[GRASS-SVN] r67659 - grass/trunk/lib/python/pygrass
svn_grass at osgeo.org
Mon Jan 25 02:23:04 PST 2016
Author: zarch
Date: 2016-01-25 02:23:04 -0800 (Mon, 25 Jan 2016)
New Revision: 67659
grass/trunk/lib/python/pygrass/utils.py
pygrass: utils.set_path function fix revert r66637, setting sys.path to handle local path and add docstring to clarify the use
Modified: grass/trunk/lib/python/pygrass/utils.py
--- grass/trunk/lib/python/pygrass/utils.py 2016-01-25 09:28:12 UTC (rev 67658)
+++ grass/trunk/lib/python/pygrass/utils.py 2016-01-25 10:23:04 UTC (rev 67659)
@@ -308,16 +308,67 @@
path = join('etc', modname)
else:
path = None
return path
def set_path(modulename, dirname=None, path='.'):
"""Set sys.path looking in the the local directory GRASS directories.
- @param modulename
- @param dirname
- @param path used to run the code locally without compilation
+ :param modulename: string with the name of the GRASS module
+ :param dirname: string with the directory name containing the python
+ libraries, default None
+ :param path: string with the path to reach the dirname locally.
+ Example
+ "set_path" example working locally with the source code of a module
+ (r.green) calling the function with all the parameters. Below it is
+ reported the directory structure on the r.green module.
+ grass_prompt> pwd
+ ~/Download/r.green/r.green.hydro/r.green.hydro.financial
+ grass_prompt> tree ../../../r.green
+ ../../../r.green
+ ├── libgreen
+ │ ├── pyfile1.py
+ │ └── pyfile2.py
+ └── r.green.hydro
+ ├── Makefile
+ ├── libhydro
+ │ ├── pyfile1.py
+ │ └── pyfile2.py
+ ├── r.green.hydro.*
+ └── r.green.hydro.financial
+ ├── Makefile
+ └── r.green.hydro.financial.py
+ 21 directories, 125 files
+ in the source code the function is called with the following parameters: ::
+ set_path('r.green', 'libhydro', '..')
+ set_path('r.green', 'libgreen', os.path.join('..', '..'))
+ when we are executing the module: r.green.hydro.financial locally from
+ the command line: ::
+ grass_prompt> python r.green.hydro.financial.py --ui
+ In this way we are executing the local code even if the module was already
+ installed as grass-addons and it is available in GRASS standards path.
+ The function is cheching if the dirname is provided and if the
+ directory exists and it is available using the path
+ provided as third parameter, if yes add the path to sys.path to be
+ importable, otherwise it will check on GRASS GIS standard paths.
import sys
# TODO: why dirname is checked first - the logic should be revised
@@ -325,8 +376,9 @@
if dirname:
pathlib = os.path.join(path, dirname)
if pathlib and os.path.exists(pathlib):
- # we are running the script from the script directory
- sys.path.append(os.path.abspath(pathlib))
+ # we are running the script from the script directory, therefore
+ # we add the path to sys.path to reach the directory (dirname)
+ sys.path.append(os.path.abspath(path))
else:
# running from GRASS GIS session
path = get_lib_path(modulename, dirname)
