[GRASS-SVN] r67660 - grass-addons/grass7/imagery/i.wi
svn_grass at osgeo.org
Mon Jan 25 03:08:11 PST 2016
Author: ychemin
Date: 2016-01-25 03:08:11 -0800 (Mon, 25 Jan 2016)
New Revision: 67660
grass-addons/grass7/imagery/i.wi/main.c
grass-addons/grass7/imagery/i.wi/tcw.c
updated main.c for new water indices libraries
Modified: grass-addons/grass7/imagery/i.wi/main.c
--- grass-addons/grass7/imagery/i.wi/main.c 2016-01-25 10:23:04 UTC (rev 67659)
+++ grass-addons/grass7/imagery/i.wi/main.c 2016-01-25 11:08:11 UTC (rev 67660)
@@ -19,7 +19,12 @@
#include <grass/gis.h>
#include <grass/raster.h>
#include <grass/glocale.h>
+double awei_noshadow(double greenchan, double nirchan, double chan5chan);
+double awei_shadow(double bluechan, double greenchan, double nirchan, double chan5chan, double band7chan);
double ls_wi(double nirchan, double swirchan);
+double ndwi_mcfeeters(double greenchan, double nirchan);
+double ndwi_xu(double greenchan, double chan5chan);
+double tcw(double bluechan, double greenchan, double redchan, double nirchan, double chan5chan, double band7chan);
int main(int argc, char *argv[])
@@ -29,22 +34,28 @@
int row, col;
char *wiflag; /*Switch for particular index */
struct GModule *module;
- struct Option *input1, *input2, *input3, *output;
+ struct {
+ struct Option *viname, *red, *nir, *green, *blue, *chan5,
+ *chan7, *bits, *output;
+ } opt;
struct Flag *flag1;
struct History history; /*metadata */
struct Colors colors; /*Color rules */
char *name; /*input raster name */
char *result; /*output raster name */
- int infd_nirchan, infd_swirchan;
+ int infd_bluechan, infd_greenchan, infd_redchan;
+ int infd_nirchan, infd_chan5chan, infd_chan7chan;
int outfd;
- char *nirchan, *swirchan;
+ char *bluechan, *greenchan, *redchan, *nirchan, *chan5chan, *chan7chan;
int i = 0, j = 0;
- void *inrast_nirchan, *inrast_swirchan;
+ void *inrast_bluechan, *inrast_greenchan, *inrast_redchan;
+ void *inrast_nirchan, *inrast_chan5chan, *inrast_chan7han;
DCELL * outrast;
RASTER_MAP_TYPE data_type_output = DCELL_TYPE;
- RASTER_MAP_TYPE data_type_nirchan;
- RASTER_MAP_TYPE data_type_swirchan;
+ RASTER_MAP_TYPE data_type_bluechan, data_type_greenchan;
+ RASTER_MAP_TYPE data_type_redchan, data_type_nirchan;
+ RASTER_MAP_TYPE data_type_chan5chan, data_type_chan7chan;
G_gisinit(argv[0]);
module = G_define_module();
@@ -53,69 +64,241 @@
G_add_keyword(_("index"));
G_add_keyword(_("biophysical"));
module->description =
- _("Water indices from nir and swir for the time being");
+ _("Water indices (designed on Landsat satellites)");
+ /* Define the different options */
+ opt.winame = G_define_option();
+ opt.winame->key = "winame";
+ opt.winame->type = TYPE_STRING;
+ opt.winame->required = YES;
+ opt.winame->description = _("Type of water index");
+ desc = NULL;
+ G_asprintf(&desc,
+ "awei_noshadow;%s;awei_shadow;%s;lswi;%s;ndwi_McFeeters;%s;ndwi_Xu;%s;tcw;%s;",
+ _("Automated Water Extraction Index - No Shadow"),
+ _("Automated Water Extraction Index - Shadow"),
+ _("Land Soil Water Index"),
+ _("Normalized Difference Water Index - Mc Feeters"),
+ _("Normalized Difference Water Index - Xu"),
+ _("Tasseled Cap Water"));
+ opt.winame->descriptions = desc;
+ opt.winame->options = "awei_ns,awei_s,lswi,ndwi_mf,ndwi_x,tcw";
+ opt.winame->answer = "lswi";
+ opt.winame->key_desc = _("type");
+ opt.blue = G_define_standard_option(G_OPT_R_INPUT);
+ opt.blue->key = "blue";
+ opt.blue->required = NO;
+ opt.blue->label =
+ _("Name of input blue channel surface reflectance map");
+ opt.blue->description = _("Range: [0.0;1.0]");
+ opt.blue->guisection = _("Inputs");
+ opt.green = G_define_standard_option(G_OPT_R_INPUT);
+ opt.green->key = "green";
+ opt.green->required = NO;
+ opt.green->label =
+ _("Name of input green channel surface reflectance map");
+ opt.green->description = _("Range: [0.0;1.0]");
+ opt.green->guisection = _("Inputs");
+ opt.red = G_define_standard_option(G_OPT_R_INPUT);
+ opt.red->key = "red";
+ opt.red->required = NO;
+ opt.red->label =
+ _("Name of input red channel surface reflectance map");
+ opt.red->description = _("Range: [0.0;1.0]");
+ opt.red->guisection = _("Inputs");
+ opt.nir = G_define_standard_option(G_OPT_R_INPUT);
+ opt.nir->key = "nir";
+ opt.nir->required = NO;
+ opt.nir->label =
+ _("Name of input nir channel surface reflectance map");
+ opt.nir->description = _("Range: [0.0;1.0]");
+ opt.nir->guisection = _("Inputs");
+ opt.chan5 = G_define_standard_option(G_OPT_R_INPUT);
+ opt.chan5->key = "band5";
+ opt.chan5->required = NO;
+ opt.chan5->label =
+ _("Name of input 5th channel surface reflectance map");
+ opt.chan5->description = _("Range: [0.0;1.0]");
+ opt.chan5->guisection = _("Inputs");
+ opt.chan7 = G_define_standard_option(G_OPT_R_INPUT);
+ opt.chan7->key = "band7";
+ opt.chan7->required = NO;
+ opt.chan7->label =
+ _("Name of input 7th channel surface reflectance map");
+ opt.chan7->description = _("Range: [0.0;1.0]");
+ opt.chan7->guisection = _("Inputs");
- input1 = G_define_option();
- input1->key = _("winame");
- input1->type = TYPE_STRING;
- input1->required = YES;
- input1->gisprompt = _("Name of WI");
- input1->description = _("Name of WI: lswi");
- input1->answer = _("lswi");
- input2 = G_define_standard_option(G_OPT_R_INPUT);
- input2->key = _("nir");
- input2->description =
- _("Name of the NIR Channel surface reflectance map [0.0;1.0]");
- input3 = G_define_standard_option(G_OPT_R_INPUT);
- input3->key = _("swir");
- input3->description =
- _("Name of the SWIR Channel surface reflectance map [0.0;1.0]");
- output = G_define_standard_option(G_OPT_R_OUTPUT);
- output->description = _("Name of the output wi layer");
+ opt.output = G_define_standard_option(G_OPT_R_OUTPUT);
+ opt.output->description = _("Name of the output wi layer");
if (G_parser(argc, argv))
exit(EXIT_FAILURE);
- wiflag = input1->answer;
- nirchan = input2->answer;
- swirchan = input3->answer;
- result = output->answer;
+ wiflag = opt.viname->answer;
+ redchan = opt.red->answer;
+ nirchan = opt.nir->answer;
+ greenchan = opt.green->answer;
+ bluechan = opt.blue->answer;
+ chan5chan = opt.chan5->answer;
+ chan7chan = opt.chan7->answer;
+ result = opt.output->answer;
+ if (!strcasecmp(wiflag, "awei_ns") && (!(opt.nir->answer)
+ || !(opt.green->answer) || !(opt.chan5->answer)) )
+ G_fatal_error(_("awei_noshadow requires green, nir and chan5 maps"));
+ if (!strcasecmp(wiflag, "awei_s") && (!(opt.blue->answer)
+ || !(opt.nir->answer) || !(opt.green->answer)
+ || !(opt.chan5->answer) || !(opt.chan7->answer)) )
+ G_fatal_error(_("awei_shadow requires blue, green, nir, chan5 and chan7 maps"));
+ if (!strcasecmp(wiflag, "lswi") && (!(opt.nir->answer)
+ || !(opt.chan7->answer)) )
+ G_fatal_error(_("lswi requires nir and chan7 maps"));
+ if (!strcasecmp(wiflag, "ndwi_mf") && (!(opt.nir->answer)
+ || !(opt.green->answer)) )
+ G_fatal_error(_("ndwi_mf requires green, nir maps"));
+ if (!strcasecmp(wiflag, "ndwi_x") && (!(opt.nir->answer)
+ G_fatal_error(_("ndwi_x requires green, chan5 maps"));
+ if (!strcasecmp(wiflag, "tcw") && (
+ !(opt.blue->answer) || !(opt.red->answer)
+ G_fatal_error(_("awei_shadow requires blue, green, red, nir, chan5 and chan7 maps"));
+ if(bluechan)
+ data_type_bluechan = Rast_map_type(bluechan, mapset);
+ infd_bluechan = Rast_open_old(bluechan, mapset);
+ Rast_get_cellhd(bluechan, mapset, &cellhd);
+ inrast_bluechan = Rast_allocate_buf(data_type_bluechan);
+ if(greenchan)
+ data_type_greenchan = Rast_map_type(greenchan, mapset);
+ infd_greenchan = Rast_open_old(greenchan, mapset);
+ Rast_get_cellhd(greenchan, mapset, &cellhd);
+ inrast_greenchan = Rast_allocate_buf(data_type_greenchan);
+ if(redchan)
+ data_type_redchan = Rast_map_type(redchan, mapset);
+ infd_redchan = Rast_open_old(redchan, mapset);
+ Rast_get_cellhd(redchan, mapset, &cellhd);
+ inrast_redchan = Rast_allocate_buf(data_type_redchan);
+ if(nirchan)
data_type_nirchan = Rast_map_type(nirchan, mapset);
- if ((infd_nirchan = Rast_open_old(nirchan, mapset)) < 0)
- G_fatal_error(_("Cannot open cell file [%s]"), nirchan);
+ infd_nirchan = Rast_open_old(nirchan, mapset);
Rast_get_cellhd(nirchan, mapset, &cellhd);
inrast_nirchan = Rast_allocate_buf(data_type_nirchan);
- data_type_swirchan = Rast_map_type(swirchan, mapset);
- infd_swirchan = Rast_open_old(swirchan, mapset);
- G_fatal_error(_("Cannot open cell file [%s]"), swirchan);
- Rast_get_cellhd(swirchan, mapset, &cellhd);
- inrast_swirchan = Rast_allocate_buf(data_type_swirchan);
+ if(chan5chan)
+ data_type_chan5chan = Rast_map_type(chan5chan, mapset);
+ infd_chan5chan = Rast_open_old(chan5chan, mapset);
+ Rast_get_cellhd(chan5chan, mapset, &cellhd);
+ inrast_chan5chan = Rast_allocate_buf(data_type_chan5chan);
+ if(chan7chan)
+ data_type_chan7chan = Rast_map_type(chan7chan, mapset);
+ infd_chan7chan = Rast_open_old(chan7chan, mapset);
+ Rast_get_cellhd(chan7chan, mapset, &cellhd);
+ inrast_chan7chan = Rast_allocate_buf(data_type_chan7chan);
G_debug(3, "number of rows %d", cellhd.rows);
nrows = Rast_window_rows();
ncols = Rast_window_cols();
outrast = Rast_allocate_buf(data_type_output);
/* Create New raster files */
outfd = Rast_open_new(result, data_type_output);
/* Process pixels */
for (row = 0; row < nrows; row++)
- DCELL d;
- DCELL d_nirchan;
- DCELL d_swirchan;
+ DCELL d;
+ DCELL d_bluechan, d_greenchan, d_redchan;
+ DCELL d_nirchan, d_chan5chan, d_chan7chan;
G_percent(row, nrows, 2);
- Rast_get_row
- (infd_nirchan, inrast_nirchan, row, data_type_nirchan);
- Rast_get_row
- (infd_swirchan, inrast_swirchan, row, data_type_swirchan);
+ if(bluechan)
+ Rast_get_row(infd_bluechan, inrast_bluechan, row, data_type_bluechan);
+ if(greenchan)
+ Rast_get_row(infd_greenchan, inrast_greenchan, row, data_type_greenchan);
+ if(redchan)
+ Rast_get_row(infd_redchan, inrast_redchan, row, data_type_redchan);
+ if(nirchan)
+ Rast_get_row(infd_nirchan, inrast_nirchan, row, data_type_nirchan);
+ if(chan5chan)
+ Rast_get_row(infd_chan5chan, inrast_chan5chan, row, data_type_chan5chan);
+ if(chan7chan)
+ Rast_get_row(infd_chan7chan, inrast_chan7chan, row, data_type_chan7chan);
/*process the data */
for (col = 0; col < ncols; col++)
+ if(bluechan)
+ switch (data_type_bluechan) {
+ case CELL_TYPE:
+ d_bluechan = (double)((CELL *) inrast_bluechan)[col];
+ break;
+ case FCELL_TYPE:
+ d_bluechan = (double)((FCELL *) inrast_bluechan)[col];
+ break;
+ case DCELL_TYPE:
+ d_bluechan = ((DCELL *) inrast_bluechan)[col];
+ break;
+ if(greenchan)
+ switch (data_type_greenchan) {
+ case CELL_TYPE:
+ d_greenchan = (double)((CELL *) inrast_greenchan)[col];
+ break;
+ case FCELL_TYPE:
+ d_greenchan = (double)((FCELL *) inrast_greenchan)[col];
+ break;
+ case DCELL_TYPE:
+ d_greenchan = ((DCELL *) inrast_greenchan)[col];
+ break;
+ if(redchan)
+ switch (data_type_redchan) {
+ case CELL_TYPE:
+ d_redchan = (double)((CELL *) inrast_redchan)[col];
+ break;
+ case FCELL_TYPE:
+ d_redchan = (double)((FCELL *) inrast_redchan)[col];
+ break;
+ case DCELL_TYPE:
+ d_redchan = ((DCELL *) inrast_redchan)[col];
+ break;
+ if(nirchan)
switch (data_type_nirchan) {
case CELL_TYPE:
d_nirchan = (double)((CELL *) inrast_nirchan)[col];
@@ -127,25 +310,53 @@
d_nirchan = ((DCELL *) inrast_nirchan)[col];
break;
- switch (data_type_swirchan) {
+ if(chan5chan)
+ switch (data_type_chan5chan) {
case CELL_TYPE:
- d_swirchan = (double)((CELL *) inrast_swirchan)[col];
+ d_chan5chan = (double)((CELL *) inrast_chan5chan)[col];
break;
case FCELL_TYPE:
- d_swirchan = (double)((FCELL *) inrast_swirchan)[col];
+ d_chan5chan = (double)((FCELL *) inrast_chan5chan)[col];
break;
case DCELL_TYPE:
- d_swirchan = ((DCELL *) inrast_swirchan)[col];
+ d_chan5chan = ((DCELL *) inrast_chan5chan)[col];
break;
- if (Rast_is_d_null_value(&d_nirchan) ||
- Rast_is_d_null_value(&d_swirchan)) {
- Rast_set_d_null_value(&outrast[col], 1);
+ if(chan7chan)
+ switch (data_type_chan7chan) {
+ case CELL_TYPE:
+ d_chan7chan = (double)((CELL *) inrast_chan7chan)[col];
+ break;
+ case FCELL_TYPE:
+ d_chan7chan = (double)((FCELL *) inrast_chan7chan)[col];
+ break;
+ case DCELL_TYPE:
+ d_chan7chan = ((DCELL *) inrast_chan7chan)[col];
+ break;
+ if ((redchan) && Rast_is_d_null_value(&d_redchan) ||
+ ((nirchan) && Rast_is_d_null_value(&d_nirchan)) ||
+ ((greenchan) && Rast_is_d_null_value(&d_greenchan)) ||
+ ((bluechan) && Rast_is_d_null_value(&d_bluechan)) ||
+ ((chan5chan) && Rast_is_d_null_value(&d_chan5chan)) ||
+ ((chan7chan) && Rast_is_d_null_value(&d_chan7chan))) {
+ Rast_set_d_null_value(&outrast[col], 1);
else {
+ /*calculate awei no shadow */
+ if (!strcasecmp(wiflag, "awei_ns")) {
+ d = awei_noshadow(d_greenchan, d_nirchan, d_chan5chan);
+ ((DCELL *) outrast)[col] = d;
+ /*calculate awei shadow */
+ if (!strcasecmp(wiflag, "awei_s")) {
+ d = awei_shadow(d_bluechan, d_greenchan, d_nirchan, d_chan5chan, d_chan7chan);
/*calculate lswi */
- if (!strcoll(wiflag, "lswi")) {
- if (d_nirchan + d_swirchan < 0.001) {
+ if (!strcasecmp(wiflag, "lswi")) {
+ if (d_nirchan + d_chan7chan < 0.001) {
else {
@@ -153,14 +364,59 @@
+ /*calculate ndwi McFeeters */
+ if (!strcasecmp(wiflag, "ndwi_mf")) {
+ if (d_greenchan + d_nirchan < 0.001) {
+ else {
+ d = ndwi_mf(d_greenchan, d_nirchan);
+ /*calculate ndwi Xu */
+ if (!strcasecmp(wiflag, "ndwi_x")) {
+ if (d_greenchan + d_chan5chan < 0.001) {
+ else {
+ d = ndwi_x(d_greenchan, d_chan5chan);
+ /*calculate tcw */
+ if (!strcasecmp(wiflag, "tcw")) {
+ d = tcw(d_bluechan, d_greenchan, d_redchan, d_nirchan, d_chan5chan, d_chan7chan);
Rast_put_row(outfd, outrast, data_type_output);
+ if(bluechan){
+ free(inrast_bluechan);
+ Rast_close(infd_bluechan);
+ if(greenchan){
+ free(inrast_greenchan);
+ Rast_close(infd_greenchan);
+ if(redchan){
+ free(inrast_redchan);
+ Rast_close(infd_redchan);
+ if(nirchan){
free(inrast_nirchan);
Rast_close(infd_nirchan);
- free(inrast_swirchan);
- Rast_close(infd_swirchan);
+ if(chan5chan){
+ free(inrast_chan5chan);
+ Rast_close(infd_chan5chan);
+ if(chan7chan){
+ free(inrast_chan7chan);
+ Rast_close(infd_chan7chan);
free(outrast);
Rast_close(outfd);
/* Color from -1.0 to +1.0 in grey */
Modified: grass-addons/grass7/imagery/i.wi/tcw.c
--- grass-addons/grass7/imagery/i.wi/tcw.c 2016-01-25 10:23:04 UTC (rev 67659)
+++ grass-addons/grass7/imagery/i.wi/tcw.c 2016-01-25 11:08:11 UTC (rev 67660)
@@ -7,8 +7,8 @@
Remote Sensing of Environment, 17, 301–306.
* Landsat TM/ETM+ : 0.0315*b1 + 0.2021*b2 + 0.3102*b3 + 0.1594*b4 - 0.6806*b5 - 0.6109*b7
-double tcw(double bluechan, double greenchan, double redchan, double nirchan, double chan5chan, double band7chan)
+double tcw(double bluechan, double greenchan, double redchan, double nirchan, double chan5chan, double chan7chan)
- double result = 0.0315*bluechan + 0.2021*greenchan + 0.3102*redchan + 0.1594*nirchan - 0.6806*chan5chan - 0.6109*band7chan;
+ double result = 0.0315*bluechan + 0.2021*greenchan + 0.3102*redchan + 0.1594*nirchan - 0.6806*chan5chan - 0.6109*chan7chan;
return result;
