016-01-25 09:27:55 UTC (rev 67657)
+++ grass/trunk/raster/r.mapcalc/xshiftru.c 2016-01-25 09:28:12 UTC (rev 67658)
@@ -1,38 +0,0 @@
-shiftru(a,b) = (unsigned) a >> b
-int f_shiftru(int argc, const int *argt, void **args)
- int i;
- if (argc < 2)
- return E_ARG_LO;
- if (argc > 2)
- return E_ARG_HI;
- else
- res[i] = ((unsigned int)arg1[i]) >> arg2[i];
- return 0;
Deleted: grass/trunk/raster/r.mapcalc/xsin.c
--- grass/trunk/raster/r.mapcalc/xsin.c 2016-01-25 09:27:55 UTC (rev 67657)
+++ grass/trunk/raster/r.mapcalc/xsin.c 2016-01-25 09:28:12 UTC (rev 67658)
@@ -1,49 +0,0 @@
-#include <math.h>
-sin(x)
- if floating point exception occurs during the evaluation of sin(x)
-int f_sin(int argc, const int *argt, void **args)
- int i;
- if (argc < 1)
- return E_ARG_LO;
- if (argc > 1)
- return E_ARG_HI;
- else {
- res[i] = sin(arg1[i] * DEGREES_TO_RADIANS);
- return 0;
Deleted: grass/trunk/raster/r.mapcalc/xsqrt.c
--- grass/trunk/raster/r.mapcalc/xsqrt.c 2016-01-25 09:27:55 UTC (rev 67657)
+++ grass/trunk/raster/r.mapcalc/xsqrt.c 2016-01-25 09:28:12 UTC (rev 67658)
@@ -1,45 +0,0 @@
-#include <math.h>
-sqrt(x)
- if floating point exception occurs during the evaluation of sqrt(x)
-int f_sqrt(int argc, const int *argt, void **args)
- int i;
- if (argc < 1)
- return E_ARG_LO;
- if (argc > 1)
- return E_ARG_HI;
- if (IS_NULL_D(&arg1[i]) || (arg1[i] < 0.0))
- else {
- res[i] = sqrt(arg1[i]);
- return 0;
Deleted: grass/trunk/raster/r.mapcalc/xsub.c
--- grass/trunk/raster/r.mapcalc/xsub.c 2016-01-25 09:27:55 UTC (rev 67657)
+++ grass/trunk/raster/r.mapcalc/xsub.c 2016-01-25 09:28:12 UTC (rev 67658)
@@ -1,70 +0,0 @@
-sub(a,b) = a - b
-int f_sub(int argc, const int *argt, void **args)
- int i;
- if (argc < 2)
- return E_ARG_LO;
- if (argc > 2)
- return E_ARG_HI;
- case CELL_TYPE:
- else
- res[i] = arg1[i] - arg2[i];
- return 0;
- case FCELL_TYPE:
- else
- return 0;
- case DCELL_TYPE:
- else
- return 0;
- default:
Deleted: grass/trunk/raster/r.mapcalc/xtan.c
--- grass/trunk/raster/r.mapcalc/xtan.c 2016-01-25 09:27:55 UTC (rev 67657)
+++ grass/trunk/raster/r.mapcalc/xtan.c 2016-01-25 09:28:12 UTC (rev 67658)
@@ -1,50 +0,0 @@
-#include <math.h>
-tan(x)
- if floating point exception occurs during the evaluation of tan(x)
-int f_tan(int argc, const int *argt, void **args)
- int i;
- if (argc < 1)
- return E_ARG_LO;
- if (argc > 1)
- return E_ARG_HI;
- else {
- res[i] = tan(arg1[i] * DEGREES_TO_RADIANS);
- return 0;
